PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. new exhaust
  2. Ignition timing on high compression street engine
  3. Stage I, can I just buy a filter?
  4. Best place/price hydraulic cam plate & parts???
  5. 96 Cubic Inch ackfiring/popping
  6. this s&s is killing me
  7. Cam suggestions '08 RK police 103"
  8. 2011 Road Glide with Exhaust D&D Fat Cat
  9. Still have some tuning to do after the rebuild
  10. Rinehart TD - Flange Nut Question
  11. Twin cam 88 question
  12. heres my map whats wrong
  13. Reflash tuner after major work?
  14. Revolution Performance EMS Review
  15. too Quiet...
  16. Cobra Slip On's
  17. ready to tackle valve noise
  18. HD adjustable push rods for 103???
  19. HD Air Cover part number
  20. What is the best carb for a Sporty?
  21. Exhaust question
  22. Motor Build?!?!?!?!?
  23. 2009 SG to 2011 RG exhaust
  24. New Slip-ons for "11" FLSTC
  25. DOC or Cycle rama?
  26. Questions
  27. Dip Stick / Thermometer - FLHTCU
  28. TC88A teardown/rebuild with lots of pics
  29. 2004 Roadking cranks, no start
  30. final dyno report
  31. Carb related Q's
  32. Need help on the Enricher (Choke)
  33. Fatboy Carburetor
  34. Motor Conversion for a 45 Flathead Trike
  35. rinehart slip-ons 07 deluxe
  36. Bike surging??
  37. Symptoms of a lifter going south?
  38. Breather ?
  39. Short and sweet slip on question
  40. Samson Pipes
  41. engine Build questions
  42. Duece Tune
  43. rush slip ons
  44. Fuel in the air cleaner
  45. Harley Fish tail slip on pipes
  46. Rinehart 2/1
  47. 1978 FXST gearcase
  48. ThunderHeader mod
  49. 2007 Ultra Exhaust Pipes
  50. Hillside stage II headwork dyno report
  51. Pet cock problem ??
  52. having some issues... :-)
  53. Vance&Hines, PCV & intake
  54. Bike won't start...
  55. higher lift = less power?
  56. both rear exhaust studs broken help!!
  57. How to run more lean
  58. carb issues
  59. Newbie pipe question
  60. oil pressure wiring
  61. head issue
  62. Lowrider Exhaust
  63. 2007 Street Glide issues
  64. Need some input on new bike mods
  65. Tapered Exhaust Port Gaskets that won't Crush?
  66. cfr slip-on exhaust
  67. Really stupid question...
  68. HELP! Question about starter motor replace
  69. 05 ultra W/EFI exhaust question
  70. TMAN Stage 3 107 Dyno Numbers
  71. **** noisy valves
  72. Screamin Eagle Heavy Breather - sportster
  73. Softail Rocker stock exhaust cross fitment
  74. Softail Rocker stock exhaust cross fitment
  75. Harley Deuce Exhaust Port Head Bolts...Torque and Loctite?
  76. noob has another 81 question bout carb
  77. Rear cylinder lean condition
  78. Power Commander V Map needed samson true dual !!
  79. Oil Pump and bearing shot
  80. 05 Ultra engine problems?????
  81. removing power commander etc
  82. Adjustable push rods
  83. "explosive" popping sound when firing up
  84. stock exhaust
  85. LAF advice
  86. got a problem, coughing threw intake
  87. To dyno or not to dyno
  88. slip ons
  89. 1999 Softail problem carb stutter hiccup
  90. Rush or Screaming Eagle?
  91. recommended set up for ultra.
  92. Overheating
  93. surging and 02 sensors
  94. roadking took a crap
  95. Re-Packing the Baffle on a V&H Pro Pipe BP
  96. true duals
  97. Squeak when I let off the gas
  98. Joker Machine Air Cleaner
  99. need some help here
  100. Life of an EFI 96cid.
  101. Selling my 131 Cycle-Rama motor need help
  102. Started Can job tonight
  103. Power Commander map? 95", V&H true dual
  104. Your thoughts?
  105. 06 FLHRSI rough idle when warming up
  106. SE Compensator
  107. Is my jetting too rich?
  108. fuel filter, 2002 fxsti
  109. bassani pro street
  110. Bad/"New" fuel, IAC, or What???
  111. Am I crazy to do this?
  112. Screaming Eagle Exhaust slip-ons
  113. tman heads and cams
  114. tman heads and cams
  115. tman heads and cams
  116. Where to buy Herko conversion kit?
  117. High Idle issues with my 2006 Ultra Glide
  118. My Night Train and Bassani Pro Streets
  119. What have you guys used for bolt in cams?
  120. Slip-on Advise Please
  121. Dyno and new Screamin' EagleŽ Heavy Breather Performance Air Cleaner Kit
  122. Engine RPM Spike, Won't Return to Idle
  123. Herko, can you
  124. Oil pressure gauge??
  125. Arrows on Evo Pistons
  126. Oil Light Stayed ON after Oil Change
  127. 96TC Barrels & Heads on an Evo 80?
  128. Big City Thunder baffles, good or bad?
  129. Diagnosing a knocking sound - need help
  130. Thoughts on Direct Injection
  131. Changed Muffs. . Do I "really" have to redyno??
  132. Cam advice
  133. CV on an 80 cube Shovelead
  134. New to HD, need help!
  135. Dyno run-no tune
  136. Slight tickeing?
  137. Leaner?
  138. Old SE 3 1/2" vs. New '10 Slip Ons
  139. Exhaust gasket question
  140. 99 Ultra TC88 engine oil pressure too high
  141. thundermaxx vs hd fuel remap
  142. K&N 63-1122P Air Cleaner
  143. SE Pro CNC Ported Factory Heads
  144. Installation Hardware for Baffles
  145. Going Carb...
  146. does installing an after market exhaust void warranty?
  147. new harley owner, have ?'s about the tuning on my Vance an Hines piped cross bones...
  148. 98 fatboy fouling plug on front cylinder and turning pipe red. also spittin out black
  149. Dyno tune differences?
  150. Only 1qt of oil after service from dealer!! WTF
  151. Best Exhaust Gasket
  152. vance and hines exhaust
  153. Loudness
  154. Exhaust on 07 'Train
  155. new cams
  156. Quick Jet Clean
  157. Stock throttle body too small?
  158. DynoJet pull behind motorcycle engine Dyno
  159. carb overflowing
  160. Ride by wire issues???
  161. Sportster 48 yellow engine light showing?
  162. screamin eagle pro high flow air cleaner kit- for Sportster 48 2011
  163. 6R12pp plugs problem....
  164. Andrews TW26 10.0:1 ???
  165. Eagle hines
  166. fuel connection leaking
  167. Another 96 tc upgrade question..
  168. Heat Shields 1200 Sportster
  169. Throttle body cleaning spray
  170. Head work
  171. Replaced Front Motor Mount, Advice?
  172. 96 upgrade
  173. Wood 5-6
  174. Covington Hot Rod on dyno?
  175. Rinehart TD's in 4" or 3 1/2"
  176. Valve releaf
  177. Lifter's on a evo softail
  178. need input pleas
  179. Metal Shaving on oil pan bolt
  180. Pipe change
  181. Engine knock
  182. baffles that work
  183. 2011 flhtk exhaust mufflers
  184. Need to know!
  185. Intake Manifold
  186. Are Kuryakyn exhaust products re-branded V&H?
  187. '11 Fat Bob with V&H Big Shots
  188. Thoughts on this build
  189. 96cc build question
  190. '03 Road King, Andrews Roller Chains
  191. TR-625 At 10.75:1
  192. Swapping Screaming Eagle pipes for V&H pipes
  193. Is it any better then stock, if so how much
  194. Is it any better then stock, if so how much
  195. Question about V&H heat shields...
  196. Loss of power on heavy acc
  197. 06 exhaust for an 05 Dyna
  198. fuel flow problem
  199. 96 TC advise
  200. exhaustfor1997sporster
  201. loud knocking
  202. Vance hines fuelpac/xied combo
  203. TC 88 to 95
  204. Wrapped headpipe on bagger
  205. Oxygen sensor stripped
  206. Oil leak
  207. Samson Original Big Guns cracked
  208. Replacing cam tensioners on 99 RoadKing
  209. Gear Drive Cam Conversion Kit
  210. 93 evo backfiring through carb occasionaly
  211. Hesitation in 1st gear
  212. Completed top end rebuild and motor wont turn over
  213. S&S Single Bore Tuned Induction Kit
  214. 103 road glide no cat.
  215. honing revtech 100"
  216. Build done,,MANY thanks Hillside!!
  217. Another Fuel Moto
  218. Backfire and sluggish throttle!
  219. Blown head gasket trivia
  220. California emissions black box
  221. Dyno tuning question
  222. Headers for a Fatboy lo?!?!?!
  223. K&N Air filter part number?
  224. Stalling problem
  225. CFRs on stock headpipe.
  226. '09 Crossbones
  227. lunati cams
  228. Fitch permanent fuel catalyst - Miracle? Snake Oil?
  229. Road King develops a roar/grinding noise
  230. 94 evo intake manifold seal part #
  231. sert tuner set up
  232. Starting problems
  233. Lifter replacement
  234. Loss of power, fluttering sound
  235. Brand New FLHTK need guidance
  236. Limp Clutch Lever
  237. replacing stock headpipe
  238. Bad fuel milage and codes
  239. DIY Cam change completed with great results
  240. 80 db mufflers
  241. taking out evo engine
  242. Tach for Roadking
  243. Oil in the fuel tank ?? Please help
  244. incurable intake leaks?
  245. O2 sensor 2009 Night rain
  246. Question on compression for gurus
  247. 2000 road king police engine size?
  248. I think I got a bad rocker box gasket...Dealer is telling me it's the base basket....
  249. Please help minor smoke in new 96ci motor.
  250. Fuelpak on 2011 bypassing 02?
