View Full Version : Exhaust System Topics
- Kuryakan Twin Velocity
- witch aircleaner to buy?
- 2006 Ultra Classic - Exhaust Rust
- Samson Exhaust 2006 Softail
- engine oil cooler
- power cone ?
- S&S 570G cam
- S/E Air Filter
- Should I seal a new gas tank?
- s&s mufflers
- Puking oil thru air cleaner
- UPDATE...Poorman's S/E Air Cleaner
- V&H Straightshots HS or Slip-Ons?
- SE pro or SE...what is the difference?
- Rinehart True Duals - Stealth Baffles??? HELP
- Nylon Needle Shim
- Good Article in American Iron this month!
- Black Ceramic Thunderheader Exaust Question
- Price of 95ci?
- Switching Mufflers Question
- Draining Fuel from Dyna Glide???
- Smog Equipment
- 2000 95 cube thunder head exhust
- Just bought 2000 road glide 95 cubic informatin needed
- here we go again
- its about time
- Different flow?
- hard start
- stage 1
- fouling out front spark plug
- Is this true?? Does V&H Make the Screamin Eagle Exhaust?
- thunder monster in V&H Longshots?
- Engine "cutting out" with SEII Slip Ons
- Doin' the deed
- another stage 1 question
- Do I really need all that?? and how many hours of labor?
- Odd Fueling Problem
- Seeking Exhaust Opinions
- Changing exhaust
- 74"&80" component mating
- Where to find a deep loud rumble?
- V&H , AirCleaner & HD warranty?
- V&H Hot tips
- 05 fat boy leaking valve stem seals
- better than sliced bread
- Removing Baffles from Rinehart Staggered
- Wild pigs....remap or repack
- Stage 1 question - from my hubby
- Adjustable push rods?
- Replace cam bearings with cam change?
- ironhead 2into 1 exhaust.
- storing take off parts from stage 2 upgrade
- Geez, not another exhaust question
- Power Commander vs. Cobra Fi200r
- sert going on monday
- Rod Bearings
- 95" big bore or 301 stroker kit?
- A Dumb Exhaust Question
- Which pipes?
- RB Racing Exhaust
- drain plug
- Exaust Mods
- Air Cleaner Question...
- One step at a time?? SEII slip ons
- Vaccum Operated Petcock
- Fuel starvation?
- 2006 Electra Glide Classic Mufflers
- Supertrapp
- SERT MAPS???
- hypercharger breathers
- oil breather
- oil breather
- K&N RK-3909
- 06 FLHT exhaust options
- Here's a option instead of tru duals on baggers
- 2005 Softail Standard EFI / Python 3
- Hooker mini staggard exhaust
- Does the V&H "Powerchamber" work?
- back to stock
- New 06 ultra
- Exhaust wrap
- Popping noise on Dyna
- Idle screw question
- Opinions on S.E. 50mm throttle body/manifold kits
- Change from Drag Pipes to Muffler System
- How does samson exhaust sound?
- Exhaust crossover tube
- 98 inch dyno results
- 05 Ultra - really really poor gas milage (30 mpg)!!!
- SE Air cleaner upgrade- K&N element
- kuryaken hypercharger
- Any one use these?
- Anyone supercharged?
- Can Someone Identify These BUB Pipes?
- HDWrench...
- High Flow Intake
- V&H Oval Slip-ons
- Is a break in period needed??
- sucks but no gaz
- Need some advise
- remaping exhaust
- Evo pushrod seals
- fuel leaks at carb
- Big Radius vs. Big shots in HP dept.
- SE, SE,Se blah bla bla....
- Stage 1 Question
- Who has had cam bearing failure?
- confused about stage 1
- SE Stage II "HTCC" piston and head question...
- '04 FXST slight bucking at 1500 rpms
- HD Flash + PowerCommander Overkill?
- Installed pipes, big sucker, and power commander today
- DynoJet Question
- Leaking Primary
- Analize Compression
- Clinking sound
- Installed New Pipes Today....
- Manifold Alignment
- '04 FXST--Runs of of guts --top end
- Normal wear????
- Cam bearings
- Which way does needle jet go into carb?
- Removing baffles from exhaust
- Chicken or Egg; Cams or stage 1
- fuel tank venting
- problems installing k&n in hamcan
- V&H Big Radius touch down!
- Road King EFI Question
- Fatboy "Coughing"
- stock pipe modify
- Cycle Shack drags
- I.D. this exhaust???
- K&N Filter vs. SE Filter
- Need to drain fuel tank--'04FXST
- Carb Question
- S&S slip on mufflers
- S&S Carb /Breather screw.
- New pipes
- Guide to upgrades
- yet another exhaust question,lol
- Has Anyone Tried The New Hooker Mid Length Slash Cuts?
- Broken breather bolt
- evo exhaust fit twin cam ?
- FI or Carbs
- Pipes With Welded On Heat Shields..
- 88 CI how many mles is too many?
- johnnie
- 49-state legal mufflers
- which way to go?
- Going back to stock carb parts from DynoJet kit
- Ok, here's what a set of Andrew 37g's make in a stock Fatboy.
- Gear Driven Cams for 2003 Road King Questions
- Slinger Carb Kit vs Dynojet kit???? '04 FXST
- Got flashed (ECM that is)
- Georges Garage
- tach for idle adjustment
- 95"
- Emission controls
- Ness Big Sucker DOES NOT FIT '06 MODELS
- KhromeWerks HP+ Sound Great!
- Anyone with Arlen Ness exhaust?
- Need some help with 06 883
- MOVED: ShovelHead help please...
- Exhaust Question?
- Who has the TCC Biker tru duals?
- 95 Softail not running right
- S&S gaskets
- Should it be on dino??
- Sea Foam for winter storage
- rejetting
- fuel float adjustment....
- Installing BB Kits at Home 95 or 98...
- 98 inch kit ROCKS!!!!!
- Breather Service
- Screamin' Eagle 103 C.I. Stroker Kit
- New Deuce and I'm sure you guys have answered this before...
- Stage 1 upgrade problem
- HDWRENCH, a question for ya
- OE MODIFIED SLIP ON MUFFLERS
- Uhhh oohhhhh........
- Cleaning Ness Big Sucker Filter
- Stage 1 stock re-map
- Rush Mufflers
- HELP!!!!HELP!!!! Bike wont run right!!!!!
- Adding cubes to engine.
- V&H OR SAMSON
- Confused about SEII Slip-on's
- MOVED: Shovelhead Cams
- Exhaust flutter
- Samson Rolled Thunder Mufflers
- arlen ness big sucker
- Pipes backfire
- 883 exhaust upgrade question
- ? about race tuner
- which jet kit?
- V&H Short Shots vs BUB Rinehart Flush Style
- 88B revving above 6000, is it bad? How many do it?
- Exhaust install
- Lolipops
- Slip on Drag mufflers ???
- Pipes and carbs
- V & H Big shots or Rinehart Flush?
- Check Engine Light
- Screaming Eagle Exhaust???
- Newbie question ...
- TCSTD...Need your advice
- S&S carb rebuild question
- Cable Tightness.
- Lubed throttle cables--now excessive play
- Here we go again.
- Fuel Petcock leaking
- cams for sale
- 91 Sportster stalls at highway speed
- Spark Plug Help
- Well, I did the same, ordered the Rineharts that is.
- V&H Big Shot Longs Baffles????
- S&S Engine Missing
- Evo engine life
- Oil blow by/ air filter
- 103 cu in stroker
- idle between cylinders
- Engine Knock...
- Fuel Injected 1340cc ultra classic problem
- Question about gear drive cams
- 90 FXSTC vapor locking
- V&H Fuel Pak Adjustments
- accel. pump probs help!!!!
- Ordered the Rineharts
- 05 Deluxe V&H Bigshots Staggerd???
- engine mods to '88 80"
- Larger Engines
- Exhaust?
- Question about main jets!!
- custom pipes?
- Am I running too lean?
- Another DEAD Ultra!
- Another filter question
- Whos got an exploded view of a stock ironhead carb?
- S&S carb help.
- Fullsac Mufflers
- This this true?
- Please help!!!
- HD touring mufflers blueing
- 99 WideGlide Misses when outside temp = 60
- HOOKER TROUBLEMAKER BIG RADIUS 86-05 SOFTAIL EXHAUST -Any personal experience?
- Need Help w/SE II's
- EVO Drag Pipes, sorry no lolli pop...
- Exhaust Shopping
- Top end tear down
- Can you HEAR an intake leak?
