PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. 1993 FXDL cuts out doing wheelies
  2. inner cam bearing toast
  3. stock heads to 103"
  4. Running hot all of a sudden - 2005 Deuce
  5. Ceramic paint in the exhaust.
  6. compression question
  7. Engine light and engine diagnostics
  8. Cheap sucker
  9. Recommendations on Head Pipes - Please.
  10. Exhaust shield question
  11. mixed messages
  12. Installing exhaust, o2 sensor ???
  13. modifying vance and hines pro-pipe
  14. Engine Knock
  15. What Should Idle RPM Be ?
  16. Does This Sound Like a Solid Build on an 04 RKC?
  17. Exhaust leak on my RKC?
  18. Removing lower rocker assembly housing
  19. recommendations for engine work
  20. So my scooter died on my way home...
  21. Shovelhead with Baker 6 in 4 exh pipes
  22. rear tire 2004 heritage
  23. 1997 ultra dead spot just off idle
  24. Gets hot, quits!
  25. Power Trip to JD's Cycle, Part-2...
  26. 107 inch?
  27. WANTED 1990 screaming eagle slip on mufflers 1990 softail
  28. s.e. 255 cams with stock springs
  29. 01 Ultra missing, backfiring and won't idle when hot.
  30. Idle Issue's
  31. Reposition oil cooler for better air flow
  32. Engine Troubles
  33. Advice on pipes
  34. Baffeled!
  35. Which one??
  36. Zenith/Bendix Accelerating pump
  37. Changeing pipes
  38. Difference Between True Duals and Drag Pipes
  39. Carbed Fatboy Sputtering
  40. 1994 fatboy bogging under throttle
  41. Engine Problem 2006 Road King
  42. SE Slip ons with a Rattle in the muffler
  43. Engine swap
  44. Sound of V&H Double Barrel staggered...
  45. check engine lite
  46. RevTech DFO digital fuel optimizer
  47. Missing Problem????
  48. rear cylinder timing?
  49. Dangling Sensor Stage I Kit (picture)
  50. Please help me get this thing started correctly when hot...!!!!!!
  51. Worn cam chain tensioners.
  52. Why is my bike spitting fire!?
  53. Engine cuts out after filling gas tank
  54. How to remove catalytic converters from an '07 CVO Touring muffler
  55. Smoking Exhaust - O2 Sensors
  56. White Smoke - Bad Deal
  57. What should I expect to pay
  58. backfire, no leaks. plz help!!!
  59. Vance & Hines modification
  60. Dome Pistons
  61. Do I need to flash the computer for slip-ons and/or intake?
  62. New piston trashed
  63. Slippons
  64. Warranty
  65. Cam upgrade?
  66. Maddog or Falcon lifters, anyone try them?
  67. Push Rod Adjustment
  68. mcr heads--2 empty screw slots-why
  69. Sportster keihin carb questions?
  70. is my dealer taking too long?
  71. bought a 4.5 gal. tank will my fuel pump plate fit
  72. 96 fuel injection acting weird??? HELP!!
  73. crank run out
  74. Inner cam bearings
  75. choke wont stay out
  76. Good under throttle, bad at cruise
  77. engine upgrade? 1450-1550 big bore
  78. Inner CAM bearing failure destroyed my SE103
  79. Cam clearance
  80. got heads back from hillside
  81. Drill into the exhaust & install Rivet-Really?
  82. bad fuel?
  83. Nikasil Cylinders
  84. Exhaust swap
  85. Fishtails: Samson or V&H? (on 09 RKC)
  86. new engine
  87. Yet another Xied question
  88. carbed twin cam 'coughing' question
  89. FXDB Exhaust
  90. hypercharger with s&s super g
  91. Rush pipes with or without baffle
  92. re-sealing tank liner
  93. Modify Rinehart 2-1 Baffle????????
  94. End caps for V&H Straight Shot slip-ons
  95. I know another 103 build questions
  96. New Bike - Long Ride
  97. Bike Broke Down--- Not getting any gas
  98. Opinions: Bub 7 2:1 or SuperTrapp 2:1
  99. SE baffle question
  100. Thunderslide Kit Help
  101. Cam Chain Tensioner
  102. Larger replacement filter element
  103. Deceleration popping
  104. Fuel alloy pellets??
  105. Attention S&S carb Experts
  106. Free 2 into 1's
  107. HQ Cam & Rods Instead of SE Stage II Kit?
  108. Camshaft change on 80" Evo - DIY???
  109. fatcat part#412-32b just for carb models?
  110. 09 road king true dual vs stock header
  111. Hard Backfiring
  112. Hot Tank... Bike Run Like Sh*t
  113. EVO cutting out on acceleration
  114. Valve Noise when engine get hot
  115. 09 v and h power duals
  116. installing samson baffles
  117. stages
  118. Running too lean? PCV help
  119. Vibration and crank shift
  120. 03 fxsti 1/4 tank lean fuel condition
  121. check valve on 04 ultra?
  122. FuelPak, Ridemaxx or Cobra Fi2000
  123. tc88 cam tension 2004 22.000 MILES
  124. Stock pipes back on for a day -- bad idea?
  125. Need help identifying 2-into-1 exhaust black w/ side exit
  126. Upsizing Rush Baffles Question
  127. EVO engine noise?
  128. A/M Air Cleaner, Spike or something like it?
  129. Milky white tranny oil
  130. 42 MM Mimuni tune questions_new cam
  131. painting slip ons?
  132. Supertrapp SE Slip Ons For 09 RKC
  133. Need A DYNO Tuner in Baltimore Area
  134. S&S air cleaner cover for Mikuni HSR42mm carb?
  135. 2005 fat boy-too damn quiet
  136. Stop running
  137. Camshaft for 2009 Night train!
  138. Chain tensioners on B motors
  139. Exhaust stud blues
  140. harley down load or fuel pack
  141. Paughco exhaust anybody?
  142. Love the look of true duals with fishtail tips
  143. Ultra oil pump question
  144. Changing Baffles On Rush Slip-Ons
  145. Which Carb, manifold and intake do I need?
  146. SE Heavy Breather for 88ci?
  147. Need advice!!
  148. the red dot on v-twin pistons
  149. slip on's that sound like old screamin eagle's
  150. Starter clutch problems on high comp motor
  151. help need input,no oil pressure on ultra
  152. DYNA " hiccups "
  153. O2 sensorthreads?
  154. Question
  155. SE II Exhaust Gen I Gen II
  156. fuel line breakage
  157. 2000 Duece set up to long
  158. 94 Sportster draining Gas from Carb when Stopped
  159. Injector size
  160. Sitting for six years.....now what?
  161. Running left muffler on right side?
  162. Valve spring broke! WTF!
  163. HELP.... Bad coil?
  164. 2008 Deluxe Exhaust
  165. Rough Cold Idle Since Oct 08
  166. ? mufflers that are quiet and
  167. I have a oil pressure question.
  168. Just got V&H Short Shots can i just install the pipes without a remap?
  169. Best performance mods for 1340 Evo motor?
  170. Need more noise....
  171. Compression and Leak down check
  172. Won't idle without choke out
  173. Sportster Backfires and sputters at take off when hot.
  174. Exhaust Help
  175. Vance and Hines Big Shots Question
  176. Exhaust question
  177. bigger cam
  178. Bike Set Up Question
  179. Surging Problem
  180. SE High Flow Oil Pump + Cam Plate
  181. Oil pressure Light
  182. Stage 1 Intake Questions
  183. Big bore kit interchange?
  184. exhaust leak?
  185. Cam Cover, WTF is this?!
  186. New Cam OLD Cam Gear Question
  187. 08 Heritage Cam Help
  188. tc 88 jetting
  189. Vance & Hines ovals not loud enough
  190. Cam question
  191. .005 Piston Rings
  192. torco clamp
  193. Air cleaners
  194. making 2 into 1 need help....
  195. big city thunder?
  196. Removing heads for Compression Releases
  197. I Hate Exhaust Leaks!!!
  198. Cam chain tensioners (maybe?)
  199. Vrod stumbling badly!! Help!!
  200. Dyna Lurches, snaps, bucks.
  201. 110ci mpg????
  202. Herko AMS upgrade
  203. Any body got VANCE HINES STRAIGHTSHOTS HI-LOW EXHAUST?
  204. Issues without baffles???
  205. high lift cams
  206. Cam change (06) tools in South Jersey.
  207. compression releases
  208. Up grade from 88 to 95
  209. Spring Height Problem Solved
  210. New Black Air Cleaner?
  211. pn # for Bosch o2 sensor 07 Streetglide
  212. Rinehart exhaust
  213. Rush or rienhart slip ons
  214. Reserve Light
  215. Stock headers or true duals?
  216. hooker tuned flow
  217. Intake pic's please
  218. '04 Road King Exhaust/Fuel Question
  219. 88B balancing parts go in 88 twin cam(dyna)?
  220. Exhaust Pushrod Problems
  221. cam alignment
  222. TC 88 Head Interchange
  223. Gas coming out of vent line
  224. 2 into 1 -1 3/4 vs 1 7/8 header size
  225. painting heat shields, do they make hight temp primer?
  226. SE AC Installation
  227. Poping on Decel
  228. Powerbraidz baffles for curved pipes
  229. cycle shack 2 into 1
  230. Lifter Noise/Ticking
  231. ironhead exhaust help
  232. 96ci s&s engine with 07 hd exausts??
  233. Removal and Installation of Adjustable push rods
  234. Runs Rough
  235. Rienhart Hanger Bracket Broken
  236. CV Carb question
  237. Won't start when sits a long time
  238. Which pipes for my 2008 105th Anniv Super Glide?
  239. Pinging
  240. PCIII with stock air filter?
  241. new 09 cvo
  242. heads with no breather holes
  243. Engine Coating
  244. flywheel
  245. exhaust 2
  246. New Engine Build
  247. 114" Carb Jetting
  248. Breathing Problem/ oil consumption
  249. Valve Train Noise?
  250. back fire through throttle body
