View Full Version : Exhaust System Topics
- S&S Intake #369
- Rinehart vs Vance & Hines? Which is louder?
- Need tools for CAM swap
- O rings on Jugs, wait, that didn't sound right.
- bearings
- 96" Stage One vs a 103" Stage Two (Factory stuff)
- Terry Components Terminal Velocity II
- Removing Tensioners,are the Special Tools Needed?
- Do I need a new cam plate?
- Cams, and pushrods on an 08 soft tail????
- SE 203 cams
- Big City Thunder baffles
- Air filter kit question?
- need some advice
- Freedom Performance Exhaust
- supertrapp - Is this a good buy ?
- 95" Kit or ???
- Performance drop with baffles installed
- 2--3 FXD carburator removal
- Water in the gas tank
- Martin Bros Exhaust Info
- Good sounding injected bike?????
- My spark plugs look a little oily????
- If running rich..what color smoke would I see?
- Small end rod bushing
- andrews roller chain conversion kit
- True Dual Suggestions
- Help with Kuryakyn Hypercharger
- modifying stock big radius baffles????
- timer cover
- Rocker Support Plates and SE Pushrod Install
- CV carb tuning question
- Air Filter Maintenance
- 120 Ultima
- ReWorking heads
- One black exhaust pipe
- Mikuni HSR 42
- OK - How Quiet are Fatcats ?
- Kuryakyn Hi-Five?
- exhaust tone
- 2008 backfire
- Head Temp....
- Help with Vacuum line on CV Carb
- Cobra Exhaust
- shovelhead pistons
- Need help bike dies on the road
- superflow
- terminal velocity FM220Q
- K&N Airbox install question.
- woods cam
- '07 FLHRS Hard Starts at 160F and above??
- 110" SE heads
- Engine start-up after new build
- internal ceramic exhaust coating
- rpm specific clatter
- Where can I get a good price on Andrew Cams
- Silver engine painting BLACK?
- EVO motor question
- A couple questions...IRT SE street legal 103" kit
- differance in standard and performance d&d baffle
- gas smell in oil
- excessive heat fix
- Harley reman engine
- exhaust question
- Torque Cones
- Advice on Installing PCIII, V&H BRadius, SE I
- Cycle Shack baffle for SE mufflers?
- Indy's going to install Andrews 54
- Garage upgrades...opinions?
- Rocker C Upgrades
- TC88 CAM SWAP special tools needed?
- Anybody run a 44h andrews ?
- Special Tools
- DD FAT CAT warranty sucks
- Andrews 54H
- Softail Gas Tanks
- Engine "Overheat" Questions
- Excessive Engine Vibration
- S&S carb, which is idle screw?
- Popping on decel Harmful?
- cam bearings d'oh!!
- help a guy make decision
- How to Rid Tank of Rust?
- D&D Interceptor Mufflers
- S&S to HD Filter adapter
- shovelhead beauty
- Measuring compression
- oil blowby with new exhaust
- rush baffle size & hd download
- Hypercharger Install question?
- More Crank Runout Questions
- Switching K&N RK3909 to SE #29773-02C
- 08 Throttle Position Sensor
- 91 ultraclassic direct replacement engine?
- intake prefilter
- 98 FXDL Electrical???
- big sucker
- Intermittent valve noise
- SLIP-ON SOUND COMPARISON
- Big radius baffles won't come out?
- 204 cam/ sound difference
- D & D Fat Cat installation?
- BIG SUCKER A/C UPGRADE
- Best Bang for My Buck
- Fatcat scrape in corners
- big bore kit
- Timing Marks
- S&S High Flow Adapter
- Plugging the cross-over to the left side
- Heat shields kicking my a##
- budget 95 finished
- What is this for and other questions???????
- Gas Smell
- EFI Fuel Pack and altitude
- Gear Cam Whine - Lifter Noise
- Engine noise
- Bub 7
- Replacing cam cover bolts
- slight knock
- 08 Night train stock
- Tuned Exhaust's / Custom Pipes
- 07 engine light question
- Only a curiosity ........
- K&N HD 0800 air filters-low price
- Largest bore size for 88 TC motors
- V2P Clearance?
- Any info on Kuryakyn Crushers?
- Intake seals
- HELP... Idle cable problems
- V&H Big Shot Duals and Thundermax
- IF ANYONE KNOWS?
- change from 2 into 2 to 2 into 1 exhaust
- HOW DOES THIS LOOK??
- Turbo chargers
- Adj pushrods - any negatives about them?
- Andrews 54 cams?
- TAKING OFF FUEL TANK
- Twin cam piston deck clearance
- FXSTC full covergae heat shields
- Air intake kit
- TP Rocker Box Impressions
- Samson Caliber True Duals
- valve timing
- TC88 gear-drive conversion anyone?
- Wild Pig Pipes
- Longevity of blacked-out engines
- Exhaust swap and EFI
- PowerPacc on '08 touring?
- Ready to install new Mufflers, air intake and Fuel Pak
- Pushrods and Lifter Bleed Down
- 95 Upgrade build
- deleate
- Glowing head pipe ?
- Question on BUB exhaust?? need some info
- Round Air Cleaner with holes in the face, searching?
- pushrod question
- Peacemakers
- Slip On exhaust-4 different answers
- Do adjustable pushrods have to be readjustaed?
- V&H slip ons a little popping
- Question for the mechanics
- 95" kit do it yourself?
- Bad Gas, the liquid type
- Engine light on and off from bad gas?
- waking up the engine
- ANY GOOD BUILDERS AROUND ST LOUIS
- Exhaust ordered
- 44G Andrews Cams
- What Happened Here ?
- Air Kit Question
- 88 ENGINE UPGRADE
- Start up engine idle - what is it
- Spark plugs replaced now gas milage down
- Bub 7 exhaust
- SE air filter vs K&N filter
- V&H Pipes / Thunder Monster Baffles...
- OK, so I'm cheap, stock pushrods.
- Andrews 54N vs 37N
- Yost Power Tube CV-40 Master kit... any thoughts?
- Slip Ons without remapping???
- rattling noise-top front of engine
- big bore or stroker
- Exhaust Recommend for 08' Deluxe
- Exhaust Leak..need advice
- Oil pump torque specs
- Custom fit pipes?
- Andrews 54G cams ???
- Rocker exhaust??
- Fitment???
- screamin eagle 2 mufflers
- S/E AIR FILTER?
- 2007 fxsdti and 204 cams
- Bassani Road Rage
- 95" stage II upgrade worth it?
- Build is done now what will a daytona twin tech do for me
- 90 degree intake
- ? about kuryakyn hi five air filter
- DD FAT CAT sound like birds chirping softail
- indy around st louis for 107" build
- DD FAT CAT Help softail
- Help decide on Exhaust
- SE Billet Rocker Boxes
- carb tuning question never covered
- Gear Cams...Shaft run-out?
- 08 Fatboy 107 Modifications
- EXHAUST HEAD TORQUE SPECS?
- cam cover
- Question about Porting my heads on my 96er
- Screamin Eagle II on 08 FLHR
- BIKE SHUT OFF ON FREEWAY
- ATTN: Engine Experts
- engine work
- compresion
- dyno on a fresh engine
- Check your air filter bolts
- 2000 Buell cylinders on a 2003 883?
- exhaust pipes
- started up rebuild last night front cylinder seems hotter
- Here's the Estimate
- Dazed and confused
- 08 RK overheating
- Thanks to Big Boyz for a job well done
- baffles for v&h staggered s/s
- Rocker boxes
- budget 95 build
- all confused SE AC
- oil pump alignment tool
- Gettin' the most from my '02 - 88
- Rebuild Start up procedures? 2 versions
- Pushrod issues bent or incorrectly placed - damage?
- D&D Fat Cat standard vs. quiet baffle
- 07 Softail Deluxe /V&H True Duals /Fuelpak 61001A
- S&S 510 or 570G Gears?
- gas tank
- Help!!! 6 speed DD6 on 04 Classic
- best price on d&d pipe
- breather ?
- 2001 FLHT 95cc looking to change
- 95 upgrade results,thanks
- Cam chain tensioner repair kit?
- rocker box stud question
- black vance and hines on black bikes?
- base gasket
- Blue vs. Gold on chrome pipes
- Bassani??
- What is the most affordable and reliable engine upgrade for 100TQ/100HP?
- Compression Ratio?
- HP and TQ penalty
- Need football replacment
- Cylinders
