View Full Version : Exhaust System Topics
- Backfire on startup?
- long storage fuel issue - bike will not idle
- noisey when hot
- Supertrapp 2 into 1 Best price?
- Rush slip-ons=fantastic!
- How tight to tight exhaust flange bolts?
- 2002 FXDWG Altitude Warning 4000'+
- 95 or 103 Screaming Eagle
- V&H Q SERIES DOUBLE BARRELL
- Cobra FI2000R O2
- Why won't The Harley flush mount fuel gauge work on a '02 and later Softail?
- milwaukee twins pipes
- Rinehart Black Tip Discoloration
- Need online supplier for Rush Mufflers
- Rinehart true dual install help
- Ceramic coating exhaust/baffles question
- Looking for round air cleaner cover
- CAM KIT QUESTION
- EVO loud Knocking
- Exhaust pipes on early FL's
- muffler gaskets
- Dobeck / Techclusion TFI-1440ST
- New Mufflers: Loctite, Copaslip...??
- Mikuni Carb Idle Screw
- NEED power commander map
- White Bros "E" Series 2-1 Exhaust
- BAFFLES
- Anti-Reversion cones
- Cold weather carb problem
- 1999 flhtci fuel lines loose
- RB Racing 2:1 Black Holes
- SE 103 Heads
- Anti Reversion Cones?
- Basic SERT Questions
- santee 2" y drag pipes "BAFFLES"
- Wrapping pipes?
- exhaust vs. performance ,get facts before $$$
- Quick question about VH Big Shot Duals
- Oil drain plug
- S&S Reed type valve breather for Evo
- Forged or Cast Pistons - which is best?
- Baffled by baffles!!!
- Crusher kits
- Turning exhaust tips on end of Big Shot Staggereds
- S&S Dealers
- super sucker use stock cover?
- V&H Dresser Duals
- 2007 Touring 2-1 Vance and Hines
- spark plugs
- What cam to use with SE 113 Kit ?
- Correct Loctite
- Info on Profile Performance in Warren Michigan
- Upgrading an engine
- Top End Clatter on 06 dyna
- Baseline Jet Sizes?
- Exhaust sound byte
- Too Lean?
- 88 Engine Build
- air filter comparisons
- 07 Stock Mufflers
- Spark Plugs
- Requesting assistance on VH baffles....
- oil leak need help
- Right side tremors
- STAGE 1 FLASH ISSUES
- Vance and Hines straight shot slip on quiet baffles
- Same old exhaust question? --HELP---
- Installing Quiet Baffels
- Is the oil leak on the front cylinder an "immediate fixer"
- Engine pop at 4300RPM
- Fatcat install
- newby question
- baffle ????? dumb ????
- sensor placement
- SLIP-ON MUFFLER LEAKS AT CLAMP
- SE Intake Manifold
- fly by wire
- Michigan Tuner Anyone???????????
- husher exhaust in daytona--open / closed-it works
- 06 injector question's
- Opinions on which exhaust to get
- Oil blow by
- rinhart duals,pc3,bigsucker
- waste of money --07 exhaust aftermarket
- 96 inch knocking or not???
- claimed 95" big bore, how to tell for sure?
- Looking for a preforming air cleaner
- Exhaust temp
- Best place to buy an Andrews TW37B cam?
- PCIII Map
- 95 vs. 103 with wild pigs (update after the build)
- Opinions on my 107 build.
- Re-jet????
- Oil Lines
- d&d exhaust
- Do crossovers make tuning easier?
- 89" stroker EVO
- Arlen Ness Big Shot? Opinions?
- Baffles too narrow for SE slip ons?
- TOO LOUD! exhaust silencers
- Motor stutters on acceleration.
- Boomcans - Exhaust - Where are they?
- Help!! emmission control device on 07 exhaust???
- V&H Side shots installed check engine light I should have tuned for stage 1
- Street Bob Exhaust....$30
- TC88 maintenance @ 55k
- Removing Baffles
- Rush Slip-Ons Installed - SWEET!
- Backfire on Decel - Carb
- true duels on an 07 rkc
- Fuel injection
- SE HTCC Ported heads opinions?
- V&H Bigshots staggered baffles?
- 07 fatboy/s/e air filter/D&D 2-1 fatcat exhaust/thundermax auto tune
- R&R 203 for which cam in 95
- Supertrapps 3" Int disc series dba ?
- K&N HD 0800 filter
- Amm-P3
- V&H Straightshots Slip-on Baffles
- big bore/cams
- 2:1 vs 2:2
- S.E. 95" stage2
- Rush Pipes
- Which oil pressure gauge ??
- Conversion from Carb to Fuel Injection
- Exhaust Mod
- Moisture in heads with Big Sucker
- Rinehart install..Pain in the butt...Another problem..
- Better Results
- Mikuni carb
- Dyna 88 Exaust
- Fuel Mileage after Stage 1
- mods needed for slip-on mufflers ?????????
- Rineharts installed...yellow pipe quick!
- fouling plugs..Disappointed need HELP please.
- GMR Performance
- short pipes vs. long pipes
- Touring Mufflers and Stage One Help
- check out this combo
- Spark Plugs: opinions please?
- crankcase breather suggestions, seeping (not a puking) issue
- Exhaust gasket questions
- Proper way to push in exhaust gaskets?
- Adding new parts question
- 07 sportster... the remaping nightmare
- Dealer 107 inch kit
- SERT part#32107-01F is obsolete
- 103 vs. 95 with SERT and Wild Pigs
- Wiseco?
- exhaust bolt?
- 06 exhaust change
- Carb or ignition problem?
- HESITATION
- v & h big shots short
- Piston to Valve Clearance tc88/95
- Stacking Baffles in VH Big Radius
- Leaking Rocker Cover
- Removing Baffles from V & H Big Radius Pipes
- Help, carb question.....
- Best Price On Oversized Gear?
- need '07 dyna build advice.
- thanks for all the help
- Looking for 100+/100+
- Recipe Thread
- What Exhaust for my -07 Night Rod?
- 100/100 build formula 07 train?
- SERT, BG3, Bigsucker I
- Exhaust Input
- My dyno run after HQ-0034G cams
- Thunder Monster baffles & Vance & Hines Big Radius pipes
- y long shots
- 10.5:1 pistons in a 98 roadking with fuel injection
- Big Radius/Thunder Monster Baffles
- Need More Power
- New, quieter exhaust wanted...
- removing baffles
- samson bg3
- Kuryakyn Pro-R Hypercharger
- Popping on decel
- TC88 vs TC96
- GMR 98" and HardKrome TRex?
- V&H Big Radius 2 into 1
- Bike hesitates on acceleration
- 2006 wide glide question
- race tuner or commander
- Pipes blueing
- Sale:New hippo build parts (silver SE heads)
- Python 2-1 exhaust question
- Exhaust Heat
- Please help with this question!!!!
- Cams or 95"???
- Camshaft belt drive
- 110" ENGINE BUILD
- Techlusion ECM opinions
- Cam Question for an 07
- 100CI X 100HP X 100 TQ
- UH OH! What happened?
- Stage 4
- Rejetting from #45 to #48 slow jet
- 07 Samson true dual map
- new fuel tank question
- 07 SG / 103 Build w/ HD 255 cams - comments ?
- my slip ons keep coming off!
- 2004 FXSTI fuel pump
- Bailey performance exhaust
- S&S Gear Drive - Gear Question
- Opinions on this build and price
- Dyno Done
- Ultima Big Growl Exhaust
- 07 96" build fatboy
- woods cams
- Samson Cailber True Duals on Ultra....Anybody?
- jetting
- 07 Dyno Results Question - Newbie....
- V&H Bigshots STAGGERED VS. Python STAGGERED DUALS
- Big Radius Pipes
- Need help with evo cam install
- 95" HQ Heads, HQ-0039 cams, etc.
- Baffle Replacement
- apology of sorts owed to some here
- S&S
- Which EFI controler
- FUEL GAUGE STUCK?
- Increased Oil Pressure
- Hippo build started with pics
- Lets Talk Cams?
- Bassani Pipes
- 2005 valve seals -- Damage?
- Rinehart vs. Rush
- Flag pole mount
- exhaust
- Ebay find, will they work!
- Drag pipe Leak
- FXDWG fuel tank r & r help
- Hyperchargers
- Air cleaner replacement on 2007 SE EFI?
- K&N RK 3910 install issue
- to rejet or not?
- Rocker Cover HELP
- Cam Upgrade
- Just installed Crane 6000 on '07
- Plug Readings
- New 2007 96" motor using pre 2007 Aftermarket pipes
- FLSTFI (FATBOY) Pipes
- EAGLE BEAKS by rinehart, BUB
- object in cylinder
- Deluxe cam choice
- How do unadjustable rods and lifters work?
- oil leak at top pushrod tube after cam
- htcc heads / compression
