View Full Version : Exhaust System Topics
- 03 Flhtpi stock exhaust modification
- Elite 3 run direction
- No Mufflers - Problems?
- air filter cfms?
- Head-Quarters Build
- SE Slip On's
- Screaming Eagle Slip-on Pipes
- horsepower inc throttlebody
- kuryakin hypercharger
- 95" engine build quote
- intake manifold
- Diagnostic Help Need
- TC88/TC96 exhaust
- Enrichener
- oil leaking out of a/c
- fuel injection tank to go on carb bike...help please
- Evo Tappet Failure
- 2-1 exhaust clearance??
- Fatcat 2-1 vs. Bassani Road Rage for '03 FLSTS
- Heritage and V/H exhaust
- 03 road king classic injected high idle
- carb on 01 fxdl
- Quiet down VH true duals for softail Deluxe?
- Pipes glow ?
- Exhaust Decision Help
- New V&H Fuel Pak maps online
- A little FYI noise info with BCT baffles
- MORE POWER
- Hypercharger help
- Poor mileage - T-Max, Rinehart, K&N 2007 FLHTCU
- Need Crane Ign. Help '92 evo
- 2-1 megaphone or not??
- Andrews 37h cams and a TC96 Stage 1?
- need advice
- '92 Evo Has Me Stumped
- vh true duals awesome baby
- Exhaust ?
- painting exhaust
- STOCK PIPES PULLS LIKE RAPED APE
- Exhaust for Softail - Choices
- change end caps on v&h
- '03 Wide Glide Hesitation HELP!
- Fatcat for 08 bagger
- Big Sucker & Water
- Back pressure
- Rinehart TD's VS. Rinehart 2 into 1
- Best cam for stock heads?
- Where 2 get Rush exhaust?
- Need Cam/Engine Advice
- Price Check on Engine Work....
- Need V&H Fuel Pak settings for SEII SOs
- Night Train Rocker Boxes on Electra Glide
- how to start a motor
- Headers for a Shovelhead
- how long to install mufflers?
- Desition Time
- What would make flames come out the exhaust
- 2007 110" Screaming Eagle Kit usable?
- Need Help..going nuts!!!
- exhaust leak question
- stage 1 air filter kit
- engine problems I think need help
- O2 sensor change to wide band??????
- Carb sputter
- Push rod question
- 08 Heritage w/Rush 2.25
- need help starting problems
- carb. modification cv40
- Python Baffles
- help!!!
- Andrews cams 26g or 37g?
- Finding a cure for heat
- 12.61 AFR...lean or rich?
- Hooker Troublemakers No Reserve
- ENGINE BUILD ADVICE
- V&H BLACK LINE
- V&H Longshots fix
- slipons for dyna
- 07 Heritage Dyno Results
- Removed/reinstalled gas tank now it won't start
- fouled plugs
- Wont start, bad gas? wire on the coil, fixed it but didnt have a chance to run it
- lean mixture? signs in spark plugs
- Santee LAF exhaust
- Thunderheader vs. D&D Fat Cat ??????
- Motor Hesatating
- twincam - evolution
- Rinehart TD muffler clamps?
- Will i need to remap?
- Muffer Question
- Slip on slipping off!!!!!!!!
- Cylinder Studs pulling out
- SE Penna area recommend needed
- Rush Slip Ons Whistle on Decel?
- Torque value for SE breather line banjo bolts
- Installing Big Shot Longs
- Rinehart Performance Baffles True Duals - Touring
- air cleaner bracket keeps breaking.
- ROCKER NOISE ! ! !
- Info on needing exhaust questions answered
- Rocker Box Oil Leak
- Slip On Mufflers
- Rush slip ons pop on decel ?
- Blowing Intake Seals
- Exhaust Leak
- RB racing LSR 2-1 vs V&H propipe 2-1?
- So it's popping a little...
- BUB Klock Werks Duals
- 95 inch build
- 98" Bore
- looks like somethings missing
- HD Down Load for K&N Kit
- Hesitation or missing in low-RPM w/ heavy or mid-throttle pulling
- SEII for 08 Fatboy
- V&H Pro Pipe HS
- SE II slip-ons, who makes them?
- More PCIII help needed!!
- sound question
- another interesting exhaust consideration???
- loose baffle?
- Forcewinder vs Big Sucker
- Does anybody know
- t-man 625 cams
- Parent Material Cam Bearing
- Stage One With SE Air Cleaner
- Rinehart TD's Used Price?
- PCIII or Fuel Pack
- Andrews 37G and CR
- 1550 SE Kit SE203 or 204?
- SE stage 1 kit question
- Oil leak, Best way to degrease engine 03 Road king?
- Yet another CAM question
- Any problems with...
- is air/fuel mix 14.6 bad for bike?
- Silly question for you engine guys...
- 07 FLHTCU MPG
- Flames out of exhaust
- a totally unique motor
- need questions answered please
- V&H Decel "Flutter"
- A couple of problems - noise and a whistle
- help with build decision
- Suggestions on Jet size
- Bike running bad on reserve..
- 1983 FLHT Shovelhead 80 questions
- screaming eagle (07) baffle modification
- spark plugs?
- best slip ons v&h or rush?
- NEW HD Slip Ons turning blue
- '03 RK HEad pipes black w/slip ons
- Engine noise
- It's FIXED!!!
- 07 Fat Boy Motor Upgrade???
- Softail pipes on FLHX
- 1985 XLH
- Fuel Tank filter screen
- cams, Andrews or Woods??
- plug wire size??
- 15 months in Iraq, bike's in strorage. What exactly do I need to do?
- Screaming Eagle Slip-ons - will 06 fit on 07
- Poor low speed performance
- I need advice. Drag Pipe Question. Am I hurting my bike?
- Base gasket leak
- Bassani power curve clamp breaks
- Motor Kickback?
- Help on exhaust
- Advice on Engine Build
- cam?
- 103 Inch big bore question
- Broken stud update
- Strange sound from V&H
- Roller Chain Cam Advance?
- HD 96" heads on 88" TCB ???
- V&H vs. Rineharts
- Yet Another Exhaust Question
- Exhaust Question
- Heat shiled
- 2005 oil consumption
- Custom SE A/C
- 510 Cam change- Do I have to re-map
- Cam Noise
- Counter balancer knock?
- Hooker Tuned-Flow Mufflers
- 07 O2 sensor question
- Cam Install Help Please
- Gear cam kit question
- baffle question
- 103" Kit 2 Questions re: 07 Fat Boy
- Quick-connect fuel fitting o-ring
- Cam and gear kit
- 08 aftermarket equipment release dates
- Stalling
- engin run on
- 06 FLSTCI
- What's wrong with decel popping?
- TC 88 Engine Mods
- new paint set fuel sender etc. questions
- Bagger Pipes
- Question about Ness Big Sucker
- removing stock Harley carb
- long story short, question on jetting
- Cam selection
- 07-08 owners. Stock=lean=hot=blue?
- What's wrong with my S&S carb? Or?
- Does my buddy need a bigger Throttle Body?
- Ping/No Ping That is the Question.
- Shell Premium Gas
- Terry Components system ????
- HD part number for the 510 SS cam and gear kit
- open air cleaner and rain???
- Exhaust Gaskets for used true dual system
- 1340 EVO EXHAUST
- Anyone else think that your first 1000mi oil change/service is a rip off??
- popping on decel Screamin Eagle slip ons
- Need a stock exhaust system for a 96 Dyna Low Rider
- Stage 1 ?
- Gaskets...Cometic vs. James?
- How tight for the air filter cover
- ENGINE TUNER
- Baffle Removal
- Coughing / Puffing at Idle?
- V&H Turndowns -- Just Curious
- Re-tune
- Need forward controls for big radius??
- What to do if Diesel Fuel is put into your gas tank
- Made my choice
- Cam parts list
- Broken exhaust stud
- Any tips on changed baffles on Rush Slip-ons?
- Baffle Options - V&H SStraightshots Slipons
- idle increases when bars at full right turn?
- Possible Intake gasket Problem?
- Air Cleaner Question
- Exhaust for the new 2008 bikes
- 07-08 softail throttle body
- andrews 37g vrs woods tw6G
- Exhaust vs Waranty
- crankcase vent
- Stuttering engine w/open throttle
- Bassani power curve ????
- Stage 1 filter install for 08 models
- new exhaust 08 ultra ?
- Engine won't fire
- CATALYST MUFFLERS
- Who has pipes on an 08?
- SE High Perf. Heads with Compression releases
- Loud Exhaust
- How long could I ride my bike after putting new pipes on it without getting it re-mapped?
- Fat Cats, Old Bike
- HELP! back pressure, torque and EFI
