PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. adjusting pushrods
  2. Exhaust torque values
  3. smelling gas in oil, 07 sportster
  4. keihin carb question
  5. help getting synthetic oil out of crankcase
  6. 04 Fat Boy Meltdown...need advice....
  7. Exhaust - What do I need?
  8. CV carb noise
  9. Rowland Sands Design Air Cleaner
  10. Engine Noise???
  11. Engine idling low and "backfiring" when decel
  12. 73 sportster poping out tailpipes please help
  13. Compression Releases
  14. S/E exhaust and cams questions...
  15. Interchangeable Part Numbers
  16. K&N '08 Screamin' Eagle replacement filter!!!
  17. 2009 StreetGlide, how different is the exhaust layout?
  18. when they need to check and replace, 2 camshaft primaire and secondai
  19. head gasket question........
  20. Need Help deciding
  21. New to Forum - Running poorly and need help.
  22. tc88 cam slack adjuster
  23. Best pipes for HP
  24. Emulsion tube in the CV... which end up? Also, my carb had a #48 jet??
  25. Rinehart Tips
  26. Rinehart exhaust on 2007 1200c
  27. Dyna Idle sputtering and trying to die
  28. CV Carb question
  29. Rush slip ons ez to install?
  30. specs and process of rockers/pushrod R&R??
  31. 93 springer wont start
  32. gascap-vented or non vented??
  33. 2003 Night Train Starting Problem
  34. Is anyone running...
  35. Bluing Tailpipe
  36. SERT required for D&D Fat Cat 2 into 1?
  37. Adjustable Pushrods?
  38. Finally got my bike fixed, and a heads up fpr y'all
  39. need to replace my 883 hugger carburetor
  40. 95 Heritage Slip On Muffler or Baffle Recommendations
  41. Idle Speed
  42. cams
  43. 95" Big Bore Kit
  44. Excessive Crankcase Pressure
  45. need some help with new exhaust
  46. Stalling under load
  47. motor is flat
  48. Rush slip ons
  49. Oil Pressure spring
  50. Carb Jet/New Carb Suggestions
  51. Help!!
  52. V&H vs. Screamin' Eagle pipes. Which is LOUDEST.....
  53. Ness 90 degree filter on an 07?
  54. surging
  55. 93 FLHTCU dies at altitude
  56. maintenance has to be done on the cam chain tensionner primary and secondary on the o
  57. 17251-07 17252-07 Heads
  58. Is this even possible? Evo80 pushrods
  59. worn cam adjuster
  60. Tapping from topend
  61. V&H Pipes for '08 FLHX
  62. 1340 evo cold start idleing problem
  63. Fuel Tank
  64. 1984 FLHTC Evolution true dual search
  65. Any one have a Arlen Ness 90deg. big sucker?
  66. Looking for input on my 103" plans
  67. HQ 113" build completed
  68. 88" to 96" swap on a dresser.
  69. Intermittant stalling on exceleration.
  70. New Fatboy cooks right w/ upper pipe..
  71. Will taking out the baffles heart my bike?
  72. indentifying cam in motor
  73. Stripping Gas Tank Sealer
  74. RevTech 100" top end noise
  75. Low Fuel Light (Full Tank)
  76. V&H Instructions
  77. Fuel Gauge
  78. 05 RK Classic w/9 spoke wheels
  79. Decel Popping/ Backfiring Cause?
  80. Too early to download map?
  81. any lifter problems with 96 inch motors
  82. inconsistant idle
  83. Evo troubles
  84. Fuel Cuts Off When Cold?
  85. Big Sucker air filter...
  86. punching out baffles
  87. strange miss
  88. flat sounding motor
  89. best performance exhaust sys??????
  90. intake leak
  91. exhaust gasket question...
  92. Cams and Tuning Questions
  93. For those who insist slip on's require fuel managment....
  94. HP and Torque #'s for 96 to 103 ???
  95. Questions on Engine Builds & TMAT Tuning
  96. 103 Dyno Results
  97. Is there a windsock for round type filters?
  98. How often to clean open air filter?
  99. Poor high speed/load performance
  100. Should I mill the heads?
  101. L/S tank fuel level not dropping ?
  102. Rinehart 2-1 center heat shield rattle
  103. Next step for a 96?
  104. Vance& hines pro pipe
  105. 07 RKC broken "Y" pipe
  106. What exhaust? confused...
  107. New 08 Heritage owner. Am I burning oil?
  108. Fuel shut-off
  109. Heat Issues?
  110. Bad Rod bearings 01 Twin Cam w/ elec ignition
  111. 96 inch or 88 inch FI or 88 inch Carb'd? Wanna do some minor mods, what should I buy
  112. Screamin eagle 11 chrome back plate cover
  113. Hesitation at full throttle
  114. Curing excessive valve noise
  115. Heads for 95"
  116. V&H Straight Shots vs. Big Shots
  117. Kuryakyn Hi-Five A/C
  118. What did I do now...
  119. OIL and SPARK PLUG Question?
  120. Rush Exhaust/Fuel Management: Advice Needed
  121. Sudden High Idle/acting up
  122. Big bore kit...
  123. for people that run dual exhaust on stock motors
  124. D@mned CV Carb! hehe
  125. Gas Mileage Question
  126. EVAP tube melted
  127. 08 fuel filter recall
  128. Axtell cylinder issue?
  129. FL: why not plug crossover pipe to control heat?
  130. what cam for a stock 08 TC96?
  131. Thanks Doc 1
  132. Injectors/Throttle Body Questions!!!
  133. Cleaning stock air filter, recommendations?
  134. Cam recommendation for a friend
  135. K&N air filter or not
  136. spark plugs? Too rich?????
  137. Ear Protection
  138. cam tensioner
  139. No Slip-Ons on 08 Softail?!
  140. Doherty Mystfree
  141. SE204's to 251's
  142. Gas Gauge help
  143. cam guides on a "88"
  144. removing valve guides
  145. Any ideas?
  146. True dual head pipes
  147. 81 shovel. early or late?????
  148. hesitation at throttle
  149. Exhaust Leaks
  150. Rinehart Clamps
  151. New Exhaust?
  152. Is there really a difference in performance
  153. Top performing
  154. exhaust quiet after new plugs and wires
  155. Zippers 103 Kit
  156. Making Rineharts a little quieter
  157. Slip on pipes
  158. LOUD pipes ARE legal in CALIF-for police?!!
  159. Arlen Ness Big sucker for a Nightster????
  160. Exhaust turn out tips
  161. D&D Boarzilla??
  162. What HP/TQ should I expect??
  163. best pipes for 110 screaming eagle
  164. Problems after Stage 1
  165. What happened to BigBoyz Cycle?
  166. Flywheels
  167. dyno testing in ohio
  168. Exhaust Pipe turning yellow Color
  169. Exhaust Pipe turning yellow Color
  170. Drilling out Stock 07 Mufflers.
  171. forcewinder intake
  172. TFI help??
  173. Covered vs. Uncovered Air filter Q's
  174. Need help getting PCIII map leaner
  175. Vance and Hines slip-ons question
  176. bassani road rage
  177. Samson Big Gun Help
  178. Vance & Hines Big Radius 2-2
  179. Rattle on Electra Glide
  180. how much pipe wrap required
  181. Jackpot Mufflers
  182. Keihin CVK 40 27492-96 Carb spit, spit, choke sputter
  183. Compression Ratio
  184. Question Regarding Exhaust
  185. 08 roadglide engine pinging real bad under load
  186. Exhaust baffling question
  187. PSI Gen IV Carb on kick only shovel?
  188. psi gen IV carb on Kick start shovel?
  189. [Deleted]
  190. Spark Plugs? Vrod Plug Hotter or Colder?
  191. Samson - Shotgun Longtails and Renegades
  192. Will a PC-III effectively reduce temps on a stock motor?
  193. cam shaft for 2006 Street Glide
  194. '96 sporty Exhaust on an '07 sporty
  195. Do I need adjustable pushrods
  196. woods cams stock 96"
  197. Got to quiet bike
  198. Cycle Shack Owners - Quiet Baffles???
  199. Fatcats on a Softail
  200. EVO Tappet Replacement
  201. uneven exhaust flow
  202. '09 Touring Aftermarket Exhaust Systems??
  203. Oil Pump Failures
  204. dYNA GUYS SOMEBODY HAS TO KNOW THIS ?
  205. iED question) Milwaukee says there is nothing wrong with my 08 FatBob
  206. 2008 Deluxe Exhaust?
  207. 08 SE ROAD KING RUNNING PROBLEMS
  208. side shots
  209. Confused
  210. bad spark plug 2
  211. bad spark plug
  212. cam chain tensioner
  213. bad spark plug
  214. I CAN'T POST!
  215. HELP top dead center
  216. XiED's, PCIII, other..help??
  217. exhaust change
  218. exhaust change
  219. exhaust change
  220. exhaust change
  221. RE: exhaust change
  222. Help me install my new exhaust
  223. exhaust change
  224. Twin cam oil pressure
  225. "Downstate" New York Tuners?
  226. Supertrapp Exhaust
  227. flattop vs domed pistons
  228. fuel pump ?
  229. Rush slip on
  230. uneven discoloration on tailpipes
  231. trouble with V&H Fuelpak Installation
  232. Fuel smell in oil
  233. Best Price on D&D Fat Cat for 07 Touring?
  234. Help pushrod o-ring leak
  235. Y Pipe Glowing Red HOT !
  236. Clatter noise after gear cams installed
  237. 08 FatBoy overheating in 85* weather
  238. glowing header pipes
  239. SE vs Big Sucker
  240. 2009 Oil Capacity Increase???
  241. Fat Bob tank on a 1973 FX
  242. Installing true duals
  243. Fuel Tank Swap
  244. BUB 7 Slip-Ons WOW
  245. exhaust leaks
  246. Mikuni SE 45mm carb falling flat
  247. Twin Cam Specs
  248. SERT, Cobra or ...
  249. 06 heritage fuel mileage
  250. Exhaust, Intake, Forward controls
