View Full Version : Exhaust System Topics
- Hate not knowing what was previously done to bike
- Buell XB12 vs Sportster engine mounts
- hp and two numbers
- Whats up with these plugs
- "95" Sportster 883 Fuel Problem
- Anyone convert their stock pipes into true duals?
- S&S EZ Start Cams at altitude
- new springs with replacement cams?
- diagnostic trouble codes
- Shovelhead making loud clunking sound when I turn it over.
- S and S Super E Coughs
- Needing Help
- infamous carb spit w/new twist
- Octane Boosters
- Swapping tanks
- Valve or lifters?
- Can I turn Engine over without spark plugs?
- Cabruretors and plastic gadgets
- head breather bracket bolt hole direction?
- S&S 551 Standard?
- ticks when cold
- Help to ID this exhaust
- Engine swap
- Reinharts 3" TD louder??
- Good engine builder near Pittsburgh PA??
- Crankcase Pressure
- 07+ cam plate
- 96 road king s&s motor
- Loud Tapping on cold start
- Stock exhaust
- Petcock Question.
- 2006 Sporty with 2007 Exhaust
- Cams with headwork vs. without?
- 106" 110HP 1987 Lowrider FXR Should I buy it?
- cams and compression
- Python 2-1 Exhaust
- loud metal to metal engine sound
- Carbon Cannister
- Air filter question
- 93 W/ 10% Ethenol vs 91 Without
- o2 sensors?
- Torque cones ...good or bad ??
- Baking the chrome off my exhaust
- Exhaust pressure not equal
- 4" vs 4.375"
- drilling muffler
- Cycle shack slip on mufflers
- TC88 cam tensioners
- Throttle body injector upgraded question
- Exhaust Systems
- Running hot
- New Road King won't rev...any advice?
- Engine/Exhaust/Intake Upgrade
- 95 inch on a 1999 FLHTC
- cam upgrade stock heads
- rebuild
- Re-balancing 106" flywheels ???
- New Bike and....
- pinging/Bad gas sound V&H on new HD
- 2000 Electra glide motor size
- Recognizing heat issues
- 88 to 103
- Drag pipe performance
- Oil Venting into Air Intake
- 2012 Softail Slim Performance Upgrades--Advice
- 2012 Softail Slim Performnce Upgrades--Advice
- Heat reduction
- New Rush pipes don't fit my 2012 Fatboy!
- ENGINE PING need help
- Evo Oil Pump
- 100 " Revtech aircleaner
- CV carb pump rod
- Any experiance with these patriout defenders?
- screamin eagle heads
- HT Silicone for exhaust?
- Samson True Dual Advice
- Andrews 67 in a 117"
- Dyna Screamin Eagle II's for 13 Sportster?
- Compression Ratio for SE pistons part #22862-00 & 22863-00?
- stripped threads on top bolt hole
- slip ons seem to big for header pipe
- Short shots suck?
- 91 versus 93 octane
- carb ignorant
- Engine started backfiring then quit and wont restart
- Which gaskets with Rush full system?
- engine swap
- Need More Power...!
- Carburetor hell... i think im screwed
- CV Performance Kits
- Sputtering by in Rocker Box
- Voes question
- What to know before calling about heads?
- How do I take out the baffles of Screamin Eagle exhaust?
- Another Twin Cam noise thread
- exhaust/tuner for my street glide 2013
- dyna cams
- This Doesn't Sound Good
- need some info.................
- S&S 106 stroker question
- Baffles Out
- "07 cam plate & cams in a '03 ???
- New cam chest - funny noise
- Cam upgrades and head swaps
- 2011 roadking clasic set-up
- Will It Go Leaner or Richer?
- Question on White Brothers Pipe
- 88b out of balance?
- base gaskets
- Torque cones, anybody use them?
- More power options? 02 train
- Little Disappointed in Dyno Run
- engine problem
- Big Boys heads-advice?
- motor knocking on my 2005 88ci
- Sound of engine pinging
- Fuel return fitting replacement
- Pipe advice
- Engine Ran Rich Questions
- '82 Sporty S and S carb issues (please help)
- stock jets
- 09 Dyna
- Engine Question 1998 Fat Boy
- exhaust bracket on engine
- Pipe slipping off?
- Cams for 2010 96Ci Fatboy
- HELP-2010 FXDWG exhaust on my 09 FXDL
- Oil Carry Over - But not from Breathers?
- S&S super e help needed
- pinion gear question
- Feedback on which engine to get - Bobber build
- Knocking
- Help!! super b driving me mad
- Help identifying petcock
- 2000 Road King Carb Problems
- Cam chest rebuild on the 05 e-glide SE
- 2004 Electraglide whine
- 2007 Ultra Classic Performance Upgrade Help
- Carb bowl removal steps 2003 Dyna Superglide
- 2004 fxstdi
- CFR Slip-Ons Video's
- Pro Pipe install, mating the headers to the heads
- Cams for a 2011 FLHTK with a 103 Twin Cam
- I want to remove my cat from 2011 RG
- Rough idle, surging, and back fire
- Questions and of course your 2 cents...
- Cams
- Help! Stage 1 Upgrade Quote seems high
- Twisted Chop Evo Ground Pounders
- Fuel Tank Disconnect Leak
- new engine sound at high speeds
- 93/94 Octane or 91 ethanol free Gasoline?
- Fuel tuner needed?
- Low MPG with TMAX on 2006 Springer
- exhaust header bolt
- How to pull heads 04fxdl tc88---in frame
- TC 96 wrist pin size needed please
- Mikuni Carb/enricher cable - Explain compatability!
- TP rocker box gaskets
- Fuelline asy tank to intake part#62349-04f
- No low end power
- Using some oil
- Evo Big Bore Question
- How do I remove/change the float valve seal on an Evo carb?
- Spacer length for Reinhart Crossback
- Any Numbers for 113ci 2-2 vs 2-1 exhaust?
- SE heads
- Thunder header removal question
- Custom 2-1 Exhaust
- feels like Im running out of gas
- Gutted s.e 2
- Cam Advise
- Bike runs horrible after warm-up
- Quick connect checkvalve leaking, need upper o-ring
- Would a pitted lifter cause ticking/knocking?
- lifter wear
- Jetting 06 1200 sportster
- 98 EVO top end
- cam gear alignment on 53 model kk
- Idle trouble
- smoke from base of push rods?
- Cam tensioner replacement
- Tapping/ticking sounds? Diagnosis?
- need more power from my 1997 Ultra Classic
- timing chain tensioners
- Can't find pipes
- Sometimes it will, most times it won't
- Python 2 into 1
- FuelMoto 98"
- 2012 Fat Bob Baffles
- rocker cover gasket, push rod seal - Help
- what else with 107
- Sportster only runs with choke
- Any Exhaust Wraps Better Than Others?
- It sounds like cam chain tensioners, but it's not!!
- upgrades while under warranty
- Sportster runs bad
- Evo engine knock - no not compensating nut
- Engine noise on decel
- Rocker Box Gaskets
- Scratched VH Pro Pipe Black
- Looking for some deep sounding ground pounding exhaust for my Street Glide.
- Evolution Bucks / Misses
- Screamin Eagle?
- TC Valve Train Noise
- Performance Tips
- Slip ons and EFI?
- 110" S&S Motor
- DIY cam chain tensioner replacement?
- 1998 Road King question
- Question about 06 dyna and screamin eagle cams
- Annoying noise
- oil pump
- Sumping
- oil leaking
- Engine Light
- Powder coat damaged Harley motor case
- gear cam change crank run out
- Crankshaft Question
- 103 Motor "ping ping ping"
- Need Opinion ON exhaust
- 1991 883 jetting
- Help!
- New to forum and need help!
- gas gauge stuck on full ?
- stouts
- air cleaner query
- Barnet clutch spring install
- Need exhaust
- Need Exhaust
- 96b Oil Line Fitting Size
- Crankcase decoding
- HELP carb swap..what coil do i need?
- Jetting suggestion Help
- EVO style Head boltsw
- Cam shim Question
- lining up cam pinion & breather vale timing marks
- Andrews 26H in a 103"?
- Triple-XXX
- Help- What to look out for at 100,000km/70,000miles
- Need some help
- 2012 48, H&H short shots question.
- Any one know how many ve’s =1 afr
- V&H Pro Pipe???
- Bike Running Rough/Rich After Repair PCV
- Evo lifter block + lifters on a Shovelhead
- Vance & Hines chrome peeling off
- Baffles for Bassani pro streets
- New fuel management or re-map
- Stock 110 Questions????
