PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. 88 to 96 engine mod.
  2. On-line store for Rush mufflers *with* tips ?
  3. Rinehart flush style noise levels
  4. SE High Comp. Cast Pistons
  5. Dyno Power Exhaust
  6. Rush torque cone ?
  7. Carb misfire at low RPM
  8. getting a little nervous...
  9. Difficulty and Exhaust
  10. GMR 107 kit
  11. mismatched heads
  12. TC88 chain to gear drive
  13. New 07 Ultra
  14. 95" Build
  15. 07 Ultra Ping
  16. Cheater true duals
  17. 4" baffle vs 11" baffle...need advice
  18. Super Trapp Exhaust 2 into 1
  19. More I read more I get confused!!!
  20. 03 Sportster 1200 heats up then shuts down completely! Help!!
  21. Anyone have any heat shield tips for Basani power curve?
  22. 4 Degree Advance Cam Gear/Key
  23. air cleaner question
  24. BigBoyz
  25. PCIII Question
  26. best places to buy D&D EXHAUST thanks
  27. '06 Wideglide still runs rough..
  28. Hesitation/deadspots
  29. 04 Sportster Carb Jetting / Running Rich
  30. 07 Springer New Exhaust?
  31. Air cleaner suggestions?
  32. cams
  33. Champion Spark Plugs
  34. Displacement
  35. screamin eagles to Rinenharts qustion
  36. Thanks DOC1 for the info!
  37. Python 2:1
  38. V&H quiet baffles
  39. Hey Engine Builders!! Am I at the mercy...
  40. Rush Slip-On Muffler Question
  41. Help...D&D Fat Cat for 2006 Roadking
  42. s&s carb question
  43. 95" build Dyno results
  44. k&N filter
  45. file fit piston rings
  46. Gear Drive Install - Gear Lash??
  47. DFO settings-2006 Ultra
  48. Anyone running with Peacemakers?
  49. SE Slipons
  50. PUSHROD HELP!!
  51. V&H Big Radius Questions
  52. Help... Pinging on 95"
  53. Broken off bolt
  54. Uneven exhaust discoloration
  55. Rush Pipes
  56. Gas Tank Removal
  57. chirping from exhaust
  58. Engine troubles, fast idle
  59. Sealing Rush slip-ons
  60. What Tuner???????
  61. Fuel Tank Removal
  62. 1000 mile service after engine build?
  63. Exhaust Question?
  64. How to improve '06 TC88 Dyna performance?
  65. How Hot Can You Run A Twin Cam Without Damage
  66. Rocker Box question
  67. FITTING WRIST PIN TO BUSHING
  68. Air Cleaner Nightmare
  69. Air Cleaner Nightmare
  70. TEST
  71. Doc...or others...question on timing tables
  72. flat spot
  73. High compression pistons for 07 dyna
  74. 00' 883 xl replaced rocker box gaskets - won't start
  75. 05 springer carb questions
  76. This carb AGAIN
  77. bike choking on rush 1.75's
  78. 07 Fuel Managment
  79. Front Quick disconnect fuel fitting leaks when off, no leak when pressurized
  80. cutting off SE pipes
  81. Race Tuner or Power Commander?
  82. Doc1
  83. engine noise
  84. Open Hole
  85. stage 1 a/c question
  86. Pythons discolored???
  87. top end noise
  88. 02 Roadking fuel problems ??????
  89. Exhaust for 2001 rkci
  90. quest. about pinging
  91. throttlebody blade (1995 softail)
  92. Drilling Stock Exhaust / More Fuel Question
  93. o7 street bob cams
  94. exhaust RED HOT!
  95. BUILD IS DONE
  96. intake info
  97. Buying an Evo or Twin Cam 88
  98. Oil in carb, filter.
  99. pro charger any1
  100. stupid AC question
  101. exhaust question
  102. To whom it concerns.....02 codes
  103. RUSH 2.50's popping on decel ?
  104. RINEHART 2 into 1 on a 2007 FLHX 103
  105. slip ons install help
  106. Rush Slip Ons Discoloring?
  107. More Cubic inches for my 88 fxstdi
  108. A/C Cover Opinion
  109. Air cleaner cover question
  110. Upgrade to an 07 Classic?
  111. Changing oil, primary and transmission
  112. Now what to do?
  113. SE cams on 88"
  114. starting problem
  115. Baffles
  116. Mikuni main jet extender, get one?
  117. Blue smoke out the carb
  118. sporatic miss
  119. D&D vs pro pipe
  120. cam suggestion, 06 dyna, mild mods
  121. Opening up stock mufflers?
  122. S&S Super E on a 1000cc Ironhead?
  123. Stage 1(rk-3909) and 07 SE Slip ons
  124. Popping?
  125. new problem,,high pitch squell
  126. Cam Choice 55G or 60G
  127. No tach. Good idle by sound?
  128. 883 to 1200 connversion
  129. help with the check eng. light
  130. baffles for V&H longshots
  131. Birds in Rineharts
  132. oil drip found
  133. Big Sucker vs SE Stage I AC
  134. Cv 40 throttle blade not going wot
  135. oil dripping frm air cleane
  136. SE CV44 Tuning - Float level
  137. Cv 40 Flooding
  138. 99 Heritage With Samson Fishtails
  139. popping and cracking (backfiring??)
  140. CARBIE HESITATION
  141. Can anyone tell me the correct way to line up the tappets with the bleeding holes in the casing?
  142. big shot staggered question
  143. Front pipe discolors, not back pipe
  144. fuel pack and fatboy
  145. Vance & Hines
  146. BAFFLES ON PYTHON S/O- TAKE OUT???
  147. CV Carb Issue
  148. 95" cam choices
  149. Anybody do your own diamond cut heads?
  150. Rinehart 2-1 FLHX install: P-Clamp help!!
  151. Pop-Stopper from Zipper Perf Products?
  152. DOC1 Will race tuner help?
  153. EFI to carb swap?
  154. DTT/T-Max and LSR Blackholes - Mods required for Install
  155. changed all 3 fluids
  156. backfiring in 2006 superglide
  157. Muffler Question.
  158. Exhaust Flow
  159. choke
  160. reversing stage 1 question
  161. 07 running lean with slip-ons
  162. Header question for 95ci
  163. Ripped off?
  164. Noise difference between 883 and TC88
  165. Exhaust Wrap, How Much is Needed?
  166. Slip ons for a '97 Lowrider
  167. HELP! With Pro Pipe Install
  168. Big sucker vs. Screamin Eagle
  169. Big Sucker
  170. Only 28 hp on the dyno, HELP!
  171. How Hot Will the Exhaust Get?
  172. Timing cams on 88 sportster
  173. Doc1 Knows stuff...
  174. Will this set-up work?
  175. Joe MInton's 95 inch Conversion
  176. Exhaust popping on deceleration
  177. switch to new exhaust??
  178. plug reading question for doc....
  179. Bit's of tensioners in your oil filter?
  180. Shovelheads and Evolutions
  181. V&H Fuel Pack with RineHart TDs - Popping Update
  182. Passwords on SE ignition modules????
  183. So I got the Train back from the Dyno
  184. CV Jet Problems
  185. ok...got enough nerve to ask -finally
  186. K&N RK-3909 vs. Arlen Ness Big Sucker
  187. Question on Exhausts....
  188. Rinehart Tru-Dual Install
  189. Rinehart sound tinny
  190. Where to buy Rush Slip-Ons??
  191. more hp
  192. Rush vs Wild Pigs
  193. Anyone have the SE Ignition module?
  194. Intake Suggestions Anyone?
  195. 800 miles and I hit my Rev Limiter tonight
  196. Max Pefromance Touring Mufflers
  197. Exhaust - 07 Ultra Classic
  198. Rear engine, tranny mount ?????
  199. O² sensor plug
  200. oil drip
  201. Smoke from left exhaust sometimes
  202. 95" Build & Gas Mileage
  203. Engine noise
  204. SE2's on 2007 FI sportster
  205. possible exhaust noise?
  206. white spark plugs
  207. oil seep
  208. Exhaust Pros and Cons
  209. What exhaust, intake , and tuner for the new 96"?
  210. RK runs on diesel!
  211. carb backfireing big time
  212. V&H BSS baffles
  213. Andrews 26g Cam Questons
  214. Washed bike, now idles high. Please help
  215. Disappointed in performance
  216. Fuel lines on FLHRI
  217. V&H exaust hits floor board
  218. removing baffles
  219. stage 1 ques
  220. New sportster, already bummed out
  221. Louisiana Performance Shop
  222. Smokin
  223. Welding header pipe cracks?
  224. New pipes for my sporty
  225. Mikuni idle problem?
  226. S&S B
  227. Any advice on Hookers?
  228. New Bike lots of Questions
  229. CV carb float issue
  230. Hot Air and the Twin Cam 96
  231. Question for carb guys
  232. Do I have to rejet again?
  233. Question about Big Sucker 2
  234. valve seals
  235. Another 95 inch Thread.
  236. SE CAMS??
  237. Rough running Dynawideglide '06
  238. SERT map help
  239. what am I missing here ??
  240. MIKUNI CARB
  241. Upgrading 88B efi motor opinions
  242. Intake Manifold Installation Please Help
  243. Major Problems after satge 1 with cams
  244. 95 build done
  245. Mild 95" Build
  246. air cleaners
  247. compression ? help
  248. Price for a 95" and a 103"upgrade?
  249. EAA air filters
  250. carb Intake air leak???
