View Full Version : Exhaust System Topics
- 57 Sportster Service Manual needed
- Vance and Hines Big Shot Duals!
- Rejet? Any instructions available or stealer only?
- edelbrock twin carbs
- Thunderheader, Does the pipe get louder as it brakes in?/
- Rinehart True Duals - older EG
- Spark plug carbon fouling
- k&n filter for ness big sucker
- Muffler Packing
- Vance and Hines Fuel Pack
- Modified Stock Mufflers
- k&n hi flow air cleaner for flhtcse
- Stage 1 05 flstn
- Best Price on V&H Ovals?
- 2005 JETTING
- Yet another Road King exhaust Quesiton...
- V&H for 2006 Deluxe?
- Is octane boost ok?
- Fullsac performance.
- Pipes for '06 Heritage Softail Classic
- Muffler Blueing
- Street Bob Exhaust
- Torque Spec. Fatboy oil drain plug
- Intake
- New T-Rex Vs. Rainhearts
- No Baffles
- Which V&H for "06" Heritage Classic FLSTCI
- Normal oil usage
- surging?
- V&H Bigshots
- Gas spewing out the air filter
- New intake HELP!!!!!
- 2005 Dyna Low rider FXDLI & Exhaust
- Engine sound changed
- Gear Driven CAMS
- Place to buy Rineharts
- Stock mufflers on a 99 Wide Glide (California Emmissions)
- screaming eagle 2 exhaust for 04 electra glide ?
- Revs
- 98" Motor Upgrade
- Remove baffles
- Wild Pig
- '76 Carb Adjust?
- stage 1 and screaming eagle exhaust question
- vacuum carb spring lid installation - help needed
- Engine Knock when Cold
- Push rods in iron head
- valve train noise,seems to be getting louder
- s+s carb spray pattern
- Propane in Engine
- fuel tank swap
- Will Stock Softtail Deluxe Exhaust Fit a Heritage Classic?
- One pipe black and the other isn't?
- Timing chain replacement question
- Vance and Hines Slip ons?
- Starting Problem
- Reinhart True Dual exhaust vs. Bassani?
- SE II question
- White Brothers E Series install question
- Yo, Mac
- New 16 Gauge HD Exhaust on, but...
- 05 Wide Glide dies while riding!
- Problem with 80 in EVO
- cut baffle reinstallation
- Spark Plug Torque
- baffle reinstallation after cut
- The best air intake set-up?
- Blued at 200 miles
- Installing my New Rineharts
- Stock Crossover to Duals
- V & H Slip-Ons
- Carb Jetting Question...
- Octane and Harleys
- FITCH fuel do dad
- Removing baffles
- cobra
- need help
- Rineharts
- Rinehart Installation
- Oil pumping out the crankcase breather tube.
- Revtech Stealth DFO???'s
- Went to far.....exhaust sound too raw!!
- K&N filters for SE aircleaners
- Ballpark cylinder temps for twin cam
- Need another re-map with V & H Big Radius?
- dead 1994 lowrider
- Painting the cylinders
- Tourque Specs?
- Hey TCSTD!
- Sputtering at high speed
- Rinehart Baffles
- Rear and Front Cylinder Temps.
- Miss fire after Stage 1 and Slip Ons
- High octane fuel question....
- dyno sheet of my daily ride
- Torque rating for Pythons?
- First real problem with bike
- made decision, please advise
- Rinehart Baffle Question.. on Staggereds
- Loctite Question
- Timer cover
- Upgrade Order for New Ride
- Removing Baffle?
- Solving Vacuum leaks
- Need help on tickin noise?
- Magic temperature
- Super Trapp slip-ons
- Stripped Out Torx Bolt
- Baffled about Baffles
- drag pipes
- Stage 1 w/ SEII's-Done Today!
- V&H big shots long on EFI Deluxe
- SE A/C Kit instructions needed
- still at war
- Touring mufflers
- ENGINE PING- BAD
- Please Help Me! Im confused!
- SE ones?
- Feeling tired
- Slippery thought
- Hooker Tuned Flow slip-ons
- Talked to Short Block Charlie
- Gear Driven Cams
- Stage one question
- SE II Air Filter
- Fatboy Breakdown...please help!
- Is this what I need?
- V&H Baffle
- Screamin' Eagle stage one A/C or....
- hey mack
- Popping when shifting up!
- Charcoal Canister?
- Oil leaking around pushrod covers
- Running Hotter
- wrap
- Torque setting question
- Python vs V&H
- Engine light coming on FLHTPI 04
- V & H
- V & H Fuel Pack in lieu of Stage 1?
- True Dual's for a 1993 FLHTCU
- Screamin Eagle pipes
- 2005 1200 sporty carb coughing
- Carb/injector cleaner good stuff or not?
- Jetting Summary
- Jets
- cam
- Big Radius or Big Shot
- Has anyone upgraded their cam?
- Big Growl Pipes
- 01 Road King engine removel
- Thunder Monsters on my RKC
- Decel Popping on 05 Heritage
- Warming up the Motor
- 1,000 mile check + Stage I
- Rinehart Question
- lifters for twin cam
- Burning oil
- Did I damage anything?
- Vapor Lock?
- S&S Troubles
- Thunder hearder
- TC 88B in the touring models
- Noise not normal
- removing the speedo sensor
- Where did my needle bearings go?
- Chroming Engine
- Heat Shields
- Pipe swap inquiry
- Road King won't start sometimes
- Rust on 2 week old pipes????
- Power cones
- Want to help that chirping sound on efi bikes
- MOVED: chirping rineharts.
- chirping rineharts.
- throttle play
- Valve Train Is Too Quiet??
- compression test
- Big City Thunder Monster Baffles
- big shot staggard vs big shot longs
- Cycle Shack Slip Ons
- MOVED: Quiet baffles for V&H
- Valve Train
- missing when hot
- Jetting
- V&H Big Radius on softail
- My take on the quiet baffles from V&H
- Old K&N SE AC or Ness Big Sucker?
- Stage II / Big Bore..
- Custom pipes
- Where's reserve?
- Stupid Clamp
- Stage 1 AC
- Low Idle Breakin
- Contents of Stage I on 2005 EFI Fatboy
- Quiet baffles for V&H
- MOVED: v&h shorties
- Gas Tank Dent update
- Drill holes in A/C or not?
- Cam Bearing problem
- Changing out exhaust on brand new bike, safe?
- Cutting stock airfilter backing plate
- Gassing without load
- Dent in gas tank? Help!
- fatboy screaming eagle 2's
- need louder pipes for fatboy
- Revtech DFO Control Box
- OIL is EVERYWHERE.......Any Ideas?????
- 5,000 mile service
- Why does my Harley sound like a Volkswagon ?
- Hot pipes-melted nylon?
- How far down the pipes is acceptable bluing?
- Rinehart say's PCIIIis the way to go.
- carb problem ( I think )
- Air Cleaner Insert Change?
- 1999 FXR2 CAM INSTALLATION HELP
- Installing SE Lifters Question
- Pipe question
- Air cleaner question
- popping on deceleration with Big Shot Staggerds
- damn oil pressure !!!!!
- Dynajet or Dynajet Thunderslide?
- Samson 2:1?
- junk in the gas tank
- Do Twin Cams make alot of noise?
- Exhaust / SEII slipons
- Which octane do you prefer in your V-twin?
- Engine Break-in S&S style
- review=S&S mufflers
- Shovelhead Pistons and Rings
- How to Remove Stripped Allen Head Screw
- Request for Python 2-1 Exhaust opinions
- Is this a problem?
- Noob ? K&N Filter Replacement
- Question on adding SE-2 Slip on's with 95B Engine
- blockage in the gas tank
- anyone got these ... ?
- Break in of new ultra classic
- True duels for baggers?
- Out of gas
- Dyna vibration
- Why more backfiring/popping when hot?
- Dynojet confusion
- air cleaner - ebay
- v&h shorties
- OEM Exhaust pipe crack - questions/solutions?
- Need Help Removing Baffles from V&H Big Shots
- LSR 2 into 1
- Stuttering, coughing, and generally dogging it!
- screamin eagle exhaust
