View Full Version : Exhaust System Topics
- Major oil leak....and a knock.
- Big Boyz Heads?
- jetting
- Which breather do I use
- Rocker Cover oil leak...
- Simple Method to Clean/Oil K&N Air Filter
- Bike running hot
- CV Carb - carb-fart question
- too lean cause sputtering?
- Heat Management Question?
- mikuni jetting
- True Duals - Huge Difference!
- Testimonial
- Stock EVO/simple mod questions
- Rinehart 2into1 Exhaust for 2007 baggers ?
- 98 inch questions,questions..........
- Rineharts on Low Rider
- New Exhaust on its way...V&H
- Braided gasline tip
- Engine Respray ?
- removing intake manifold on 04 fatboy
- Looking for new headpipes
- bike sometimes stalls...
- diChrome engine screws and bolts
- Big Sucker Air Filter Question
- What should i do
- SE Air Cleaner don’t fit w/ CNC Ported HTCC Heads
- Blueing exhaust
- Thinking about upgrading to 113CI
- Are you trying to find SE pipes?
- An EVO with points?
- Thumbs up for Ness Big Sucker
- Half tank of gas and sputtering at idle.
- mikuni or S&S
- 1999 FLHTC Cam Replacement
- Harley TX125
- build in progress
- Temperature and idle question.
- backfiring?
- Custom Made Heatshields?
- 1991 soft tail custom - Diesel fuel??
- 883 - 1200 upsize
- Stock exhaust way more power!
- Stock or aftermarket exhaust?
- part #s for screaming eagle slipons
- Want to make Inner Cam Bearing Removal Tool
- Budget 95"....someone help a brother out!
- more sound form my Bagger
- Dome top/flat top
- How to tell if head is good?
- Help, won't idle without full choke
- Air Cleaner Bolts... Need Help ASAP!
- which pipes??
- Stock exhaust going back on
- V & H sideshots on fatboy.
- Where can I find an exhaust for a shovel to evo swap?
- How Many Plugs
- Black Road Rage W/Chrome Heatshields?
- 06 Heritage Classic stalling
- Not enough fuel?
- Screamin Eagle AC with stock pipes
- Do I need to re-flash my ECM?
- New Performance Baffle design for RTD?
- Oil Leak coming from Cyclinder 1
- torque cones
- Any tricks to getting RTD Baffles removed?
- New carb on Twin Cam 88: which one????
- West Coast Choppers Maltese Cross air cleaner
- exhaust cross-over
- Opinions on Carb / Ignition Module Mod.
- Which jets do I need...
- Cylinder Leaks?
- MOVED: Told NOT to use synthetic oil, shortens engine life
- CV carb float inlet needle valve question
- WTF??
- Loudest and Best sounding pipe!
- HardKrome Kickers on 2006 Deluxe
- 42 or 45 mm Carb..?
- Just a cam?
- Any After market news for the 2007 96ci yet ???
- Installing softail exhaust on a DWG
- Sputtering problem...possible solution? Read this!the engine was good an hot
- Replacement Engine
- Jets
- Heavy Breathing Revisited "AMERICAN RIDER MAG."
- Bassanni Road Rage 2-1 exhausts for baggers
- problems fitting SE air filter 06 bob UK
- vibration
- white smoke from both pipes
- V&H Dresser Duals
- 95" install and remap question
- Couldn't wait
- reinhart slip on
- Opinions on Revtech DFO
- 93 EVO crankcase breather and mounting issues for HSR42
- Has any one ever attempted to put an extension on the SE II's to move the lower of the two staggered
- BigCity Thunder Monster Baffles
- Sealant with metal base gaskets or no?
- Road King exhaust
- Sportster jet sizes
- few questions about 06 Bob
- SE torque slipon mufflers
- How do you remove the broken plastic.....
- Need info, advice
- Chrome engine kit
- True Dual Exhaust Warning
- Saw Some Cool Looking Chrome and Black Pipes
- Bassani Pro Street Pipes...Would like some input
- Dragon pipes...
- Dead cylinder
- Storing Cylinders?
- Bike with a slight cough
- Anybody ever missmatch a set of black
- New download part number? Help!
- softail silencers
- Need help with arlen ness stage ll
- Help with acceleration w/Fuelpak
- Stage I mileage problems
- exhaust
- My 97 1200 Sportster is knocking
- Converting dyna motor to Softail Motor and Vice Versa
- 03' XL1200C with a cold....
- 99 evo 1340...caughing after high flow & pipes
- new se II's on 06 flstci
- engine backfire
- fuel foweled plugs
- Confused and pissed
- Engine oil in air filter
- acceleration stumble
- volocity stack
- Got my Wild Pigs today
- SE torque slipon muffler help
- Exhaust deposits
- 2006/ with upgrades or 2007 96ci ??
- Exhaust note
- '98 fuel injection
- Oil leak? Between cylinder & case...
- slip-on pipes
- 2007 road kings & up grade exhaust's
- engine knock
- Power cones help?
- EVO exhaust stud size?
- 1550 Gaskets?
- Vance & hines
- What to use to seal exhaust leak?
- EVO motor ID and acceleration stumble
- VOES?
- Info on TC96?
- exhaust tone
- slow return to idle
- Sportster 1200C Engine Life?
- ANYONE?!?! know how to get MORE noise out of vance & hines ovals? FIGURED IT OUT!
- Dem Wild Pigs is LOUD! Help please
- New pipes, poping, back fire on decel
- BEWARE!! smooth bore mufflers on ebay
- 2 into 1 vs stock fuel mix?
- Can stock jugs be bored
- True duals and lean/rich
- Gear changes?
- installed V&H Classic Slipons
- '04 Fat Boy Exhaust
- A question regarding pistons
- V&H head pipes & Hookers
- Need some help with carb set-up
- New Khrome Werks 3" slip-ons
- Arlen Ness "Big Sucker" intake for 2006 EFI
- No manual - fuel switch question
- mukini 42hsr
- Tapping lifter
- what is the best way to torque exhust bolt?
- small shoped removed exhust bolt
- Bassani 2 Into 1 On a 88"er?
- Flying Oil
- Do I need ECM calibration for Screamin’ Eagle slip-ons?
- carb spring installation
- Khrome Werks baffles in SEII slip-ons
- Fuel tank size
- cam shoe replace
- Fuel flow?
- Next step???
- Andrews cams or S&S cams???
- Pushrods or timing?
- Stage 1 back to stock
- Drag Pipe time
- wrapped vance&hines pics?
- Solid Lifters
- exhust bold broken 1 st front
- Anyone have Hooker Troublemaker exhaust?
- my fuel level dropshow to vent gas tank?
- Exhaust leak????????????
- another slip on question
- Heads need info
- Mufflers
- 2007 Has new Twin Cam 96 inch motor!
- Cams, cams, and more cams!
- fuel tank question!
- what is it?
- Stock Lifter Oil Hole Orientation
- Info on slipones
- Eagle Beaks, Suspicion, and other stuff
- 06 vs 07
- Knocking Motor
- Opinions sought on output
- Python 3 baffel question.....blockage plate??
- Size of hole in baffles for Dyno HC sniffer?
- Nice Exhaust sound
- Getting Started
- Feuling Lifter's VS S&S anybody using them?
- Rough after 1 gallon of gas
- CV Carb Running Rich
- Engine won't fire
- Just ordered my Stage 1 Plus V&H Pro Pipe
- 04 RK Classic - EFI Problem?
- Cover for T-Bird
- Thunder Headers - Good and Bad??
- s&s 510g's
- Installed SE Slip-ons w/o SE A/C
- V&H Fuelpak problems
- Carb Access
- 95” BIG BORE ONLY 74HP ON DYNO
- need help!
- Cleaning Silver Powder Coat
- Accelerator pump
- 100" square motor
- gaskets
- Need to borrow...nevermind...got 'em!!
- Remove the balancer stuff from ya 88B motor
- Springer Classic Duals will they fit
- D&D Big Boss Fat Cat 2 into 1 pipes DYNO CHART
- Screamin Eagle Exhaust Gasket issues..
- oil pump
- Compenstaor Sprocket / nut service bulletin...???...
- Cams for a TC88
- Thunderheader 2 INTO ONE .VS. D&D FAT CAT 2 into 1 ?
- 95" Big Bore
- installing Bub true duals
- thunderheader slip ons @ true duals
- Bike hard to start, backfiring
- Fuel coming out the overflow tube
- Dual Cone Intake
- I need to know!
- Help! effects of cam timing off?
- Help wake up,rebuild my scoot
- Any special tools to do exhaust, air cleaner, and FuelPak?
- Stalled
- oval exhaust
- Recycling engine parts?
- Keep losing lifters on my evo
- sporty problems
