View Full Version : Exhaust System Topics
- First Build for a 95 (Advice)
- '07 SE Slip-ons mods
- 06 Dyna 35 anniversary
- Horsepower/torque:stock/stage 1
- QHP Heads
- How to tell if engine is running hot?
- Will the HD computer rat me off?
- Fuel System Problem
- Fiberglass everywhere!!!
- SERT or not?
- supertrapp exhaust
- wont stop running
- Your thoughts please about exhaust setup...
- Leaking CV carb
- Out with the new!
- Baffles & MPG
- cold and jetting probs?
- Hacker Pipes
- PC111 map with SE11 slip-ons Question
- Stock Air Cleaner Mod.
- FUEL MILEAGE
- 110 screaming eagle kit for 07 bagger
- Suppertrapp or Thunderheader?
- Help from the pros about engine mods
- Possible to remove baffle from left side only?
- rattle evo top end
- Installing Santee LAF on Evo, help
- Feedback on BC thunder monster baffles
- Big City Thunder baffles: HOLY MOLY LOUD!!!!!
- Sporty carb ?
- Replacing Rinehart TD's with SE 65115-98B's
- Heat Shield rattle
- Flange torque
- One Last Slip-On Question...
- Muffler removal difficult?
- Santee slip-ons....
- Seating Header and Muffler, WTF?
- 107 Build Finally Done
- oil breather
- E85 fuel blend?
- Rejetting True Duals
- 07 Dyna / PC111 need help with a map
- SEII with out baffles
- Rineharts or SEll slipons?
- Bike dies when hot, won't start till cool.
- Flange Gasket
- Set float level on Mikuni 42
- Cam Timing?
- 2000 FATBOY BAFFLE QUESTION
- Need Straight answer on Slip-ons
- Exhaust Wrap Cont...
- 2001 FLHTCI exhaust
- Idea to baffel end-curved pipes.
- 95 Inch Kit?
- Neeed Hooker opinions by morning please?
- 4" big bore for se 103 ??
- engine upgrade
- S/E baffles
- Stock Exhaust
- GENESIS "BIG AIR" CARB
- Puffing @ idle
- Removing baffles from V&H
- Rich Mixture?
- Idle mixture screw
- Screamin Eagle air filter question...
- woods cams $ ?
- Stage-1 kit ... Problem: stalling & backfires.
- Troublemakers do not fit!!!!!
- TFI / Tank Removal Question
- Fat Cat Quiet Baffle ?
- baffle mods
- idle mixture screw
- Just ordered PC111 and SE1 a/c
- v&h vs rinehart
- RB Racing Black Hole -- FINALLY
- Supertrapp SE slipons
- Softail and Fat Cat exhaust
- Lifter Block Alignment....Necessary???
- oops
- Screamin' EagleĀ® Street Performance Touring Mufflers Upgrade question
- Soft cams or poor bearings??
- 48mm H.P. Inc. Throttle Body
- Stage 1 installed - Carb leaking gas
- Big Sucker or K&N?
- Short/Open Pipes vs Back Pressure
- How to make HP out of an 07 96 motor?
- leak between the cases
- Python staggered duals for $250...
- Anybody Here Done The Conversion?
- Won't start!
- Front O2 sensor--Where is it???
- Installed my V&H straight shot HS's, and some feedback
- Need a brother that knows his shit !
- Vance & Hines Quiet Baffles and Torque
- New Exhaust
- SE 211 Cam ? on 2007 96 cu in w/o higher compression
- Slip ons ? SE's and Khrome Werks for 07 Fatboy
- Is a PCIII absolutely neccesary?
- Hooker exhaust?
- Supertrapp SE's
- Rinehart exhaust
- Any tips on swapping my exhaust?
- 07 oil pump, what is the real deal.
- Which Mufflers
- petcock
- Engine Light and Samson Big Guns 3
- Confused...Exhaust Help Please
- TC 88 cam timming question/problem
- exhaust
- CAM Installation
- Carl's Speed Shop
- Samson Straight 33" Fishtails.
- Need carb rebuild kit for '82 FLH
- 06 night train EFI...want intake
- Couple questions regarding Big Radius V & H
- Street Bob exhaust
- True Dual Headpipes
- Indy's in North OC
- Completed rebuild and now having hard time starting
- Idle Adjustment
- big shots long...HELP!
- Rocker cover help
- police bike mufflers
- V&H Big Radius - Matt Hotch Slants
- Stage II install labor
- Vance and Hines short shots
- First 2 rides after the 103 build- tuning questions
- 82 fxrs superglide running rough
- Ordered 1.75 rush slip-ons
- Cam Chain Tensioners
- 2000 ultra "lemon"
- I'm conducting a $20K experiment
- Do you run Big Radius without baffles? Come on in.
- help what carb do I need?
- tools...
- cycle shack pipes for 06
- Rookie question -- blueing
- home made exhaust pipes, will it work?????
- 64910-99 pipes on an 07 ultra
- nightmare engine rebuild
- Which slip-ons for TRUE Harley sound
- Whoa, white plugs!!!
- Baffel Removal
- good and bad news with (Dealership)
- Exhaust baffle question...
- Lifter concerns
- SE adjustable pushrods
- Arlen Ness or K & N...?
- Rinehart Eagle Beaks for Springer Classic
- NEW PIPES FOR BAGGERS
- What is wrong with my set up !!!
- '07' stock exhaust on '06' bike
- Soot behind the air cleaner backplate
- Threadlocker on Cam Plate amd oil pump???
- woundering about porting heads 95cc ,510 s@s gears
- engine light comes on
- Weird engine noise-Help
- SE 11's & Noise
- Engine rattle???
- rinehart true duals baffles?
- HQ 0034 Cams
- V&H Big Radius problem for 07 Fatboy.....I need help...
- Anyone run Sampson exhaust?
- Andrews 37g vs. 26g
- anyone sue doherty aircleaner??
- Minnesota Dyno?
- Power cones
- what do I do.........
- aftermarket fuel injection management??
- can someone tell me what this means??
- 103 Build
- Quiet Baffles vs. Standard Baffles
- Pop, Heat and Slip-ons Only on FI
- Loud valve noise
- pre-installation advice
- Confusing?............YES!!
- Idle is a little high, is this to be expected?
- new a/c & se muff. a waste accord. to American Rider..
- Horsepower
- Big Shots Long
- no baffles
- 0903 Torque Calibration
- custom exhaust and baffles??
- Se High Compression Cast Pistons
- HELP!!! NEED SOME INFO
- Changes at PowerCommander/Dynojet?
- What do you think of V&H Longshots?
- O7 Screamin Eagle Road King Exhaust MOD
- What Jets to get
- My build finally starts tomorrow...
- SHOULD I RE-JET?
- 65115-98B Pipes on 2007 Ultra
- Compression releases
- Head gasket thickness
- ProPipe silent baffle project.
- Enricher Cable
- Screamin Eagle Pipes - Will they fit?
- 2003 Fatboy In the Shop for 95 Build
- HOW to De-GUM / clean a Road King Carb
- Pro's and Cons , of V&H fuelpak????
- 2000 88cid
- 99 FLHR factory carb de-gum question
- 98 FLHTC motor ?
- 96 build up
- V&H Softail Duals
- 95" Build - Repost
- Pipes discolored ??
- Can't decide which 2-1 pipe for my 113 motor.
- catalytic on my bike? baffle question ?!?!
- Aw, crap! Baffle help please.
- S&S Hot Kits for Twin Cam 88
- Chinese Dilemma
- Bike drinking oil
- What goes into a Stage one
- Do You really Need?
- Need some help
- DC/MD machine shops?
- Tune-up Blues
- new 2007 heritage softail classic
- Exhaust recommendations, EVO?
- Cam Bearing puller EVO?
- S.E. Air breather problem
- Is it a must....
- INSTALL quiet baffles for V&H BSS
- Simple Cam Question
- Who's running Trex duals?
- I see the "club" members are here
- poor customer service and atitude, spell never again
- sealing heatshield cut
- Stroke it or go home
- Bassani Road Rage 2 into 1
- Slip-On Question!
- Exhaust Temp?
- 06 Fatboy 88 upgrade
- 05/06 valve seals
- cam upgrade
- oil dripping from exhaust port
- DCOE carb, will it work well on a bike?
- V & H ovals vs Rush slip ons
- SE High Compression Cylinder Studs threadlocker
- Questions about TC88 Upgrades?
- Exhaust pipe temp
- SE Air Filter Element
- DROP NEEDLE A CLIP
- Backfire on startup?
- long storage fuel issue - bike will not idle
- noisey when hot
- Supertrapp 2 into 1 Best price?
- Rush slip-ons=fantastic!
- How tight to tight exhaust flange bolts?
