PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. New Lifters Needed?
  2. Exhaust tightening sequence
  3. Increased engine vibrations??
  4. Round air cleaner cover with hidden bolt?
  5. How to Set Compression Ratio Question
  6. To get headers or not.....
  7. cv 40 carb help please!
  8. compression engine
  9. Ethanol additive
  10. Questions about V&H quiet baffles
  11. V&H Comp pipe and Thundermax?
  12. 96" bb on an 88"
  13. Carb farts
  14. Wood 777 Cams
  15. True Dual Kit
  16. Yet another cam thread, but with a twist...
  17. New exhaust--- what can I expect?
  18. Not Sure If Bike Was Dynoed In Right Gear
  19. Remap/programmer for exhaust alone?
  20. Automatic Compression Release Questions
  21. bike misses code p0263
  22. Cylinder piston fitment
  23. Piston-cylinder clearance?
  24. tc 96 upgrade
  25. Engine Oil Leak
  26. Exhaust Install
  27. how much bigger
  28. 2010 ultra clutch question
  29. bike stalling
  30. Cam chain and cam?
  31. Engine Stumbles, coughs, backfires
  32. Who's changing lifters??
  33. "try" figuring this one out
  34. A Little Disappointed In Dyno Numbers
  35. Looking for a GOOD mechanic
  36. Noise Coming from the Fuel Tank?
  37. cams
  38. need help with harley slip ons, part # 80103
  39. twin cam
  40. twin cam
  41. TMAM 555's
  42. 03' cam tensioner
  43. any jims 120 owners out their?
  44. Rocker Box Leak on a 08 XL1200N; couple of Q's
  45. Air cleaner intake question
  46. Evo cam install
  47. Mufflers or Air Cleaner
  48. EFI Fuel Leak
  49. How do you Install Plastic fuel line???
  50. Fuel economy, Heres my setup, what should I expect? I'm getting low 30s/gal, not good
  51. engine noises
  52. Will any other HD fuel tanks fit on an 05 883L sportster?
  53. Baffled
  54. When do you need to rebuild 96 Cu?
  55. Khromewerks Mufflers
  56. What's with the 103 AC fitment
  57. 2005 Gas Tank Removal
  58. 213 HP POWER 183 TQ DRAGO'S Bike Works
  59. Cam Kit
  60. Engine Light came on FLXH 2008
  61. Chev roller lifters in a 96"
  62. Stock FLHRC Mufflers,are they all the same?
  63. Casting #'s For '08 Crossbones Heads???
  64. new memeber first question
  65. More power from the 103!! ??
  66. Intake Oil Blowby Clogged
  67. Dobeck Controller going bad??
  68. exhaust back fire and hard start, help!!
  69. Coughed Once, Then Died
  70. Compression test?
  71. Putting on slipon, sealer grease I should use?
  72. Closing hypercharger crankcase breather hole
  73. Stage 1 questions
  74. Advice please - Nightster exhaust issue
  75. Out of gas, with a FULL tank!
  76. Oil Pressure
  77. Sound clip of 103 with stock pipes and de-catted headers?
  78. SE mufflers + de-catted headers = thumbs down
  79. Install a tank lift.
  80. D and D Exhaust
  81. 110 head mod
  82. Hard Starting 04 FXDWGI
  83. Question about screaming eagle exhaust
  84. Cough through carburetor
  85. 2001 Fatboy FI Cuts Off, Won't Start, Throws Codes 23, 32, 33
  86. Drilling out the Exhaust
  87. HD - HIGHFLOW to K&N AIRCharger Question
  88. Crank Run-Out Who has checked prior to cam swap?
  89. exhaust leak
  90. Replacement for SE heavy breather
  91. Sound Levels Measured - Big Shots
  92. Adjusting Super E.
  93. f'in MOCO "bad news on my new to me 10 FLTRX" crank runout
  94. 88" Stock 03 Heads VS 06 Heads?
  95. O2 Sensor Question
  96. Different sized baffles in slip ons ???
  97. cam sprocket alignment
  98. 88" crank in a 96"block
  99. THose with S&S 106 BB Kits..how High is too High?
  100. Looking For Good Shop
  101. 2 into 1 ideas
  102. ECM recalibration needed for slip on mufflers?
  103. vacuum leak, but where? evo
  104. 103 build, 2012 FLTRX
  105. 2001 RKC Intermittent running
  106. Sneeze on Throttle
  107. stoked about the new jug huggers
  108. Bassani Road Rage 1D5250
  109. Rinehart exhaust
  110. Leak down test?
  111. PLEASE HELP! 95ci build on 2004 electra glide
  112. Baffle question
  113. engine performance
  114. 2001 Road King
  115. 1975 Sportster Engine question
  116. Oil line on Oil Filter Adapter keeps on blowing off
  117. O2 and bung issue
  118. Can I use 07 Mufflers on my 10 RKC?
  119. Cold weather and jet sizes
  120. TC heads
  121. Theoretical underpinnings
  122. Fishtail pipe recommendations for 2011 roadking
  123. Looking in Pensacola
  124. Help!
  125. Stock Baffle - Iron 2010
  126. question regarding head gasket popping
  127. exhaust fxsts for flst-help
  128. oil light issue
  129. FLHTK exhaust
  130. Where to buy bike engines and parts?
  131. 883 hard start
  132. thread lock on oil pump and cam plate bolts?
  133. 95" Stage II Kit
  134. '06 Road King Factory Exhaust
  135. Lifter Question
  136. Mill the deck before cams?
  137. Ready to go the 107" route..OPINIONS
  138. tail pipe color
  139. Will it make much torque difference?
  140. Revolution Performance Jugs
  141. Lets talk Cold Cranking Pressure
  142. In the middle of a tc88 cam swap
  143. Lean codition on front cylinder.
  144. Issue with Auto Tune
  145. fuel gauge?
  146. Which Ultima Motor 113 or 120?
  147. Winter project upgrade 88"
  148. 1340 evo bored out .20
  149. Which cam for a 97 build
  150. Head gaskets
  151. Stock air filter replacement.. oil it or not
  152. couple questions about crank runout
  153. Comments on my proposed Stage 1 upgrade?
  154. American Custom header pipes?
  155. Unimpressive Stage 1
  156. Exhaust leak
  157. Bassakwards fuel issues
  158. Small fuel leak on 92 FXDC
  159. Reluctant to start when hot
  160. fuel pack
  161. TC crank shaft threads
  162. Will slip ons fit on 1-3/4" drag pipes?
  163. Just Added S&S SPO-80 Mufflers
  164. 98 FLHT Electra Glide backfiring
  165. heads and cams...
  166. Re-sealing a fuel tank???
  167. Best True Duals?
  168. SE Adjustable pushrods
  169. Differences in lifters
  170. Just A Remap?
  171. vieds or xieds
  172. slight ticking in my motor
  173. difference's between a 96ci and a 103ci?
  174. $200 for de-catted head pipes, or $450 for headers?
  175. Andrews 48N cam shaft
  176. Vibration in a 01 Heritage softail
  177. firecracker popping exhaust
  178. K&N Military Discount
  179. Black Smoke -Too much fuel?
  180. wrapped pipes melting my leg
  181. Help with upgrade!
  182. Sporster exhaust bolt torque? Also new gaskets?
  183. True duals = less torque?
  184. Forged Pistons VS Cast?
  185. 2001 Fatboy FLSTFI Crank Position Sensor
  186. CV Idle mixure queston
  187. Getting the urge to improve again.
  188. Power band
  189. python throwbacks painted black
  190. What is this wire?
  191. Brand new 103 Dyna leaking oil
  192. front cylinder tapping like crazy
  193. '00 FLHRCI gas gauge not working
  194. 97 FLSTC jetting
  195. 51mm CV Forcewinder?
  196. Rienharts Mufflers
  197. better oil
  198. 09 street glide engine cases
  199. air filter kit for 103 2012
  200. What exhasut will fit my bike
  201. Hard starts and runs rough at cruise
  202. Samson Rolled Thunder Oval vs Rush 2" slash down?
  203. Hammer Performance ?
  204. Rush 3" Slip-ons w/ no baffles?
  205. Backfire out of carb
  206. screaming eagle pro cnc ported factory heads
  207. Fatboy engine, help
  208. case repair
  209. carb swap
  210. Air Filter- most flow?
  211. Fill plug blew off
  212. Carb Jetting
  213. can SE slip-ons be modded for more sound?
  214. 98 evo burning oil
  215. 120" Merch Engine
  216. Not a leak after all.....
  217. will not start
  218. Stock Petcock issue?
  219. Ultra Calssic Missing.
  220. Aim vp clutch vp92t install for high hp motors
  221. Exhaust leak from push rod seal?
  222. Oil leak from solenoid
  223. cyclerama cams
  224. Verdict on the hydraulic tensioner upgrade?
  225. Torque cones
  226. Engine oil in primary
  227. any good jims 120 out their
  228. ecm question
  229. Evo valves
  230. Question regarding A/C breather
  231. Vance and Hines fuel pack
  232. Unblended Fuel
  233. Brown color inside of exhaust pipe
  234. Hyd Lifters
  235. Screws, sockets, or what?
  236. 08 toad glide problem
  237. no start help!!!
  238. New noise from motor...opinions???
  239. '06 Electra Glide Standard Engine Light
  240. V&H Pro Pipe Baffle Mod ?
  241. Roller Rockers are they worth it
  242. 123hp/117ft.lbs... Dyno Sheet included
  243. 02 night train with "valvetrain" noise at high rpm
  244. 95 and cam install how to?
  245. no oil pressure after replacing pump cover!
  246. 103" Mod
  247. Fuel MOTO is great!
  248. Anybody using se-257's in a 95"?
  249. What do you think of this engine mod quote/setup?
  250. Very high idle
