View Full Version : Exhaust System Topics
- jet scream
- Stock Needle #???
- Rear cyclinder out
- Wild Pigs installed last night...
- Why is this happening?
- SE Pro "Torque" slip-ons?
- Octane Booster
- Slipons versus full install
- Stage 1
- V.H. vs. Cobra
- make it a little louder
- HD-0800 filter
- True Duals
- Modify stock muffs??
- Hard start when warm
- SE Pro vs SE Pro II Slip-fit Mufflers
- SE Slip-ons
- Carb, Cams, & Thundermonster Baffles
- rocker box leak
- 2-1 Exhaust
- any feedback on Bailey's Performance slip ons
- Cut-a-way Linkert carb photos
- Screaming Eagle Air Kit for Softail?
- cams?
- 16 Gauge Baffles Altered?
- air cleaner
- V&H Bigshots Vs. Stock Vs. SE pipes for soundleve
- gear cam retainer plate
- street bob and se 2
- Need some help with jetting mikuni
- Exhaust and Dyno Tuning...
- Popping on deceleration
- Air Cleaner for 03 Ultra Classic
- S.E. Heads, 10.5:1 pistons, other changes?
- 2000 Road King backfire HELP!!!!
- V/H slip-on's
- SE slip-ons vs. SEII Pro slip-ons?
- true dual install question
- Removing SE II Baffles..... How ??
- exhaust wrap
- need some help...please
- Don't skip this
- Changing slow jet..
- Crane Gear cam-S&S ovals-95"
- just changed plugs what does this mean?
- Just rejetted but no stumble when tuning.
- How does EFI and Carb affect exhaust sound? (Videos!)
- How do I get top off?
- OK To Punch Out Stock Baffles?
- cpmpression help
- WTK: Float Arm Adjustment - Up or Down?
- Baffles
- Fuel mileage check post-dyno...
- what air filter u rec. for v&h bigshot stag and powercomander lll for 06 dyna
- Stage one for FLH question
- newbie performance upgrade
- DR DYNO
- HELP: Popping & Backfiring on Deceleration With New Exhaust
- SE A/C KITS EXPLAINED?
- Champion plugs??
- Drill the slide or not? any opinons?
- Blue S.E. filters
- Hi! Looking for a little help
- big shots
- EFI temp sensor
- more BB questions
- installing sert
- ECM updates and the PCIII USB
- CONVERTING TO TRUE DUAL PIPES
- gutting exhaust
- Warm up recommendations
- Crank position sensor
- Best DYNO Tech???
- Jet size
- Buell question. . .
- PISTON HELP NEEDED
- back fire out the carb
- New Cam
- Cat's in the '06 muffler's (pics)
- Cometic gasket
- Exhaust End Caps - Ever Loose Them on the Road?
- Hard Krome true duels
- question Re adj pushrods
- SE slip ons
- Anyone tried Head quarters cams?
- Hello Im Tara and have forks need help!
- EFI to carb swap
- Popping when I decelerate..
- Air Cleaner
- blower ? for a roadglide ?
- QUESTION ON EXHAUST
- Tank removal
- 100 octane
- fuel pak
- street bob question
- Cam question
- Vance & Hines Dresser Duals?
- Inner Tank Lining Peeling up
- hpercharger on a 2006 fxsti
- Stroker Help
- Novice ?, but I'll ask it...
- JIMS H D ENG EXCHANGE
- Engine cooling fin Question
- Carbed Dyna runs out of gas
- Slip-On's
- yost power tube for fxst
- Bassani True Dual's, any good ?
- Long Shots on a Bagger
- bullet air cleaner
- Lean Cough
- Vance & Hines Turning Color After 4 hours
- 95" night train
- Question about Screamin Eagle
- 04 roadking new slip-on backfire, skipping,help
- Hemi Design heads
- slip on help
- Mikuni 42 ....ballpark
- Traveler is a "Road Master" now...
- Woody's Superchargers
- knocking noise
- Muffler Question
- 2004 Twin Cam Pros cons
- CARB JETTING
- CVO 103 head porting?
- Speeds Performance to dyno
- LSR 2-1 Exhaust
- Catalytic on stock exhaust?
- 2006 Dyna problem in cold weather
- General cam question
- Porker Slip ons
- need recomendation on S&S 546G cams
- carb set-up?
- Future engine problem?
- Baisley Spring on '04 Softail??
- They're not 05 heads !
- WTK: Painting Exhaust Heat Shields ...
- Stage I Rejet not good over 5,000 feet?
- Sounds
- RollingThunder
- stage1 air filter set up washing/riding in the rain
- poping on decel
- Evo Cam and Tappet problems - help
- What is your fuel mileage?
- Doherty power vents
- Tool Question
- SuperTrapp X-pipes experience?
- o2 port location
- Gas Problem
- carb question
- Faulty Valve guide seals
- True duals- are the mufflers interchangeable?
- Gas Ring Screws are screwy!!
- SERT Question
- Specific fit of Slip-Ons for an 04 Heritage
- Pinging on acceleration only under torque
- 95" break in questions
- 510G "intended" +questions
- TERRY TERMINAL VOLICITY II ALPHA N
- 1989 Evo Cam Bearing
- 2006 Dyna slip on silencers
- starting problems
- 06 1200c
- loctite blue for new exhaust install?
- idling problem
- S&S carb
- Baffles in or out?
- Carburetor Cough
- Excessive Fuel from Carburetor
- NEW 06 ULTRA How long shouuld I wait to change pipes
- 06 Ultra Calif. exhaust
- rejet
- Exhaust Torque Settings
- Rejet Question
- dyna exhaust on a softail
- Educate me Please
- Carb Question - How to remove linkage?
- newbie: derby?
- Spark Plug Question
- Need outstanding dynotune Tech
- Vance and Hines End Caps
- Q about an engine combo?
- jetting
- Rinehart touring slip-ons
- 29440-99c or 29441-99a???
- How to check your cam tensioners and add S.S polished bolts
- softail tank swap, HELP!!!!
- Dakot Kid carbs? info needed
- gas blowing back out of carb
- Single Backfire Issue
- DG Hardkrome true duals
- Compression Release
- 2 into 1 from RB Racing
- 06 Ultra Classic
- combo question for hd wrench
- Cam chain -adjusting shoes - gear drive etc...
- Best price on a thunderheader?
- Heat - moco vs Metric
- poor man's se air cleaner--stupid question
- USA Twins Dealer - Are they reliable?
- Anybody have any exp with these???
- Idle Mixture Screw
- SLIPON vs. SLIPON
- M&M EFI
- 1980 shut off when warm
- thunder header vs. vance & hines pro pipe
- True Duel headpipe kit
- Rinehart alignment- is it off or just me?
- Checking cam tenshioners
- Mikuni HSR 42 Install
- Follow-up to my previous post
- Dyna Scramin Eagle Muffler opinion
- Evo exhaust on TC88
- Replacing Butterfly Carb with a CV
- 06 heads on 02
- Life time warranty
- Take off engine parts/storage?
- "carb puking oil" 1990 dyna sturgis
- How to check Deck Height ... **Updated**
- Thining 95"er
- Mufflers for SE Ultra
- Choke not working at rejetting carb??
- No More Screamin Eagle Exhaust
- Big sucker & K&N
- D&D exhaust
- TC88B Oil Pressure
- Looking for a good dyno tech
- Please help identify Cam
- Carb rejetting
- V&H Pro pipe HS baffle Q
- 60 miles per tank??
- Sound Quality
- Ideas for crossover slip on muffler?
- Overlooked Performance Mod
- SERT help ASAP Please..
- Pushrod adjustment with hydro solid lifters
- what cam for revtech 100 is best
- SERT and Part Numbers?
- motor and exhaust questions!! 103 or 98?
- V & H Big Shot Duals
- venting gas tank
- Exhaust Port Gaskets - Need Advice
- EVO Timing
- K&N 3909 vs Ness Big Sucker
- slip-ons sans baffles versus drags
- Tailgunner exhaust pipes
- New 06 FLHT carb, too lean
- Intake options on RKC (EFI)
- Cam Check
- SE Hi-Flo kit install info needed
- SE 103 Part Number Breakdown for Engine
