View Full Version : Exhaust System Topics
- 2007 road glide
- M8 de-cat
- 2012 Heritage Softail Advice
- What The Quietest 2 into 1 Exhaust for the Rocker
- Like a little more sound from my V&H HO
- S&S Race/Tour Mufflers Verses Fuel Moto Jackpots
- Installing stock exhaust
- Installing Stock Exhaust on 12 Fat boy lo-Help
- Copper exhaust gasket vs Harley OEM??
- Big Shots on Wide Glide
- are slip ons designed for specific engine sizes
- Best affordable slip ons for 2016 HD Fat Boy s
- True duals rear head pipe
- Low Rider S V&H slips on baffles
- Issue Installng
- Blue tooth
- Samson Exhaust
- Damage Risk(s) - No Muffler Cans - 2017 V-ROD NRS
- What's the best method for buffing out knicks in a pipe end cap?
- loud slip ons
- loud slip ons
- Bassani Mufflers on stock head pipes
- Supertrapp fat shot 2 into one
- Blue tooth
- Slip ons for my 09 ultra
- D & D Fatcat Exhaust
- S&S Power Tune Duals for 07 SG
- Fishtails blueing ?
- s&s woes
- Screaming Eagle Nightstick 2-1 dyna switchback
- Just ordered the "Dragula 2" two into one, with a ghosts pipe.
- Buying Cali bike
- Fullsac DX Pipe ?
- Rhinehart true duels Exhaust gasket
- Exhaust help
- Lost of power in 6 gear
- Fitment Question
- New Tri-Glide knocking sound now in motor
- FLHXS mufflers
- 96db out of the exhaust
- Cat removal
- MC Garage - truth about aftermarket exhausts
- RB Racing Exhaust
- V&H short shots vs Crusher maverick for 103 street bob
- rinehart 2 into 2 flush volume
- phil 02 fxd dyna
- phil 02 fxd dyna
- 2017 Street Glide w/ V&H Power Duals and Hi output problems
- Looking for quiet Slipon suggestions
- Cut exhaust on street glide??
- black end spark plugs
- Exhaust issues
- Anyone ever put a light wrap under their Heat Shields
- Rush Big Louie Baffles
- Stock pipes with SE gasket?
- Thunderheader vs Thunderheader??
- Hash Pipes Exhaust
- Big shot staggard install - 05 Fatboy
- Bassani at sturgis
- 2000 Ultra Classic w/ Hooker Tuned Flow Popping
- 2008 softail springer cvo one cylynder firing
- Straightshots popping after off throttle
- Short shots
- Screaming Eagle M8 Slip Ons
- '95 sporster & V&H Short shots....
- Exhaust for my M8 2017 RGU
- 2003 Electra Glide Classic Head Pipes
- Not sure what I'm looking at
- Sportster re-map or not?
- Fitting a 103ci V&H True Duels to an 88ci. (Please help)
- Need an exhaust that doesn't cook my calf
- What would you do?
- Vance and hines short shots
- Monster Ovals
- CFR pipes
- 2017/m8 Forsch slip ons
- Carb Specs
- Rinehart Questions
- gas
- Let's talk 103 head pipes
- 2:1 Big Radius Exhaust on Fatboy S
- 2 into 2 Exhaust Recommentations
- vance and hines high output
- V&H Slash Rounds slipping off!
- De-catted headpipe question
- My experience with headers and stock mufflers
- tuning bike need help
- James Gaskets
- Where to buy straight pipes with O2 sensor holes?
- D&D Fatcat
- SE intake manifol
- S&S 342X intake
- Moving to Germany, Need quiet pipes for registration
- CVO mufflers & Fullsac cores
- V& H short shots
- Magnaflow Riot 2 into 1 install problem.
- High flow vs stock air filter
- What to do - keep 2 to 2 or go 2 to 1
- HD street tuner
- Problem installing Samson Cholos on Softail
- Quiet pipes
- Cobra Speedster 909
- Power Bands
- E-series, or TBR? Who has one?
- 2012 883 Iron: go from v&h short shots back to original exhaust
- Rinehart 2.5" Standard End Caps Fit Older BUB Straightaways
- 2002 Sportster 1200 Custom
- True Duals for Heritage Softail
- 1995 80cu.in. Dyna: dbKiller for Screaming Eagles?
- 2012 road glide take offs fit a 2014 limited
- 2017 Road King Special with Vance & Hines Power Duals
- rinehart churchill 2/2 on fxdwg
- Exhaust pipe identification
- FACT vs OPINION
- Anyone Have Freedom Performance Declaration Turn-Outs?
- Anti-seize use with muffler
- Valves, and cylender heads
- torque cones?
- What model thunderheader will fit the 1984 FXRT w/ mids
- Ultima exhaust
- 2017 slip ons
- Newer (2014? 2015?) OEM touring pipes can be drilled
- Headpipe heatshields, good or bad for performance?
- Loudest pipes
- Short shots on a 97 sportster - yes they fit
- Cat removal and tuners
- Dismantle V&H Monster Ovals?
- Exhaust
- Help my friend
- 2016 dyna, new thunder headers, no tune! Piston popping! Pleas help!
- 2013 Iron 883 Exhaust question
- Rush 2/1 decel noise
- V&H SS Install help
- 2007 touring supermeg exhaust fit 2002 touring
- Help finding the right mufflers
- Packing Burnt Out on Big Louie's?
- 06 cvo slip on does it have the sleeve inside.
- Louvered vs. Perforated
- 2-into-1 options for XL1200CX/Roadster
- FLHX Crossover Gasket
- cams
- S&S Slip-ons
- V&h dresser duals w cfr slip ons
- I need to know what exhaust this is!!!
- Thunderheader quality really that bad??
- cat removal
- V&H pipes
- Stage 4 on my softail slim 2015
- Fishtail baffles
- What exhaust is this?
- Freedom performance turnout or python rayzer?
- No cut out bag exhaust
- 2006 Sporty 1200 exhaust
- CFR's decrease on tone
- which one?????
- When is ECM flash required
- Two Bros v Bassani
- $7 flex pipes from Autozone. Anybody?
- Asking for best exhaust configuration for 81 Shovelhead
- Straight pipes for 13 RK, possible side effect.
- 2008 883 exhaust shields
- cfr exhaust question
- Recommendations
- S&S 124 replacement engine
- Need help identifying Exhaust insert
- Exhaust question
- Magnaflow Tru-x head pipe
- CFR's with power duals and big sucker
- Exhaust Stud Broke Off !
- Exhaust Stud Broke off
- CFR? with power duals
- Bassani 2x2 dual head pipe pn#1F14A
- Vance and Hines Staggered Short Shots Question..
- 103 vs 110 head pipe
- SuperTrapp 2-1 Header with Cone Engineering Muffler
- Screamin Eagle High Flow Exhaust System
- 2 into 1 with fishtail...
- D&D Diablo Gato on 2016 FLHXS 103?
- super e carb tuning for Rhinehart 2 into 1 exhaust on 2002 night train/ softail
- Installed exhaust now bike won't start
- Exhaust Question
- Cfr's/// V&H Titan 450 slipons
- CFR question
- Exhaust
- 2011 softail with the dreaded active exhaust actuator
- School me on Slip-ons
- Another D&D question...
- Trying Fullsac cores etc..
- 2016 FXDLS install question
- Cfr exhaust
- Pro Pipe Problem
- 2014 FXSB exhaust valve delete?
- For those who don't know....
- Cobra Power Pro HP 2 into 1....
- Name that exhaust system!
- D&D exhaust
- Street Cannons on full stage 1?
- V&H full system vs slip ons
- Passenger Heat Shield
- Exhaust change. V&H to Dirty Bird
- Revert to stock exhaust
- Serious Question
- Exhaust Pricing
- Fullsac duals with Rineharts
- se airfilter with stock mufflers?
- Power Duals / 2:1 exhaust questions
- Noise..Fatcat v Bassani
- D & D Baffle
- Which 2 into 1 exhaust is Quieter for my Dyna?
- How to: cheap easy "on bike" fix for rattling slip on baffles
- Thunder torques with/without baffles?
- Correcting exhaust modification in California
- Exhaust help, suggestions/dyno charts
- HELP!! Slip On's & 2017 Pipes Do Not Fit! :-(
- RB Racing Exhaust Question
- 09 flhr stock exhausts
- Milwaukee 8 exhaust question.
- Street Cannon's on a 07 Ultra?
- V&H Monster Oval Rattle ?
- My 4 speed just died.......
- Fp3 nd V&H 2-1
- Identify this baffle? I took out of sportster
- Are Rineheart Xtreme True Duals Catless?
- Slip-ons and low end torque
- Exhaust is loose
- Screaming Eagle 2 into Supertrapp?
- Crusher sale
- Rinehart Endcaps
- Swap Fitment on Vance Hines Short Shots
- Firebrand 4" Loose Cannon A+
- exhaust for 74 xlch
- Slip-on's and breather?
- Help me to choose an exhaust and custom things!
- Quiet baffles in my 06 Sportster v&h straight shots
- Swapping OEM exhaust for......
- Fat Bob pipes
- Fat Bob pipes
- Quite exhaust, best torque and power
- '16 Lowrider S Exhaust Advice
- Installation questions
- Bassani TD Down Under Head Pipes
- Need HELP with Freewheeler exhaust!!!
- Who sells bassani?
- 09 Ultra needs mufflers
- Californian looking for advice
- Best way to wake up vance and hines big radius
- Cerakote Air Dry
