PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. 103" kit stage 2 versus stage 3 or 4?
  2. Super-G vs. Super-G w/ Thunderjet vs. Mikuni HSR48...?
  3. 2009 Ultra Classic Pipes for 2008 UC
  4. AMSOIL Ea Air filters-dry filter option
  5. What Oil Pressure Gauge are You Running?
  6. LaRos Turn Down slip on-s
  7. 117 S&S and monster baffles...
  8. HQ 113 Dyno today
  9. what would the ideal AFR be?
  10. Cams to cool the 08's
  11. Help from anyone with a D&M Air cleaner
  12. Zenith/Bendix adjustable main jet carb.
  13. 883C won't keep running
  14. S&S Intake or Screaming Eagle
  15. 2000 Road King Carb Question.
  16. finned headbolt bridge
  17. Spark Plugs
  18. making 2 into 1 pipe. need some input...
  19. air cleaner?
  20. Skinned Cat
  21. rocker box sucking air
  22. SE 110" kit for 2007 NT
  23. Quick Exhaust Question?
  24. 09 Sportster Cutting out
  25. V&H Straightshot HS Slip-ons - 09 FXSTB
  26. help the ignorant (fuel guage wires)
  27. Jetting Help
  28. 95 Heritage 1340cc just quit
  29. 99' cam bearing info?
  30. Rough idle, stall, hesitation
  31. Heritage ON FIRE!
  32. Belt peeling, power trip to JD's Cycle Works...!!
  33. Sputtering Deuce
  34. Gas leak
  35. Really fast idle...
  36. Please Clarify top end loss with cam change
  37. Help! Engine noise
  38. Hooker tuned flow exhaust?
  39. 95" factory big bore???
  40. screamin eagle air cleaner ??
  41. zippers 103 muscle kit?
  42. New 95" kit with low power gain
  43. New cam or dyno tune = poor mileage
  44. Causes of Rod Bearing failure
  45. Piston Quality
  46. Big Sucker Cover Suggestions
  47. Backfiring
  48. 99 Roadking Exhaust Compatibility
  49. true dual question!!!!!!!!
  50. CO measurement at exhaust...what should it be?
  51. chain drive to geared cam ques
  52. Help with my CV carb
  53. Dyno numbers on new build ?
  54. switching from efi to carb
  55. Vandalism or Maintainence issue????? Check this out, all inputs welcom
  56. R&R 113" SE Build - Nearing completion.
  57. Oil Temp Gauge Install
  58. true duels wanted
  59. HELP! Problems with my 95 Evo running REAL hot.
  60. intake and exhaust for efi
  61. stage iv 103 problem
  62. wanted a 1990 or 1991 stock air cleaner backplate 29134-90
  63. Fuel leak problem
  64. knocking sound
  65. s&s carb, rebuild kit
  66. Centering Oil Pump
  67. V & H Big Shots Staggered
  68. stage II 103?
  69. Fuelmoto/Jackpot Exhaust
  70. Quiet Baffles, installed!
  71. poping
  72. EFI touring models remap question
  73. Exhaust Extras!!
  74. Backfiring Through Exhaust
  75. D&D Boss Slip ons
  76. LOUD pop at throttle up; occasional
  77. 98" hillside build
  78. Slow speed riding & knocking issues?
  79. Evo: Jugs, pistons and rods gone, looking for advice
  80. 08 Street Glide Exhaust
  81. 87' softail custom engine issue.
  82. SE Touring Mufflers
  83. porting stock throttlebody.
  84. Andrews 26 and SE Hybrid Cam Plate; DONE
  85. 2008 Train will not start
  86. SE Heavey Breather make more power than Stage 1?
  87. INA bearing took out my engine
  88. Which Exhaust
  89. Build with Andrews 54
  90. EFI tuning Nightrider style?
  91. $700 mistake?
  92. SE A/C install question
  93. Need Some Tech Help 08 Rocker
  94. Locktite on exhaust flange nuts?
  95. New SE Heavy Breather installed today
  96. TC88 and Woods TW6G
  97. LSR Prostock Exhaust
  98. money is tight
  99. Se touring mufflers 64985-07a vs fullsac 1.75 recore
  100. Bigger Injectors For Delphi System
  101. Supertrapp Fatshots 2into2
  102. stalling when hot
  103. New SE II Slipons, need to do anything else?
  104. screamin' eagle slipons
  105. ignition timing?
  106. Cranking Engine With Plugs Out
  107. Head Bolt Torque - '06 Softail
  108. 08 fxdc with V&H pc/pipes
  109. Looking for ideas for a "moderate" build on a Fatbob....
  110. 4* advance with cam
  111. inner cam bearings
  112. Blown head gasket
  113. Need gas milage info for 2009 SE ultra classic
  114. Exhaust question
  115. exaust questions
  116. True Duals hard to put on?
  117. Cylinder Head Volume
  118. High Compression Baggers
  119. Redshift 575 cam w/PC-V in '08 103 Need map
  120. Cam Chain Tensioner Wear Picture Attached 14.5K miles
  121. Thundermax question
  122. Base gaskets for 130 cubic in ultima el bruto
  123. Road King starter remove
  124. Cant pinpoint oil leak!
  125. power commander for new build
  126. From 88" to 95" story
  127. Any suggestions on how to make V&H quiet baffles quieter ?
  128. Fuel tank quick connect leak
  129. Out of whack!
  130. SE Slip-Ons and Stage 1
  131. street glide exhaust???
  132. Fatboy exhaust upgrade
  133. 4 degree advance on a set of 211's?
  134. Engine Popping at idle
  135. Gas Tank differences
  136. inner cam bearings
  137. Looking for shop to port/polish heads in Milwaukee area...
  138. Touring Slip On Help
  139. any option for making Supertrapp SE louder??
  140. I am confuse
  141. V&H short shots
  142. Sputter and Stalling at Idle '95 1200
  143. Fuel Leaking quick Disconnect
  144. Question - new exhaust install
  145. V & H Big radius bungs
  146. Valve spring compressor??
  147. Baffle rattle
  148. True Cost For Cam Change
  149. Fat Cat Baffle question
  150. Slip-ons Question
  151. D&D Fat Cat problems
  152. should i get it tuned again?
  153. Need some strange suggestions.
  154. Our 30-Tooth or 31-Tooth transmission pulleys
  155. Plug Color Jetting Issue
  156. Can I get a cam that will work now and later?
  157. Oil Pressure Check/ Gauge for TC88?
  158. Cycle Shack Mufflers
  159. shovel throttle doesnt throttle...? help
  160. Valve Spring Recommendations?
  161. Magnetti Morelli Question
  162. Gas Tank Rust
  163. FatCat vs. Big Shots Staggered
  164. SE Big Bore Kit
  165. Running lean??
  166. 2009 ultra - help
  167. Where to buy a big bore kit?
  168. exhausts
  169. 01 flstc randomly almost or actually dies
  170. Swapping out exhaust
  171. cam advice for all
  172. Stripped/rounded exhaust nut
  173. 07 Street Bob running rough
  174. HELP - Wanting to change V & H Pro Pipe
  175. how to tell if 883cc has been converted to 1200cc
  176. Bub 7 sound reduction baffle
  177. VH Big Radius 2-2
  178. Engine pinging.
  179. Easy for some, baffling for others (intake)
  180. Oil pump question
  181. Compression in cylinders
  182. Another pushrod question..
  183. Vance Hines quiet baffle worth it? Install problems?
  184. RSD air filted
  185. P1357 1358 code
  186. Willie G. LED fuel guage
  187. Diamond Heads
  188. Outer cam gear removal what tool?
  189. Swapping Throttle Bodies
  190. Baffles
  191. New Cam, Lifter Noise=Frustration
  192. Need Help w/ exhaust ID
  193. Need advice for rear header pipe install on '03 Glide
  194. now i know why the engine was popping
  195. Carb vent line
  196. pc3 set up for 95 inch with stage 2 ecm
  197. how can i put a cam gear back in place?!
  198. Rocker box leak Questions
  199. Top end engine 'tapping' '04 XL 883 to 1200 conversion
  200. Torque on Slip-on Clamps?
  201. remove exahaust baffels?
  202. Changing The build !
  203. What exhaust gaskets for Fatcat?
  204. Do I need the Wood +4 degree cam gear?
  205. 06 Street Glide ruff idle and hesitation
  206. True Duals and Fuelpak 08 RK
  207. Need some advice on labor time
  208. Question about exhaust wrap. HELP!
  209. 1999 tc 88
  210. help with exhaust
  211. oil tank pressure
  212. Exhaust Gaskets for Rineharts
  213. '08 Police 103" How much valve lift with stock springs?
  214. Stage one kit for 09 FLHCR
  215. Jet sizes for 06' RK custom?
  216. 95 big bore
  217. Engine Knocking on Decelaration
  218. heat 2:1 vs True Dual, Rinehart or V&H
  219. 2007 FXDBI engine wont idle.......
  220. exhaust removal
  221. HQ-TC-500-HC Cam Owners
  222. Doing it on my own...
  223. 1994 EG EVO Coil
  224. Strange sound under hard acceleration
  225. I lost my Race tuner
  226. Which Cam? Help!
  227. Ruxton Engines
  228. Good Tuner in the Midwest?
  229. Fullsac true dual
  230. Help, opinions needed
  231. head quarters pro tuner
  232. SERT Stuck With bike???
  233. RB Racing LSR Prostock Spyder exhaust
  234. V&H Dresser Dual Tips and Tricks
  235. stock exhaust gaskets
  236. Is it true..
  237. Screaming Eagle Pistons
  238. Arlen Ness Big Sucker stage 2
  239. Choke Help
  240. Witch of these 2 baffle is the quietest ?
  241. is there a screaming eagle air cleaner kit for a 1990 evo?
  242. Another exhaust leak
  243. Black Heads
  244. Glowing heads
  245. Cam and bearings advice needed
  246. Rinehart True Duals Question...
  247. Ignition Timing and Vaccum
  248. Adj Pushrod ? Need Help!
  249. After installing a big-bore kit, what do you do for the initial tune for break-in?
  250. Exhaust Leak!!!
