- 95ci Head Porting Question
- Breaking In my new 95 build
- Niagra Falls
- HD Stage 1 Download
- TTS map
- Tuner/Cycledoctor
- Iron 883 conversion
- CV Pilot Jet questions
- 07 08 Throttle Body CB SB
- Browning pipes
- Air Cleaner
- Help with 06 FXSTSI engine upgrades
- Feedback on hydraulic tensioners
- Klock Werks SS Mufflers
- Slippery Slip-on's
- Cam Gear Questions
- Anyone with S+S Easy Start Cams??
- Cams again
- Big City Thunders Header Baffle
- S&S Carburetor modifications.
- Intake Seals 1998 Electra Glide
- Piston Arrows - Which Way Do They Go?
- '06 valve seal problems?
- Valve to Valve Clearance.
- Who in Florida....
- T-Man.625
- Please define "stage 1,stage 2,stage 3...etc...
- Yet Another Cam Opinion Question
- Welding o2 bungs in.
- Cam Swap Recommendation
- Suggestions for Mild Cam Upgrade
- power not what it should be?
- SE Kompressor Heads?
- Pipe City Info
- woods 408-44 cams
- Screaming Eagle Butterfly Carb info
- Manley Valve Componentry Kits
- Big Growl Exhaust
- Looking for new air cleaner.
- Help with slip ons
- 09 Softail O2 sensor?
- SERT Question
- Rinehart vs Old SE II slip ons
- Identifying CV Carbs
- Removal of lower Rocker box covers?
- 08 to 98 exhuast ?
- Need some cam advice please!!
- What build is best
- Headquarters hq95s kit.is the 11:1 comp ratio too high?!?!?
- HQ-TC-525-HC Paul Bunyan Cams ?
- Big city thunder
- Cylinder Head Bolt Torque
- 2010 Cat. headpipes - how restrictive?
- BUB Lakester 2-2... buy them or avoid?
- Edelbrock RPM Package
- Help with adjusting the tension on my throttle cable...
- Left or right rineharts?
- Exhaust fitting question
- CVO pipes on non-CVO bike
- Dual Exhaust
- Compression Ratio
- Twincam Heads
- Valve bent?
- welding crank????
- Atwood 2020 Heads
- It's Alive !!!
- Stage One - wear and tear
- Twin cam performance ?
- exhaust options
- New "BUB" Slip-on Muffs
- Most bang for my buck
- TC88 Chain tensioner???
- V&H VO2 Drak Air Filter Kit
- 95' build (need mor power)
- Branch Engineering
- Oil cooler adapter - oxygen sensor clearance issue
- About how many hours does it take to do a top end and cams?
- Slow Idle Jet Screw
- Anyone in OC / near Fullerton with RB LSR?
- Can I get performance without going loud?
- baffle wrap
- Crusty Sparkplugs
- Need info on Piston sizes for the Harley
- Advice needed from the cam experts
- Swapping exhaust.
- Cam Sprockets
- Piston Coating
- Stock HP and torque for a TC- efi 88
- Added an Andrews 26H cam to the mix
- Benefits of bigger throttle body & injectors
- Question on sound
- need help removing fuel tank - wiring removed; cannot purge?
- help with upper end chirp/squeak
- Twin Cam 96 Oil Pump Wave Spring
- Engine clatter
- Torquing Head Bolts
- Carb issue?
- Pistons
- 2 into 1 or true duals?
- cams help
- 80" evo Mods ??
- Elbruto 113 max hp/revs
- 95 upgrade needs more juice
- Is "cams only" worth it?
- 74cid rebuild and upgrade
- se204 cams
- 88 Upgrade
- Engine oil change - better with engine hot or cold?
- Cam storage
- V&h ?
- Evo cam question
- Looking for cheap power?
- Searching FXD (Evo) slip-on mufflers (S.E.)
- Can I paint the engine?
- Cam change TC 88
- Winter Cam Change
- Harley Stage III-kit
- 1983 flh-80 fuel tank assembly
- Indianapolis thanks for the replies about a builder
- Andrews 55N Cams
- TC top end questions...
- Big bore for Evo???
- Little help big bore 06 Ultra Classic
- A time estimate
- 95" big bore
- 131 engine
- 2010 Exhaust
- se pro compressor head reviews?
- Andrews 54H vs 67H
- Revtech Evo Heads Question
- bolt on cylinder kit
- Excessive Backfire
- S&S 106 BB kit
- question for a buddy
- Torque Cones
- cv carb question
- please help me understand
- Question re Fatcat and SE211 CAM
- Help! Discoloration at exhaust pipe coming right off the engine
- Jim's Cycle Shop - Axtell, Texas
- Vance & Hines Basic Slip-Ons and Doherty PowerPACC Air CLeaner
- interchangeable models
- Compression Releases
- oil pressure gauge
- fuel tank?
- Nightrider xieds, what do you think?
- Build ???????
- whats your take? your opinion please
- Vance & Hines Dresser Duals
- 96" in a 88B frame?
- CV rebiuld
- New Lifters & Adjustable Pushrods
- Oil hose routing
- Black-Out Rocker Boxes
- how much more to be gained
- Add Quiet baffles - does it need a re-tune?
- CV Carb Spacer
- Vance and Hines FulePak
- BSD Exhaust Gasket
- TTS and the new super tuner
- bottom end
- Split Durations
- SE 16952-06 heads anyone know valve stem diameter?
- se 255 cams with a V/H fuel pak?
- anyone running SE II's & NRHS hurricane ac?
- need a little advice please
- Cycle-Rama
- Boring 88 to 95 cost
- Christmas tool time... changing the manifold
- Minor valve train sound.
- hd stock cam with c on lobe!
- 114" cam choice - heavy bike
- Teach me to check engine oil level.
- Changing Gear Driven Cam Brands
- Upgrading my 95"
- Excessive Backfiring
- Merry christmas
- Why so many SE Heads on EBay
- 1200 96 Sportster misses at 1/4 throttle
- Too Rich with jetting??
- Aside from the sound, is there a noticeable difference in the quality of mufflers?
- Torque, torque, torque. Bla-bla-bla.
- need help please! updated info to build gone bad
- BUB 7 Tru Duals
- cracked bassani pipe
- Bassani headers question?
- Loud Knocking From Bottom End????HELP!!
- 1990 FXRS Lowrider
- Odd Knocking
- '98 80" Tear down
- Air Filter Oil
- Instructions & Video for Measuring Right-side Crankshaft Runout
- D&D Fat Cat installed on the Fat Bob
- engine oil and filter saturation
- CAM upgrade on 06-later Dyna
- SE 255 Compression ?
- Engine life ?
- Removing Loctite?
- Question about dead Harley engines.
- How will it effect fuel mileage?
- Need help-Dragtron vs Screaming Eagle AC
- How do you know when engine is too hot?
- K&N Filter/SE Ventilator ?
- Procharger ordered for Rocker!
- Replace/modify stock baffles on Dyna
- Manifold suggestions for Mikuni 45mm TC 95
- Looking for a 2&2 straight dump Exhaust for 113 EVO? ADVICE???
- Forged or cast pistons
- wimmer air intakes
- Harley Evo Engine Umbrella Valve
- Super B carb Body
- Milling heads
- Manual Compression Release - Install Costs?
- 103 Stage II Builds - Feedback
- 95 Roadking crankcase needed
- Head Gasket Up side down?
- sportster rear exhaust carbon build up
- What is MOCO?
- A Question for the Pros.
- SE Heavy Breather 90 degree
- Is "too restrictive" a bad thing?
- SE 110 take offs
- Cam?
- How to Get to the 103"?
- Twin Cam Heads
- police bike heavy breather upgrade???
- stuck
- Starters
- torque dip? dyno sheet (pic)
- Vance and Hines Q series
- thinkin bout getting Samson 3" true duals !!!
- Biting the Bullet - Changing to a SuperTrapp 2-1
- Help with my 1340 EVO. Wont start. (long)
- Need more Grunt
- Engine dies out after revving to rev limiter
- How does this help with engine reliability?
- Fuel Stabalizer
- Quick twin cam lifter question for anyone that knows....
- Possible issue with Magneti-Marelli
- Debaffle 01 Ultra Classic??
- 103 + vance and hines monster ovals
- efi rough cold idle
- How long does it take to replace pistons, cylinders and cams?
- EFI to Carb, Ignition question
- According to Haynes manual normal compression is 90 PSI. What is your compression?
- I need of MAJOR help
- 2010 FLHX Stock Muffler
- Slip ons (vance and hines)
- Which high performance engine?
- Highway Motor?
