View Full Version : Exhaust System Topics
- This fell off the carb
- Help! Bad noise in engine!
- Drilling out baffel on 08 Heritage Softail
- 88 -> 95, which cam?
- What type of Samsons are these?
- Fuel in Crankcase!!!!????
- How much more displacement will I have?
- Cosmetic assistance
- Wrapping Rineharts
- Fuel Moto 2-1 pipe
- V&H Hi Output
- V&H Dresser Duals Vs. Kuryakyn Crusher Heads
- S&S gear drive outer cam gear
- 07' FLH TP engine problem
- Which cam? ...too many choices
- S&S Easy Start Cams
- Complete exhaust replacement question
- 98 wideglide, smokes like a bus!
- Head Gasket Oil Seep-88 cu. in. twin cam
- Removing old gas
- Can this be se 255 cam Ithink not
- Should I believe the dealer?
- 95" bore What the ^%$
- andrews TW50 cam question
- Pushrod tube question
- Billet Clutch Basket?
- New slip on's
- Cam Base Circles
- Engine Noise on 2003 RoadkingFI
- Screaming Eagle to Fatboy 2009
- Cams in my SG
- 2008 Sportster 883 V&H Short Shots Install
- lookjing 4 bub 2into1 2009 fl chrome
- Stumblin' and coughin'...
- 2001 Low Rider choke
- stuck exhaust gasket
- Throttle Lag/ hesitation
- Gas Gauge inaccuracies
- True duals vs Slip ons ith crossover
- Question about cams and valvetrain noise
- improving the crappy v&h 2 into 2....
- Multi-Colored Headers?
- Head question
- any thoughts on this combo...
- S&S teardrop
- Bottom end value
- twin cam fouling spark plugs
- Evo base gaskets question
- oil in exhuast
- Pushrod came loose.....
- Push Rods rubbing in tubes, what to do??
- deceleration issue 2006 FLHTC
- Cams?
- 103 w bassani what is better fatcat, bub7??
- clutch suggestions
- 08 Nightrain Flooding???
- Exhaust ?
- case boring?
- Whats wrong with Hyperchargers?
- 2010 Street Glide
- Dual pipe conversion
- Please Help do i need to remap my flhti
- at daytona, having engine issues!!!!
- 103 is it enough ????
- big sucker vs. heavy breather
- trike fuel mpg
- Questions about my Rush 2" Slip-ons - 2009 Heritage Softail Classic
- What size baffles?
- Heritage won't start
- Rear cylinder running rich ?
- Stock O2 Sensor for '07 Sportster
- SE Heads vs. custom heads
- Exhaust
- International Model specs
- Loud but not too loud
- SERT Question
- McMaster-Carr shims
- Ring Gap
- Red Shift 575 CAM Dyno Results (chart and video)
- 95 FXDWG popping from exhaust
- 09 R K Cam choice
- 2010 limited with 103 inch
- SE 103 Stage 4 package
- head polishing
- Quick question about blowing head gaskets
- 95" muscle kit
- fitting slip ons
- do I need to re-map
- 1 3/4" vs. 2" pipes
- Fire Ring
- What needle valve do I have ?
- Which Oil for new cams, heads & cylinders
- Part Number for Piston rings, cyl head gaskets
- Wanted nj machine shop head porting boring
- Bub and Reinhardt
- quick jet question
- Ultima motor any good?
- Quiet Baffles for SE 2
- iron air cleaner upgrade
- power loss
- Fatso Motor
- 95 dyna wide glide backfiring
- Update to Cam Change post
- Maybe Cam Timing problem
- cam for my 93 fatboy
- Extended crank after sitting for 1 week
- Cam Change Opinions
- compression
- valve jobs
- Installing Vans Hines Short Shots?
- Woods belt driven cams?
- dyna rebuild
- My 100th deuce is obsolete no more parts ..help!!
- Here is a trick question look at pics
- Engine noise kieth black pistons high compression
- Custom Heat shields
- Cam Swap Help....Please
- 06' FLHTCUSE goes from 103CI to 107CI
- With the bigger cube motors, making like 130/140 and HP/TQ
- cv carb question/ zippers 3rd fuel circuit
- Help removing old base gaskets
- Removing Gear Driven Cams
- A couple of things that I need help with
- Video of bike after Woods 6-6 install?
- What brand of slip ons do I have? Pics inside.
- A little help for a buddy
- fuel problem? HELP!!!
- Tappet Lifters: Feuling HP+ or H-D ?
- motor build update/brokeboystreetglide
- SEH-4 nCam
- 103 build cam question
- CVO 255 same as SE 255?
- Compression Question
- Hpi 55
- Installing Baffles in Original Big Guns?
- 97 fatboy knocking any ideas
- New Build?
- Previously posted in the wrong place...sorry
- HP rods Vs Stock pictures
- T-Man tr-525 cam dyno numbers?
- Question about pipes for an Evo
- 2into1 vs true duals
- Dyno'd the bike today. What exactly has been done to my bike?
- DYNO Numbers
- Dropping the bike off tomarrow to get the cam tensioners checked.
- will 96" exhaust work on my 88"
- Its a great feeling when you get lucky
- true dual recommendation
- just wondering
- Compresion releases ???
- 80 Evo Rebuild
- cam question
- cam question out of 1994 flstc
- Anyone know if 2007-08 pipes will fit 2004?
- air filter change
- lower Oil pressure
- cats and the cure
- Seafoam, correct usage...???
- 2000 Deuce, Duals.. question, advice???
- Need some help please
- Do I need to re-jet for this pipe change?
- Pushrods??
- Andrews 37 or ?
- Will RB Racing gaskets fit thunderheader?
- Why True Duals ?
- D & D Fatcat - Big Bore Baffle or not
- Jims 116 crank
- Cam change
- Pan/Shovel base gaskets
- Rev Limit increase
- Engine will just die with little warning
- I may have made a mistake, advice please
- Oil Cooler question
- Yaffe X Pipes and Rocker?? Can they go together?
- fuel management
- Linkert Carb Adjustment
- screaming eagle breather kit
- Looks over performance?
- HD said i have to go another 500 before the dyno
- rinehart 2 into 1 mid range power
- Gear or chain?
- Cam Support Plates
- Harleys new screamin Eagle muffler
- Stock Pushrods w/.030 Head Gaskets?
- Piston to Valve Interference
- Changing to full Rinehart True Dual
- Adjustable Cam Gear
- Cam Opinions on cams TMan 590 vs HQ 575 for 02 Bagger
- benifits of going with a 2 into 1 d&d fat cat exhaust
- Headwork - Any Suggestions
- Just got back from cincinnati v-twin expo!!!
- Cam Installation
- Hi flo or no hi-flo
- 2010 Wide Glide 106 build.
- Lifter Replacement
- crazy compression question
- 95" badges
- andrews tw37h cams in a 07 dyna?
- cyclinder swap
- K&N without adapter kit?
- Compression Ratio
- Hacker 2-1 pipes
- Identify these pushrod tubes?
- Roller Rocker Arms?
- Cam help
- Hi flo tap
- Help me get together a parts list for a cam swap.
- Your thoughts!
- Red shift 575 cam question.
- Compression Release Recommendations ?
- can anyone identify the maker of this cover?
- Head Bolt keeps coming loose
- HQ 500 cams in o6 dyna?
- 04FLHTCI gastank fitment question
- Rinehart / So confused ???????????
- Air filter need help
- oem exhaust fitment/compatability question..
- 2010 tuning w/o cats on touring
- Domed pistons in stock heads
- Pics of 2-1 pipes wanted. Comment on noise volume also good.
- stage 1 with slip ons
- Sputtering and popping under load
- Exhaust Pipe 'spigot' question
- Throttle cables HELP!!!
- dyno runs?
- can anyone tell me what exhaust is on this fatboy?
- 4" or 8" Baffle Question
- Stage one with stock pipes?
- Se 204 Cams/103" Users
- heat shield question
- bad gas bike will not start
- Zippers Sleeper 103????
- Engine Rebuild
- Newb Questions
- SE Rocker Arms 1.725:1
- How To install a fuel inlet fitting
- Why Roller Rockers?
- S&S cams not really good?
- cometic/pushrod ?
- Cam breakin.....whats that and why....
- nightster 09 forcewinder intake ?
- intank fuel filter
- Lifters & pushrods
- 96B to 103 (or 107) - What things i should consider before starting
- Who's going to the cincinnati v-twin show?
- 95ci Head Porting Question
- Breaking In my new 95 build
- Niagra Falls
- HD Stage 1 Download
- TTS map
