View Full Version : Exhaust System Topics
- Engine build 95 or 103
- throttle body size
- Exhaust Re-tourquing?
- Exhaust re-tourqing
- just curious
- What's the loudest slip-on for an 08' RK?
- Help road salt on heat sheilds
- torx bit as an ez out
- oil from air cleaner
- Fuel Pak or Power Commander..?
- Active Exhaust Valve
- Downloading tune after 103 questions?
- Cam bearing issues, bearing plate too??
- B&E or Wild Pig Slip-ons for RK
- What companies make the best throw over saddlebags for a 08 softail custom?
- Download a must??
- Anybody modify stock pipes?
- stock touring mufflers
- confused
- Will this carb fit on my bike??
- Another tribute to the HD stage 1 air cleaners
- FUELPAK 2008 Fly By Wire problems...
- 02 sensor question
- VH Slip Ons Getting Louder?
- Oil coming out air cleaner
- sertand narrow band senors?
- Idle ?
- Rinehart baffle change
- Engine Missing
- damn inner cam bearings
- 59g cams 11.25:1 54 mmtb thunder header ne1 running
- REPLACING STANDARD EXHAUSTS
- injector part number what degree
- 88 vs 88b
- HOW TO REPLACE A BROKEN CHOKE ON EVO CARBURATED ENGINE
- Anyone run Bassani prostreets with heat shields?
- Fuel Pack on 07 Fatboy
- Torque Cones?
- New Rush "true duals"
- Cam for 06 Deuce
- Help..Pipes, Fuel management and filter
- picked-out mufflers now what the^&*%$@
- stock slip-ons
- What Kind of Slip-ons are those???
- Engine question...smoke from tail pipe?
- CrossRoads A/C and Terry Components
- Andrews 37G cam timing advance question
- feuling cam plate question, pn 8000
- Replacing stock petcock with new one.
- 1200 conversion Compression Question
- Installing cams on 07 dyna
- S&S Intake #2577
- O2 sensor DTC P0131 & P151...need help
- O-Ring Question, CV Carb
- W-6 CAM SET-UP
- Andrews 54H cams
- HELP! Barfing Gas!
- O2 sensors
- front cylinder shut down 125 miles after build
- DynoJet kit tuning advice
- Modifying STOCK Exhaust - no remap. How to?
- stock exhaust modification
- cv carburater
- Had the Dealer do a re-jet and...
- I need advice
- Any input on Speeds Velocity stack?
- suggestions
- Rinehart Slipons require RACE TUNER??? WTF
- Confusion over Cobra Dragsters
- anyone know number for injectors.
- compression aloow for new valves
- Andrews 21 Stock 2006 88vtwin
- Exhaust Suggestion
- D AND D EXHAUST FOR 07 HERITAGE
- 01 tc88b carbed/510g cams and jetting
- boring my 96 to a 103?
- S&S Single-Bore Tuned Intake
- Could use a little jetting advice...
- 08' cylinder heads
- CAM bearings repalced; O-Ring failure
- new build for my 06 Dyna Lowrider
- 95 ci w.194/160 valeve will hit
- Stock Cam duration/lift on 96 c.i. 2007 FXD
- Jims 120 on Softail
- Crappy Gas
- Diff. in Mikuni HSR42 and HSR42 easy
- Had it dynoed today.
- motor upgrade
- Buell Blast question
- V&H Ovals to Rinehart True Duals - no mapping done
- slip-on exhaust
- Performance changes after upgrades???
- Rinehart's 2 into 1
- Anyone using KB pistons?
- Piston Cylinder Clearance for SE Flat Tops
- Cyls Expansion/Contraction:
- popping
- 06 NightTrain engine trouble!
- Engine rebuilding skills needed?
- whats the thread size on 96" spark plug?
- Completed the roller cam chain conversion
- Induction Module Alignment tool.......
- New O Ring different size than original one
- Question about Pistons
- dyno results need help to interpret
- 07 Fuel Gauge
- TC inner cam bearing installer
- fuel in my engine
- Milling heads for compression/2004 FLHTCUI
- Liquid to prevent pipes from discoloring.
- se 120 tc bored out to max anyone
- gettin ready for cams,,, gear drive
- more carbon in one exhaust than other...why?
- How Can You Tell?
- Stock carb settings on pre CV Carb? '87 Electra Glide
- 07 CLASIC EXHAUST IS IT TRUE?
- Carb STILL leaking! Help!
- andrews cams
- First ride on the new build!!!
- removal of Vance & Hines baffles?
- cams for 103"
- Re-packing V&H ProPipe Baffles
- Need advise from experienced tuner
- What Should I Expect
- FULSAC QUESTION
- A new used bike owner has some questions
- BUB 7 TD on 08 RG
- thundermax maps and injector size
- need feedback on which baffle to use
- Give me some ideas...
- 96" dyno reslt with 204, pipes, tune, breather
- Exhaust pop
- 110 is running and is ridiculous
- 88" to 95" upgrade/everything but the kitchen sink
- 2001 FXDWG2 major modifications
- Vance and Hines baffle question
- CAM FOR TC88B
- Stock header pipes size
- DO you need tools for a cam/engine upgrade?
- Andrews 54N Cams
- Dynojet Numbers? How are these?
- true duals with crossover or not?
- added true-duals headers - Remap?
- Attn: all Crossbones Owners and future owners!!!!
- air cleaner modifications
- Slip ons without power commander
- Hooker Slip ons anyone?
- Why new pistons say .0005 on them
- andrews 55h
- Thought on How to Increase torque on 06 Cop Glide
- How to tell if she is running "Too" Lean?
- Kuriakan Pro R Hypercharger
- Install Stage 1 myself?
- cycle shack baffles
- Horsepower gains with cam change only?
- Stock TC tourer exhaust heat shields
- Sure, it doesn't ping
- screamin' eagle exhaust gasket vs stock type gasket
- Andrews 26 or 37
- TW6 vs Andrews 54
- Black Smoke from pipes - New Pipes installed
- Staggered Double Jett
- 95 ci upgrade, lost mpg
- Perfromance Heads for TC88
- evo exhaust on a twin cam?
- New Build / Standard Oil Consumption on 95" / 2004 FXDWG
- Rejetted Carb
- catalytic converter
- question on crankshaft bushing
- big radius stock baffle
- Sort of beat to death but give me your ideas.
- Anyone installed Funtail endcaps..
- Another Cam question for 96 incher
- No fuel gauge!
- New Samson Fishtails turning Gold
- Vance & Hines Slash cut slip ons
- 88 vs. 96
- High Performance Engine
- V & H Big radius pipes
- Head Porting / 103 Stage Two 2008 Motor
- Swapping pipes. do I need to rejet?
- v&h differance
- Revolution Performance
- Aftermarket performance
- V&H Big Radius 2 into 1
- Replacement Tank
- Rush or Rinehart slip-on's for my 08 RK?
- New pipes installed, serious popping on decel
- Andrews 31 or 32 cams
- Where to buy Torrington 148B Inner cam bearings??
- BCT Baffles + stock V&H baffles in Big Radius
- deleeeeet!!!!
- SE Stage 1 A/C Install question
- KICK START 96 INCH MOTORS
- Building bottom end pressure!
- Engine dead, need help please
- broken exhaust stud
- Quench?
- bigger injectors
- Remap Or Not?
- New Exhaust
- Idle RPM Question
- Rinehart Slipons
- CAM plate removal
- Carb leaking-HELP!!
- Fatcat 2 into 1
- Mikuni return spring question
- Need a map
- no oil pressure on twin cam
- embarrassing
- custom map
- Alittle advice on somebody who found out the hard way about pistons!!
- true duals and proper muffleres
- Need help redo'ing PCIII map
- 95 build, compression question
- Dynojet THUNDERSLIDE kit
- Wrapping Exhaust Pipes. TIPS?
- Air-cleaner Stage 1
- How to clean exhaust
- Santee exhaust
- Help!! Need to I.D. SE Cams
- What's up with the '03 TC 88's ?
- Big bore kits
- Please delete this thread. Posted in wrong forum.
- carb tank on injected bike
- PCIII map question
- SE 4 3/8 Cranks Are they true?
- v&h slip-ons
- Any info on Screamjet Plus?
- Rear outer cam bearing
- VH Short Shots - Baffle Recommendations
- Which cam for a stock SE 110"?
- Exhaust leaking question
- Bub 7's not for me
- Catalytic Exhaust On All 2008 U.S. HD's?
- yet another carb question
- Cam Gear Issue:
- D&D fatcat performance baffle
- Help identify cam
- S&S Intake #369
- Rinehart vs Vance & Hines? Which is louder?
- Need tools for CAM swap
- O rings on Jugs, wait, that didn't sound right.
- bearings
- 96" Stage One vs a 103" Stage Two (Factory stuff)
- Terry Components Terminal Velocity II
- Removing Tensioners,are the Special Tools Needed?
- Do I need a new cam plate?
- Cams, and pushrods on an 08 soft tail????
