View Full Version : Exhaust System Topics
- 95 Inch Cams Heads
- Cylinder head casting #'s
- Rejet on 06 heritage 88
- Exhaust dilemma
- Rebuild Question
- 95” vs. 96”
- V&H Fishtail II slip-ons w/quiet baffles report
- Seeking advice for 2007 Night Train exhaust
- Ness Big Sucker stage 1
- Mounting V&H shortsshots !!
- 103 build and cam choices - again
- Vacuum line and oil discharge
- S&S Shorty "E" or Mikuni
- Having engine bogging problems.
- TAB PERFOMANCE Exhaust
- tickity tickity says my topend
- Doherty Power Vent & Arlen Ness Super Sucker
- s&s carb question
- SERT Question
- bad fuel in tank
- Going to tear it back down.
- 08 HD Heritage softail classic exhaust question
- Gas tank 2004 fatboy
- loudest & best sounding TURE DUALS !??
- help
- strange sound after build
- Exhaust for 2008 Road King ?
- TC96 rev limiter problem?
- Rush Baffles
- RB Racing Exhaust
- Brute Horsepower
- Hypercharger ?
- cam bearings
- Gear Drive Cam Recommendations for a 88TC
- exhaust question
- Looking for A/C advice
- on sound only...not performance..help
- Vance & Hines oval slip on muffs
- Best 95" kit? cams?
- Headquarters 103 Build Complete - Dyno Sheet
- fuel starvation
- Reputable builder
- Sounds Like A Diesel
- Which exhaust is louder?
- Muffler Clamps
- Fuel tank switch questions
- Ported Heads,made strange beast,out of friend
- stock exhasut
- keihin carb
- Fuel Tanks / skins
- Head porting, any recommends?
- Changing carb needle
- edelbrock quick silver PLEASE HELP!
- IRRATIC IDLE
- NEED A CARB AND MANIFOLD FOR ULTIMA 113
- exhaust for 2000 RK
- Screaming Eagle HEEELP
- AMS lifters and Wood cam
- Which way to turn oil holes in new lifters?
- quick wrap question
- Arlen Ness Big Sucker "after spray"
- fuelpak settings for fishtails w/ duals on an 04 RK Custom
- Should I expect more or less flow (air cleaner replacement)
- Glendale Harley in So Cal
- Mileage question
- o2 sensor bypass using powre commander
- Big Sucker Pre Filter
- Dynojet slide spring tension vs SE spring
- adj. pushrod ???
- Pinging .. or just a noisy 88?
- Looking for exhaust advise...
- Removing Cycle Shack baffles
- Ah Crap!!
- FatCat baffel change
- Engine Light
- Help! Losing power at speed.
- Engine Bogin out
- Compression and such
- Burnt pipe
- Inside SE slip-ons ??
- Engine Problems
- 98 Electra Glide cutting out and backfiring, dies
- Stock exhaust for break-in, or not?
- o2 sensors on rhineharts
- hard to start
- Sreaming Eagle Air filter fitment issue
- Won't Start after ride. Any suggestions ?
- Help needed with 1200C
- Thunder header sound Byte please !!!
- Python S/O,s Great sound !!
- Noisy 98"
- 95" to 103"
- looking for a map for 07 sg w/pciii
- Big Radius Rocker Bracket
- 02 eliminators
- SPOs
- Engine Cut-out issues - 88 Softail Custom
- exhaust map
- air filter cover question from iraq
- Cam Change
- Cam tensioner shoe replacement covered by ext warranty?
- 03 softail carb trouble
- BIG RADIUS 2-2 or 2-1???
- Tuning Edelbrock QwiksilverII carbs
- Bassani Road Rage,T-header,Fat cat ??
- CV carb
- 95" Build Advice
- Big City Thunder Monster Baffles?
- valve noise
- Exhaust without tune?
- Spirolok removal
- 98 FLSTS will fishtail II fit?
- Installing V&H Exhaust
- S&S Carb washing out oil?!
- 110" cam choices
- SE heavy breather ??? opinions ?
- Will true duals off of a 2000 Heritage fit on a 1993 Heritage?
- Adjustable push rods
- Tuning question
- Screaming Eagle Heavy Air Cleaner
- Fuel Line
- 2008 Fuel Tank
- Motor/Transmission Trouble
- Stock Outside Exhaust Diameter FXDBI??
- Doing a Stage 1 tomorrow and have a question
- Advice on Fuel Management Please!
- Have to remove eng for base gaskets?
- Oil blowing in air filter. PART II .
- Changing pipes on 88B engine, install ?
- Wrist pin Bushing Install
- Dyno Rear Wheel Slipping off Drum
- S&S vs Big Sucker
- I've got an oil leak. HELP!
- 08 ultra classic with rattle around motor
- Evo cam recommendations.
- Need to re-Dyno??
- stock or adjustable push rods ??
- New exhaust, no baffles, questions!
- Carb cleaner fuel additives
- Thinking about buying Dayton Twin Scan II
- softail shut down
- Hot Shot Motorworks
- Cruise Control Adjustment
- Bore 88 Cylinders to 98?
- HQ-0034 versus Woods TW6 cams
- More power???
- Samson Pipes
- EVO rear connecting rod pin "too tight"?
- Re-Wrapping Baffles
- Anyone running Hooker True Duels on their bagger?
- STOCK VS AFTERMARKET
- Wiring change over ( 97 EFI to Carb. )
- 2008 Road King Classic upgrades
- air cleaner replacement
- piston pin clip tool
- clicking like a chevys poorly adjusted rockers
- 06 roadglide quits while riding?
- S & S 106 Hot Set Up - Twin Cam
- backfiring in sportster 1200
- 96 build question
- cam change problem
- db comparison chart by exhaust type available?
- I can't help it, it's driving me crazy.
- billet cam plates ?
- Thundermax ECM
- thunderheaders, question
- Heritage Stalls when accelerating from Idle
- o7-o8 Primaries
- What stage is my bike considered?
- mixing headers and mufflers..
- WHO RUNS SYNTHETIC?
- Which exhaust? 05' Road King Classic - 95"
- Need help with intake
- Dust in the wind
- 1991 - 883 Screamin Eagle Kit problem
- 79 Sportster Carb Problems
- Ironhead Exhaust problem
- big shot
- Torque specs
- More horespower and Torque
- Supertrapp 2in1
- jugs/pistons/cams
- big city thunder
- Rhoads Lifters ??
- Larger Engine- Louder Exhaust ?
- just dynoed new combo today
- Excessive fuel use
- Black ceramic Bassani Road rage heat ?
- Anti-inversion tubes ...aka torque tubes
- K&N air filter question
- Have to recalibrate ECM with SE stage 1?
- New Air filter
- Whizzing noise on TwinCam88 please help
- How much $$ to make a 100 HP
- EFI to Carb. change over
- 2-1 exhaust ? supertapp,thunderheader,Cat
- Need Exhaust Selection Advice
- Part numbers on scII's????
- Need cam advice
- bike dies when coming to a stop
- V&H 2-1 BR has a plug?
- lanale fan
- Installing daytona twin tech ignition
- s&s "E" questions....
- No oil pressure
- Do you have an all-SE modified engine?
- circlip installation
- fuel pump location
- sifton camshaft
- Gas and octane booster in the HD
- Gas Tank Question (98 Springer)
- K&N RK-3909 vs SEAC
- tommy gunz
- "Gusher"-Oil in Air Filter 1990 FLT-EVO
- Pants on Fire
- Ignition, VH radius, dm intake
- Thunderheader
- 2005 softail 103 how much hp??
- Rineharts 2-2 vs Bassani 2-2
- ground electrode on plugs turning somewhat white
- Engine miss
- Bassani road rage 4 stbob
- V&H Propipe or Rinehart 2-1
- Oiling a Big Sucker
- '02 Fatboy - No Top-End Power
- New exhaust 2008 FLHR
- I think my motor is about to blow up.
- stroker evo question
- Cobra Slip ons...
- 05 Roadking upgrade, now engine noise?
- Funny noise
- paughco mufflers
- Paughco 2 into 1
- Roadking fuel mileage
- Info on BCT QQ Baffels???
- Ness Stage 1
- Put on a Super E to my shovelhead
- 2007 ultra exhaust upgrade
- Big Shots Staggered
- Finally did the cam change
- Redshift Cams, *update*
- Chirping--Banging--Chatter
- Who makes Screamin' Eagle EVO Pistons?
- Head bolt breaking
- New Pipes Roasting my Thigh
- spark plug thread
- Cylinders are going south - options?
- air filter question
- Why the Y pipe?
