PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Bike Running Rough/Rich After Repair PCV
  2. Evo lifter block + lifters on a Shovelhead
  3. Vance & Hines chrome peeling off
  4. Baffles for Bassani pro streets
  5. New fuel management or re-map
  6. Stock 110 Questions????
  7. Engine Codes
  8. 2-1 thunderheader exhaust
  9. Harley davidson packaged exhaust flange nuts
  10. Less than 20 min warm-up = misfiring and backfiring
  11. Installed +4 cam gear and...
  12. new motor
  13. Adding Slip Ons to a CVO
  14. Woods lifters
  15. cam options
  16. Help Identify Logo on covers?
  17. adjustable pushrods
  18. Exhaust/upgrade question...
  19. Changing Exhaust from Supertrap to Vance and Hines
  20. 05 xl1200c upgrade help
  21. dtc p1353-ideas?
  22. Heli-Coil pulled out of case? Any fixes?
  23. Changing exhaust. Need help!
  24. exhaust flanges and gaskets
  25. Help me with my plan, just want a little more power
  26. Best performance exhaust
  27. Cam I.D. ??
  28. Where to look??
  29. Stage 1 question
  30. Power commander/exhaust question
  31. Hard to start new build ?
  32. Need pc3 map for 117ci Build
  33. Cam for 88"
  34. catalytic converter removed
  35. 07 flhx no oil pressure! help!
  36. What SERT canned map should I be using?
  37. Stupid Fuel Question
  38. TC 96" Push Rod/Tappet Blocks Leaking *PICS*
  39. Air Filter & Exhaust installation
  40. Compression test question
  41. stalling problem 06 SG S&S T-111 Carb
  42. Need help with '07 Sportster
  43. valve cover oil leak
  44. Error code p0263
  45. Need help...06 FXDL wont idle after tank install
  46. Only one exhaust working
  47. Vance and Hines Baffles..
  48. se120r v's S&S106 pros n cons
  49. Rinehart Churchills 2 into 2 & Roland Sands Air Cleaner?
  50. Rush Baffle Removal (Attempt) - With Video
  51. How much more power
  52. Can I use OEM pushrods with new heads/bore/ev27 cam
  53. Diagnostics dilemma... any ideas?
  54. New exhaust any suggestions....
  55. Thunder Header Tail Cone
  56. Road King Oil Indicator Light
  57. A motor flywheels in a B motor?
  58. my 88ci is running like crap
  59. Which ones are louder?
  60. throttle pak question???
  61. Engine Knock
  62. low idling and dies 2001 fat boy FI
  63. Bought hell bents - power cones?
  64. performance
  65. noy getting fuel
  66. thunderheader question
  67. Intake and exhaust pop
  68. 1987 fltc tour glide clissic. Recommendation for new pipes
  69. 2011-12 CVO Mufflers
  70. Dynojet power vision maps 2011 wide glide
  71. Spark knock
  72. 76 Iron Head running fine, now no fire
  73. new old bike. question about miss and s&s engine.
  74. Wood Cam Upgrade Question...
  75. Differences between 06 vs. 07 exhaust.
  76. SE 204 to Andrews 48 ???
  77. Engine Error Code P0131
  78. Oil blow back from breather area
  79. Octane boost
  80. VE tune question
  81. Major carb problem
  82. Who do you suggest for headwork?
  83. Engine sputtering and dying AFTER heavy acceleration...help
  84. s&s vs other brands
  85. Black Ops Lifter Bleed Down ?
  86. pinion shaft bushing
  87. Cam bearings
  88. Replaced SE Stage I with K&N - New Tune?
  89. S.E. 103 kit
  90. rear cylinder seems hotter
  91. Burning oil...no smoke?
  92. Oil Tank Pressure
  93. Best 2-1 pipe
  94. Jim's V-twin performance in Charlotte NC???
  95. 2006 FLSTNI Engine Perf Questions
  96. FXWG Drag pipes
  97. Age old problem but I have a question anyways...
  98. Rear wheel lock up
  99. What oil for a Stage IV 103 rebuild?
  100. too much oil on air filter
  101. k and n air intake kit and lower fairings
  102. pappie
  103. Removing the baffels on True duals
  104. S&S Stroker 106 question
  105. 95 inch 255 cams
  106. 103tc with too much compression! Looking for tips...
  107. True Duals to 2-1 without retune?
  108. Help woth 1340 softail prob please
  109. Head Pipes
  110. Backfire
  111. vibration from cams
  112. ultra passenger heat HELP!!!
  113. Right and Left Mufflers
  114. Stock exhaust questions.
  115. pingel guzzler
  116. DNA Heavy Breather knockoff
  117. Compensator Bolt
  118. ' 98 Carbed Evo issue.
  119. More power for 883?
  120. Northern California Mill Work
  121. Exhaust install questions
  122. Need help on cam plate upgrade
  123. Twin Power EFI Calibrator
  124. Fish tail advice
  125. 04 RK need more power, 95" SE or 97" S&S?
  126. New Tank Prep ??
  127. Decel Pop
  128. SE255 cam swap - bike seems louder at the pipe
  129. Decel Popping Solved the Easy Way!
  130. Stuttering 08 sportster
  131. puking oil!!!
  132. Leak Down - Oil leaking from air cleaner
  133. question about s and s 107
  134. cracked rear pipe part interchange
  135. CVO mufflers w/ 103 ci Stage II kits: high flow & good sound?
  136. Big bore vs superchargers
  137. 110 engine shutting down early, before redline
  138. 2006 Sportster throttle response issues
  139. Do I really need to drain the tank?
  140. No Power Bad Mileage HELP!
  141. 2002 Road King Codes
  142. head work
  143. 02 Sporty 1200 bogs sputters and backfires
  144. Fuel lowing outta carb overflow tube
  145. how much $ to Rebuild a 92 80" EVO
  146. This Is How you Make a Fish Tail Exhaust
  147. Touring at 100 kph in 6th - Can it destroy your engine?
  148. oil pressure fluctuation
  149. Andrews 37 ?
  150. +4 cam gear
  151. Fat Boy Lo is hot - make it run cooler?
  152. Stripped Timimg Hole
  153. Need Recommendations for Tank Cleaning
  154. Won't Idle
  155. Seep - Anyone Seen This Before?
  156. reinhart slip on
  157. proper pcIII map?
  158. All Units, Be On The Lookout For....
  159. XL1200 First mods
  160. changing heat shields
  161. Fuel question - -93 w/ethanol vs. 91 pure
  162. EVO 80: EV-23 Cam and Screamin Eagle Heads
  163. Sideshots vs Competitio​n Series 2-Into-1
  164. Recommendations exhaust 2012 RG CVO SE110
  165. What is durability of ceramic coated pipes
  166. piston fitment and engine noise
  167. Why 93 octane?
  168. Intel on disconnected o2 sensors?
  169. night rod blow head gasket twice
  170. 94 FXSTS 2¼ inch pipes
  171. Do I Have To Retune?
  172. Harley and stupid ticking noises. geeze
  173. super e tuning, need HELP.
  174. fuel problem need help
  175. Bike Cutting out while driving.
  176. Tell me the differances between the Mackie510g and the andrews 37g
  177. Ticking after new cams
  178. What's that noise?
  179. Bourget with engine stumble
  180. S&S 124 for 07 and up
  181. Another Cam Question
  182. Taking off Mufflers
  183. Re-Tune after A/C Cover Change
  184. fuel quick dissconnects leaking
  185. Road King Exhaust Options: Educate Me, Please
  186. Compression releases
  187. need advice on throttle body / injectors
  188. The Aliens have landed, or at least it sounds like it.
  189. Camshaft advice please...
  190. 80" evo back fire problem!!
  191. Finally getting the stage I'VE
  192. 96 Electraglide hard starting, bogging down, and dying when riding
  193. Engine Temp
  194. 2011 FXDWG tapping sound(s)
  195. Softail custom heads pitting
  196. Doherty Powerpacc maintenance
  197. Exhaust header question
  198. Lean smell?
  199. Short length turn down slip-ons?
  200. Grain Alcohol
  201. Tic toc 04
  202. Need help with limp mode
  203. Engine Upgrade? Help
  204. mukuni carb
  205. Brass pieces in Cam Shaft Support Plate/locked up oil pumpo
  206. Too much pressure
  207. no fuel from tank
  208. Digital Technician vs Tuner Kits
  209. Big Shot Duals
  210. Question about fuel moto quiet baffle
  211. 58mm throttle body vs. 56.7mm mounting plate opening
  212. 12' 1200 Sporty exhaust question
  213. 2010 FLTRX sputtering after exhaust removal
  214. No spaerk
  215. Fast idle
  216. FXDX stalling
  217. 91 EVO suns fine until cruise speed, then dies
  218. Exotic choppers fuelies
  219. Real Techs/Mechs must see
  220. puzzled on weird engine noise.
  221. Fat boy problems help!!
  222. Help,need knowledge before I tear it apart?
  223. s&s 510g
  224. Jetting XL1200S
  225. 06 street glide true duals
  226. Dilemma-Upgrade Engine or Trade it
  227. se255 cams and noise
  228. evo heads
  229. 2010 iron 883 exhaust ?
  230. High oil pressure
  231. 2006 night train
  232. Remove Slip-ons, Run Headers ?
  233. SE II inside diameter
  234. Carb jetting help. . . . guru needed
  235. The Best Gear Drive Cam for the 2012 Road Glide Custom?
  236. pops at idle
  237. Ceramic coating & discoloration
  238. Rebuild or go New? 1998 Road King
  239. Poor Fuel Mileage
  240. HD Dyna Slip On Mufflers/Rush Slip Ons
  241. stripped threads
  242. 96 roadking
  243. 06 Softail NT
  244. What size is the hole in CV40 slide?
  245. sumping
  246. Power Loss
  247. 58mm TB and .650 lift woods cam in a fatboy
  248. CV Carb Question
  249. Rinehart Question
  250. tell me i'm not going crazy!
