PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. 99 Ultra cams????
  2. Axtell 107" in the works!
  3. put a ortho scope in my head to see my piston and wow!!
  4. S.E. Intake question
  5. 2007 96" t0 103" head questions?
  6. TV fuel pack
  7. monster ovels
  8. 87 flhtc
  9. 1340 rebuild
  10. Pardon my Noob-ish lack of knowledge.....
  11. Arlen Ness Big Sucker air filter replacement
  12. 96"/SE204 Combo With A Little Extra ?
  13. Stock 96" Cam Questions...
  14. 1989 FLTCU starter issue
  15. Removed Cats Need Help
  16. v-rod engine rebuild service
  17. engine noise
  18. Python Exhaust
  19. Bike idles like crap. cv carb totally redone.
  20. fuel pack
  21. Stage I limitations
  22. replace baffles w/ thunder monster baffles
  23. liner thickness
  24. exhaust=hp mind games?
  25. piston to vavle clearance
  26. Why does my SE 103 sound like the space cars from The Jesons?
  27. Exhaust crossover
  28. Thinking about a 107 build, would like some advice on options
  29. Feuling 525 cams
  30. engine noise
  31. 120r
  32. cam cover
  33. What Fuel Tanks fit the 80+ FLHT/FLT/FLHS bikes ?
  34. Question on tank swap
  35. CFR mufflers on Street Glide
  36. Cam Lift on Stock Heads / Valve Springs
  37. Looking for slightly more power
  38. Baffles
  39. just bough 76 shovelhead
  40. High mileage opinions
  41. D&D Exhaust baffle help please
  42. 96 CU IN 08 vs 09
  43. back to stock
  44. Mik 42 Advise required
  45. What air filter fits a S&S Super E with S&S cover?
  46. Screamin' eagle twin cam 103
  47. Help identify these pipes
  48. Wood 6-6 questions..
  49. flooded damaged V-rod
  50. Rattle from front cyl
  51. Cycle Shack exhaust vs Kraft Tech?
  52. fuel and spark management
  53. 2010 ultra blowby problems
  54. Just got my rineharts and pc-v!!
  55. 2003 running terrible
  56. 255 cam question
  57. o2 sensors on 06 train???
  58. What size are the stock W cams in a 2004 1200 C
  59. decel pop
  60. cam only, is it worth it?
  61. Removing catylictic converter
  62. èxhaust switch up
  63. Exhaust and Hypercharger on 2010 Softail Deluxe
  64. Cams and Lifters
  65. Quick Disconnect from Gas Tank
  66. Fall Away Adjustment-How Critical?
  67. Removing baffles from pythons ok?
  68. How hard is it to port and polish your own heads ?
  69. Just Wondering
  70. Tuner suggestions
  71. Best Tuner in Houston Area
  72. CFR mufflers on 09 SG with 103 stage 4 SE kit
  73. possible lifter failure "update"
  74. Question for the experts...
  75. Another Exhaust Question
  76. 2008 street glide
  77. 09 Touring exhaust advice
  78. looking for a good shop on Ohau
  79. exhaust question
  80. po133 ait senser
  81. Cutting out / Fuel strarved.
  82. Twin cam breather kit
  83. Best Tuner Shop in Michigan?
  84. Screamin Eagle heavy breather
  85. 2010 SG Exhaust
  86. Motor Build Up
  87. EFI explanation
  88. Hopefully not the same question
  89. Engine backfiring
  90. pro pipe bp rattling noise inside
  91. fouling plugs in 50 miles or less
  92. Engine builder/tuner?
  93. Just ordered Axtell 107 kit!
  94. Maine Motorcycle Noise Law
  95. Blue smoke
  96. Opinions on SE 103 kit
  97. rough engine
  98. k&n filter life
  99. pulling float bowl on SS Super G Shorty
  100. No compression on the rear cyl....
  101. cam-choice
  102. 103" bag 'O' marbles
  103. 103" screamin eagle big bore stage 1 kit...is it worth it?
  104. SE Cam - what's the differnece?
  105. Disappointing dyno numbers
  106. Need Help...Intake & Exhaust P-Rods
  107. Screamin eagle air intake
  108. Drag pipe question
  109. Air Intake - Cobra PowrFlor,V&H Drak, Screamin Eagle
  110. HD Motor??
  111. Need advice on rebuild
  112. 103 engine - clever marketing or real performance gain?
  113. new cam
  114. Lifter problems please help
  115. cam replacement?
  116. Cylinder Manuf. HD/Buell
  117. --Looking for info on head/cylinder removal/replacement on a evo
  118. Doherty Powerpacc question
  119. Lost the nuts for kmy rineharts at the head, what size/pitch are they?
  120. New b lifter won't fit in bore
  121. rocker Cover gasket.. 88inch
  122. dyna won't start
  123. 2-1 Install
  124. carb rebuild kit for 84 electra glide flht
  125. Throttle/Idle cables Issue
  126. HSR Woes
  127. 2005 road king starting problem
  128. Jackpot Powertube Muffler for 2010 Harley For Sale
  129. Performance Mod
  130. mikuni carb setup
  131. Doebeck performance
  132. Starts missing when hot
  133. 2 into 1 upswept exhaust for Dyna/FXR?
  134. Scramin' Eagle 2 to 1 Exhausts
  135. Lots of smoke on start up
  136. Who has the S&S 106
  137. gas puking out air cleaner
  138. SE Ventilator AC and Rain!!
  139. Small exhaust leak with new slipon
  140. O2 sensor question
  141. Road King sputters at 70mph
  142. Adding some back pressure to slip-ons
  143. Fat Bob Rush Slip Ons or V&H Slip Ons...What to choose?
  144. BIG Build?!
  145. Fat Bob Rush Slip Ons or V&H Slip Ons...What to choose?
  146. Is this possible?
  147. Fuel additive for E-10
  148. Cutting out at speed
  149. swapping exhaust
  150. Fuel pressure ,Computer,Injector,?
  151. Adding Paul Yaffe exhaust tips
  152. Is there an official HD list of dB (Sound) levels by model / year?
  153. 1999 Sportster with forward controls
  154. needle clip position?
  155. How is the header pipe on an 09' SG?
  156. Oil Leak?
  157. Hillside 117 finally done
  158. o9 roadglide
  159. True Duals, which ones should I go with?
  160. "Tweeting" Sound on Decel
  161. New cams, now ticking
  162. Back Fire - wasn't good
  163. Kings Dragway Top Honors
  164. Twin Cam 88b to S&S 106
  165. mikuni carb and ac issue
  166. New Woods Triple Nickel
  167. Fuel inlet broken on S&S carb
  168. Woods Cam noise
  169. Possible lifter faliure
  170. 2000 HD softail 88 cubic Wont start HELP ME PLEASE!!!!!!!!!!!!!!!!
  171. need help quick
  172. Woods Oil cooler kit
  173. 05 fatboy trouble
  174. V&H Customer Service
  175. 96 883 Backfiring, fouling plugs
  176. Front Exhaust Studs
  177. True compression vs advertised
  178. Heat question...
  179. What AFR?
  180. Engine Stalling
  181. Pushrod adjustment to address valvetrain noise?
  182. 02 Bung plug removal
  183. Wrapping and Unwrapping the exhaust
  184. TC96 TC103 Flywheels
  185. Potential performance gains by changing my exhaust?
  186. S&S tear drop air cleaner - performance or looks?
  187. Cylinder head
  188. Market for stock exhaust
  189. engin running hotter than normal!
  190. 883 to 1200 conversion pros and cons
  191. Inner Cam Bearing "Hole"
  192. Looking to squize out a little more HP.
  193. Stage IV Upgrade Questions
  194. Break In / Performance
  195. 09 road glide head pipes
  196. Valve guides problems... and consuming oil in a 2005 88B
  197. 96 Heritage softail cough and sputter!!
  198. arlen ness big sucker
  199. evo visual differences??
  200. 95 softail gas tank fit on a 98 softail?
  201. At-Home Setup of SERT?
  202. cam advice for 88 to 95 big bore
  203. Engine running rough
  204. Bassani 2-1 shorty meg exhaust - opinions needed please
  205. Erratic vacuum at idle.
  206. exhaust swap
  207. Timing marks for 96' EVO
  208. pushrod adjustment with dry lifters
  209. Oxygen sensor output
  210. install o6 efi on a 04 efi RK
  211. Beware of unfamiliar noises
  212. Keihin CV Fuel inlet elbow
  213. 97 FXSTC SE-11 cam questions
  214. Cams and gear ratio
  215. Evo engine - oil out one exhaust
  216. Fuel Leaking from bike, Please Help!
  217. Cometic (or MLS) head gasket torque procedure
  218. carb removal
  219. 88" Evo Rocker Box Gasket Kits?
  220. V&H Slip-on help
  221. Rough starts after 95" upgrade on a TC88
  222. Breathers blocked?
  223. tc 88 knock HELP
  224. overheating and engine noise question?
  225. Best comparison of pipes/a-c/hp/tq
  226. Longshots fitment
  227. 09 Road King Police stage 1 dyno numbers Help?
  228. Older MM fuel injection problems
  229. Samson FIT?
  230. Storing a bike - Sta-Bil FYI
  231. 90 degree "big Sucker" intake
  232. Are my plugs telling me something?
  233. True Duals
  234. 2010 StreetGlide Needs some Help...Desperately
  235. pushrod adjustments
  236. American Iron Magazine Build
  237. Ticking noise on cold engine
  238. no start troubleshooting
  239. broken exhaust studs
  240. Help Swapping Exhaust
  241. White spark plug ceramic tips?
  242. 1998 electraglide hesitation.
  243. What a strange noise.
  244. Gas tank interior is peeling
  245. Best 2 into 1 exhaust
  246. Engine Problem
  247. Do I need HD to do this?
  248. slip ons
  249. What can I expect from headporting?
  250. taking my pipes off
