PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92
  1. Sportster rear rocker cover removal
  2. Exhaust for '07 Fatboy
  3. D&D Fatcats
  4. Cycle ShackSlip on Question
  5. Discolored Pipes
  6. dissapointing dyno run
  7. KHROME WERKS SOUND BYTE
  8. SE I vs SE II Slip On Mufflers (difference)?
  9. Kuryakin cams
  10. Chirp noise
  11. Thunderheader and EFI ???'s
  12. 06 streetglide exhaust
  13. too many conflicting stories...
  14. 95 inch cam question
  15. Stage O N E Question
  16. K&N Air Filter question
  17. sprocket shaft seal
  18. flashing red key light on
  19. Carbon buildup on exhaust pipe
  20. Spark plug question
  21. Fouling Plugs issues...
  22. Best Motor Builder In Seattle ???
  23. Heat Sheild ?
  24. power commander
  25. SuperTrapp Mean Mothera
  26. Compression release valves
  27. calling all bassani road rage users
  28. Oil from exhaust gasket? Help needed..
  29. Is this true ?.
  30. Winter Storage
  31. Right side "choke" for CVCarb???
  32. Fiberglass wrapping V&H Baffles
  33. 2007 Exhaust Changes
  34. octane booster
  35. Big City Thunder header pipe baffles
  36. Water cooled engines
  37. T-Rex 3" Duals, Road King Installation
  38. Stupid ? From Me
  39. muffler removal?????????
  40. Cylinder problem...
  41. engine light stays on 05rkc flhrsi
  42. Help With a decision !
  43. Questions regarding '05 FXDI Stock Exhaust Mods
  44. HD Slash Down "Slip-on Mufflers"...Part #80366-99
  45. Bassani Power Curves vs stock headers?
  46. whats the difference in 88 ci head & 95 ci head
  47. THUNDER HEADERS "True Duals 2007"
  48. Intake manifold removal
  49. 1995 FXD running rough AGAIN!!
  50. Exhaust/Air Cleaner...
  51. Rush slip ons, BAffle size?
  52. New guy type question
  53. se 211 cams thoughts or experences please !!!
  54. De-Baffling SE Slipon
  55. t-rex pipes
  56. Oil pump gear confusion
  57. help with hypercharger...???
  58. Even HD says they're the same... sort of
  59. AFTER THE HATE !!! The "07"'s Are popular !
  60. 2006 Big Twin Stock Muffler Modification
  61. 07 True dual "THUNDER" Thunderheaders!
  62. Cam Tensioner shoe replacement
  63. Ringing Rattle
  64. website for Forcewinder
  65. 88A-B Head question
  66. Dewey's air filter covers..
  67. S/E plugs and wires-worth any HP?
  68. WILD PIGS
  69. Calling all engine builders
  70. Stage 1 on Ca 99 EGlide
  71. Muffler Baffles
  72. T.C.88 by peterson
  73. 510 cams and @ gear grive change efi
  74. New Pipes for 2007 Deluxe
  75. Fullsac
  76. Gaskets... James Genuine vs. moco
  77. HELP, from buddies in the Palmdale, CA area
  78. Sound posting of exhaust systems!!!!
  79. Evo Pushrods
  80. Running a little rich
  81. Heritage classic Get Y-pipe or true duals?
  82. K&N filter kit rk-3909
  83. Molding/bending Fuiel line
  84. My V & H pipes are TOO loud!
  85. Engine builder in Illinois
  86. Gas Cap Hanging Thing Selling Idea
  87. fuelpak
  88. 03 duece exhaust
  89. attn: 1 screamin eagle...... mate
  90. Exhaust Popping and Backfiring Fatboy 06
  91. Fatboy Pipes and fuelpak
  92. 2006 ultra performance problems
  93. Hooker Darkside Exhaust
  94. Drag pipes or tuned exuast on evo's
  95. Question about horse power with,
  96. measuring for new pipes
  97. running rough
  98. Evo eng temp and Cooling fans
  99. se heads
  100. Thunderheader
  101. Questions/Advice on '07
  102. Wimmer Intake
  103. got thunder header from ebay what jetts shuld i use
  104. EXHAUST HEAT ON PASSENGER
  105. accelerator pump adjustment
  106. Carb farts on my '06 Sportster 883c
  107. Removing the CV carb
  108. S&S oval touring mufflers
  109. Do 06 slip-on's fit 07 s/tails?
  110. my numbers after SERT and dyno tune on 07
  111. Exhaust - not to loud suggestions?
  112. Installing Thunderheader on 2000 FXST
  113. S&S slip ons
  114. What are the spec's for the Evoultion engine
  115. mean carb farts and my bike smells like gas after riding
  116. Street bob exhaust
  117. Performance filter
  118. Carb problems?
  119. word of warning.....
  120. 2.25" baffles to 2.5" will it make a big difference?
  121. 1982 FXR Gas Tank
  122. Right cam combo?
  123. Pro Pipe vs. SuperTrapp
  124. 99 FLHTC Crank Position Sensor
  125. Possible Vapor Lock or ?
  126. Decel poppin and hiccupping.
  127. need a stock air filter element HELP
  128. S&S 510 GEAR DRIVE CAMS ON "07"
  129. decel popping and plug gap?
  130. rocker box torque question?
  131. V&H BRACKET ?
  132. hard starting warm 95
  133. stage 1 explosion??
  134. Exhaust Y-Pipe Crack/Glowing Red hot!
  135. Cam Specs
  136. 98" Build questions
  137. M and M Cycle
  138. rubber manifold seals
  139. back fire?!?
  140. She's runnin like keeeyrappp!
  141. New valve seats - big bore required?
  142. Thunderheader vs Road Rage
  143. Which gear drive cams are....
  144. Smoke coming out of carbeurator
  145. Best price on the kuryakyn cams?
  146. problems with Mikuni carb
  147. To lean / To rich
  148. Cam Bearings/Big Bore Kit
  149. My Rineharts are whistling. Please help!!!
  150. Whistling pipes on my FLH???
  151. minkuni on shovel
  152. SU carb problems on 58 pan
  153. Cam chain tensioner replace & oil
  154. Valve Stem Seals - what a difference
  155. Big Sucker caused Dipstick to Blow
  156. Rocker Box Torque Question...
  157. Push-Pull Throttle Cables on Fuel Injected Bike
  158. Slip on slipping
  159. Starter Question #2
  160. 06 sportster exhaust ( ?)
  161. Modifing stock mufflers
  162. 81 shovel engine problem help
  163. Will a hex head main jet work in a S/E 44mm carb?
  164. Exploded view of TC88?
  165. SE II & SE A/C ?
  166. 1996 V&H Pipes/ modifying?
  167. V&H/Stock vs Fatcats?
  168. Yet Another Pipe Poll
  169. 95" upgrade
  170. pinion gear breaking
  171. power cones question
  172. Rocker box gasket installation questions...
  173. did not use loctite on top end
  174. ? about which Jet
  175. True Duals
  176. Carb ? - 2002 Heritage
  177. Rebuild, or start fresh?
  178. 95” BIG BORE KIT/SERT TUNING QUESTION?
  179. 07 TREX
  180. OK, I Went 'N Done It!
  181. Hard Krome 4" duals
  182. Ever heard of windage issues in TC engine?
  183. Manifold absolute pressure sensor (map)
  184. Remapping?
  185. engine light
  186. Cam vs. Big Bore
  187. Rineharts on the 07's ?????????????
  188. VH True Duals vs Stock Pipes and Slip On's
  189. remove
  190. 2007 FLHRCI Sounds like a chatter box!!!
  191. vacuum leak?
  192. 07 Screamin Eagle 2 Pipes?
  193. 40mm cv on 95" motor?
  194. ProPipe switch to Bigshot Longs
  195. S&S carb on 95" RK- likes gas
  196. 1450 to 1550 Stage 2 kit
  197. Gasket issues
  198. Yost Power Tube Kit Review
  199. Stage 1 vs Stage 2 Big Sucker
  200. S&S carb question
  201. OK, The After market has done it ! now what ?
  202. Rush slip ons and tuneing
  203. SERT on an 07 96ci
  204. Cyl base oil leak
  205. engine question
  206. Which is a better shovel: 66-69 or 70-84?
  207. stage 1 crankcase vent tubes
  208. S&S crankcase breather
  209. CV Carb
  210. 2007 Street Glide true dual question
  211. Thanks PhilM!!!
  212. Another Popping Question
  213. Rinehart Baffle Welds
  214. Oil from Air Filter
  215. cams
  216. I want to buy V&H Shortshot Staggered...
  217. K&N Filter Questions!
  218. Caliber Exhaust?
  219. Fuel for 1989 1200 sporty
  220. Mounting V&H ProPipe HS on Road Glide
  221. Pinging under hard accelaration
  222. V & H customer service.
  223. SERT
  224. Cost of cam install
  225. Hardware for V&H sideshots?
  226. How to find out what I've got &.................
  227. Engine noise
  228. oil leak
  229. Wild Pigs
  230. Motor Noise
  231. exhaust question
  232. painting pipes w/ hi-temp
  233. major overhaul or new crate engine
  234. power commander 111
  235. Not sure what I have?
  236. Oil Leak....
  237. jetting
  238. too rich?
  239. Help
  240. 96" specs harley's new motor
  241. 02 screamin eagle road king engine miss
  242. 883 Rocker Box Covers
  243. SCEAMING EAGLE 2 VS. STOCK ON RD-king
  244. Drag pipes to stock exhaust
  245. Exhaust leak
  246. New Exaust for FLSTN softail????help???
  247. fuel petcock
  248. 2 into 1 options?
  249. Tools for Xhaust swap?
  250. Do torque cams help?
