View Full Version : Exhaust System Topics
- 05 EGC fouled plug
- Is it possible some of the stage 1 cooling improvement
- exhaust type
- New stage 1 Air Filter
- Fuel leak
- Anyone running Cobra mufflers???
- Georges Garage, ROCKS
- Engine Ranges
- Reinhardts versus Bassini True Duals
- Cold Start Problem
- Head Porting
- Need Help! D&D, Thundermonster, Puking oil from air cleaner
- SE pipes left and right baffles
- Just put some new pipes on my softail fsxt...look!!
- Question for '07 & '08 Stage one owners
- Exhaust mod only...
- Kieth Black
- Pipes, Sizes, and sound?
- Pipes got rubber sole stuck on them
- Sportster Exhaust
- Rhinehart TDs - Wrapping baffles?
- rinehart heat shields
- Newbie needs help w/2006 Electra Classic
- Nostalgia Cover
- stock pipes and baffles....
- ZIPPERS Intake Part Number
- Help copper tip
- How to tell which SE kit installed on 02 RK
- V & H Big Radius 2 into 1 - Any one using?
- Rev limiter
- S.E.filter
- Best method to brake in a new engine?
- '08 Dyna Super Glide Custom question
- Carb Popping Maybe????
- Pipe benders.....
- What's up with all the cheap 95" kits on FleaBay????
- SE Air Kit Filter vs K&N Filter
- Compression Release ?
- 97 FLHP cam
- Will baffle change require new download?
- 2008 FatBoy engine question
- How Fast
- Put on True Duals - REMAP???
- Embarrassed about popping, could use expert advice/help please
- Mikuni T 40 vs. HS 40
- Velocity stacks w/filter
- Rush Pipes
- Could this be my prob.....
- Exhaust Ring Torque
- rush baffles
- Cam cover
- Very mild decel popping with Fuelpak
- BUB (Rinehart) 2 into 1
- loud
- 07 fatboy Exhaust upgrade???
- SLIP-ON EXHAUST QUESTION
- Rear Cylinder no Combustion
- will 96" jugs from a 2007 fit on an 02 Dyna?
- S&S 124 Exhaust Recommendation?
- Uneven sooting of mufflers
- Big sucker- cracked
- Do K&N filters ever go back to red???
- 2007 Street Glide Exhaust???
- changing pipes- how to
- Vance & Hines " basic " slip ons ??
- Exhaust bracket on 07 SG
- Build ??s
- New air filter setup
- dumb question
- head temp?
- POWER COMMANDER ?? OR OTHER
- CAMS for a 03 low rider
- D & D Exhaust ?
- Stage I and re-map ???
- run right
- Reinhardt TD Sound ? ? ?
- Stock 2007 muffler question
- new h-d cam plate
- PSI Genesis/MC Advantages Big Air
- Oil Leak from Breather
- Suggestions for Slip on mufflers
- hp and tq
- Left Pipe and Right Pipe
- S & S carb plate sticks need clear detailed diagram
- Opinions on Street Sweepers and Rip Saws
- adj.pushrods oil leak
- just wondering
- big sucker dry or oiled?
- Running rich and fouling plugs, Mikuni carbs
- gear drive or conversion roller chain cam
- 90/90 on a 07 Fatboy. What do I need?
- carb jetting almost perfect
- What the HE.. is that pinging?
- FYI on Roadhouse brand exhaust
- Cleaning Filter
- My cams are out,,, major damage what now?
- Fuel leak @ fuel sending wires
- Mikuni 45 Choke
- Air Cleaner
- stock exhaust
- Burned/Hole in Exhaust Valve
- 06 Ultra exhaust question
- Hot idle miss
- Will changing baffles require new download?
- Can't get it to stay runing WTF????
- AN BS- Am I the only one this is happening to?
- se255 cam
- Dyno settings -- adjustments?
- carb.
- '08 info needed
- Fatcat install / need help please
- installing 50mm throttle body .Tips?
- Torque Cones
- I have a foghorn in my exhaust
- Oil pump rebiuld
- Best fitting headers for 2007 Ultra Screaming Eagle?
- Okay obvious newb question
- engine oil leak
- Are carburetors the way of the tuner?
- Removing baffles on SE pipes, slight problem
- Hard Starting
- Supertrapp 2:1 supermegs on 07 SG
- Making a 2 into 1?
- its still vibrating...
- Does 2 into 1 run cooler ?
- Installing baffles
- CARB LOGIC
- V&H 2 into 1 big radius------anyone?
- ?!? S&S E-Carb Adjustment ?!? Jet change?
- Intake leak test ?????
- Which Gasoline Station do you go to... Florida?
- What Cams should I buy
- LEAKDOWN TEST ?????
- NEW CAM on 07 - NO REMAP!!!
- oil leak
- 97 evo cam
- Exhaust Question
- eadSE air filter cleaner
- Modified rush baffles
- Torque Cones
- Hooker Fourbidden Performance--anyone?
- Question re: stock pipes fitment
- Crankcase Pressure?
- OMG, I thought that was all in my head...
- Big Boyz head porting
- fuel pak map??
- HELP,,,,, I could cry,,,,,
- Binning O2 sensors...
- The new screaming ealge mod
- Football air cleaner
- Tornado Air kit in the rain - how does it perform?
- Got engine noise - p'd off
- True Duals -vs- Stock Headers
- upswept pipes
- My Propipe is getting annoying
- remapping after slip ons
- Help! Mystery part during rejet
- what's going to be the best way
- cylinder firing
- SE Air Cleaner P/N 29440-99D???
- cycleshack slip-ons ?
- engine rebuild
- exhaust question
- Exhaust
- Choke broke
- Chrome plated exhaust clamps
- Carb Probs on my 99 Sportster too much carb?
- HELP! Can't get things running right with new jets.
- Good cam install "How To"
- Making Stock Exhaust louder?
- Cam Chain experience
- Harley factory fuel maps
- Sealing up a Pro Pipe?
- Anyone ever try this stuff?
- delete
- Do I need my bike re-dyno-ed?
- Stage 1 for Carborated Fat Boy
- Terry C. Doc is back
- '08 --Any problems ie trans or heat etc.?
- Dyno'd and Need help finding air cleaner cover
- Fuel Purifiers
- Part numbers! anyone?
- fuel enricher
- push rod tube clips question
- Engine builders experience with cylinders & sleeves beyond 95"?
- Screamin Eagle SE43 EFI Induction Module Kit
- fuelpak
- C/V to Mikuni anyone ????
- V&H slip ons or CycleShack slip ons?
- Revive your exhaust gasgets before re-install
- Lagged power following Jetting--Problem solved
- Popping on deceleration -- problem solved
- Going quiet [Update]
- will this work?
- i NEED EXPERT HELP FOR THIS ONE
- true dual header pipes
- Rush Baffle HELP!
- top end parts
- Top end noise
- TC 88: Remove Baffle in Screaming Eagle exhaust
- New SE Touring Exhaust with the A suffix
- Hooker slip ons without tuner
- AIR FILTER ELEMENT SERVICE
- bassani exhaust
- baffled by quiet baffles
- Front Stabilizer Link
- gas cap problems
- S & S Intake
- Baffle sizes?
- 2008 harley performance upgrades
- whistling pipes
- Timer Cover Screw - Broke!
- Backfire/frt cyl '92 Fatboy
- Hesitates under hard acceleration at highway speeds
- Rinehart True Duals Chirp or high pitched rattle
- melted sensor
- '05 Fatboy vacuum operated fuel valve
- 2008 - FXD -SEII Exhaust or NOT ? is the question
- 96" Motor Upgrades - Anyone done any yet?
- update on nightster
- Doherty PowerPACC
- Rough start
- Jetting??
- air cleaner and remap only
- What the heck is a stage?
- S&S CARB HELP/ENRICHER
- Exhausting
- Oil BLOWN out Breather Bad
- evo puffs a bit of smoke
- 04 Road King is missing bad most of the time
- Vance/Hines True Duals - 07 Softail
- Deuce Fuel Filter
- Basanni power curve?
- Got my cylinders & heads diamond cut! WOW
- exhaust leak from head oil? gas?
- I don't get it - no closed loop system on an '07?
- Inverted Sensor
- Slip on sealer
- nightster died
- Need expert help. I know some one can help me.
- Installation INstructions for D&D Fact Cat 2into1
- Screaming Eagle slip on with the 2007 engine??
- Tappets
- true duals?
- How loud?
- Can you identify this part #
- TC rocker box bolts
- Dyno Basics - Help
- help w/ stage1 kit ?
- Ruch Pipes
