View Full Version : Exhaust System Topics
- Cylinders
- V&H Fuelpak vs Power Commander III ??
- Samson pipes Baffles, Cones, or nothing
- power commander
- Hawgs Breath Air Cleaner
- cam question
- Dyno Run info/ Questions about Andrews cams
- 07 Engine Temps
- Samson Exhaust
- Can I run my motorcycle with new exhaust before I put a fuel management system on
- LSR-Blackhole vs Supermeg 2-1
- Syn. on break in or not?
- )* air box sensor
- WHICH ECM SHOULD I USE?
- Looking to upgrade exhaust and get horsepower...
- 2006 FLXI Tank Removal
- can you do this??????
- Shotgun mufflers
- Fish tips change flow?
- Quick question about upgrading stock exhaust
- new se pushrods
- Big Breather problems in wet?
- Rebuild Start up
- 95" Kuryakyn Build - Tuning Help
- 2-1 performance exhaust question
- Great service
- Looking for a similar config and opinions
- Supplier who ships outside US
- Screaming eagle ultra mufflers
- D&D Fatcat
- Big Growl on '07 FLSTC ????
- poor milage 1200 custom 2007
- s/e mufflers
- screamin eagle slip ons
- Worn Cam Lobe:
- 2008 Stock Horsepower and Torque
- 2 into 1 worth change over 2 into 2 exhaust
- Size?
- Rocker Arm End Play
- Stock 2 into 1
- 95 or 96?
- HQ 500 Cams any opinions?
- SEII's or V&H straight Shot slip ons which sound better and why?
- 103 questions
- Help id'ing a cam
- TC 88 Heads VS TC 96 Heads
- D&M Customs Spear AC vs SE AC
- SEII's Do I have the right ones?
- Maybe the stupid ? of the day...but
- HELP, AGAIN--CAM TO CRANK TIMING, CHAIN CONVERSION
- Santee or Samson pipes?
- Red line on 88TC
- SE vs. Rinehart vs. Vance & Hines
- Noise from SE easy install push rods?
- Help, please, cam chain conversion
- cv carb
- o-rings
- Parts indentification for an EVO
- morepoweracing???
- Rinehart true duals and Stage III????
- Got a question that may be crazy
- HQ 107"
- 2008 FLHX 103: Do I need to redyno if I change pipes???
- Cam Part #.
- exhaust washer trick
- New gas tank on '05 Softail Deluxe
- flywheel assembly
- Need advice on aftermarket starters
- what does pinging or knocking sound like?
- Return of the torque
- anybody got a dyno comparison
- Amsoil Air Filter?
- xemco starters
- Indys near Idaho
- What is the cam lift of stock 88 tc?
- 25 degree injectors Retro
- building 88
- advice on 96"motor upgrades
- A few items For Sale
- whats needed ?
- 88TC build
- 2007 Road Glide Pinging?
- mods after stage 1 and exhaust?
- Touring 2 into 1 Exhaust
- Best new cams 21 or 27 for stock ultra?
- flex exhaust kits
- Rinehart/BUB prices going up?
- Pick of the litter , or 88 best year ?
- Cyl/Piston Kit Recommendation:
- Dynojet - Wide Band Commander
- Should I replace stock cams?
- big radius 2 into 1 exhaust
- Need Help Please
- Bit by a turbo bug... **UPDATED 3/21/08**
- ENGINE IDLE TEMPERATURE MANAGEMENT SYSTEM FOR 08 BAGGER
- 07 Fatboy Exhaust Change - Stuff needed
- 08 superglide K&N filter
- red exhaust coating?
- Andrews 26G Install Question
- what down load
- thunderheader
- New pipes.
- 08 Ultra Classic
- Head Gaskets leaking
- Has anyone used the Edelbrock kits?
- High Idle and Some Surging
- 2006 Dyna or later service manual for chain conversion
- Khrome Werks 3" HP+
- 103 Upgrade Parts Order Opinions
- Catalyst Mufflers
- ss carb throttle return spring tension
- Help identifying cams ?
- Just had buke dyno'd - change oil?
- V&H Slip-On's No Baffles
- Getting a pace maker
- Installing Drive Gears w/o a Press
- Screamin Eagle Street Performance Touring Mufflers
- Supertrapp 2:1
- cams & carb adjustment
- Aircleaner
- SE slipons
- ss gear drive timing
- oil pump inner /outer rotors orientation
- head question?
- Fuel gauge sender replacement
- High compression pistons vs. screamin' eagle heads
- Need help troubleshooting fuel/elect problem...
- volume of big radius
- Screamin Eagle HTCC Heads?
- HELLO, ATTENTION MODS
- SE on an 04 Low Rider...
- PC3 Accelerator Pump???
- B&E SUPER FLOW Street Glide performance mufflers
- t max bad mpg
- FatCat or SuperMegs?
- Spike air cleaner help?
- cheap upgrade
- PC III map help
- ? Screamin' Eagle Street Legal Slip-ons
- andrews 31 cams
- Question about baffles?
- Building stock 06 88
- 2008 Cylinder Head Question
- new intake without new exhaust ?
- Intake/ Air filter help
- Iriduum spark plugs ?
- Stock HD Aircleaner Vs. New.... Computer?
- IS 95" UPGRADE WORTH IT?
- S&S carb filter
- dresser duals adj. can't remove side cover
- SE HP oil pump cam plate combo
- 08 flhrc calipers
- remove packing?
- Comparing the 88" vs 96" eng
- S&S Head Vent Problem:
- Hard starting 88" evo
- bone stock bike/need cam advice
- Bassini pipes
- Little mod help?
- Does anyone know?
- ThD&D Fatcat Exhaust
- New engines overheating?
- Fuel stabilizer
- Stock Harley air fliter CFM ratings
- Bigger Petcock needed?
- rinehart slip ons
- 2002 FLSTF Carburated
- fatboy evo base gaskets
- Filter impact
- PClll, Dualls, Big sucker vs 103 kit
- high comp cams
- gas tank...
- 258 cams
- Getting it started
- carb top cover replacement...
- s&s booster kit
- andrews 26 and HQ0034
- Removing Stock Cams
- O2 Sensor Placement
- 510c
- Big radius 2 into 1 for older dynas
- should the carb slide be lubed after R/B
- V&Hines true dual $$$$quote from HD Dealer
- Fuel gauge removal ? - '02 Fatboy
- TAPPETS
- t-body
- Crank Case Vent Issue:
- Kuryakyn Pro R Hypercharger Installation
- new (old?) bottom end for a 96" twin cam from my 07 EG?
- Which Stage 1 kit
- Just got my pipes-question about fuel Mgt system
- bassani slip ons
- Crossover Pipe Removal
- BUB 7's & foot boards
- Cam tear down
- oil change help
- What is the best setup to increase HP & TQ to 100+ in a TC88
- Fatcat Questions
- Exhaust Baffels
- Wrist pins
- 2008 Street Glide Exhaust ?'s
- Gear Drive Backlash Measurements
- Air Filter
- oil pump gerotor
- D&D 2 in 1 fat cat vs Vance Hines Pipes
- What else needed with a cam?
- 2003 Heritage Cams...
- Rinehart Eagle Beak or Rush
- if your looking to get a pcIII for 2008!! look
- True Duals and Torque Cones
- 99 FLHR Misfire
- Exhaust Packing?
- Advice with cam selection 02 FLSTC
- Adjustable Pushrods / Stock Tubing
- Question on tuning after installing new pipes
- Valve To Piston Probs??
- rich plugs???
- BAD GAS???
- HQ-0034?
- Chrome engine kit
- anyone know anything about Rush exhaust?
- Engine Case Replacement - EVO
- Cams and Lift
- Need map for PC3 for 08 bagger with true duals
- Please help
- Build on 2007 RK opinions
- se throttle body???
- Advice on getting a 96 incher to 100/100 club
- Exhaust / Dyno / Idle Questions!
- SE 255 cam
- Top Breather/AC install help
- labor
- Cobra Mufflers
- Stage II Air Cleaner
- Pinion Shaft Bearing - EVO
- 95" upgrade has engine light on - need advice
- HOW DO YOU TELL, BIG BORE QUESTION
- another cam question
- Cam Chain Tensioners
- delete
- HQ is not selling carb kits anymore - who else for a needle?
- picture of exhaust flange
- I'm looking for an Indy
- Slip-on muffler resluts - measured noise
- fuel system cleaner
- Gear CAM Upgrade Video
- cam gears or not?
- oil in air filter
- rush vs vance hines
