View Full Version : Exhaust System Topics
- Crappy running road king
- Louder Rinehart TD's?
- S&S Super E carb problem
- Exhaust blew apart..this happen to anyone..?
- R+r 131
- TC 88 Mikuni Jetting
- Rattling baffle in my SE slip-ons....2006 FLHRCI
- s&s on stock carb
- Enough compression?? Woods 555 cams & 103"..
- Excesive crankcase venting
- Dtc
- negative pressure in oil pan
- Missing and stalling
- changing valve springs
- V&H Big Radius in Dyna Custom
- Marietta Ga twin cam build.
- Should i be concerned about my Dyno Chart
- problem with gas or vacume?
- Need some exhaust advice
- removed double barrel 16ga pipes baffels
- what to expect from 95'' big bore kit
- Suddenly I'm getting oil puking from breather
- What should I expect from these upgrades ?
- +4° adv on a .555 cam gives me what?
- Efi to carb?
- Head Temp on a 11 Dyna
- Black Big Radius 2-into-2 For 2010-2011 Touring?
- 120R + 8 lb's boost =191 HP !
- Tell me what you think of this
- 98 kits vs 95 kit advice
- help help help !!!
- Experience or thoughts on wood tw9f cams?
- Monster Oval end caps
- cams for my o7 dyna
- Flathead in an Evo frame?
- which slip ons for my 06 Roadking
- Installed Slip-Ons, bike has quit on me three times
- Slip ons
- A Newbie Needs Your Help
- Constant Fuel Pump Whine?
- Kuryakyn Hypercharger
- Vibration
- Fuel Injection Squeals 2011 FLHX
- Stock Twincam 88 vavle train noise
- cam ideas for an almost stock 09 FXSTC
- Not Loud Enough! Reinhart 2-1
- Cams in a 103?
- Screamin Eagle 17987-98A pushrod TPI?
- fixed baffles, can i replace?
- Touring Fuel Tank Outlets
- Lifters for twin cam
- Very loud engine noise...
- why not drain oil from the bottom of the case?
- American Custom Exhaust
- Stage upgrades & best bang for buck?
- First time exhaust install
- Fuel hose leak
- Popping road king
- 1999 TC88 Question
- Dyna Exhaust Question
- Rush exhaust question
- Hydrogen Generator, run your bike on water? WHAT is HHO?
- Cyl Head Volume/Compression Ratio
- 2005 Deuce help
- Rocker box gasket job
- why does it idle so fast?
- 2 shovelhead's 2 problems
- 2001 ultra
- Actual impact of cam alignment
- XIED leads on a softail
- Exhaust experts What tha??? Totally stumped!
- I hear lots of air
- Rinehart Popping?
- Dresser Duals Knock
- Cobra fi200 settings & fm 107 kit ? Need help
- Exhaust for Dummies
- I really need help, advice, guidance, SOMETHING! Please read, full of details!
- Rush Slip-ons - Am I missing something?
- 2011 CVO 110" S.E. ..I need more umphhh!
- New 2011 Fatboy Questions
- power vision
- Samson Big Guns v V&H 2-1
- Need help.....intake leak?
- Baffle removal vs Slip ons?
- Rejetting/tuning a '97 Fatboy
- Voltage regulator
- 99 Road King mufflers "slip" toward engine
- Screamin' Eagle Street Performance Slip-ons ??
- Street Glide exhaust popping and dies at stop?
- EFI Tuning
- Deuce 'Farts' & 'Belches' every 100 miles - HELP!
- 107" cam and heads
- SE203 vs SE204 in Softail.
- TC 88 Heads
- thinkin upgradin to bigbore 95 and 211 cam.
- Deuce Engine Replacement
- Removing the cat question
- HD Reman program
- '08 Dyna front end ticking
- Screamin Eagle Heavy Breather Vs. SE Ventilator Performance Air Cleaner Kit
- Breather Bolt Question
- Sounds like a bird chirping in my pipes!
- Primary oil. How much is enough?
- 2011 dyna big radius picture help
- Dyno Numbers 103 LTD FM Heads TW555
- O3 ultra running rough at idel!!!
- Big Radius install HELP!!!!
- Oh boy, cam bearing shelled out...
- front pipe
- motor opitions
- Cleaning exhaust pipes...
- Upgrading 95" Stage 2
- Exhaust problem?
- Dual Exhaust
- Tranny/primary oils....
- Air intakes... How to decide
- Stage 1 defined???
- Torque wrench help
- oil weight
- 07 fatboy misfiring
- fuel leaking out of breather bolts
- Light Valve Springs and Lifters to Check Piston to Valve Clearance?
- was this a mistake?
- Stage I Filter Kit or Heavy Breather? (103 SERK)
- 80493-07 screamin eagle mufflers
- Mikuni HSR42 float bowl screws
- low oil pressure
- compensating sprocket removal
- Revtech O-ring Gaskets
- 124" S&S Sputtering Off Idle....
- I need urgent help please
- Need help with tuning...
- Which Cam?
- gas mileage question
- 2000 fatboy - asked mechanic how to get more sound and HPs. here is his answer..
- need help
- Cam chain tensioners, yep they’re checked w/pictures
- Cam change...low power...advice.
- Thundermax Map for 103 stage 2
- SE Pro Heads 17071-03B for 107
- 103 build tuning help
- 84 xlh troubles, any suggestions?
- Ceramic Coating
- creating modified exhaust
- Cracked block
- tts vs. ?
- 1999 MMFI to carb quesstions
- Hillside and DJL....
- Engine Experts Please Read....
- advice on 103 stage 4 cams
- Bigger cylinders
- Approx. Cost True and Weld Crank?
- Heat under seat from Rinehart true duals
- fuel mileage with cams
- Nightster 1200 Vance n Hines question
- Intake
- Dynojet Thunderslide
- Are andrews 26 noisey?
- Push Rods
- Stock VS Stroker
- Air flow
- sounds like a marble is rolling around my engine??
- FLHT stock to sreaming eagle II switch
- 2011 jugs & heads on a 2003 RK
- Swapping pipes
- Help - Loud "clatter" from engine ?
- low-mid range carb issues
- Head Gaskets for Performance and Squish
- andrews 21n vs 26n
- Hillside 107" build finished/tuned
- Evo intake valves.....
- Help! Need Advice...
- Changing Slip ons
- Exhaust swap question!!
- Oil pump question
- Reusable air filter for SE110?
- Removing Flange "C" Clips
- 2011 Ultra Classic Exhaust question
- Won't run past idle
- Stock exhaust
- How to tell if your carb has stock jets?
- Broken heat shield mounts
- K&N Air Box Assembly - RX-3909
- New exhaust...what to do?
- Options on 124 kits
- 2008 fxd strange noise at idel
- Do 88 Cylinders fit 96 cases and heads?
- 2000 Road King Engine Noise
- Stock exhuast
- 107" build
- Samson exhaust help
- s.e. 103 stage 2 upgrade problems
- rear cylinder cut off after "pop" from intake
- Too Much Fuel????
- Anybody ever tried this product?
- Slip on muffler question
- Performance Heads
- Upgrades for '03 Road King?
- What the he'll is wrong with my bike!!!
- pull starter
- carb leak 92 ultra
- my attampt to tackle valve noise
- 2011 103 ci street glide
- Need Slip On muffler suggestions for 2010 Fatboy
- Memorial Day
- TC95 upgrade, Carb question??
- tech problems
- DRAGOS BIKE WORKS SETS NEW WORLD RECORD 194 HP 107 INCH Prochager
- engine only runs on one cylinder! please help!
- Technical questions for PCV folks
- petcock diaphragm help
- crane singel fire igntion
- Big bore
- Change from carb to fuel injection
- have i set pushrods correct
- Anyone from the Rochester NY area
- 50,000 miles?
- wondering what the best air breather is...
- Thanks DR. V-TWIN!!!!
- Enricher cable question
- D&d exhaust gasket into port
- MAP for PCIII USB 2001 Ultra Classic
- Rinehart TD on an 07 Ultra
- removing baffle from Rhinehart two into one pipe
- Advanced Hydraulic Cam Plate/ Inner Bearings/Cams R&R???
- Oil Consumption
- 1999 fxdx
- crack exhaust pipe
- 2011 SE 110 Engine Noise
- Age old cam upgrade question - Yes again - Sorry
- Exhaust gasket wont come off
- Evo 1340
- History of HD EFI
- Painting engine with rattle can recomendations?
- Well...no more MM EFI
- cranking pressure
- cam?
- carb hoses???
- On dyno today: V&H competition with DB killer vs not
- new exhaust
- Ignition timing on high compression street engine
- Stage I, can I just buy a filter?
- Best place/price hydraulic cam plate & parts???
- 96 Cubic Inch ackfiring/popping
- this s&s is killing me
- Cam suggestions '08 RK police 103"
- 2011 Road Glide with Exhaust D&D Fat Cat
- Still have some tuning to do after the rebuild
- Rinehart TD - Flange Nut Question
- Twin cam 88 question
