View Full Version : Exhaust System Topics
- Completely Stumped engine problem
- Need D&D Performance Baffle
- DK Customs TTIs with Samson Big Guns?
- is this even possible?
- Good machine shop (cylinder boring) in Milwaukee area?
- Cam decision
- Fuel line?
- Outer oil pump gerotor orientation?
- Problem with inner cam removal tool, doesn't fit?
- How to record pipes audio?
- balancing assembly on 2006 88ci b engine
- Stumped
- EFI Coversion or 98" cylinders
- V&H Heat Shield issue
- stage 1
- Warranty Question
- Front Cyl always richer- 2011 Sportster
- Anyone running Sikpipes Exhaust ?
- Have "106 BB and cams. What next, if anything?
- 08 Night Train exhaust question
- Which pushrod????
- Cams need help
- What Carb should I use???
- EVO Cam Hi-Perf
- Vance & Hines question?
- 2014 Street Glide special upgrade
- Engine break-in the controversy
- Active exhaust
- True dual question
- Just thinking of porting heads Only
- 95" mild build exhaust ideas
- 2013 street glide stage 1 questions.
- HARLEY SE 536 cams
- 2011 Street Glide Exhaust retrofit on 2002 Electra Glide
- fuel moto 107
- Help! Need replacement AC element
- 2008 Dyna St. Bob Dyno report...204 cam etc.
- Rocker Boxes
- Considering a new air cleaner - opinions wanted
- De-Cat
- 04 Electra Glide Running Bad
- Exhaust thread repair, too short now
- Where to buy a 80in crate motor
- removed the cat and
- Cam swap - stock pushrods
- Which D&D Baffle???
- Hard startup after cams
- engine rattle
- Opinions or ideas on this build
- Which brand of exhaust is this?
- Catalytic Converter
- For us motorheads...My Hillside 117
- older street bob tank 4.7 or 4.8 gallons
- 103 winter mods
- Evo - Lifter & Pushrod Advice Needed.
- S&S hard cranking problem
- Header wrap on baffles?
- 10.5:1 compression, is this to much?
- exhaust/intake change 2014 103ci
- dyno tuning question
- Help with Exhaust
- adj p/r
- looking for input on a 103 build
- 2014 HO Twin Cooled 103"
- cams bearing install
- Twin cam oil puking from a/c
- Ajustable Push rods & Stock Tubes
- Cold exhaust from front cylinder 2014 FLHX
- Help with a V&H Pro Pipe
- Trouble starting 1340 Evolution
- Geared cams
- Worn cam tensioners TC96?
- what throttle body and cam to use?
- RSD Intake
- One quick question then we can let this thread die
- V&H pipes starting to yellow...
- Breakout 103 Piston/Cam Combo
- Product to Quiet V&H 17545 Pro Pipe?
- What do you think about this..
- Is new H-D breather baffle OK?
- Brief overview of how exhaust works & improving Exhaust Gas Velocity
- Which Cosmetic .030" Top End Kit for S&S 106
- 107 build - Fuel Moto jugs or bored stock?
- Fuel Moto head pipe?
- Cam Selection on a 103 SE Stage IV build
- changing pipes
- Sea Foam
- special tools for building an engine
- SE Stage 4 vs. Other 103 builds
- S&S Power Tune Duals vs V&H Power Duals
- S&s pistons problem
- Clicking noise FOUND and strange cyl marks
- Breather gear Problem.
- Help with a noise please!
- which loctite help please
- clutch cable
- Help me build my 103
- Something ain't right here ! ! ! !
- Ideal Exhaust for 48" "Sound and Performance
- Winter Build: 103, 106, 107
- Fuel Additives
- Fuel Moto 107" build
- "Blue Printing"
- Sifton pistons
- Installing Quiet Baffles V&H Short Shots
- S&S Starting Cranking problems
- Screaming Eagle Heavy Breather
- 2012 harley 48 motor build for wheelies
- New Exhaust for 2010 Street Glide, help me.
- Vee Twin Performance Stage III Heads
- looking for a heavey breather
- oil tank emptys
- V&H big radius chrome 883 iron
- CV Carb to Intake Rubber Seal
- Baffle Rattling
- SG exhaust recommendations
- A little engine mod...
- S&S motor puking oil
- 2014 Breakout Cam thoughts?
- Gas leaking from the air cleaner?
- What will the 1.725 SE Pro Rockers do for the andrews tw 21 cams ?
- FLSTS w/Carb Won't Accelerate Until Warm
- 1970 XLCH build!
- Son's 2001 FLHR
- Gear drive and other help needed
- Will this work?
- Tips for lifter installation?
- Big numbers can come in small packages !!!
- engine stains
- Guess my numbers?
- Carb Question
- F/S: 2004 Harley-Davidson Stock Exhaust
- 90+ hp/tq build
- 103b with stage 1 kit/ stage 2 kit
- Can you do a mild set of cams like the Andrew tw 21 and keep the stock ECM
- Cams for 96"
- FuelPak Data Sharing Project
- bigger intake valves
- cylinder bore
- Pro Pipe Competition Baffle
- Kuryakyn Hypercharger breather...
- Crane 302-2 cams
- Engine Noise with Video
- Bike puking LOTS of oil out the breather
- Rocker box breathers
- Roller rockers
- Valve spring replacement
- Sticky Suggestion: Poll - which tuning system?
- twin cooled tru-dual options?
- Thinking of removing baffles. Pros, cons, and advice needed,
- Cam upgrade for my stock deuce
- Power to the ground...bar advice
- Bigger valves in 103 build pros & cons??
- Heads
- Low Profile air cleaner for 1986
- tw 26 cam install
- Cranks too long then fires
- fixing/upgrades
- Odd exhaust problem
- Another £5 air cleaner cover
- Andrews or S&S cam install kit?
- Valve work question to the pros
- Loud tapping noise-top end once warmed up
- Help with Intake/Tuner decision
- TC88 any reason to bore over cyl replacement?
- Back to SE II's from Rush
- Road Rage II B1 installed...with a squeak!
- Adjusting push rods
- piston cleaning
- 2014 Stage 1 Engine Braking Decreased
- intake gaskets
- HD 88-95 Kit
- stalls
- 2011 se 110" tuning issue pulling my hair out
- Bassani Exhaust on my 08 Fat Bob
- CAT Removal
- Excessive case pressure
- 131" Starter problem HELP!
- tru duels on a 08 softail deluxe?
- Looking to upgade motor...help!!
- Yost power tube on HSR Mikuni carb??
- Ticking/Knocking From Front Of Engine
- High performance air intake and exhaust question
- Weird noise fromn the engine
- EV27 cam question
- Running Lean Issues / Help Please / On The Road
- Exhaust Leak?
- 80" Evo motor S&S carb Jetting ???
- S&S 4 1/8 cylinders and pistons on HD 88
- Intake advice requested
- Limited Travel Spacer
- QD fuel leak
- 2005 883 carb slide issue
- MM fule injection - hidden screws?
- tc88b startup clunk
- Need some help... Have a 97 Evo merch 131
- lifters
- iNTAKE VALVE SEAT HELP
- Heat Wrap
- D and D bobcat for the breakout
- Clean fuel tank
- 113' been sitting for a while....need to hand crank.
- S&S Super Choke
- 103 Upgrade -- First Dyno?
- 103 upgrade hard starting
- Vance & Hines
- Vance and Hines VS. Rinehart
- Engine Died
- 95 xlh w/kit makes noise when slowing down
- Which A/C flows the best?
- I thought it was pinging
- Backfire on start up when warm
- Fuel Standoff issue
- 110 Heads
- Another 1980 FXS Cam question.........
- How often do you clean the throtte body?
- Adding HQ heads and cams to a 95"
- fxlr base gaskets
- bassani road rage 2 b1 on 103
- De-catted headpipes from Ebay.
- mikuni jet
- H-D SE 2>1>2 Nightstick slip-ons
- do any 07 or later HD's have speed limiter?
- S&S Air Cleaner question
- gaskets
- 2009 FLHTCU Automatic Compression Releases
- fuel management
- cam chain quides
- Do I really need a fuel tuner?
- lifters
- jetting help
- Need advice on exhaust back pressure
- 124 with S&S Power Tune Duals
- New build wont start
- Stuck in traffic & heat in Seattle
- need a dyno tuner! A good one
- Wimmer Macine filter on SE Heavy Breather?
- Engine shutting off
- 107" keeps backfiring
- HPI Throttle body
- 103-107 help
- Slip ons on 2014 Sportster 883
- Rust inside of brand new exhaust?
- D Carb and 1250cc
- SE 120R carb engine
- Stage 4 103" OVERHEATING!! What works to cool it down?
- piston pin clips
- Fullsac
- 02 Ultra
