View Full Version : Exhaust System Topics
- 2009 Oil Capacity Increase???
- Fat Bob tank on a 1973 FX
- Installing true duals
- Fuel Tank Swap
- BUB 7 Slip-Ons WOW
- exhaust leaks
- Mikuni SE 45mm carb falling flat
- Twin Cam Specs
- SERT, Cobra or ...
- 06 heritage fuel mileage
- Exhaust, Intake, Forward controls
- HD Road King 2007 Engine Light ON
- 08 Deluxe running hot
- 03 Sporty...dies when you hit the throttle
- Need Instruction Sheet.
- roller rocker noise
- Need a little help
- Headbolts Leaking??
- screamin eagle intake?
- 80 Ironhear 1000 valve lifter tube leaks oil
- GOOD SET OF SLIP-ON'S
- 1999 WG lost oil pressure
- my hog has a cough
- fiberglass in baffels
- Rinehart Quiet Baffles
- Check engine light coming on briefly after start up?
- valve train need adjustment?
- Spark Plugs and Popping part 2 - Deleted
- AMS lifters dead after 5000 miles
- K&N Custom Air Cleaner
- removing stupid exhaust covers
- Cam thrust washer?
- Ethos Fuel Reformulator
- Do Harley tanks have a liner?
- Need breather!
- Power Commander Maps - Road King
- Air Filter Question
- Se Big bore Stage II
- mikuni carb Good, Bad ??
- se air cleaner
- 07 fxd engine dies
- True or False on FI
- HOW TO ADJUST S&S CARBURETORS
- Rush true duals
- OEM TC96 - hammer hit - metallic bang at start up
- why does Rinehart 2-1 uses JAMES exhaust gaskets?
- carborator backfires
- SE Slip-ons and BCT baffles
- Rush Fuel Moto Custom Dyno tuned mufflers
- Smoke from left pipe / rear cylinder
- Air Injection into exhaust
- newbie installing BSS first time need help pls.
- Vance and Hines # 16725 Basic Mufflers
- Anyone with Tailgunners?
- JET Throttle Body Mods
- Mikuni HSR42 Question
- what pipes for my ultra classic ?
- Exhaust/Intake Question
- CHECK ENGINE LIGHT
- recall 04 flht
- bassani power curve
- jetting
- TRue Duals
- engine miss at all speeds
- rejet for thunderheader
- stage 1 upgrade
- rocketman69 help..
- slipons
- 100 MILE FUEL PROBLEM
- Regular Fat Cat to LOUD!!!
- 96" Upgrade to 103"
- Part throttle to WOT hesitation
- why cross over pipes
- 99-00 Cam Bearings Recall Question
- TSII+ Knock Retard?
- Carb Question
- True Dual or Cross Over?
- '08 FXDWG head pipe heat shield
- fuel leaking
- Engine oil bleeding into primary
- Replacement baffles or wrap to make SE II mufflers quieter
- Supertrapp - how many disks
- need some help?
- Vance & Hines Pro-Pipe BP
- Any comments on S&S slip-on ?
- Wont make power
- failed emissions
- New O2 sensor seal rings needed?
- What did I do wrong?
- Cost to install
- flywheel problems again
- valve springs
- I know..another TAPPING question!
- 203 cam ?
- Thunderheader questions
- sert 113" base tune badley needed for my 05 softail
- 06 dyna flooding bad, wont start..help
- rocker upgrades
- Screaminmg eagles vs Vance Hines
- Gas leak
- Clunk start????
- S&S Carburator Xpert Question
- vance and hines slip-ons
- Remapping-baffles ??
- 82 FXRS hit the throttle, she stalls
- Custom heat shields
- 07 & later CRANK ISSUES?
- baffle removal help needed
- Klock Werks double back headers
- rejet or not??
- chice air filter
- Paul Yaffe/Supertrapp Phantom pipes? Crack pipes?
- primary whining
- sert??
- expected HP from 50mm throttle body
- Chrome big sucker back plate?
- what the %&%(*%???
- harley engine differences
- Valve/Lifter Tapping?
- valve seat issue
- gear drive vs chain drive
- Cam install
- throttle body upgrades
- Bassani Power curve True Dual
- Need help with carb problem
- spit-sputter
- O2 Sensor Size
- Good cams for a stock 96 inch
- looking for 2 pice throttle body Rephrased it this time
- V/H quietr baffles for staggered duals
- BLOWN ENGINE???????
- S&S mileage.
- Rear Pipe Discoloring
- football cover vs SEgle cover
- Bigshots Staggered on FLSTC
- sprk plug size & thread count
- Installing true duals- how difficult?
- Cam difference Help pls.
- SE Pro 110 + Heads
- pipes for FXSTSSE2
- repair video
- MONSTER OVAL SLIP-ONS - Feedback
- rear cylindercoldout exhuast
- engine running after shut-off
- CV jetting revisited
- 95" big bore kit!!!!!!!!!!!!!!
- question for the HD techs
- 88 to 95 - Simple cylinder swap?
- HD DOWNLOAD OR POWER COMANDER
- HD 42316 reamer
- slip-ons vs. removing baffles
- EZ Mikuni vs full kit hsr 42mm
- Help finding replacement air fuel idle screw
- 50K service
- Front cylinder running hotter then rear?
- Thanks for the info
- quiet Big radius pipes
- Blowing gaskets
- Budget torque...
- Much needed advice
- squeak
- cams for 103 with headwork?
- Drag Specialty Exhaust
- 2003 top speed
- My numbers
- somethings wonky with the board
- Dumb advice needed...
- Drag pipe mods
- Plugs foul and backfire on cold starts
- @ pc injector for 06 and later
- Screaming Eagle torque mufflers
- Top end/Bottom end rebuilding
- o5 flht hestitation
- Compression releases
- Help Identify Air Fliter
- installing an aftermarket set of pipes to a 1200Nightster
- V&H Short Shots on a 01 1200C?
- fatboy tanks, carb vs. injected issues.
- DIY engine hop?
- 08 Bagger running sluggish
- Running without mufflers
- Terry Components, Terminal Velocity II
- TP Engineering Roller Rockers?
- Cycle Shack Oval Slip-ons
- compression calcs
- 08 ULTRA CLASSIC / HEAT ISSUE
- Allen screw
- Replacement Fuel Injectors
- vibration
- Tank back on - now have stumble and pop
- New Record Set At Maxton Mile
- Valve train adjustment
- Quieter mufflers for Bub 7 true duals?
- getting shopping list for 124 combo suggestions?
- Running rough
- Rush slip on mufflers - OD?
- wrong screw turned
- Big Sucker chrome cover?
- Oxygen Sensor wires Crossed????
- Rush Pipes slip ons
- Engine Tap on 93 Low Rider
- 99 Dyna Engine Rebuild
- Head Quarters 120
- Is this a decent set up?
- anyone thoughts re:Edelbrock 95 kits
- Results from SE 110
- PYTHON SLIP ONS VS THE PYTHON 3
- Gas tank leak and pressure
- No Fuel
- ADJUSTABLE PUSH RODS
- Cam tensioner removal with cams still installed
- Cam Swap...Forgot to Install Snap Ring
- Baffle questions
- crankcase filling with oil?
- 06 dyna heads milling info
- Stage II 103 with Cam, advice??
- Hanging Idle
- Anybody running Edelbrock 95" kit??
- head gaskets 10-5-1 compression
- head gasket leak (cost of repair)
- carb question 03 sportster 1200c
- Fuel Starved Mikuni HSR 42
- 06 Streetglide Vibration (reposted)
- Have you had crankshaft problems on a 2007 or 2008?
- Header type, o2 sensor placement question
- 103 build results
- Top plate for bagger gas tank...
- High Idle After Constant Throttle
- Carb question
- what is the diferance
- 07 sportster exh ? a quick reply would be nice thanks
- ARLEN NESS BIG SUCKER for a '08 FLSTN?
- Need help - Stage 1 Air Filter install - please!
- bad gas OR??
- 1994 FLHTCU Cycle Shack mufflers wont fit
- mileage and mods
- Screamin' Eagle Pipes
- Re-jet Evo Cv carb
- need input on upgrading 883 with more power
- Oil dripping from air cleaner
- Boggedy misfires at 1/3 to 1/2 throttle.
- Compression ? Need to figure static close guess would help
- popping
- Mufflers keep sliding back.
- Hot right side pipe
- Idle Problem
- mikuni or s&s
- Cam chain tensioner replacement
- Pistons?
