View Full Version : Exhaust System Topics
- installed thundrmax want idle
- Thunderheader Exhaust Mount
- Best AIR sucker ??
- 08 SE A/C standoff bolt torque?
- Fuel pump/gas tank noise?
- Mo power
- SE CVO 103 HEADS
- Longshots replaced my stock exhaust
- Big City baffles in true duals?
- to remap FI or not to remap?
- Vance & Hines on 04 Heritage
- Hemi
- Gas tank sound
- Haven't started my engine since January..HELP!!
- Re jetting for Longshots???
- Mikuni Carb HSR45
- to build or not to build
- Where should I set my shift light?
- Exhaust Vibration = Numb hands
- procharger 166 horse power on 95 inch 211 cams
- my engine build compleated
- Rush muffler chrome quality and customer service?
- Cam Drive Gear Lash Chatter
- carb jetting
- GEAR DRIVE CAM NOISE
- K&N HD AIR FILTER QUESTION
- 98 FLHTCI EVO Stage One Download
- Newbie with an 883
- gas milage terrible since big radius
- Next upgrade - Head porting???
- power commander map?
- Some exhaust, air filter, re-mapping thoughts
- Changing carb needle instructions?
- Torque amount on exhaust installs
- Just wanted to say "THANKS"
- Why so much much negative talk about SE heads?
- Could Screamin Eagle HD brand air filter actually be a K&N?
- fuel pump question Need tech data
- D and D question
- Vance and Hines on Heritage
- Smoking
- Zippers Cams
- Exhaust gasket issue
- Engine Hesitates / misses under hard acceleration
- Stage 1, cheap and easy, or $$$
- Big Radius exhaust installation problem
- engine heat
- Serious problem with motor or ???
- Bike will not start. just turns
- TMax & Vista
- Engine seems to tap TOO much...
- hotroad king
- 96 Evo Starts on 1 Cylinder...Why?
- Cam for Stock 96"
- Cough/cut out when started.....
- Pre-dyno tune advice
- Pop Coming Off Cruise
- anyone running v&h stepped drag pipes?
- Yep - another intake/exhaust question
- Hooker install instructions?
- SE slip ons?
- V&H/Rush Questions...
- How Many Hours to:
- cam gears on a 88ci rkc
- 08 Night Train Piston Look question
- air cleaner sporster tube....
- Anyone tried an S&S 625G on a 103" build?
- exhaust stud broken
- help problems fith fatboy
- Loud pop on decel after hard acc
- V&H Monster Ovals
- Rattling Chains
- V&H Q-Series Double Barrels
- PCIII Question/Is it burning too rich?
- slip ons for 2007 superglide
- Looking at Black Hole 2:1 What's your opinon?
- 96" to 103" possibly ?
- Help -- oil leak
- True duals
- Not so nice engine noise
- Yost kit on a Mikuni HSR 42 issues
- Air cleaner options for a '98 FLHRCI?
- chirping reinharts found my trouble
- Larger inner pushrod tubes for Evo BT ?
- Screamin eagle and Screamin eagle II
- HeadQuarters Web Address
- time for topend rebuild
- Header pipes for 06 RKC
- Headquarters and GMR?
- Fuel starvation?
- PC3 map for Rinehart TD's no baffles
- went for ride w/o air cleaner
- Oil Leaking from A/C My idea dangerous?
- Stage I down load Is it needed
- Intake problem
- Gas milage
- noise control valve
- What's the best 2-1
- Samson vs V&H
- looking to get more out of my 88
- Keihin 27029-88 carb ID
- 2 into 1
- EVO Valve Train Noisey
- ? Advice.... please help!
- Dan Vance Reference Check
- Vacuum Petcock ??
- Morelli EFI air intake?
- Fatcat Install
- Trying to find part numbers to screamin eagle air intake, not in service manual
- airfolw experts aplly within
- engine rebuild
- S&S crankcase breather reed valves
- cams in stock '07 96" motor
- Supertrapp S/E ???
- hq dyno?
- 96" build up
- Nightrider Stage I-II-III results
- After new exhaust install, vibration?
- Need your thoughts SE Exhaust and the FI adustments
- compression
- M&M tune-up
- update on jims hydro solids
- injector identifaction
- new combo,excessive valvetrain noise
- Build or Not
- Dynoed again, a little better this time.
- Should i upsize my filter?
- engine mods
- A little quieter
- 09 ENGINE ?
- Start bendix life
- Mikuni Carb and Throotle/Idle Cables??? HELP!!
- big radius 2 into 2 download on 08 anyone?
- Converting a Mikuni to methanol
- 08 SE A/C install on 08 SG?
- Baffles
- S&S vs. SE AC
- Vance and Hines baffles
- Any dyno charts with 54H cams on a 103?
- Power Commander vs. Vance and Hines Fuelpak vs. Arlen Ness Big-Shot
- Screwing around with my SERT
- Elevation with Carburator
- about screaming eagle air filter kit
- Are your V&H quiet baffles too loud?
- Smog tests
- Bassani
- Help with Heat Shields
- Kuryakyn WildThings Cams
- exhaust flange bolts loose
- V&H 2-1 Collector cover/clamp?
- Vance & Hines VO2
- thundrmax will not link IDEAS
- 2208 TC96, Stage 1 a/c, slip ons and PC111 HELP!!!
- Exhaust Recommendations for high comp 95 build
- Carb Re-Build... What am I getting into?
- Fatcat Baffle
- Drill Ou Python Slip-ons?
- Stock TC88-A cams 99-06, are they the same?
- Sampson Pipes
- Stage One & PCIII Install
- FLHTCU/SE stock muffler question
- Fuel mileage
- Hypercharger for 883H
- crack around oil drain plug
- Blueing Pipes Protection
- OCCASIONAL SPLUTTER
- 04 duece cylinder size
- Modified exhaust for bagger
- Tuning the 120
- After the chain tensioner replacment.......
- Idle a bit low and modules..
- tuner
- time for a carb goddbye fuel injection
- 2007/2008 HYD Tensioners
- Pushrod Adjustment -- What If I'm Wrong?
- What EFI Tuner Do I Need?
- california legal short shots.
- LOUD pipes ARE legal in CALIF
- plug fouling
- DO THE BAFFLES COME OUT
- Modified Throttle Body????? Looks good
- maybe just compooter illiterate connection to thunder max
- starter question
- the good ol'days
- Twin Power EFI Fuel Calibrator-Questions
- rb racing exhaust
- 103 and valve size
- My dyno sheet with Andrews 37H cams
- Cam Cover Replacement
- 2 QUESTIONS??
- my Road King hicups.
- PC III Installation
- buying either woods or andrews cams
- True duals glowing
- True duels or slip ons!!! need help
- Compression release valves to Evo SE-heads?
- Back to a CV carb?
- Compression and head work help.
- Big Sucker, PCIII and V&H Pipe installed- not running right???
- Sportster heavy backfiring
- 2000 88B cam and cylinder advise.
- V&H side shots
- Rocker Box Gasket
- more power 96ci deluxe
- 88 and 96 intake manifold body
- BCT Baffles
- Hydraulic lifter adjustment
- V&H Ovals rattling
- Woods Cams. Define what "louder" means.
- Bub 7 Heat score
- SE Stage I Air Cleaner Kit
- fuel pump not working??
- Exhaust gasket advice
- Slip on low end power loss ?
- Jims 131
- bigger injectors needed, which ones?
- Hydraulic to solid lifter change On a 1979 Shovelhead
- Rear Mudguard Removal
- quiet baffles on true duels?
- Fuelpak settings with S&S Single Bore Tuned Intake
- different plug fouling front and rear
- true duals
- new 08 fatboy question
- Fuel Consumption 08 ULTRA
- 103 build falls short of expectations
- sporty sprays gas
- power commander
- V&H Big Radius 2:2 vs 2:1
- 08 Fatbob...Can I do my own map
- Baffle question
- power loss problem 1978 flh
- exhust
- Ful Sac
- Just How Much Does 2into1
- HQ 113" build
- Dyno Equipment Questions
- Are 07 & 08's too HOT?
- PACC
- 05 RK duals install help w/jetting please
- D&D Police Interceptor
- dyno results???
- how big before case boring?
- anyone ever tried exhaust prot etxtending plate on harley
- IDLE VERY LOW, ON FUEL INJECTED HARLEY
- Exhaust by-pass valve with SERT
- Oil Pressure Gauge Website
- 95" Upgrade; best MOD so far!
- Kury Hi-Five / Ness Big Sucker air cleaner and riding in the rain
- exhaust/rejett ????
- carb tune
