View Full Version : Exhaust System Topics
- compression
- Removing SE Slip on baffles.
- Installing slipons, Should I use Silicone to seal connection?
- S & S SHORTY E CARB QUESTION
- Fullsac vs. Superflow
- Rocker Cover Removal
- Dual bore throttle body Gerolamy
- Oil leak
- Lift on Stock Valve Springs
- edlebrock performer carburetors
- spark plug read - too lean?
- Carbs and altitude
- welding crank
- What's the best exhaust for the buck on a sporty?
- Newbie EFI questoin
- Thoughts on Screamin' Eagle Build
- 08 Fatbob Air Cleaner Choices
- changing baffle,,,re-dyno ?
- white soot inside pipes
- 8 degree to 25 degree injector conversion for pre 2006 TC
- FXE wont stay running when giving throttle! HELP
- Help with backfiring problem on 96 super glide evo Can you help?
- stage 1 download and battery disconnect
- Please Help!!!
- Fuel Light
- Vance and Hines/popping!!
- Richen with enrichener
- Cams for my 07 Ultra
- 94 RK exhaust help
- Rinehart True Duals 06 Ultra - Allen Key Size?
- Broken carb fuel line connector
- sportster exh HELP
- best crank assembly for 124
- please delete
- 05 Road King Rattling noise from engine
- Hard starting suddenly
- Lifter noise?
- 2008 Fat Bob Exhaust questions
- best nos sytstem for bagger
- Valves/rocker arms/or something else noise?
- SLIP ONS w/K&N
- air filters
- Touring Exhaust
- please delete
- SE air filter affects MPG?
- 07 wideglide exhaust?
- Interconnect gasket?
- small oil leaks??
- 1995 evo pushrod tube leaking
- Bub 7 True Duels
- o2 sensor information
- Help! What is that noise?
- wont start after running long
- Backfire thru carb
- Stage I air cleaner
- Is it ok to put slipons on w/o PC?
- Which Slip on are louder?
- HELP!! Wifes 05 FLSTI cuts out
- Idle "lopes".. untill 2000 RPM
- Ready for the bad news! I think!
- D&D 2 1/2" touring slipons opinions?
- SERT Displacement Setting
- V&H Short Shot Question
- Shovel Dies when I accellerate then comes back when i slow down
- SE II Slip-On Compatibility Question
- oil leaks
- V&H Shortshot Staggered for an '08 1200N
- Dyna fat cat on the way
- OIL OVERFLOWING
- Passenger leg extreme heat
- Rocks in my engine.
- Mild decel popping now that....
- download
- rhineharts
- Lifter noise
- Screaming Eagle slip ons-silly question
- Supertrapp supermeg open end cap
- best dual exhaust for low end torque
- What Temp Are Your Heads Running!!!
- Samson True Duel's-longtail's-any good?-loud?
- REMOVE BAFFLES???
- Blowing headgasket!
- New Cams installed, NO POWER?? Wont rev high.
- FYI...a very interesting read about dynos
- Who sells D&D true duels?
- NGK sparkplug for TC96?
- Using stock ignition with cam & higher compression?
- Warming up my TC88B properly
- Would I have to RE-Dyno?????
- IS THIS NORMAL?
- Need to quieten Rush exhausts
- Woods TW6H cams
- wont idle
- 06 dyna superglide cam change help
- Swapping slip-ons?
- Exaust Bracket Missing Bolts 92 FXR HELP
- Oil Pump Alignment in TC88, How Critical is it?
- FourBidden 4into1
- Removing the oil pan on a TC motor
- Compression Question
- Compression Releases on Andrews 26n?
- Power Estimate - Woods TW5G
- Cam options?
- Pipe fit ??
- Bike has a problem...??
- 1999 Twincam ???????
- Exhaust pic needed
- V&H Basic Slipons
- LIFTERS??
- V&H V02 intake, any experiences?
- Broken motor mount.
- Mikuni HSR42 Pilot Screw???
- Heat Management system with a PCIII?
- i have a broken exhaust
- Newbie needs help
- Looking to do a 103cu in kit....
- engine noise: squealing and ticking
- Bike died in the Rain yesterday..suggestions?
- Please delete
- More sound from V&H Big Shots
- Cam opinions for a light softail...
- THunderheaders 2-1 VERY HAPPY
- SE HTCC ported heads vs SE MCR heads
- SE Heavy Breather vs Hyper Charger
- D&D fatcat 2to1
- new pipes
- Stage 1 Download w/ Slip Ons????
- 07 exhaust help
- XIED?
- 94 RK fuel fitting on carb
- Hooker rebel 2.5" drag pipes!?!
- 2005 sporty se a/c + k+n parts
- EVO in need of more power!!!
- Anyone use a cobra FI2000R o2?
- Question about Novello Copper Performance Exhaust gasket
- Question about slips-on and Thundermax
- Slip-on muffler
- Big sucker size ??
- Dyno run done. Help! Carb adjust?
- Air Filter Cross Reference Guide?
- Doing a 98"GMR build and have oil pump???
- SE Tuner vs Power Comander III
- broke muffler clamp - hose clamp ok as a temp fix?
- SLIP ON MUFFLER LEAKAGE
- anyone ridden a procharger equiped bike
- SE Street Performance Mufflers vs. stock
- Amsoil air filter
- Slip on Mufflers SERT
- Torque specs/part # for SE A/C assy.
- True Duals Gone!!!
- Anybody using a Yost master kit on a carbed EVO?
- ANOTHER REMAP NEEDED?
- Houston, TX - DYNO TUNE REQUEST
- SE CVO Mufflers
- delete
- what do think? crank run out
- Stock Exhaust as 2into1 header
- Any one using Rollingthunder slip ons ?
- any one have this configuration
- right side engine case is cracked
- SE Air cleaner
- chirp/squeak from front cylinder
- evo ignition for TC?
- engine cooling advice
- Oil leakage?
- engine running hot
- want to build my own pipes.
- Doherty air cleaner cover
- carb? bent valve? timing? im baffled...
- V&H Longshots (Big)
- How to reset throttle?
- TMAT with hillside heads
- RE-JET FOR AIR FILTER
- EVO won't start when cold.
- Exhaust Help
- Engine Code Instruction
- AVERAGE JOES IN MESA AZ
- Engine code P0152
- leave 02 sensors on or plug off with PCIII ?
- Won't Start
- whats the largest bore factory cases will handle
- 95" BIG BORE KIT!!!!!!!
- big city thunder baffle for.....
- top end 88 b ?
- Rush baffle sizes
- S&S teardrop on BS?
- Rush, Big difference over stock
- Exhaust Temperature and Pressure
- shovelution problems
- Gear drive 54's installed
- V&H fuel pack vs Power commander
- Really good SERT tuner in NJ
- Gas Tank question
- exhaust
- Engine advise request
- 2 into 1 Suggestions
- installing Mukini carb 1996 ultra
- Spark Plugs
- Replacing Rear rocker gasket on a 883
- 02 Sensors
- V&H short shots black
- Vance and hines Long Shot Baffles
- cracked sheild
- custom carb
- Cam advice for 96" Stage 1
- 07 RG exh. bracket failure
- Compensator nut
- exhaust sounds
- Adjusting push rods
- What carburetor do I need
- Air Cleaner replacement
- Genuine Keihin jets
- BAFFLES OR TORQUE CONES?????????
- intermittent lifter noise
- power commander error 39
- What did I screw up? Just changed rocker gaskets on my 1340 evo
- Bolt Striped
- Who makes this exhaust?
- black D&D FATCATS blueing
- Indy drilled hole in baffle?!?!?!
- Putting Back on Stock Slip-Ons?? Stage 1
- shovelhead + s&s carb = what jet?
- PHONE # OF Khrome Werks
- High mileage cam, what did I expert!
- Dynamometer Location
- Motor won't run with out choke
- Tapping sound/ vibration
- 07&08 crankshafts
- Tapping noise.
- Carb mixing screw plug removal
- O2 or no O2 sensor
- Baffle lifetime
- True duals with slipons- opinions?
- Baffle options for Straightshot HS mufflers
- slipon question please
- Fuel range indicator
- adjusting velva touch lifters for evo
- head bolt and stud dimensions
- Nightster + Short Shots (sorry to be a noob...)
- V&H Shortshot setup:
- What baffles to get for straight pipes. Need more torque!
- 1st gear Take Off Problem
- Engine sputter/skipping 100 miles into a ride - ideas?
- Engine load
- 2008 Ultra and V&H classic slip-on
- problem solved
- V & H big shot duals
- Put on slip ons myself and pretty fired up
- Fat Cat Exhaust
- Major Oil Problem
