PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. cant seal this exhaust leak
  2. comp. ratio for andrews 55?
  3. S&S smokin hot!
  4. odd sound from V & H quiet baffles
  5. Removing SE slip on's & return to stock
  6. SE-203 cams, think I just got robbed on ebay
  7. 2010 48 Popping from exhaust
  8. 96 - 103 - diy?
  9. A little help please
  10. Baffle question
  11. SE 110 cases vs. non-SE 96 cases
  12. 2007 UC hard to start
  13. First Harley, ??? Big Bore Kit
  14. V&H Dresser Duals
  15. 1989 FLTCU oil breather issue
  16. Pushrod cover issues??? help
  17. slip-ons for her RK
  18. Rinehart Slip Ons
  19. Big Radius
  20. Keihin carbretor
  21. power commander options and suggestions?
  22. pilot jet
  23. generator alt engine cases with HH stamped
  24. Need help with Jet Kit for Road king
  25. Can I increase air intake without retuning?
  26. need jetting advice
  27. Information about SE ACR Heads
  28. aftermarket exhaust w no pwr commander? will it work?
  29. Help With My Heritage Pipe Decision
  30. Air filter cover pic. Question.
  31. Anyone seen this before??
  32. Bub 7 dual position 2:1 exhaust 06-09
  33. deep rumble sounding pipes, not necessarily loud
  34. Dual Cam issues?
  35. Exhaust Flange Nuts ...
  36. Miss at steady rmp's
  37. drilling screaming eagle baffles
  38. Wrapped header pipes?
  39. Where to take it??
  40. SE II mufflers vs. SE Street Performance
  41. 97 S&S 88" anyone know compression ratio?
  42. Is it possible to build an evo...
  43. New 120 Build Opinions
  44. Two questions about pipes
  45. Hydraulic Tensioner Upgrade????
  46. EVO Problems
  47. Race tuner options
  48. What Does "Splitting the Cases" Mean?
  49. slip on mufflers
  50. stripped threads
  51. White smoke
  52. Darkhorse Cranks & H&D Cycles
  53. Amother desaster from H&D Cycles
  54. tk14609
  55. Engine Builders
  56. screamin eagle slip-ons
  57. Stock Pushrods or Adjustables.......
  58. Sputteriing When Hot
  59. PCIIIusb Map
  60. Help Help Help fuel injected or not
  61. 93 Sportster carburetor problem
  62. What can I do to my stock exhaust?
  63. Doherty Powerpacc question
  64. 2002 Roadglide FLTRI Sputtering
  65. rear cylinder sucking in all the time
  66. Sputter, caugh and cutout, 92 H Softail
  67. Stock 96 with SE251s
  68. Andwers 48H Cams
  69. Rush Slip Ons and Baffles
  70. Wimmer ESB Air Cleaner
  71. 117" 120" or 124" build?
  72. Knock that was increasing
  73. "Harley Car" shakes, need options
  74. Tool for holding lifters up ?
  75. Engine problem I assume?
  76. help with my peeling gas tank sealant
  77. slip-on installation
  78. 98 dyna fxd wont run right....carb prob
  79. Flstc drips gas from vapor valve
  80. 2010 wide glide, Fuelpak or HD dealer download.
  81. S&S BB106 vs RevPerf BB107
  82. 2000 Softail Heritage wont start
  83. SE Exhaust
  84. Another Dumb Question From Me!
  85. Outer Cam bearing shot
  86. Bendix Carb Frustration!
  87. #1 cam
  88. carburetor problems?????
  89. Which is louder?
  90. K&N filter . Which one ?
  91. Check engine light problem
  92. Freedom Performance Sharp Radius
  93. Screaming Eagle Exhaust Slipon Question
  94. Starter clutch wich one is the best??
  95. Where to have 02 bungs installed
  96. Where is the cat located?
  97. problem with 08 street bob need help
  98. I need alinement tool
  99. how do i go from double to single cable carb
  100. 2010 Wideglide exhaust mod
  101. Why fueling over SE for cam plate?
  102. Help 58 mm TB
  103. Fuel drips out of aircleaner after hard acceleration
  104. Rocker ratio
  105. Carb problem
  106. Please read my plugs.
  107. crack pipes??
  108. Mikuni 42mm intall
  109. TC 96 Cylinders on TC 88 case?
  110. my 88b vibrates
  111. 96" crank in 88 cases?
  112. Georges Cam Tool's
  113. 07 fxdwg motor build???'s
  114. Help with Master Tune
  115. 08 Road King Classic Exhaust Upgrade
  116. Healthy 103" Build...Suggestions
  117. Rocker Noise after Upgrade
  118. Evo Engine Oil Blow-by Through Breather
  119. Poor throttle response at initial turn
  120. 80 ci upper end upgrades
  121. Stumbling Street Glide
  122. hd top end gasket kit head gaskets
  123. Question about 03' 88B Twin Cam... HELP!
  124. Question from USMC2803 about Head compatibility
  125. Softail Deluxe 07 stalling issue
  126. Installed bearing backwards
  127. Troubleshooting sound after install of AC
  128. Changing slip-ons
  129. 1999 FLHT carb question
  130. Dyno Duped! Tunning help/advice needed
  131. 86 Sporty leaking fuel from carb
  132. True Duels w/Largest Diameter Head Pipe?
  133. '97 fatboy--how to check fuel level in tank?
  134. lifter wont bleed
  135. '06 Superglide overheating problem
  136. looking for a good sounding cam
  137. Oil pressure light
  138. 2004 Deuce 88b Stage 1 and Vance & Hines long shots
  139. How Long Can I Run a Stage I AC Before I Get to a Dyno?
  140. Engine seizure causes rear wheel lock up
  141. What's the Difference Between Screamin' Eagle Stage I AC & Screamin' Eagle Pro AC?
  142. Cams and MPG
  143. 89 883 misfire?
  144. Do I need to remap with slipons
  145. In the middle of a cam swap...????
  146. Thinner head gaskets for new cam?
  147. Help?
  148. How difficult to is it to swap exhaust on a Road King?
  149. Vance and Hines Pro Pipe
  150. SE 258 cams shot
  151. Transmission Pops down!!!
  152. Full Sac True duals users ...you new 24" heat shield is HERE!
  153. 1550 Big Bore 211 Cams
  154. Reinhart Truduals
  155. Hillside 124 to 128 build
  156. Mikuni HSR 42 problem
  157. emergency help needed
  158. 88 Twin oil change issue
  159. screamin eagle heads
  160. help - no compression
  161. Hastings Piston Rings
  162. will engine tins overheat engine
  163. SuperTrapp Supermeg and Retune?
  164. very fast service..
  165. How to check engine compression?
  166. Rocker arm "ticking"
  167. Sound off, Pro Pipe or Fat Cat
  168. Crankcase Vent - 99 Sportster
  169. exhaust ?'s
  170. New pipes and AC with efi
  171. Rear pipe glows near head ! 04 Ultra
  172. Disappointed in Rinehart pipes?
  173. exhaust clamp breakage
  174. 2006 Street Bob won't run
  175. Baffles, torque cones or both???
  176. Cam for 96"?
  177. Another 103" Upgrade Question
  178. What cam
  179. KickStart???
  180. New bike needs help...
  181. Carb tuning
  182. 2009 screaming eagle cam changes
  183. True Duals on 1999 FLSTC
  184. Is this a TTS USB-to Serial Cable?
  185. Need help !!
  186. stage 1
  187. Rinehart Crossbacks
  188. Fuel with 10% ethanol
  189. Mistake with exhaust?
  190. TC88 winter progect shopping list, what do you think?
  191. screamin eagle 51mm SE carb 27926-02 or 27928-07?
  192. Is a 1980 fxe rubber mounted?
  193. Anyone know who makes and sells Dual Carb kits?
  194. Master tune cables
  195. I know "Check Your Bolts!" has been said a million times...
  196. F**k. Supertrap 2-1 Discretention screw snapped
  197. intake manifold alignment question. LEAKS!
  198. stage 1 air filter gasket - make it fit?
  199. Lifter Replacement
  200. rear heat shield part #
  201. Need part # for pushrod tubes
  202. Oil out breather
  203. do new mufflers create vibration
  204. Broken Exhuast Stud Jig
  205. TTS Mastertune VS Fuelmoto PCV??
  206. New engine/oil light flickers or stays on
  207. Slight oil leak around rear rocker bolt on rocker cover where it meets head
  208. Thunderheader
  209. +/- of gear driven cams?
  210. FXDWG Stage 1
  211. 03 Ultra low engine knock recent cam chains
  212. what push rods should to run
  213. what lifter should to run
  214. 04 ultra Hesitating and Missing
  215. Fresh Air Intakes- Aftermarket Differences?
  216. Do I need to retune the motor if I put my stcok pipes back on? '06 FLHR
  217. Big radius 2 into 1
  218. Petcock
  219. 2007 lifters are loud ...
  220. Question about Samson pipes...
  221. What pipes do I have?
  222. Need a Carberator
  223. Changing exhaust without a tune???
  224. R&R 525 cams in a stock 96"?
  225. Engine alignment question???
  226. Cylinder stud problem.
  227. lower end noise
  228. New Bassani's on a 2010 stock 48
  229. backfire 89 sportster
  230. Base Gasket
  231. Loss of rear cylinder in 2006 FXDi35
  232. Braided EFI and Crossover , less than $25 !
  233. Touring & Dyna - Same Cam?
  234. Burnt Top
  235. Vance and Hines verses D&D
  236. Houston area dyno
  237. losing fuel economy
  238. twin cams
  239. Low fuel light question
  240. Fuelpak...WTF?!
  241. se 110 heads on a 96 to 103 conversion???
  242. vance and hines look alikes??
  243. Near catastrophe
  244. The new pipes get mellow after a while...
  245. Choke problems on Magnetti Marelli inijection
  246. Paint in the fuel tank...!?!?!?
  247. home made quiet baffles
  248. Need help getting my CrossBones on the road over here in Japan.
  249. S&S 124" and my stock wire wheels
  250. Dresser Dual Vids
