View Full Version : Exhaust System Topics
- power loss at upper range
- Bassani Firesweep versus Vance and Hines short shots
- O2 Cable Extension ??
- muffler
- checking timing marks Twin Cam
- Vance & Hines Monster Ovals Chrome Peal
- Interchanging Evo Rocker Boxes
- Cam install and dyno tuning quote
- Having trouble with carb flooding...i think
- S&S High Performance Tappets and adjustable pushrods
- Having Bike dynoed for the first time
- P0505 code
- air cleaner question
- Cost For Dresser Dual Install
- Sportster dies with throttle
- What Bearings for 25284-11/TW21 install
- throttle body push pull???
- 2001 1200 sportster
- Low End Torque
- 07 road glide mystery
- Breather Bolt Kits
- pinging
- can i cut my exhaust
- Vance and Hines Long Shots No Baffles
- Heat shield chrome going pitting
- Help with piston?
- Engine dies at idle when hot ('01 Road King Classic)
- Burnt Piston
- Exhaust and intake questions.
- whys my 95" slowww
- In FI engines would an aircleaner UG require tune?
- Is this noise normal? Help please
- david
- Can anybody deal me who makes these slip ons?
- 4 degree advance for gear driven cams???
- Stage 1 upgrade question
- Worked fine when I took it apart...
- Headwork suggestions in the Jacksonville area?
- Will putting a high flow on my 1012 rg ultra make it run cooler
- air cleaner comparison, specs? ness vs s&s
- Timing marks
- stuck exhaust gaskets
- Cam and Tensioner upgrade - 2006 Heritage Softail Classic
- Problems with my 1997 road king
- Noisy valve train... thinking of replacing lifters
- cheap source for cam chain tensioners
- To Rebuild or Replace the Rocker Arms?
- another dyno tune question
- Stage 1 or not?
- Remap on new exhaust
- SE 120R vs TMan 117" Kit
- Removing baffles okay to do?
- Engine Rattle / noise
- Head Pipe Install ??
- Induction module install on 103 motor?
- Sputter and hesitates
- 06 or 09 Ultra Classic exhaust slip-ons for a 08 Street Glide
- harley without muffler
- Twin Cam exhaust stud repair.
- Engine heat on 2008 Ultra
- Delayed return to low idle
- K&N RK series
- Vance and Hines Question
- New cam will not start
- Big Sucker breather bolts fell out
- which would you guys prefer
- Any tips for Shorty E on Evo, short of rebuilding carb ?
- Power commander required ??
- Cam Position Sensor
- Push rod adjustment ?
- Reinhart Baffles
- Running Rich
- 2010 Streetglide 2-1
- aftermarket pipes.
- 1995 Flhtcui loses power
- Should I re-hone & re-ring???
- 01 wide glide
- Looking For Machine Work Lima Ohio
- Zippers Max-Flow vs HD Screamin Eagle Ventilator
- Finding filter for Rivera Engineering Air Cleaner
- intake/heavy breather of 07 train
- dynobad or what?
- 94 FLSTC Fuel issues
- Vance and hines big radius 2 in 2
- 2005 Sportster won't accelerate when warm
- engine noise
- Your Review of Joe's Cycle - Mechanicville, NY
- Cam Upgrade
- exhaust change?
- Breather gasket?
- 2013 Street Glide Induction Module
- Bottom of Jug, slight liquid leak
- Maine dyno tuning modded 120 r street glide
- Help ! Head bolts washers
- 06/road king is too quiet!
- Slow acceleration engine response
- Tuning carb?
- 92 EVO clatter
- Exhaust skip
- 103 inch engine heat
- Loose Pushrods (Andrews Adjustable)
- Someone please help me😫😫😫😫
- exh fit
- Burst Collection Rain Sock?
- I Drilled Some Hoes
- Just installed Monster Rounds WOW!
- Gainesville Fl, need someone who does machine work on Harleys.
- Evo top end rebuild(first timer!)
- Screaming eagle exhaust on 2011 wide glide
- need input on exhaust and tunner set up
- Cr - s&s 551
- SE Heavy breather vs Dual tuned S&S on Ultra
- main flywheel bearing walked out
- 09 xr1200r
- temporary exhaust noise reduction
- Where to buy choke screw
- Are 29267-08 and 29762-08 Breather Bolts the same
- Exhaust on 883
- edelbrock heads for 80 inch evo
- Exhaust switch and tuning question
- oil smell & oil in air filter
- Evo cylinder installation question
- 1966 sportster
- Muffler
- 98 sportster engine noise
- Thunderheader...will it fit??
- VIDEO - Noisey after CAM swap
- Engine noise? 88b TC
- Locking fasteners on the header studs
- Change cam plate or not???
- Thunder Max Computability Question
- Installing my tappet blocks
- What to expect from my build?!
- Andrews 54h
- Upgrading air cleaner
- Old pan gas tank shutoff
- Adjusting Throttle...
- Cam change Considerations??
- E3 spark plugs bad
- hard starting
- Tuning needed ????
- Couple of questions
- weird starting issue twice today
- Sinister pipe w a built motor?
- CAMS and HEADWORK MATCH?
- I'm Baffled and Already Exhausted the Search.
- Twin cam plate
- Comparison between Head Quarters HQ-107-PK or HQ-107-ST...
- Kuryakyn hypercharger issues
- Cough/Backfire
- Cam change complete, now noise?!?!
- High Perf/High Comp & maintenance?
- Strange noise coming from exhaust
- compresson releases
- Gas cap questions???
- heads and cam selection...HELP
- Exhaust decibel comparison
- Any idea ?
- Head porting 95" build??
- CV pilot jet problems
- 2009 FLHTCU Header Question
- ACR removal
- SE and Supertrapp Exhaust
- Injectors too big? 103 build
- Hq-0034
- Does a Stage 1 Re-Map actually help?
- Wrapping Vance and Hines short shots
- whats in this motor?
- Maintaining high airflow with new product
- Samson Slashers
- 10' flhx
- left side
- Replace aircleanersys for better looks on 1200XL
- Broken Exhaust Stud, Broke off inside head, frames in the way... What to do
- bad dealer or bad dyno ?
- How to de-cat
- Shaving stock TC88 Heads
- Catless legal question?
- ev27 cam
- 25 miles into 95 inch build. Problems...
- Exhaust vs Warranty
- fuel line broke in two...
- Cam Chest Tools
- Issues upon issues
- I am looking for a Dyno tuner in the King of Prussia, PA area
- Lifter?
- Big City Thunder
- 2 inch mufflers to 1 3/4 pipe??
- Full exhaust for 2012 Street Glide
- Got the nerve to take it apart and do the big bore
- sportster 48 stalls and rough idle
- Street glid headers on softail???
- Quick disconnect for petcock
- MORE air flow out of pipe...???
- Make my stock pipe a 2into1? Good or bad?
- se pusbrods locking nut replacement
- small leak at primary..what tools to buy
- Carburetor Application
- Crazy question in regards to exuhaust
- Cam suggestions
- Suggestion
- Jackpot 2-1 header pipe - good pipe?
- Will the nightmare ever end?
- SE Stage I
- SS Super E Q's
- Twin Cam 88B Knocking at low RPMs
- sspark plugs and popping
- 103 Stage 1.5 ?
- 91 Softail Springer wont run!
- Early Twin Cam EFI MM to Delphi tank fittings ??????
- Does this setup make sense?
- SuperTuner Charts for Vance&Haines
- outer cam sprockets different between TC88 & TC96?
- Pinion Shaft Bearing 24623-99B
- Engine noise on start up
- New mikuni hsr on a 97 fxdwg
- Heritage dies at idle.
- slip ons
- Cam chain tensioners done, now valve train noise
- Cam and pinion gear issues.
- Need advice on a 2001 road king with mm efi
- Ceramic coating
- Removing Baffles from Screamimg Eagle II Slippons
- 2000 evo 1200 sporty rocker box
- Blue HD Heavy Breather Replacement Filter
- Changed headers but could not fit with the bracket
- Air Filter?
- Need Map/Tune for a Power Vision 2012 FLHX w/Mods
- 2013 iron 883 question
- Cast Jugs
- oil pressure relief on new se cam plate
- Benchmark air cleaner
- cam plate
- Help needed with miss at constant speed
- 1990 FXR Super Glide Evo set up for Screamin' Eagle 2-into-1 exhaust?
- SE adjustable pushrod question
- Air cleaner swap help, please.
- two into one exhaust modification
- motor build
- Vance & Hines duals with Rinehart 3 1/2" slipons... question
- Too Much Heat!
- Performance upgrade!!!!!
- Best pipes!
- Piece of zip tie down crank!
- 3.5" Rineharts vs. 4" Rineharts
- Which exhaust for Sportster 48 ?
- exhaust for 2013 roadglide custom
- Piston Question
- Cam change Road King evo questions
