View Full Version : Exhaust System Topics
- how much big bore is to much for evo?
- Any difference in hydrolic lifters
- Replacing Pistons - Do I need to Hone?
- Compression & MCR's
- rush pipes
- Terry TV with wide band o2's?
- V&H BR and BSS
- 06 bob and want more power what to do??
- Twin cam heads
- fitting se 50mm tb
- 2007 Softail MPG?
- D&D Fatcat Install - HELP
- I need cam tools!
- Deluxe vrs Road King air cleaner cover
- Gas on Spark plugs?
- GMR Performance 98 Inch Power Pack 2
- Question from a newbie
- SE Stage 2 Big Bore Kit $1690 installed
- MAGNETI MARELLI ????
- lean pop? whats the cure
- SE I Mufflers
- Cylinder and Heads total weight for shipping purpose
- Builds & Heat....
- Lean condition made worse by colder weather.
- 103 Big Bore Kit - Worth it?
- Evo exhaust?
- I gotta know!
- older SE Ignition RECALL??
- Gearing down compensating sprocket
- Fuel pac or Power commander?
- Harley Carb Kit/Rejet question
- do they make this exhaust for a ST bob
- 03 FXDWG problem
- Harley Davidson slip-on mufflers (with script writing)
- Vibration - need some info...
- Exhaust wrap...
- 88" stock HP and Tourqe vs Stage 1 88"
- 2000 RK running rich now...???
- New bike/Stage 1
- Cams,Cams,Cams?
- Should I or Should'nt I
- 95" upgrade
- HELP exhaust in the crankcase
- Screaming Eagle Ignition 6200 Rev limit
- Below freezing temps - Effect on Mikuni?!
- Sa ma na bitz!!!
- Heat shields
- Help me understandincrease of compression
- 107 with 525s in an 07/08.
- air fuel ratio gauge
- Honing the Cylinders
- 10.5 : 1 Compression Ratio. Too much?
- Branch #4 preformance package
- 07 96in cams
- To stabilize or not to stabilize?
- 2008-FLSTC Softail Heritage exhaust to quiet?
- Spark plug color
- SHould I do valve work after port and polish
- How much would it cost ?
- 88 to 103
- need advice EFI issue
- Engine Idle
- Importance of equal length headers ?
- Lifter Orientation
- D&D Fat Cat in Canada
- O2 bung location
- buying exhaust?
- Deluxe pipes size ?
- FatCat baffel comparison
- Open loop / closed loop
- Advantages?
- Screamin' Eagle slip-ons
- Help with cams
- Camshaft Identification
- Primary seal blow up question
- advice about procharger
- vibration at low cruising speed
- new guy, old question
- raise compression
- help for a newbie
- intake for 883 xl
- V&H Classic's or Ovals
- gear drive cam change
- 103 Compression Ratio
- installing exhaust gaskets?
- SE 103 build for a 96
- Jesse James Thunderbyrdz or Crackers
- How many discs for SuperTrapp 2-1?
- Mufflers parts numbers Deluxe ??
- What type oil in 3 holes
- Bought used, maintenance question
- Another Stage 1 question
- RB Racing pipes.
- Engine Cases - which is Best for money
- Stupid question, sorry
- Intake? Whats the best?
- Replaced the front motor mount......
- 2008 cylinder heads- question
- How hot will she get ?
- Opinions needed regarding engine build up or swap in my FXSTDSE
- Rush slipons ?
- What do the marks on SE heads mean?
- Cobra Fi2000R O2, not happy
- 08 ultra dyno results
- Khrome Werks slip-ons
- Throttle Body Question
- K&N filter difference
- 103 big bore question.....
- 88 verus 96
- Hooker Headers Tuned Flow
- Do your Thunderheaders discolor?
- 98ci big bore
- V&H Softial Dual Install
- top end speed Question
- 07 Ultra...Headers
- price of take off heads
- Pipes... Stage 1 multiple choice:
- Compression Leakdown Failure
- Exhaust sound question
- 103 w/ cams is this worth it????
- Stage 1 Problems
- DTT settings?
- motor work
- Spark plugs
- Hel with REVTECH engine...
- Re-cored Mufflers How Did You Like Them?
- SE I Slip On Muffs
- K&N Stage 1 kit
- Rinehart Performance Baffle??
- Cam bearings and chain tension
- EVO 80ci engine changes year to year
- nor-cal t-max tuners/installers?
- HELP
- axtell 117 ?
- x-pipes or crackpipes
- SE I Exhaust modifications
- K&N for 2008 SE Air Cleaner
- New Cases
- help a noob out ?sporty won't start
- Install slip-ons
- Can you recommend a good octane booster?
- BEST PRICES FOR '07 EXHAUST
- stage 2 big bore kit
- whos been bagged for having SE s/o's?
- SE heads
- DO TORQUE CONES WORK??
- Carb sucks and blows
- Rush vs. V & H Classic Slip On's
- Does anyone have Thunderheader Exhaust for a Softtail?
- Piston skirt chipped
- Engine cough?
- 95" kit
- ThunderMax Autotune? Worth the Expense?
- Whats your opinion of the Bub 7 exhaust ?
- Mikuni carb sprays gas into air filter???
- Rush Slip On Touring Mufflers
- Flow of HTCC vs. stock
- Tool Rental
- Piston for 04 E-Glide
- HP and TQ estimate
- BEST SPARK PLUGS ?
- Engine case matching
- andrews 50g cams
- Exhaust PN's?
- Why not 65467-05?
- QUESTION:LENGTH OF VANCE & HINES TRUE DUALS
- Pro pipe question
- PC III or not PC III. This is my question
- SUPERTRAPP X-PIPES
- White Brothers 2 into 1
- Swapping cam, should you also...
- newbie - rejetting question - WHITE plugs
- Thunderheader Install doco
- The gain of INCHES
- SE compression releases: stainless?
- Question about flywheels
- synthetic oil for break-in on rebuild
- Cam Plates and Roller Rockers
- MILAGE
- TMax adjust my map now my bike runs ruff and pops on decel.
- Which Cams?
- Exhaust/header for dyna
- watercooling
- Screamin Eagle Mufflers.
- S&S 124 Twincam Help Needed
- Engine Cuts Out when Cold
- Hypercharger issues...Help!
- looking to go BIG
- SE cam change info
- Cam Choice: 203 vs 204
- 96 Inch Jugs and Heads
- backfiring
- Thread size for HTCC compression releases
- Slip Ons
- Larger fuel tank on EFI EGC?
- k&n rk-3909 and rk-3910 help please
- Hemi heads on my Harley
- Okay Fullsac Bagger MUFFLER owners...
- Cams and fuel management
- Hooker Exhaust
- Which exhaust gaskets to use ??
- K&N for 2007
- Need Fuel Pak map for ultra
- '99 flhtcui fuel line
- RUSH BAFFLES
- '87 FXSTC - Engine Bogging - S&S Carb
- How to install Rush slip on pipes?
- Exhaust opinions for 2001 FLHT
- 95" upgrade
- Anybody have Screamin Eagle air filter kit install instructions
- 08 se compression rreleases
- Just about ready except for
- s/e 65115-98b
- new exhaust for my 08 ultra
- Head Quarters Engine Parts
- V&H Pro Pipe BP or D&D FatCat for FLHTCU? Opinions anyone?
- Carb for 1967 XLCH,easy start/tune
- V&H Black Pipes
- Supertrapp Supermeg 2-1 Install
- adjusting screaming eagle pushrods
- Fatcat is installed
- 07 & 08 Pipes on earlier years ?
- engine running sluggish
- 204 cams and compression
- started HQ 113 build.......DONE !!!!!!
- trying to identify these slip-ons ? anyone?
- D&D FatCat question
- new guy help
- Carb and pipe questions
- Cycle Shack pipes, and huge flat spot
- raise compression with pistons or heads
- I thought 2 into 1 was supposed to be better
- slip ons
- SE BIllet plate or 07 style roller chain and plate?
- SERT settings ever go bad?
- Crankshaft Runout
- Any body have a tmax map for a 07 road king
- Chronic rear plug fouling
- Head removal
- Another Exhaust Question: Rinehart or VH
- bore and stroke
- Thndermax Turners
- Which carb to get?
- Part # for 08 SERT CD
- Tmax 07 road king dyno run, Is it too rich?
- SE cam plate w/gear drives?
- Dyno Sheets Wanted
- Thunderheader slip-ons on to Rinehart true duals possible?
