View Full Version : Exhaust System Topics
- Deluxe cam choice
- How do unadjustable rods and lifters work?
- oil leak at top pushrod tube after cam
- htcc heads / compression
- Cam tensioner shoes
- I made a mistake/Opinions??
- Cam Plate
- SE Pro Heavy Breather Intake
- Engine Vibration
- Thunderheader vs. Bassani
- Luvin my Supertrapp SE's!....pics
- 95" questions
- Sportster 1200 pushrods
- PCIII setup ?
- Tips for Exhaust Work
- New air cleaner
- Engine swap
- attention anyone power loss highway speeds
- Exhaust(ed) Confusion
- EVO Air Cleaner
- POLL -- Odometer When Cam Tensioner Shoes Replaced
- fuel pump removal??
- Amsoil power foam.
- Fullsac recored mufflers
- Dyno on carbed baggers
- Oil temp. high after cam chain tensioner change.
- Exhaust pipes glowing?
- K&N filter question
- Big Bore Upgrade - Stage I or II
- black hole exhaust
- Are the upgrades worth it? I don't notice a performance difference.
- My Gear Driven Cams Install
- POWERCOMMANDER MAP
- ironhead 1980
- SERT part number
- Exhaust flange replacement question
- Wrapping on exhaust baffles??????
- cam noise
- Sifton 140 cams....97 evo
- sound not wanted
- 07 SG exhaust....Best setup???
- Rush/Tuning/07 Heritage Help
- Rush slip ons
- FCC14 cams
- carb leaking on 83 Sportster
- the facts needed on cams tc88
- Dual headers/SE slip on mufflers?.....
- Canned Ham
- Question about Andrews 26G cams
- Fat Cat Baffle....how loud?
- V & H Big Shots Staggered ?
- air breather
- 97 evo skipping
- SE 16 Gauge Exhaust
- QHP HEADS
- help
- 2006 street bob . SE AC questions / parts list and #s
- Opinions of 07 Screaming Eagle mufflers
- 89 Police EVO question
- Stage 1 Download and Rush 1.75 Slip-ons
- hildreath heads
- too lean???
- Oil Pump Gerotors
- Tank Swap/FI-carb
- Woody's blower: Finally amazing results after 3 years!
- Pistons and Jugs????
- which cams?
- Cam diagram wanted for 1989 1200 sporty
- DYNO / PCIII Question?
- 96" with big bore 103" or 110"
- RINEHART SLIP ONs ?
- Part Numbers
- Andrews 37G vs HQ-0034-G
- cone air filters and rain ???
- SUPERTRAPP VIDEO CLIP
- LA Choppers Exhaust
- TC88B Cam Chain Tensioners....
- open element air filters good or bad?
- Exhaust "blueing" questions answered / myths busted!!!!
- The mufflers are on. no fuel optimizer yet, no remap
- Best Carb For a 95 C.I. Upgrade?
- Is this a Deal on 95" Upgrade????
- anyone know about the D&M brackets for forcewinder intakes
- Best place to buy OEM HD parts?
- V&H Ovals
- BETTER A/C???
- Vance & Hines question
- Compression test on a dry cylinder
- Rocker Box Removal, Lifters, etc.
- RB Racing Black Hole 2-1
- ?what oil do i buy??does it have to be HD,brand
- 07 exh mods
- Will I need a map or flash?
- anybody heard of this?
- From SE Slash w/Stage 1 to V&H Big Shot
- K&N 3909 kit
- Rush Slip Ons Question?
- A little help?
- Andrews 26g Question
- 2 into 1 compared to drag pipes
- Will these pipes fit this bike
- Rush mufflers
- i am ordering 2 /1 lsr black hole ,any feedback
- Thunder City Baffles
- Doherty Mistfree?
- Ness Big Sucker Stage I or Stage II?
- Looking a a Ness Big Sucker intake for a 99' king
- Confused
- Best Prices on V&H Pipes?
- SE Slip-Ons vs. HD Catalyst Slip-Ons
- Performance intake advice needed
- opinions welcome
- Modifying baffles—V&H Big Shots Staggered
- A/C Question
- Removing intake
- HD remap download?
- Difficulity To Install Chrome Engine Kit On FLHT?
- Backfire
- How many hrs to pull/reinstall TC96 heads?
- Kuryakyn pro hyper charger air cleaner
- engine knock
- Slip-ons for Deuce?
- reserve fuel
- Supertrapp SE series slip-ons
- stock o6 heads
- Harley Davidson slip-on,s mufflers
- Whats the best carb re-ject kit,for 1200 sportster
- Rinehart exhaust tips
- Power Commander Vs Race Tuner
- Exhaust Wrap
- knocking
- oil in my carb filter????????
- question??screamin-eagle,,2003 to 2004??
- Slips Ons for an 06?
- Which 2 into 1 for me?
- Performance of Rush Slip ons
- cam cover
- Andrews 26G tested
- Newbie... exhaust question
- python for xl
- Disappointed in new cams!
- Which cams to have dealer install?
- V/H SLIP ON'S
- Anyone make a "quieter" 2 into 1?
- '07 Touring Mufflers vs '06 and Earlier
- 07 SE RK planned upgrade question
- Exhaust ? Heritage and True duals
- Rinehart 2 into 1
- ENGINEERING DIMENSIONS
- anyone know about the doherty power pac
- Upgrading from 96 to 110 cubic inch Engine?
- Vance & Hines short shots staggered
- AN Big sucker question
- decrease db
- Comp. release ?
- im getting a little spit,,at a real quick rib???
- Python Slip-ons
- Broken stud
- Cracked Exhaust Header
- 2007 FLSTCI exhaust
- TIPS NEEDED ON MOTOR MOUNT INSTALL
- Screamin Eagle Race Filter
- Screaming Eagle air cleaner question
- 103" Time
- 07 96 jugs/pistons/heads on TC88
- Question on V&H Big Radius Exhaust Part Quality
- Break in of 95 Kit
- FatCat Quiet Baffle vs. Std Baffle ~ Test
- tw50 cams
- evo rattle 92 heritage
- V&H Fuel Pack & 06 Models
- 2007 Screaming Eagle Street-Performance
- TC96B and aftermarket exhaust
- Tech Bulletin M-1185 and vehicle configuration
- Tight Andrews Outer Gear Sprockets
- stock headpipe turning blue
- 07 RK w/ Rinehart. Rear header pipe glows
- 96 to 103 B.B Kit
- Needle jet instal question
- Road King: Supertrapp SE vs Vance & Hines Ovals
- A new Idea for your Harley Engines
- Air filter options
- Rejet?
- Piston Ring Question
- Forcewinder XR-2
- Exhaust wont fit right????
- PC III ?
- thinner head gasket
- sound
- Screamin' Eagle Slip-on from 2003
- Street Walker pipes
- V&H Long Shots
- 2 into 1 exhaust worth it?
- Vance & Hines Longshots
- Kuryakyn Hypercharger
- FXDL with Screamin Eagle/K&N Air filter
- Fuel tank Problem
- Engine / Primary rattle
- K&N Air Filter
- 96 Cam bearing removal
- new motor wont start 100" revtech
- 95 Inch Big Bore Kit - New or Bored Out
- All a bit confusing
- monster baffles and big radius
- Install complete...
- V&H Big Shots Staggard VS SE Slipons
- V & H EXHAUST
- what engine probems with an 07?
- How big can a TC88
- Flow difference SE -vs-Stock mufflers ??
- New 07 Rhinehart true duals question
- Arlen Ness , new fuel mgnt sys.?
- Necessary Mods???
- Sputter@3000RPM Help?
- heat shields
- Mikuni 42mm & Bassani Pro Streets
- New Kuryakyn Corsair air cleaner
- Problem with chain-driven cam vs gear driven cam on TC88?
- B&E Mufflers
- Has anyone used Fullsac duals?
- Making a basic tool kit... What tools?
- K&N HD-0800
- '07 Screamin Eagle Slip-ons
- 2007 96' to 103' motor parts list
- Pipes & Cams
- Noisy Top End
- Exhaust Change
- 2k4 motor parts on a '99
- fiberglass packing
- 95" dyno results anyone?
- Low Fuel Light at 125 miles
- Stock vs. HD Street Legal Pipes?
- RUSH Exhaust
- Pipes and ECM
- 1962 flh motor questions HELP
- tor becouse the motors back then can rust from the inside out .1962 flh motor questions HELP
- K&N RK 3909 vs RK 3910
- WTB burette ?
- TC 88 JUGS
- 07 stock vs 01 stock mufflers
- Advantge of aftermkt backplate vs stock?
- airfilters, K+N, Vs SE
- Slip-ons and nothing else?
- FLHXI exhaust choice?
- upgrade carb
- 95" cam?
- Oil Pressure Gauge Hookup
- Engine noise after gear drive installed
- Stage 1 with exhaust quote
- 95" build
