View Full Version : Exhaust System Topics
- '06 Electra Glide Standard Engine Light
- V&H Pro Pipe Baffle Mod ?
- Roller Rockers are they worth it
- 123hp/117ft.lbs... Dyno Sheet included
- 02 night train with "valvetrain" noise at high rpm
- 95 and cam install how to?
- no oil pressure after replacing pump cover!
- 103" Mod
- Fuel MOTO is great!
- Anybody using se-257's in a 95"?
- What do you think of this engine mod quote/setup?
- Very high idle
- 06 flhx tank
- Smith Bros Pushrods
- Plug color
- twin cam to evo????
- Looking for a little more out of my 103.
- Need carb jetting help - 88" w/S.E. 203 Cams
- 2008 road king true dual rineharts with thunder monster head pipe baffles
- Temperature-Related Performance Issue
- TC top end noise after rebuild
- Thunder-max vs pc v
- 2" Drag Pipes for 2009 Dyna?
- Screamin Eagle 95 comp ratio
- Gas smell in garage
- pebble in a beer can noise at 70 mph . . .help!
- Who has used underground performance?
- 103" Big Bore question
- exhaust nut size 1200
- Need PC Map - 07 Touring
- very low power after 95" build
- True Duals to a Fat Cat, Lost it all....
- engine trouble...HELP!!!
- Question on Engine Timing
- Can't Remember Exactly Want To Do
- California Models
- Cat in a CVO muffler?
- Adjustment of EFI throttle/idle cables
- piston to valve clearance, what to do?
- Pr confused
- Timken Bearing, Crank durability vs HP level?
- New exhaust; slip-ons or gear change?
- Runs rich and idles bad - Complicated CV carb 1200
- fxdwg missing when cold
- Gas dripping from AC after a run
- heads and throttle body
- Baffle Disassembly
- O3 FXSTB bogging issue
- Best single source for Andrews products?
- Hydraulic cam chain upgrade kit.
- Engine stall
- Baffle Question
- Slip-ons, no tune vs. warrenty
- SE Muffler Baffle Modification
- Mid range peformance problems
- High idle and random carb farts.....2006 FXST
- SE Super Tuner
- Heavy Breather Rain Sock
- which cam for 2002 95 se road king
- compresion
- Thinking of doing this to my exhuast..need input?
- Custom gas caps?
- 05 softail ecm in an 06 dyna?
- Recent Upgrade: Stage II 103 Big Bore Kit Numbers
- New piston ring coating
- South Carolina and open pipe
- sputtering and backfiring
- Smith Bros
- Muffler Chirp Fix?
- 2010 Road King exhaust and performance recommendations
- need Torque specs for header pipe bolts ...
- Andrews 48H cam
- Twin cam top end gasket sets?
- Exhaust leak
- How big of a throttle body
- Will a 2005 SE FLST AC fit a 06 88" FLST
- HQ0034 Cams in a TC88
- Please define "runs out of steam"
- Upgrading to True Duals
- Dyna Exhaust Cross Reference
- Screamin' Eagle exhaust = screamin' chicken
- idle adjustment on fuel injected twin cam
- Please help: wrapping my stock sportster pipes
- Looking to trade cams and advise on build
- 96" or 103" stock muffs on a 88" Just as bad as OEM?
- Tapping noise from front pot on idle
- Engine flush
- best 2-1
- Exhaust leak at head pipe to head connection
- bike not running right
- cost of cam replacemnt?
- Exhaust Bolt Stuck
- Rejetting for Straight Shots
- cvo exhaust
- Advice on set of Slip Ons
- Fuel Moto 88" and 95" Kits? Where's the Thread?
- Need advice on which high flow evo oil pump to get
- 120 R case boring
- Backing plate differences?
- need to remove baffles from Samson ripsaws?
- aftermarket heads ???
- Warranty compliance question
- Cam Info Needed
- Head Gaskets, which ones?
- Timing Issue HELP!!
- getting ready to do a stage II 103 upgrade
- 883 runs only with choke partly on
- Vance & Hines Big Radius 2-into-2
- rev limiter w/ pcv
- Shakey deuce
- A few more cam questions
- Intermitent starting, throttle boggs engine :/
- Just ordered, Rush 1.75 slip ons
- RevPerf head gaskets.
- hillside support
- 09' street bob building pressure in crankcase
- Samson sound
- Deployed and looking for new exhaust when I return
- 4 inch
- Crankcase sealant
- Who's done this?
- 2005 Deuce Heads
- What brand pistons for 107"
- Compression realeases malfunction?
- I take it that a fuel Pak is needed
- stock heads and cylinders on big bore stroker evo HELP!!!
- XLS Exhaust system
- Sumax Pushrod Tube Removal
- Exhaust flanges came off= bent pipes?
- 07 CVO 110 performance boost
- 1.725 rockers
- 2012 Ultra Limited & Rinehart True Dual Question
- Sensor In between
- Taming the Rinehart bark....cheaply!
- Removing plugs from aluminum heads
- JET-HOT anyone
- 2011 lifter noise
- BUB 7s and Power commander maps
- Dyna Muffler Question
- A couple of crank / flywheel reassembly questions
- compression too high?
- Satin Chrome Exhaust Mufflers for a Fat Boy
- Idle high after stage 1/short shots install
- Welded head??
- Dargo's will over custom built new cylinders near future take a look.
- connecting rods
- Rear Cylinder Exhaust
- can somebody help with my pushrod calulations
- SE Stage I Installation
- Fuel Moto SE Stage I + oil?
- Pro Pipe High Output thoughts.
- head quarters 95" kit
- Cutting breather ears off Ness Big Sucker II
- Exhaust Questions?
- carb or electrical
- Revtech Top End Gaskets
- Oil Leak from Carburetor on 2003 883 Sportster
- Hard to rebuild carburetor? Keihin CV
- Exhaust question
- high idle
- 2012 103
- High Idle, pcv andO2 sensors
- 88 to 95
- Air Filter Element replacement question
- Fuel/Petcock Issue
- Head Pipe Swap
- Shovelhead idle problem
- Help - Bike sitting for 1 year
- S&S 95" hot set up kit
- Drug my pipes the other day and lost the end cap for my Vance and Hines Longshots.
- I Hate My New Bike!
- Screamin Eagle Stage 1 Install
- Hard turn over and leaking oil...
- Is it ok to use SeaFoam with every fill up?
- 2007 Ultra heat issue
- more horse power
- Kuryakyn Velociraptor
- exhaust issue
- 97 sportster rocker box
- Having a tough time figuring out...
- oil out of head breathers
- $1200.00 to change cam chain tension shoes???Really???
- Too Hot or Not
- 2000 Roadglide idle motor
- Vance & Hines Replacement Heat Shield :-(
- 103 cid & rpm
- Engine Shuts Off When Warm
- fixing an intake leak
- Does This Seem Right
- Never buy Vance and Hines again
- Removing Baffles From A Particular Slip-On... PLEASE HELP!
- cylinder head temp
- Gas tank removal question
- What mods to complement true duals
- vance and hines exhaust installed
- Cometic Gasket Kit
- Dyno Problems
- Tune Up
- JETTING ADVICE needed>>>...
- Motor work performance question
- Throtel by wire
- Ok - this may be a stupid question...
- Cough
- Please help !
- 97 big bore which cams???
- Leak
- compensating sprocket nut
- Need some advice before I install my V & H VO2 AIR INTAKE SYSTEM
- Don't settle for cheap parts!
- 2010 Heritage engine knock
- Stage 1 / Shorts Shots Issue....help!!
- 2005 screaming eagle CVO heads - which cam?
- Stage 3 to Stage 4
- 2009 Ultra Classic - Exhaust Upgrade ?
- Sportster engine problems
- Weird knocking sound?
- Fuelpak mystery
- Newbie Exhaust Question
- PCV Map for Big Shot Duals and SE Stage 1 air cleaner 2010 FLHTCU 96"
- Oil Pump & Clutch Upgrades Needed?
- Octane Question
- HQ ST 107" Kit
- 6th vs 5th at 100 kph
- V & H Fuel Pak 61009
- here is what the mechanic found
- Compression
- Baffle Question
- what should i use to flush an oil tank out
- Build Question Heads, HQ 500 cam, stock pistons
- 1988 dresser with sending unit problems
- my 98 fxdl jetting question
- 2 Harleys doing the same thing!!!
- What do these pistons tell you?
- how to fit Twin CAM mufflers on EVO softail
- Help - Don't know what intake and Exhaust combination to buy?
- Fuel delivery problems?
- Fuel issue
- Fuel spray inside tank?
- KN air filter and VH slip ons
- Engine swap project. Please help.
- CV carb jetting back to stock?
- Twin Cam Crankshafts?
- Whats the best cams for my set up?
- oil pump
- Breather Recommendations
- Screaming Eagle Slip on
- Need an HD veteran's advice...Screamin' Eagle II vs. Screamin' Eagle slip-ons
- high pitch sound
- Exhaust Pipes
