PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92
  1. BEWARE - fake Dynojet kits
  2. Gurgling sound from a kickstart
  3. EVO
  4. better performance for 06 Screamin Eagle Ultra Classic
  5. yet another true dual question
  6. gas comıng out from aır cleaner
  7. Help needed
  8. Exhaust slip ons
  9. 06 Dyna: hollow metallic ticking noise?
  10. Hooker Headers
  11. Vance & Hines 2 into 1 pro pipe
  12. new roadking needs exhaust help
  13. Fueling Cam Plate for TC engines
  14. Velocity Stacks
  15. Anyone tried the RK 3909 K&N filter kit?
  16. ssamson slip on leak help????
  17. Terry Components Terminal Velocity II
  18. Smoke under heavy acceleration..
  19. Whos Air Filter is This HELP
  20. 95" less then expected
  21. 04 Heritage
  22. rolling thunder pipes
  23. Small Exhaust Leak / Should I be Concerned...?
  24. cv jetting recommendations
  25. rinehart or vance and hines true duals
  26. samson rolled thunder or rolling thunder
  27. new 95 kit,10.5 to 1,htcc,pinging just a little bit?
  28. 06 XL 1200L Backfire w/68 Miles
  29. 2 into 1 Pro Pipe
  30. K&N filters?
  31. 06RK stage 1 help what will work
  32. Rinehart true duals cracking
  33. Slash Cut - Stock Pipes
  34. Porker Hatchets Installed
  35. Tachometer???
  36. Is it OK to...
  37. too cheap true duals/
  38. Backfiring
  39. oil blowing on oil tank
  40. Twin cam engine, A or B model ?
  41. 95 kit for 05 fatboy with carb
  42. BUB "JUG HUGGERS" Exhaust question...
  43. Help with Exhaust install
  44. Twincam 88 Expectations
  45. ????Advice on new exhaust????
  46. CV carb part#
  47. Exhaust question
  48. toss the clamps out that came with the V&H oval and use new TORCA clamps from HD??
  49. Torque Cones on a Stepped Pipe (True Duals)
  50. HOW DO YOU GET THEM OFF?
  51. Paint Removal from the engine
  52. fuel coming out of the aircleaner! 00 Fatboy
  53. first Harley, Oil loss
  54. s&s spo's
  55. 2nd Time This Has Happened
  56. Big City Thunder Baffles- SE2
  57. Rinehart/Bub Exhaust question
  58. reading a spark plug
  59. Any Suggestions??
  60. Kuryakyn cams?
  61. V&H Big Shots
  62. Stock vs stage 1 rev limit
  63. Screaming Eagle Slip-Ons
  64. enrichner knob
  65. Fuel inlet fitting
  66. s&s carb vs. stock cv
  67. white milky substance coming out of breather port on rear head
  68. super bowl accelerator pump parts for Super B
  69. Weber 45 MCHH
  70. S&S Or Andrews Cam Gear Conversion?
  71. Fatboy pipes
  72. V&H Quiet Baffles on...
  73. ENGINE NOISE
  74. V/H big radius
  75. Gear Drive Cams
  76. Samson Rolled Thunder Video
  77. Compression - front vs back??
  78. blue buster
  79. SE Stage 1 air filter
  80. Fuel Gauge Problems
  81. CV jetting with only SE pipes?
  82. Exhaust Installation not quite right...
  83. Upsweep pipes for a bare roadking/ will it work???
  84. SE vs SS air kits
  85. S&S Carb
  86. Low Idle
  87. SE II pipes on Street Bob
  88. Let's talk intake/filter kits
  89. Big Radius vs Big Shots Staggered HELP/ADVICE PLEASE
  90. Ride it to the Dyno
  91. SCREAMIN' EAGLE EXHAUST DISCONTINUED !
  92. S&S exhaust
  93. 16 Gauge baffles
  94. S&S Super E Intermidiate and Primary Jet question
  95. Dumb airbox question
  96. Other companies plan to design new exhaust?
  97. Straight pipe baffles
  98. 06 Dyna Cam Install"SE203"
  99. Python vs Rinehart volume
  100. washers
  101. Big Sucker Vs S/E Vs K&N A/Filter kits -- a winner?
  102. HP gains w/ new exaust
  103. PC111 or Vance & hines Fuelpak
  104. Exhaust w/o lost of low end torque
  105. Need advice on exhaust decision
  106. Maybe this one
  107. 06 Heritage Classic Dies Sputs
  108. Better torque with Vance &Hines long shots with Quiet baffles??
  109. idle mixture
  110. gear drives.wich one?
  111. fuel line leak?
  112. Which PowerCommander MAP for 2005 Softail
  113. Short shots / other 2 into 2 pipes
  114. Power adders.......
  115. Gas mileage again
  116. Poor finish on pipes
  117. Anyone Looking for SEII's for a Dyna?
  118. V&H Quiet Baffles....Warning
  119. Another injector victim??
  120. Fuel mixture issue? Is it the air cleaner?
  121. Dieseling problem
  122. went to dealer...
  123. never run out of fuel again
  124. rinehart VS vance and hines big radious
  125. Stage 1 Upgrade, Stock Exhaust?
  126. mufflers for FLSTSCI ...
  127. Stage 1 download???
  128. What do you think?
  129. Carb. only runs w/ choke on and no throttle...
  130. Big Radius specifics cause looks ain't everything
  131. Still learning
  132. V&H Classic Slip-ons
  133. 95" Dyna Super Glide Custom
  134. RB Racing 2-1 vs D&D fatcat
  135. 06 883 jet sizes
  136. Mikuni 42mm and AN Big Sucker
  137. Head Temp Difference?
  138. How to Identify Heads
  139. Ness Vs S.E. backing plate.
  140. Engine dies after 15-20 mins.
  141. Rinehart 2 into 1's anyone have one?
  142. muffler baffles
  143. High altitude trip coming up.......
  144. fuel reserve tap for EFI dyna
  145. Remap necessary question
  146. Dynatec FI Question
  147. Big Bore Kit Question
  148. V & H Big Shots Staggered baffels
  149. Running stock pipes minus mufflers?
  150. 1200 kit on my sporty got jetting question?
  151. Help! No engine light
  152. Heads porting stages w/pics
  153. Suggestions for exhuast pipes?
  154. straight shots / short shots
  155. Screaming eagle Stage one kit for EFI
  156. new v&h big shot longs
  157. which exhaust for best gas mi.?
  158. Digital multimeter with inductive pickup for checking idle speed $84.99
  159. Popping pipes?
  160. Rejetting question for an o4 night train
  161. Proper warm-up procedure
  162. beat to death
  163. 25 degree injectors
  164. Exhast/intake Question
  165. Self install issues need help
  166. How's a 95" 100hp/100trq engine ride?
  167. JIM'S 120 ENGINE LOW-DOWN
  168. Screaming Eagle Stage1 Air Kit + Water = ?
  169. BUB exhaust
  170. Twin Scan 88 Question for you Techs
  171. took engine apart and found...
  172. panhead cam shim
  173. Vance&Hines Fuelpak
  174. What is the Quietest 2 into 1 exhaust system?
  175. thunder monster baffles for v&h
  176. what kind of options do i have?
  177. Exhaust Wrap, How Much Do I Need?
  178. Very strong gas smell
  179. Exhaust Upgrade - EFI Question
  180. Important?
  181. Packing baffles
  182. Never Mind
  183. Vibration
  184. HELP, she won't start
  185. Sreamin eagle mufflers
  186. rejetting
  187. Full Pipe System
  188. Improving Sound
  189. Checking for Intake Leak??
  190. Exhaust - color inside pipe?
  191. SE Active Performance Exhaust System
  192. pipe confusion
  193. SE II Slip on Mufflers Only Everything Else Stock - Help a New Guy Please - Thanks
  194. exhaust change for the steet-bob?
  195. ironhead cranks
  196. Altitude and air/fuel mixture?
  197. Head bolts lose?
  198. How to? Has anyone ever put on Exhaust Wrap?
  199. Any Performance Suggestions ?
  200. HP question after a stage 1
  201. Thunderheader questions
  202. Ordering Jets???
  203. pipes for fatboy
  204. CV Carb restoration
  205. Spark Plug - Gloss Black
  206. Vance and Hines Baffles?
  207. HD performance heads ?
  208. New Exhaust
  209. New Pipe Question
  210. Am I running too rich?
  211. Air in-leakage in intake
  212. Fuel Line Leaking
  213. Super E and Super G
  214. bassanni sft-211tru duals on heritage ffse
  215. High mileage FLSTFI?
  216. To Dyno or not to dyno????
  217. Mikuni HSR42mm Carburator
  218. K&N air filter for 2006 TC
  219. WILD PIG BAFFLES
  220. hypercharger
  221. K&N
  222. Thundermonster installation tonight.
  223. TC88 question
  224. Cones or no cones on true duals?
  225. 29773-02B not blue?
  226. SEII slip-ons but no crossover??
  227. Mikuni Carb Jet and Intake Questions
  228. Not the blue filter!!!
  229. Big City Thunder - Straight Pipe Fix (Performance Baffle)
  230. Porker Hatchets
  231. SE Air Cleaner/Breather Kit
  232. A little gas leak
  233. Gas Mileage on 02 Fatboy
  234. oil in air filter
  235. using to much fuel
  236. Talk to me about compression.
  237. Strong Gas Smell After Shut Down
  238. Vance & Hines Shortshots for Softails on an 02 Fatboy
  239. Big Radius stock baffles vs. Thundermonsters.
  240. Which Locktite for Cam Gears?
  241. Jet Sizes
  242. Rinehart experience
  243. SE Stage 1 A/C, SE pro slip ons, PCIII
  244. Evo - Wet Sumping
  245. SE 203 cam replacement
  246. Open up the intake?
  247. 113 UPGRADE - 06 DYNA SUPERGLIDE
  248. Thunder headers
  249. V&H slip on's
  250. jet scream
