View Full Version : Exhaust System Topics
- Crankcase breather valve - straight scoop?
- Laid the Fatboy over!!!!
- Hydraulic Cams
- Carb Tuner, Angola, Indiana
- 98" hillside build
- Power commander... really necessary?
- Running Rich??
- Vibration in floor boards and highway pegs
- S&S Super G Carb Help
- Wild Pig Pipes End Caps
- drag pipes
- 103 install problems
- PC3 Autotune, anyone have one
- Checking for sumping
- Automatic Compression Release
- Couple of Q's on cam install
- Exhaust pipe???
- PC III Map with HD ECM Download?
- Need Assist: Stuck on Stage 1 Upgrade
- Pinging Noise
- Best Price For a set of D&D Fat Cats for Dyna
- Vance & Hines popping on deceleration
- Looking at Samson Pomonas on 2009 XL1200 Custom
- installing compression releases
- True Dual's on a 2010 FXDF
- Hard starting 106 Big Bore
- Baffle Wrap Questions...Opinions
- Can't turn motor over
- Thunderheader
- Rev-Tech to Drag Pipes = PIG Rich
- Jet kit questions
- Head question
- Question about exhaust packing
- Rocker box seals
- Installing / removing a 4* advance key?
- No Exhaust Gaskets!!
- Old Gunny's lifters
- TC 88 stalls
- simple O2 question
- bike backfires then dies coming to a stop
- Re Jetting California Bike
- Help with new tank
- titanium valves ??
- Cold Engine-Bad idle
- I need some help for this problem
- removing ECU 2006 FLTRI
- fuel starvation
- breaking "T" key off cam drive gear side
- stock induction module or 58mm ???
- Edelbrock Performer RPM 95" Package
- Stock exhaust change
- newbie needs help
- Help with evo Bike tops out at 75 MPH.
- Help with carb
- Evo exhaust hardware replacement
- Oil filler cap blown out...
- Puch rod tube
- V&H shortshots diy install
- Most hp out of a 96" twin cam ?
- Installing Cam, What Main Jet Evo
- Bike cackles very loud.
- T MAN 625 Cams....
- V&H Pro Pipe Chrome
- 2009 Road King won't start
- programmer/tuner help please
- Not happy with my 2-1
- Weird exhaust note at cruise with cams
- Best solution for throttle body upgrade? Is it worth it?
- Replace/Upgrade TC88 HEAD BOLTS
- Bassani, BUB or D&D Which is the best
- Rinehart vs. D&D - Experence with Contacting Rinehart
- Bub exhaust on a 09 Fat Bob
- Dave Mackie TC510s in 95"?
- D&D Fatcat Installation
- 2010 Limited looking for my combo
- +1 For B&E Superflows
- Carb Problem?
- CV carb overflowing
- Need suggestions for carb jetting
- STD contact number?
- Flange Retaining Ring Pliers
- 99 Sportster 883, are valves adjustable?
- CV Carb Help!!
- Good dyno guy??
- Boom Cans, Cutting Baffles
- Need a Part# for a K&N Filter
- sert alternatives
- fast idle ironhead
- leaking oil at stator wire.
- jeting stock carb-1200c
- Does it make sense to do a Stage 1 & Download for 2010 Touring?
- will screamin eagle heavy breather bolt on...
- Break-in After Big Bore Install
- Sreamin Eagle 1340 heads
- cam advise
- 2009 Sportster Custom, exhaust mod: Some Questions
- V&H quiet baffles
- stock pipes re-baffled
- Engine rebuild?
- will these headers fit
- What kind and will I need fuel management?
- Carb break-in?
- Maybe a stupid question...
- Old Style SE Slip-ons ... Bad Idea?
- Help, NO oil to the rockers
- how would the exhaust sound if i did this
- Samson or Bub
- Did I get the wrong kit ?
- Re-installing heads
- Starter Install- 2005 Softail
- Exhaust install question. Help please? Bassani.
- Cam Chain Tensioner
- 01 RoadKing Fast Idle
- loose gas gauge tank cap
- 181 hp 151 tq 09 bagger
- New Lifters - Oil Pre-Fill??????
- Bad wrist pin bushing and poor MOCO service
- +4 advance
- engine pushing oil into primary....
- Started Missing
- fuel pet cock tap
- Camshaft over lap
- S&S E carb, backfires thru tailpipe when shifting
- Fat Bob FXDF exhaust / air advice
- Where to find 2" baffle for bagger
- Sert map
- runn'n lean
- Anyone use Mathews Performance Products or services?
- S&S Easy Start Cams - Anyone running them?
- Breaking engine in
- EVO push rod tube leak
- cable routing
- More torque than Andrews 26?
- Andrews website says 37H - "Smooth idle, broad torque (2200-5600 RPM) 9.0 to 9.5 CR"
- best bang for the Buck
- S&S super E popping out carb 60-70 mph
- Rear cam end play
- Compression releases which ones
- Slip-on question
- 103 stage V rough idle
- should I stroke it or blow it up?!
- Drag Specialities question
- Next step Air filters. choices
- Slight smoke and extremely strong odor.
- Cam swap Help and Advice
- Abnormal engine vibration
- Arlen Ness Big Sucker Stage 1 or 2
- 98 FXD fuel gauge help please
- S & S Single Bore Tuned Intake
- .......... Problems.
- '90 FLHTC CV "hiccup"
- Evap, emissions canister removal
- Exhaust for Sportster 48
- 06 Nighttrain won't start
- 06 standard carbureted not idling
- Intake Leak
- Push Rod Question
- Vance & Hines Question
- Which cam for HTCC and 10:5 to 1?
- air cleaner with 58mm TB?
- won't start
- TC:Evo Exhaust Interchange Question
- Need Specs on Cycle-Rama 575 Cam please. Thanks
- Klock Werks Slip on's ??
- alternate float bowl vent forcewinder. Pics!!
- Spark plug recomendation for 95" Road King?
- 88B Counterweight Removal
- Camshaft Repairable?
- Gas Streaming from Carb/Air Cleaner
- change your fuel filter
- Changed my cam tensioner and she's not running right
- 2010 FLHX Jackpot 2-1-2 Headpipe
- Engine paint question
- anyone tried the Andrews 37H with 4* adv key with stock compression?
- Andrews 26 or 37?
- 2010 crossbone 2 miles
- Woods TW408-48?
- intake cover question
- Installing TW6-6 cams - advice needed
- Finding an Exhaust Leak
- 2003 screamin eagle deuce air cleaner
- Carb Problem?
- Stuck on the side of the road
- low oil pressure
- Loud Valve Noise!
- break in
- where did I go wrong
- s&s crankcase breather reed valve
- HELP!! Exhaust Mouting Issue...
- What way should baffels face?
- Cam Synch/Timing
- 88CI Upgrade????
- 88CI Upgrade????
- High performance air filter....
- Fuelmoto Power Package
- Wild Pig vs Rush
- Question V&H 2in2 BR for an 88ci on a 96ci
- need help on headpipe
- revtech 110
- Cam question
- Ignition Harness 32435-00 for Efi to Carb Conversion
- Stupid Question. . what type of metal are Harley heads comprised
- screaming eagle II exhaust
- Pistons for dummies like me
- upper valve train noise??????
- Ultima El Bruto ou RevTech in my '07 Dyna ?
- My Wide Glide dies on me. Why?
- Twin Cam S/E Cyl Head Swap. Need Help
- Questions on 2003 Deuce EFI to Carb conversion
- What type of motor
- Intake manifold?
- difference between std andsae dyno sheet
- red line
- Swapping out tank & fenders on '01 Sportster
- Freedom Performance Union 2-1?
- Exhaust Recommendation...
- O2 sensor plugs for V&H pipes
- Bassani 2" baffles
- fuel management needed?
- street bob timing gear
- Engine Temp VS Oil Temp
- 883 Sporty Idle Issue and Exhaust QUestion
- Anyone heard of 52/52 Performance Tuning?
- High RPMs
- Any good dyno tuners in Los Angeles?
- New Jets??
- At Witt's End
- octane boost
- Help My Ultra
- K&N HD-0800 Air filter
- Pipes and Fuel Mgmt up for grabs
- Best pipes for the Forty Eight??
- Download Req for Slip on's?
- lowcat opinions
- Idle and cold issues on 80" evo
- Bub 7 Headers & OEM Mufflers
- My Woods 7H with Dyno...09 Train
- EVO head leak?
- Loud Ticking after Gasket being replaced??
- Portable dyno service near north central Illinois??
- Good Down Low Quiet Cam
- Rush Mufflers.........Re-map or no?
- Which heads /pistons?
- I want it all!!!
- Help with my 103 build
- New Cams - Excessive TICK
- Balancers Chain on an 88B ??
- Swapping Stock Mufflers / Nightster to 883 Low
- screaming eagle pro tuner help
- Help me decide on a 2-into-1 pipe for my '06 Street Glide.
