PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. V&H Big Radius 2-1... baffled by baffles!!
  2. Poor Man's High Flow Filter KN-1499 and...
  3. Dealership can't fix spit/sputter problem on 06 Dyna
  4. any better intake designs
  5. Kurakyn Hyper Charger or Heavy Breather?
  6. Best SERT tuners in Missouri?
  7. Vance and Hines on a 2007 Sportster, do I need a Power Commander?
  8. Muffler removal?
  9. Primary cam sprocket spacer?
  10. New SE Tapered P-Rods
  11. Just not happy with harley power.
  12. Inner cam bearing install
  13. True Duals ?
  14. Excessive Vibration
  15. O2 Sensor question ?
  16. WHAT SHOULD EFI SPARKS PLUGS LOOK LIKE?
  17. rinehart exhaust
  18. stock FLHTC--looking for pipes/stage 1 info
  19. one for the experts
  20. advance key for tc
  21. help have the horsepower flu
  22. plugs how often do you change
  23. Different types of SE Exhausts?
  24. Annoying Start Sequence...sometimes
  25. Anybody else using HQs Mikuni tuning kit? *UPDATE*
  26. New build Woods TW7H valve noise?
  27. Yaffe Exhaust and Pwr Commander III
  28. Fuel Gauge Problem
  29. New Jersey Dyno Tuners
  30. Occasional Hesitation while at a steady throttle
  31. bike hiccups or cuts out
  32. No Start, Clacking Machine Gun Sound
  33. Dyna fuel pump instead of a Sporty fuel pump???
  34. Vance & Hines bigshots baffles
  35. Thanks Doherty!!
  36. exhaust feed back
  37. Replacment baffles for SE slip-ons 2007-2008 model touring
  38. Vance & Hines True Duals
  39. SE HEAVY AIR CLEANER KIT
  40. Vance & Hines Replacement Baffles for Classic Slip On's?
  41. Need a little help with AC kit
  42. moved to touring
  43. Cam timing question
  44. 08 street bob tank question......also pertains to other models.
  45. Opening up OE backplate
  46. 2001 FLHT 95 cu in 2004 Ported heads idle?
  47. Sound Samples
  48. Screaming Eagle II exhaust great!!
  49. Engine Newbie
  50. Thunderheader 2into1
  51. Best sounding 2 into i exhaust?
  52. EVO CV Carb DynoJet kit help
  53. Bub 7 slip-ons or 2 into 1
  54. Short whistle sound
  55. Fuel leak from thru tube in tank
  56. top end noise sounds like coming from carb
  57. Which Cam
  58. How about this exhaust upgrade??
  59. STRANGE WHISTLE SOUND???
  60. EFI dyno tune numbers
  61. Engine shakes bad between 2300 and 3000 rpm
  62. quiet baffles for hooker troublemakers
  63. Big Sucker O Ring Size
  64. - removed
  65. SE slipon mods
  66. V&H Basic Slip Ons
  67. o2 sensor on aftermarket pipes will fit
  68. Where do I stick this hose??
  69. will not idle
  70. Spyke Compression Releases
  71. 2007 Street Glide oil leak. How much should I worry?
  72. I need Pipe and tuner help
  73. Intake Manifold MAP, heat sensitive??
  74. Andrews TW55 cams
  75. break in and my engine build
  76. Stage 1 Time Line
  77. screamin eagle carb
  78. 74 ironhead 1000 VS DELLORTO PHM 40
  79. Thunder Monster baffles and remapping
  80. "Goodson" Air Cleaner Assy.
  81. Carb Rebuild Help
  82. Anyone put an andrews 54 in a stage 1 96 yet?
  83. NEED STEPS TO GET DTCs ON '01 TC
  84. Can damage can be done by running a new build without a hotter ignition?
  85. Too Loud
  86. Tear Down of 88 TC
  87. Slip-ons for 07 road king ..HELP
  88. Doherty or K&N?
  89. LM-1: Digital Air/Fuel Ratio Meter
  90. Need help with a power loss problem.
  91. Opinions of my future Build
  92. Hooker Tuned Flow pipes decel popping
  93. Need Some 96TC Engine Help !!!
  94. Rebuilt Motors?
  95. 06 cams, heads, other ???'s
  96. baffles or new set of pipes?
  97. Dyno Tuning at Harley
  98. Bigger intake valves in a 103ci??
  99. Jetting Question
  100. SCREAMIN EAGLE DYNA TWIN CAM 88 RACE IGNITION
  101. RE: 95", 82cc chambers, flat tops, .030 gaskets
  102. She has to get naked - what to take off first
  103. PYTHON 2-1 any good?
  104. Drilled out backplate
  105. Heat Sheild for a 1980 FLT
  106. long winter, bike wont start please help
  107. coparing stock cv to 42mikuni
  108. Twin cam cylinders & Heads budget build
  109. Powder coating exhaust
  110. Anyone using a Speeds Performance air filter?
  111. 07 upgrades
  112. Possible Twin Cam Engine Damage After Crash
  113. Crank Case Breather Question
  114. Cam Install Question???
  115. SE Street Legal Stage 2 KIT
  116. high temp paint
  117. HELP! Air box problem
  118. loose slip-on
  119. heads and crank question
  120. Cleaning inside of engine.
  121. Nightster Upgrade Questions - Need to Buy Soon!
  122. True Dual Conversion for Heritage Classic
  123. Dumped my oil after the build.
  124. Baffles?
  125. Ported Heads & Existing Rideability
  126. I need help finding new Injectors
  127. Put the V&H Big Shots on today- now AC and PCIII-discussion???
  128. my engine build
  129. Almost finished on 95 Stage II build
  130. Installing baffles on pipes w/o mufflers?
  131. EFI Questions
  132. Hushers?????????
  133. Air cleaner question
  134. V & H slip on
  135. Exhaust - cleaning inside of pipes?
  136. roland sands Nostalgic Velocity Stack opinions?
  137. spring oil change: synthetics and additives
  138. Gas tank removal
  139. n4 cams and compression
  140. pipes question
  141. total cost to make it fast
  142. ne1 running a forcewinnder or have knoledge of them
  143. HAS ANYONE USED THE RINEHART 2 INTO 1 ON A 110 SCREAMING EAGLE
  144. Tunable Exhaust..what do you know?
  145. Super charger for Harleys
  146. will 2008 96ci heads fit on a 05 fatboy with 97ci axtell jugs
  147. New Cam - One small step
  148. SE Pro end caps
  149. Engine Breakdown and Bets on what the problem is
  150. SE 203's in 07 Road King
  151. Considering True Duals any suggestions
  152. Vance & Hines Monster Ovals
  153. Rush "true duals"
  154. TwinCam oil pump HD vs Fueling
  155. Question on ultima rods
  156. SE 95" head gasket thickness
  157. Stock Big Twin air filter????
  158. 08 Rocker Exhaust
  159. Exhaust combo ??
  160. Does anyone else like the Super Trapp true duals?
  161. new Rineharts True Duals
  162. 150 Miles on new build when should I dyno?
  163. Remember me, Mr. disappointed, well not any longer.
  164. 95 Build on Friday
  165. SE Catalyst Mufflers?
  166. S&S air and exhaust
  167. Anything you want to know
  168. Soot on Rinehart Duals
  169. 883/1200 rebuild
  170. cam selection
  171. Big Bore Stage II install
  172. J&P Cycles.
  173. 02 EFI Deuce starts and dies...
  174. S&S Tuned Intake for '05 Springer FLSTSCi
  175. Dented Exhaust Head Pipe- Problem???
  176. Can anyone tell me about 96CID crank bearings?
  177. What end caps for old SE pipes
  178. CAM Lifters on 95" Build
  179. What to spend it on???
  180. Bore tolerances for SE cast pistons
  181. Compensating bolt on the crank
  182. 06 RKC noisey as heck tranny
  183. Alternative methods?
  184. Screaming Eagle Slip ons (80029-95B) Help
  185. 99 Cam Cover Oil Leak!!! HELP!!!!
  186. Damn ticking is making me nuts!
  187. case question
  188. Get a simple understanding of cams and how they work
  189. Bub 7 True Dual w/o Crossover
  190. Stroker question
  191. Torque specs - '02 Softail exhaust?
  192. crane cams?
  193. cam selection/ performance advice???
  194. sticking throttle
  195. Help with Cam Selection - Please
  196. Power Commander setting help needed.
  197. bike with hiccups
  198. TERRY TERMINAL II & ANDREWS CAM SWAP
  199. 07 King with 03 SE exhaust?
  200. Opnions on SE street performance exhaust
  201. 1st gear klunk
  202. One Blue Tip
  203. Performance Query
  204. Does anyone make a true dual conversion kit?
  205. burning oil !!!
  206. Re mapping with which Air Filter system
  207. mikuni jetting on a '73 sporty
  208. SE street legal muffs too loud
  209. Dome volume
  210. Only a 2 into 1 will provide top performance? Fat Bob
  211. Cam Gear Noise
  212. removing o2 sensors
  213. idle help
  214. When to Check Cam Chain Tensioner/Bearings
  215. santee boa pipes
  216. High-Flow aircleaner
  217. V&H Pro Pipe-Bad for Low End Torque?
  218. gray sparkplugs jetting help please
  219. thunderheader 2-1 question
  220. hacker pipes
  221. V&H Straight shot slip ons
  222. HAS ANYONE USED THE VANCE AND HINE 2 INTO 1 PRO PIPE ON A 110 SCREAMING EAGLE
  223. Strong Fuel Odor
  224. Martin Bros. Exhaust
  225. Locating a Panhead
  226. Spray water into intake to clean valves.
  227. Installing Springer duals on a Heritage Classic
  228. evo valve lift
  229. Throttle Cables on Carbed
  230. Valve train noise after cam change in an evo
  231. Jims hydrosolids ne1 running them
  232. 883 Pops back through the Carb
  233. Intake Valves shot at 16k miles?
  234. chronicEvo motor gasket problem
  235. Thinking about getting a tire machine
  236. What motor do I have???
  237. mpg?
  238. Stock Cam Specs for 2008 96" Ultra??
  239. exhaust ! 2008 R/C clasic
  240. Cam Tensioner question again
  241. S&S 124" Project
  242. Andrews 32h cam set
  243. do torque cones work?
  244. Fatcat Install
  245. EFI K&N factory replacement filter
  246. black vs. chrome exhaust
  247. SE Street Performance slipons?
  248. need some help please
  249. Adj pushrod came loose then fuel from exhaust after adjusting it
  250. Cam question for evo big twin
