View Full Version : Exhaust System Topics
- 95" build
- Ironhead's back...let my heartaches begin....
- Drilling holes stock backplate
- Rinehart and V&H True Duals
- V&H Oval Slip-ons question
- Softail pipes on FXR
- need advice for 07 2/1 muffler sytem
- Exhaust pipe coatings
- 95" budget build thread
- building motor help
- Vance and Hines Big Shots
- HackerPipes exhaust!!!
- v&h short shots
- Exhaust Discoloration
- Wireing connector for trailer
- Strange Cutout During Dyno Run - Help?
- How do I replace the baffles in V&H Longshots?
- Samson Caliber 2 into 1
- SE11 Slipons with stock AC
- No answer from Wild Pigs?
- HELP!!!! Need part numbers, can't find them!
- Tuning
- sportser headgasket leak
- Vance & Hines Straightshots HS Slip-ons
- Removing baffles from new Screamin Eagle Slip-Ons
- Perfect Fit pushrods.
- Knocking plugs out of pipes. Good or bad?
- How do my plugs look?
- 07 Screaming Eagle mufflers
- Proper way to do a plug check?
- Mikuni & Big Sucker mounting problems
- PLUGGING 02 PORTS ON 07'S
- Sparkplug Analysis
- R&R Inner Cam Chain Tensioner TC88
- do i need to dyno tune
- Factory 2-1
- Do I need to go to a PCIII ?
- Thunderheader
- After Market CAMS and Pistons for 07
- What cams to use
- Got some new pipes
- Finding Exhaust Leak at Header.
- How much should I expect to pay for....
- Better performance with reliability
- Tech Install V&H True Dual Tools?
- D & D Fatcat website????
- Mechanics- Need your help!!
- Gas in the aid filter... Please help!
- Just installed Khrome Werks drag pipe baffles.
- Cycle Shack mufflers
- Pipes !!!!!!!!!!!!!!!!!!!
- Exhaust Temps
- V&H Big Radius and 07 Custom
- Sportster - gas in air filter
- o7 baisley or lmr
- Screamin Eagle 42mm Carb
- Numbers for air/fuel
- exhaust, air intake, pclll
- Rush vs. V&H BSS questions....
- S & S Crankcase Breather Valves
- RB racing 2-1 headers
- chirping bassani pro streets...
- ID on pipes
- Exhaust Decibels
- question about fuel system
- Crankshaft Bushing on Cam Plate Question?
- Truth about tru-duals vs factory headers
- v&h big radius vs. slip ons
- V&H Big Radius
- V & H dresser duels
- Plugging a hole
- 03 FXD need CV jet help!
- 05 FLSTNI Cam Choice Question ?
- Reliability of 10.5 to 9.8 compression builds
- Big Bore Question
- who makes hooker tuned flow slipons?
- Horsepower
- slip-on muffler interchange
- Air Cleaner 'Outer-Only' Covers?
- stock 96 top end on 88 bottom?
- Feuling Hydraulic Tappets
- Fuel all over floor...help!
- dyna trouble starting
- Branch Heads.
- Pan / Shovel vs slabside shovel
- Stage 1 remap question.
- SAMSON EXAUST
- adjustable Pushrods
- 2007 Rinehart True Duals
- Slip-On Muffler Identification
- 07 redesigned engine
- xl oil pump
- Noise ordinances and our exhausts
- 95 cu. in.
- NEED HELP CHOOSING CAMS?
- Tuner in South Carolina?
- PCIII tip - reset zero throttle position
- Removing the O2 Sensors...
- Ultra Classic Fuel Tank Removal
- Dyno Chart, To Lean?
- How to quiet drag pipes just a bit?
- Too Lean or Rich?
- 95" high comp pistons
- TC88 Adj. Pushrods and Tubes
- Exhaust baffles
- Quiet Fatcats
- screamin eagle street performane mufflers 07 question
- After market Lifters
- Help to confirm,, what dealer told me
- Flywheel Bearing question
- Twin Cam B motor removal
- 07 Exhaust Question
- SE BB Stage II Build - Opinions Please
- Rocker support noise?
- Tips for install of BIG Radius V&H pipes on Softail?
- 95” Build Question?
- EVO Engine Upgrade
- Cobra Exhaust or Drag Pipes? Advice please?
- 88 to 95 upgrade pieces?
- Which cams?
- Rush slipons backfiring
- Modified Stock Mufflers
- OK So why cant I just plug and punch????
- PSI’S Genesis 'Big Air' Carb
- best prices on Harley parts
- ANDREWS GEAR DRIVE CAMS
- SuperTrapp Super Pak High Performance Kit
- cams vs primary gearing
- Cam Tensioner replacement
- Issues with Big shot Staggereds
- running rich?
- baffles pulled on pythons, really like it but....
- cam Lifters
- Knock, Knock
- Newbie Question - RoadKing Classic stock bike
- SET UP OPINION for a '07' Train
- Rinehart 2 into 1 on an Ultra
- HSR42 runs real bad with TC88 need help
- TIMING ISSUE
- BIKE HAS BEEN STORED 2 YEARS
- fuel tank not venting
- Question about gaskets / o-rings
- ALP (American Legend Performance) Exhaust
- BIG BORE STAGE 2 KIT FOR EFI 1690CC??
- Spark plug chaser
- Cam chest surprize!
- slip ons
- 2006 cam question
- Engine Temp
- 07 FLSTC Exhaust, EFI tuner combo- my choice and how it worked
- 2007 cam choise
- Terminal Velocity 11 Who is running with this set up are you ok with the result?
- Help - A/C backing plate
- 48 Pan won't start without starter fluid
- Help make a 2007 Screaming Eagle Springer perform
- shadows in cylinder walls
- Fumes coming from fitting
- psi Harley carb
- Baffle removal performance
- Oil pressure
- Oil pressure
- Bypass spring/ LMR
- Removed 06 Baffel
- Gas Mileage Worse?
- Someone has a pic of the D&D Ghost pipe
- Clicking noise in engine.. Please Help
- head question
- Dyno results
- maintaining reusable air filter?
- new pipes for '07 Fat Boy
- What's so good about a Pan-Shovel?
- XL1200C Problem
- SERT 2007 - discontinued by the MoCo?
- PC111 maps
- s/e pro vs v&h pro pipe
- Vance and Hines
- Carb removal / Fuel dripping - Help
- Active exhaust system
- SE Stage 1 Filter or Big Sucker? More questions?
- Power Commander USB Factory Map Quality?
- How do you find Top Dead Center
- Cam Change
- Drag pipe question
- compression how high
- 203 cams
- Cycle Smiths Finned AC - Comments?
- Fuel Filter FYI
- Question on terminology
- New Cam gear drive install parts list
- How Big Can I Go (Safely)?
- Do lifters need to be replacd with cam change
- Whats the difference between TC88 & TC 88B?
- Kerker P.A.T. performance baffles
- rinehart eaglebeak slip ons
- DIY muffler removal tips
- Exhaust pipe diameters
- abnormal vibration
- Anyone found fishtail tips for rineharts?
- sound of new style 2-1 cobra exhaust
- MAKE 2" SPIRAL BAFFLE LOUDER?
- Bigshot staggered questions
- '07 103 Stage II kits
- S&S Carb change or keep
- 06 Calif. Exhaust a NO NO!?
- NEW SETUP, let me know...comments?
- 07 softail aftermarket exhuast advice
- Best Price on Rinehart's
- S&S "E" Carb
- bub or vance and hines exhaust?
- 72 1200 sporty needs help
- put her on dyno today
- Pressure from exhuast one side weaker
- S&S SPO's on 2007 Ultra
- How's the gas mileage on your 07?
- Pic of cam chain tensioner shoes
- Which exhaust system?
- plug concerns
- QHP heads
- Khrome Werks slip-ons
- Exhaust on right?
- Powerband hole
- Jet Needle help
- Colortune?
- Cams and Porting
- slip-ons, PCIII and stock filter
- BIG BORE KIT FOR MY STREET GLIDE
- Pipes, AC, rejet, performance and paperwork
- Engine Fit
- Slip on install help
- SE Performance Heads, flat tops, and 203 cams?
- Turbulator
- Cams: Can I do it myself?
- Ness Big Sucker or HD Stage 1 Set-up
- Someone explain Porting and theories
- Bigger Jet caused back fire/carb fart
- Replacing the Stage 1 air cleaner element
- Stock Needle Jet 98 FXD-CONV
- Easy jet change now?
- Pipes & stuff
- Cam Comparisons
- 2007 Exhaust Glows in the Dark
- Screaming Eagle EFI vs Race tuner
- Air Filter ??
- oil dripping out of crank case breather tube?
- How to quiet down Rinehart TDs?
- Smoking & Cutting Out
- backfiring python pipes
- Starving for fuel
- Thunder Monster baffles?
- adjustable pushrods for TC88
