View Full Version : Exhaust System Topics
- Need any tuning after changing exhaust?
- rsd slant exhaust on a 2014 breakout.
- What Model of Exhaust is it ?
- Help identify Slipon Muffleres
- CFR knock off's
- Full Moto SPC and my dilemma
- Locating the impossible V&H baffle.....
- Sound difference d&d fatcat, drago dragula 2 and rush wrath systems
- Supertrapp 2:1 Supermegs for 2011 HD Ultra Question
- Yaffe Exhaust tips
- need advice on wrapping a baffle with FG
- GlassPack the right side baffle only, any problems?
- MPG drop after installing slip ons, normal?
- Cobra Power Port dual Headers w/S&S Race Tour Mufflers
- V&H Power Dual decat?
- Need help identifying Harley parts.
- 2007 Electra Glide True Dual Question
- Big Pipes and No Cat
- headpipes question
- touring header
- 2 in 2 indipendent for 94 FLSTN
- Fullsac DX or Jackpot 2/1/2 head pipe?
- Freedom Performance Combats. 2014 SGS
- D&d 2-1
- Screaming Eagle 4" Street Cannons
- 2 into 1 header only? To fit 4" Jackpot slip on
- New Header and Slip ons - 2016 SGS
- V&H Monster Round vs V&H Hi Output
- Problem with bike after exhaust install
- supertrapp mega with disks on a basini road rage headers
- RB Racing vs Area 51... 2:1 exhaust
- Cobra Speedster Short Swept vs Vance & Hines Big Radius
- Exhaust??????
- CVO mufflers on an 88"
- Re-installed OEM pipes, leaking & blue-ing FLSTC 1999 EVO Heritage
- Need advice on Exhaust Upgrade
- Building Manual Valve for Noise Control Exhaust System
- True dual conversion kit
- Softail dual question
- Frankenstein Trike
- S&S Upgrades 2015 Road King
- Moved to Cali
- V&H Pro Pipe 2015 Dyna street Bob FXDB question about unmentioned part
- CVO baffles
- V&H exhaust, air filter ID
- Big Radius 2-2 Heat Shield Problem
- Internal Exhaust Coating
- 99 Sportster 1200 Evo
- what do you think of this setup
- Need help to identify Vance and Hines pipes
- screaming eagle slip ons
- help with 2:1 side exit identification please?
- Cobra Exhaust
- Screamin Eagle Slip On
- RC Components 4" Slash cut slip ons
- D&D 4 inch touring slipons
- baffle removal
- Fat Boy S FLSTFBS exhaust recommendations?
- V&H FP3 Calif. + V&H Monster Rounds Calif.
- Cracked head pipe
- O2 Sensors? Mandatory? Yes, No, and What should I do? 07 110 eagle.
- Bassani RR Air Filter and Tune
- Samson Longtails.
- My 2016 FLHTK w/de-cat
- Rinehart 2/1 too loud,...
- 16 FLSS Slip-Ons Tune Needed
- effective heat reduction ??
- Probably a stupid question
- Fullsac Recore kit
- New Tune Needed?
- Baffle removal and X-pipe
- 4" Cobra slip-ons, sound same as stock!
- SE Street Cannons-better MPG?
- Kuryakyn Crusher Exhaust
- Baffled
- Pipe Swap - Sporster
- Head pipe
- 2 Brothers Exhaust / Fat Bob
- Warranty void onSE race tuner
- Vance Hines Slip-on VS Head Pipe with Slip on
- SLIP ON MUFFLERS FOR A 2015 or 2016 Road Glide
- Good air cleaner to pair with Bassani Road Rage Mega Power Exhaust
- S&S PT Duals & RCX 4.5" on a 103" Rushmore
- Head temp. water verse not
- slipons for 2015 FLSTC
- Samson Exhaust B-Stock
- who makes this exhaust?
- Fullsac 2011 Eletra Glide question.
- New Header, Tune?
- Question about Louder Pipes
- Fullsac true duals and 2" CVO baffles
- CFR knock-off question
- Help with pipes for 2014 FXSB.
- Which pipes???
- Cobra 2-1
- S.E. street cannons 88" motor
- reinhart exhaust true duals
- Help Please - Unique Dyna Exhaust Question
- V&H Straight Shots Heat Shield
- Rush head pipes
- Full sac DX vs Fuel Moto Headers
- V&H Exhaust issue
- crush? washers installing OEM pipes 1999 FLSTC Heritage
- exhaust heat
- Vance & hines vs. Python
- FXSB Options
- Removing baffle material
- Another Full Boar Install
- Fuel Moto E-Series 2/1
- Mufflers
- Decatt stock vs new v&h power duals
- 2001 RKC tick up front around 55 mph
- BARGAIN ALERT: Bassani Pro Streets on Closeout $199
- custom built 2 into 1 with aftermarket muffler?
- V&H Big Shots to a Thunderheader 2 into 1 pipe???
- Fishtail slip ons
- What do I want?
- Exhaust Options on 2015 Road King
- Rush Slip-ons??
- V&H power duals/dyno?
- stock 2015 fxdb
- Powder coating exhaust tip
- Twin Slash Cut 3" Slip-ons Comp Baffle
- Is it worth de-catting the converter on 2010
- 09 superglide stock pipes
- Discoloration of Rineharts End Caps
- V&H Super Radius Dragging Ground
- Not sure if this is normal
- Screamimg Eagles vs Vance & Hines help
- V&H hi outputs
- Slip-on dis-coloring
- 2012 sportster 72
- Questions about no mufflers but still have cats
- CFR smooth chrome
- Cracked Pipe
- CFR knock-off slipons
- Supertrapp 2-1 vibration
- Dyna Rush slip ons installation process...
- Best price on S&S PT duals
- Rejetted and exhaust still turning brown
- Bassani FireSweeps TTS MasterTune dyno
- FP3 auto tuning very lean, HELP!!
- Decatt/back to stock
- A/C Install (wrong model or missing something)
- Baffle size
- 2002 FLHTCUI pipe same diameter as 1996?
- Road Glide Exhaust on Softail (Fat Boy Lo) ?????
- K&N filter noise normal?
- 2015 Street Bob
- Tuning required after changing pipes?
- Your thoughts upgrade for putting on slipons
- New Setup help please?
- Vance & Hines Short Shot Baffle Opinions
- D&D Bobcat or Thunderheader
- Question about exhaust
- Broken exhaust stud. 99 Sporty.
- What are these slip ons?
- O2 sensors Thundermax vs. Stock??
- 2014 ultra limited header tips and tricks?
- tri glide slip ons
- 2011 Electra Glide questions.
- did exhaust systems
- Do I need a new map after catectomy
- Stage 1 Upgrade
- 2012 Tri-Glide
- O2 sensor bung location
- Exhaust note @42mph in 4th gear
- Rienhart exhuast shield removal
- Reuse Gasket??
- V&H Short Shots on an 03' Road King Classic
- True duals and mufflers
- Hammering in tight baffles, worries?
- Pipe/Tuner Questions
- Exhaust Question
- Breakout options
- What tools for catectomy?
- V&H true duals
- Stepped vs. Non-stepped headers on 2-1 system
- Exhaust question
- Vance and Hines slash cut baffle removal
- Vance & Hines True Duals
- Loud rineheart
- CFRs sputtering
- Cobra 3" Slip-Ons - Standard vs RPT?
- What brand are these dual exhaust tips??
- Torque Cones?
- Removing Cat
- I am screwed>>>>need help
- Thunderheader baffle mod
- V&h high output slip ons
- Strange exhaust problem
- AFR table?
- Question about removing cat
- ebay exhaust?
- Paul Yaffe X Pipes without baffles - baffle options?
- Code P0134? oxygen sensor high/open front
- V&H Baffle & End Cap
- S&s power tune on a dyna
- fishtail tips
- Does fuel pack offer a map for stock pipes with no baffles?
- Anybody add wb o2 sensor ports on stock pipes?
- Help a Newbie please
- Burned boot rubber on Vance & Hines black exhaust
- anyone build their own?
- will 2014 exhaust fit on tc88
- Dragos Dragula 2 Ghost Pipe
- Sound opinions
- Long Vance and Hines vs Short
- Tips for using silicone sealer
- Rinehart Classic dual exhaust
- Whistling Noise
- "Wild Pigs" pipes and baffleing
- Thoughts on OEM gaskets with THeader? TC88
- Will V&H SS for Softail fit to my Sporty?
- Thunderheader thundercone slip ons 2013 Dyna Switchback
- Looking for opinions on Ness Magnaflow exhaust
- Fitting exhaust from a 96 to an 88?
- 2001 fxdxt - thunderheader or dragula???
- V & H stainless hi output duals
- 204 Softail Catalytic Converters
- RK 2004 changing exhaust, do I need to...
- Looking for the loudest and toughest exhaust for my 14 limited
- Which exhaust wrap
- Exhaust for 2105 street glide
- Muffler bushing?
- Vance Hines Power Duels Important Tip
- Grenades
- Taking out the baffles.
- Baffles and bolting
- Comparison between CFR's and Rinehart
- 2008 Ultra Cracked Crossover
- Buyer beware vance and hines powerduals
- 2013-2015 breakout
- Lollipop for drag pipes myth - Confirmed
- Bassani Slip-ons
- Bought V&H sideshots, bracket wayyy off
- 2008 Ultra Classic need crosover pipe
- Taking out baffles
- V&H duals fit?
- Short Shots Prices
- Bigger diameter tail pipes for thunderheader
- Trying to figure out who makes these pipes
- 2015 SGS exhaust suggestions
- 14 sgs exhaust glows red
- Exhaust stud size? Head side
- Exhaust Chirp
- Stock A/C with exhaust change
- vance&hines short shot exhaust
- Cutting Pipes
- New pipes
