View Full Version : Exhaust System Topics
- Good (BAD) Vibrations
- Another source for V&H angle tips?
- Bag o'nickles?
- CP Pistons or Wiseco Pistons?
- EFI to Carb Mod
- Modifing My Heritage Exhaust
- Need cam help
- Cam bearings
- Power Commander V Map request
- FLHRCI Slip Ons Have No Baffles
- Cruise control for 07 FLHP?
- Help! My Cam Support Plate Won't Go In!
- Two into One
- Engine modification break in??
- tenison adjusters
- Big Bore Carb
- shovelhead engine angle
- Strange home made exhaust pipe question
- building my own exhaust
- heritage cuts out at high speeds
- spitts and sputters
- Engine keeps running after shut off
- Bike will not start
- Debating changing my Cams
- shovel problem ,rear cylinder
- Recommendations On Good Air Filter
- How Many Hours to Dyno Tune a TTS?
- Tune after slip ons?
- 100 hp EVO update
- Heritage w/EFI won't idle after cruising
- 103 Screamin Eagle BB upgrade. ECM/tuner question
- Mystery part on Keihin CV carb?
- vance and hines pro pipe??
- DNA Specialty Air Cleaners
- what do you all think of the S&S 510G cams
- Bad noise in my Evo, has anyone ever seen this?
- Mikuni carb problems
- wrapping pipes over heat shields
- Newbie question
- Intermittent Sputtering
- Tools for overhaulin a 88ci
- S&S 124 from Star Racing
- Replace flanges/rings?
- Spitting, Coughing, Frustrating 89 Sporty 1200
- evo pushrods
- 883 to 1250 conversion-> new carb or re-jet what I have ?
- 103 cam
- check valve in fuel tank vent line?
- need more power
- 95" big bore and andrews 21 cams
- exhaust headers
- Difference Between all the HD Shorty Slip On Mufflers??
- Claying for clearance
- 2001 Road King Hiss
- Performance Machine FASTair vs Screamin Eagle Heavy Breather Intake
- 4.060 Cylinders
- cam chain guides failure!?!
- 883 to 1200 conversion question
- 04 Roadking, quick disconnect assembly help!
- S & S Super B causes High RPM's
- How does this idle sound?
- Pipe question
- 100 hp evo
- 2003 road king compensator nut 5,500k
- slow as a snake
- 4" Pistons for 4 5/8" Stroke Crank?
- 96" to SE 103" kit upgrade. Compressing level question.
- 86 Sportster rocker tick HELP!
- Want more juice for my stock 88. Screamin eagle kit?
- How much damage could I have caused??
- HOLLY s/e 2BBL CARB
- Keihin CV accelerator pump rod
- 88ci to 95ci
- Screaming Eagle Street Preformance Slip-On's
- 95" build
- A bit disapointed
- DK Custom HiFlow 587 DIY Installation Video
- Engine/Battery lights come on after engine shut off???
- Engine Upgrade
- Cam
- 88b Torque Upgrade Recommendations
- 120r for older bike
- S&S 88 to 103
- need help with 03 Eg standard HELP Please idle problems
- Recommendations for new Ultra.
- valve/ piston contact ?
- which head pipe to use 09 or 010 & up o2 sensors
- witch heads to buy 09 ro 10&up o2 sensors
- 99 FXSTC backfires & won't idle
- Will Bassani Softtail slip on mufflers fit my Sportster
- Do you need to remap with slip-ons?
- 04 electraglide wont start?
- How to tell if an engine has been bored?
- 2000 flhr
- What heads to use???
- Cleaning inside pipes/carbon build up
- 120r
- Engine stumbling
- Has anyone done an 88" build???
- Lightened rotating parts
- vance and hines big radius exhaust
- V&H Staggered Short Shots
- HD SE Night Sticks AUDIO
- Engine stalls 10 minutes after starting 2008 Softail
- 2000 Heritage ST Backfires
- Any tricks to get lifters to bleed
- screamin eagle head help
- Most efficiency with least noise
- new v and h big shots... use their exst gaskets?
- What to put a screamin eagle 120r in my softail
- Air cleaner recommendations please
- 07 fxstc with 08 tank needs fuel pump
- Screamin' Eagle tensioner upgrade kit TC88
- CV Leaky Accelerator Nozzle
- baffle
- New HD 103 Upgrade Kit
- Cam Swap Time, Help steer me into the Right Cam
- ignition changes
- How to retrofit a TC88 into 1989 Dyna
- Will this tank fit my bike?
- How to remove melted rubber from exhaust?
- Rollin free
- Cheapest route on getting more power outa 88"
- '92 Fatboy surging at low speeds
- Crankcase Thread Stripped
- straight pipes
- ss 111" exhaust question?
- Best material to rewrap v&h quiet baffles, and where to buy it.
- Need exhaust suggestions
- Carb Iceing?
- head gasket issues - I need advice
- smell oil on decel
- Exhaust for a 2013 Street Glide
- 1991 Heritage Help,Please
- still smoken
- New to forum and choppers, need exhaust help.
- V&H Monster rounds
- Shotgun vs shorties
- CFR Exhaust
- MM Fuel Line Fix
- True Duals by Wyatt Gatlin?
- trouble starting my evo
- Upper engine noise
- Dual Intake Identification - WhAt iS thIs?
- 106 build done needs more cams.
- question on re adjusting pushrods
- Hi perf air cleaner on 2006 103 CVO Ultra
- Next step for 1200 sporty
- bike keeps dying
- Leaking carb problem
- Fuel quick disconect question?
- cv carb issues
- 103" build compression question
- OOPS Fogger Spray Tube in Front Cylinder
- 2012 Road King Classic cobra pipes too quiet
- Excess Blow-by
- Bassani Quiet Baffle
- CFR exhaust question again
- 2009 OEM 2 into 1
- I need help....which model is this for?
- Shovel cases with evo internals
- where to buy cam shims
- TC 96 to a 107 in my 08' Bagga'...have a ???
- damn ebay
- Pan/Shovel cases
- Engine not starting
- 84 FXST CV carb conversion
- TwinCam 88 Back Pressure - How Much?
- S&S power tune duals
- different makes of roller rockers in bike
- Would you recommend the S&S 100cu. for a street bike?
- 2007 Streetglide with 114ci having some serious problems
- Road King/Vance & Hines Issue
- Rush 4" Slip-ons with 2.25" baffles
- A decent amount of oil coming from carb
- O2 Sensor deletion question
- muffler heat shield
- jets
- Gas Gas Gas!
- V & Hines StarightShots Mount Bracket 91-05 DYNA
- 103 Engine "stuttering"....?
- Engine problems please help?
- cfr true dual exhaust
- Ultima motor
- RSD Turbine air cleaner on a 120R ??
- 131" rebuild, who do you call? Not ghost busters!
- Ultima 131 ????
- Andrews 288999 kits
- torque cones
- 103 Engine Life
- upgrading exhaust
- perfect set up for 95 kit? suggestions?
- Mid-range, top end pull.
- more restrictive slip ons after a dyno tuni
- Tuner - MN/ND/SD
- SE Hydrulic Tensioner Kit
- Road King EFI fuel leak
- Top speed
- Acceptable CVO 110 piston clearance
- ironhead wont start
- 103 build/exhaust modification?
- slip on mufflers on new street bob - advice needed re: tuning
- Exhaust/Performance
- The Ultimate Softail Slip on Thread 2012
- hard to start when hot.
- slip ons
- Vent breather tubing mod-Tucci?
- H-D CNC ported heads
- Won't start
- 09 twin cam misfires on rough roads???
- 2010 OEM exhaust on a 2000 RK?
- backfiremissfire and noisy spool up
- Heritage softail oil leak
- rebuilding cam tensioners
- SE 204 cams in a TC96 - hard to tune?
- 95" twincam popping noise
- SE 103 cams?
- S&S 113 ci oil leak
- Convert TC103 to carb?
- Don't know what's been done...
- Dual spike air breathers
- S&S slip on
- 2000 road king bad miss
- Cam Change 2012 FLHTK 103"
- Valve Train / Rocker Noise on 103
- S&S T111 bent valve
- Switching S&S cams
- Ready to build a torque monster 124" need help
- Exhaust Flame Thrower Kit - Good Or Bad ?
- Question about starting
- Jetting Stock Carb on Stock bike
- 2000 wide glide Stage 3 kit
- Undecided
- Removing baffles SESP 2012
- Jackpot Dyno Tuned Stainless Steel head pipes?
- Deceleration popping cure, perhaps?
- Exhaust flap/valve removal
- 107" Running HOT?????
- Dummy cap removal
- Whistle/Chirp when releasing throttle
- Whats the dif with these 2?
- problems continue Super E carb
- Idle problem
- Can't figure out engine noise.
- Has anyone tried the new TW-222 Woods Cams from Fuel Moto Yet
- will these heads fit Twin cam 96 models?
- Oil in air filter
- lifter noise
- tc 88 engine noise
- 2005 Ultra exhaust question
