PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92
  1. Which slip ons sound best?
  2. 1998 ROAD KING CLASSIC
  3. break-in period and mods
  4. V&H PRO PIPE or D&D Fat cat 2 into one ?
  5. dyno tune at red river
  6. dilemma !!
  7. High idle when runnig hot ?
  8. Serious Exhaust question (urgent help needed)
  9. Open face Arlen Ness Big Sucker?
  10. cv carb problems?
  11. dfo 1340 st tfi
  12. Backfireing
  13. 06 Night Train pipes
  14. GMR Performance
  15. spark plugs
  16. Ness Big Sucker
  17. SE Breather Question
  18. hesitation during excel
  19. Yost powertube -- WTF?
  20. Compensating Sprocket
  21. Exhaust pipe question....
  22. Twin Cam Troubleshooting
  23. Main jet size ???
  24. Fuel valve question
  25. dyno in Omaha?
  26. Stock Exhaust Burn-In
  27. EVO S&S New Motor Burping Oil out Breather
  28. Thunder Monster Video
  29. Whinning noise
  30. Engine Light 2006 Street Glide EFI
  31. Staightshots installation Question
  32. Ethenol Blues
  33. CV44 Carb
  34. #46 slow jet
  35. And then it DIED?
  36. supertrapp exhaust
  37. NEw hooker exhaust
  38. keihin cv screws
  39. Compression/ Kuryakyn
  40. SERT
  41. mixture screw confusion
  42. Exhuast whistleing sound
  43. 80" performance engine mods
  44. changing rocker box gaskets on my 99 sportster how to
  45. enrichner
  46. Best prices for Bassanni exhaust?????
  47. wont start?
  48. slip ons
  49. Lifting of Front of Gas Tank
  50. Differences between SE 16ga DBL Barrell and VH Bigshot Staggered...
  51. Need advice for slip-ons for 97 Heritage
  52. D&D Big Boss Fat Cat 2 into 1 pipes
  53. fouling front plug
  54. Screaming Eagle active performance mufflers ?
  55. S&S breather reed valve
  56. Screaming Eagle active performance mufflers ?
  57. Bike died while riding in the rain. Carb maybe?
  58. Starting to get a tad pissed...
  59. SERT Where do you get the values????
  60. Cutting out
  61. need more noise
  62. sooted blugs
  63. thunderheader exhaust pros & cons
  64. Sportster Top Speed
  65. Post wash issue
  66. oil leak
  67. popping on decceleration
  68. stupid question re: K&N fitment
  69. California Emissions
  70. vtwin slip on exhaust
  71. Another Exhaust question!
  72. Life Expectancy of an 88 engine
  73. HELP
  74. Mileage w/ Stage I & Pipes???
  75. SERT tuner in NY
  76. Fuel line broke [:(]
  77. Installed V&H and SERT
  78. Samson Pipes?
  79. Mikuni Cable help
  80. Sporty dieing on me
  81. Fatboy SE11 to Deluxe
  82. Ahh, some good news for once
  83. 99 FLHTCUI fuel leak
  84. Help with tuner
  85. changing out the header pipes
  86. Loud pipe ticket. Backwards with exhaust...
  87. Anyone heard of these guys "Smooth Bore" Exhaust
  88. slip-ons between stock and SEII
  89. Fouling front plug on 1340 Evo
  90. Screamin Eagle Question
  91. sputters
  92. Anyone know Peacemaker Pipes?
  93. what exhaust for new street glide EFI 06!!
  94. 883 cv jetting
  95. 99 night train - carburated - SE high flow kit...
  96. How do I adjust my pushrods?
  97. 883 takes forever to warm up.
  98. Code U1016
  99. B&E performance modified stock mufflers, you hear of them?
  100. Hot Engine?
  101. Pipe diameter and sound difference?
  102. exhaust wrap, do headers get to hot?
  103. Calibrating electric gas gauge on 06 RG
  104. engine ticking
  105. loud pinging or cracking noise from engine
  106. Free-flow AC and rejet w/stock mufflers?
  107. Atwood Performance?
  108. Yost power tube?
  109. dynojet setup
  110. Stressin' out
  111. Need help with jetting issues
  112. Fuel Shutoff valve problem??????
  113. Pipes WTF
  114. ???’s for: Samson True Duals Owners.
  115. 98 muffler fit '03?
  116. 01 Sportster Sport 1200... Oil exiting Air Cleaner
  117. Exhaust 2-1 comparison
  118. Looking for close-up pics of the Big Sucker
  119. 100/100 W/Low CR 95"?
  120. Twin cam 88 cam chain tensioners
  121. what do you think?
  122. Rinehart 2 into 1 or True Duels
  123. Dual Exhaust
  124. mikuni air cleaner kit
  125. EFI warm up problem
  126. Any changes to the 06 TC88B?
  127. sicshovels carb
  128. Stage 2 Big Bore Kit Question
  129. New super trapp SE series slip ons
  130. 2005 pipes on a 1997?
  131. Who has considerable miles on a 95 incher
  132. trouble
  133. Which pipe is Louder?
  134. '99 Evo crankcase/flywheel assembly rebuild
  135. flushing gas tank
  136. Possible Probs w Powder Coating Head Covers
  137. Motorcycle Compression: How Much Should I Have?
  138. Slide ons for 2006 road king
  139. back fire
  140. Horsepower
  141. Leaking Rocker Boxes
  142. Need Map SERT
  143. Engine Compression..How To Check It (Revisited)
  144. front cylinder not fireing
  145. What air cleaners would you suggest ?
  146. Narrowed it down to Rinehart true duals or V&H PRO PIPE
  147. Custom Exhaust
  148. SE II's dumping baffles
  149. Front plug fouled...not the back one?
  150. Stock Cams vs SE-203
  151. samson bone shaker pipes
  152. Edelbrock heads
  153. How much HP
  154. air cleaner
  155. Should I put Drag pipes on my 06 EFI Fatboy/INFO NEEDED PLEASE
  156. rocker box leak
  157. Dyno tuner in Tacoma area
  158. Changing ths stock heads...
  159. '05 RG Front Plug @10,000
  160. S&S or Mikuni?
  161. LOUD PIPES or Performance PIPES ?
  162. Engine problem
  163. 2 into one or 2 ?
  164. COBRA SLIP ONS, ?
  165. 95" vs 98"
  166. story
  167. Porous heads?????
  168. Rinehart pipes, where to find them ?
  169. to install or not to install my new SE II slip ons
  170. Rush slip-ons/Remapping??
  171. Carb Gurus, I need some help
  172. Gas Running Out of the Air Cleaner
  173. Sealing Mufflers to Header Pipes
  174. SAMSON BIG GUNS 2 CANNONS
  175. Intake Hiss
  176. custom intake or adapter
  177. delete how?
  178. Pipes for Street Bob.....
  179. Anybody have Hooker Troublemaker Pipes?
  180. What exhaust to get
  181. Baffle removal?
  182. To put pipes on!
  183. Glowing Exhaust pipes
  184. Screaming Eagle Air Filter
  185. S&S Carb Jetting
  186. HD Lifters?
  187. Rear Cylinder Knock?
  188. Roadhouse Systems
  189. Exhaust coughfs on decell
  190. hey motorheads
  191. fuel mixture screw
  192. Hooker Pipes
  193. road king rear cylinder exhaust split?
  194. about reving
  195. 94 883/1200 Compression High??
  196. VANCE & HINES
  197. Anyone running edelbrock heads>
  198. Cycle Shack slip-ons, do you like the sound??
  199. Cold start engine light -- purpose?
  200. Screamin' Eagle Active Muffler Kit
  201. V&H Classic Slipons on 06 SG
  202. Front engine mount-vib
  203. Rejetting after new pipes are installed
  204. How Do I Get Rid of Carbon Build Up?
  205. Pre Igniton Knock at Start up
  206. Mechanics In Las Vegas
  207. V/H exhaust
  208. do you think I'm running lean?
  209. Mufflers for 2004 Road King Standard Injected
  210. Drag pipes and performance????
  211. D&D Big Boss Slip ons
  212. Can Gas Gauge Be Calibrated?
  213. Vance and Hines Big shot staggered w/power chamber
  214. Idle Speed Screw (need pic)
  215. Idle speed
  216. Carb rejetting advice
  217. Trak-Tek A/C...question about rejet
  218. Oil/Breather question
  219. Rinehart 2into1 anyone tried these?
  220. Hooker
  221. 04 softail missing under partial load
  222. Kerker Slip on mufflers?
  223. Fuel Tank Swapping
  224. What causes plug damage?
  225. can i get a new petcock
  226. idle screw on f/i
  227. Dakota Kid 48mm Delphi Throttle Body
  228. SE Exhaust 65115-98B
  229. Fuel additives
  230. another carb jetting question
  231. Miss/Backfire Problem
  232. The great exhaust debate
  233. Rear cylinder exhaust soot
  234. Best Sound for FLHPI
  235. BUB Rinehart Pipes - 'Repair'?
  236. ADVICE NEEDED: compression on a 95"
  237. Compression question ... please help.
  238. Fuel tank vacuum fitting
  239. what's better Fuel Injection or Carb?
  240. K&N RK-3909 vs. SE Air Kit?
  241. exhaust pipe problems
  242. HELP
  243. Fuel Guage - Calibration Marks?
  244. Open throttle sputter, again
  245. installing V&H Big Shots Long on Softail Deluxe
  246. Info on Rinehart Staggered 4 FXSTI
  247. sprocket shaft seal
  248. dyno tune worth it for a carb bike?
  249. Troublemakers Big Straight Pipes
  250. Dual fire coil question
