PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Good deal on a big bore?
  2. carb problem
  3. Bub seven or v&h ovals
  4. Did the picture post?
  5. California Exhaust / SE Slip-ons
  6. Engine Light
  7. cobra upswept speedster
  8. heat wrapping exhaust on an EFI bike..??
  9. Oil Pressure Relief Valve
  10. Baisly Spring with SE Hybrid Cam plate?
  11. Cam timing
  12. Inner Cam Bearings
  13. bassani 2 into 1 heat shield problem
  14. Thanks for your help
  15. Oil pump alignment screws
  16. Blended/ ethonal Gas?
  17. Internal pic of Twin Cam
  18. 1986 883 cams C1's and D1 cams??
  19. leak under my gas tank
  20. Hey Seascape
  21. Wrong 0-ring?
  22. Braze Exhaust pipe?
  23. Automotive Machine 105" kit
  24. Will it fit
  25. Header bolts
  26. Need some advice
  27. 09 Pop at start up
  28. Air/Fuel ratio question on 103"
  29. Riding with Camshaft Position sensor code
  30. Piston Evaluation
  31. Dyno Comparison: 96" Stage 1 VS SE 103 Stage 2
  32. 11:1 ration pistons in stock evo
  33. Am I wasting my money on an old model muffler?
  34. Lash question: new pushrods?
  35. what numbers should I expect?
  36. Instruction Sheet Needed
  37. twin cam into evo
  38. What pipes for new Fat Boy
  39. Valve Train Noise
  40. Does Anyone Have This?
  41. Exhaust crush gaskets
  42. Can't get my 04 Lowriders slip on to slip off
  43. black ceramic pipes
  44. Exhaust
  45. Slip-ons w/o tuning: warning signs?
  46. Advice on SE slip ons
  47. Difficulty for big bore / cam install?
  48. Cycle Shack Slip Ons
  49. sputtering
  50. Mikuni clatter?
  51. Changing short shots to long shots
  52. What do these SE Slip Ons Fit?? 66080-06B
  53. advice on engine upgrade
  54. lifters
  55. ?low cost EVO upgrade?
  56. Inspecting inner cam chain tensioner?
  57. quick disconnect
  58. Evo lifters
  59. 93 vs 91 Octane
  60. Evo cam choice
  61. Ness-Tech Velocity Stack
  62. Looking for cam advice
  63. Snapped Jackshaft Bolt..Help!!
  64. Cutting pushrods?
  65. Exhaust fitment issue (WTF?)
  66. SE Hybrid Cam Kit It Is!
  67. Need Help !!!
  68. supertrapp fishtail question??
  69. Cam / outer roller bearings
  70. Tuning a Dyna Carb???
  71. 26n cams
  72. What will it be?
  73. EFI Fuel Tank Petcock bung size
  74. Seeping at Cylinder Base?
  75. fuel modual
  76. Big Radius, Heavy Breather, SERT, 2 much?
  77. Andrews TW54 Spring Question
  78. I HATE ! my cams
  79. Gear driven cam questions
  80. "Exhaust Noob" Question about Pipe Change/Tuning
  81. Hq500
  82. Vance and Hines pro pipe
  83. No Fuel 98 Road King
  84. Hi Compression Stock Bore Pistons for 96"
  85. Throttle Body Information Needed
  86. Break in period if just doing top end?
  87. Questions for high altitude
  88. New 113" Build is well underway and progressing
  89. Quiet Baffle in V&H straightshot
  90. Help, fuel mileage stinks
  91. Engine temp for 96" 07 & up
  92. Conversion Cam Install Instructions?
  93. 2009 touring mufflers
  94. SE 103 or 110 upgrade for my 09 Road Glide?
  95. rpms/mph per gear
  96. 1340 EVO opinion needed - see video
  97. 1200 Sportster Air Cleaner
  98. 2002 California 1200 Sportster
  99. tappets
  100. Cam worthiness for install
  101. Break in after Kit install
  102. Starting Problem
  103. Who does the "best" Head work???
  104. 2005 Heritage Classic Exhaust donut
  105. HD PIPES.COM...should I order???
  106. Ultima 127"motor on FXR frame?
  107. Need a map to get started
  108. Working with the PCIII
  109. Improve California Touring sound
  110. What SE Heads do i buy? Or do i P&P mine?!?!?
  111. Hydraulic Cam Chain Tensioner Upgrade (Cam Crazy)
  112. Stage II 103" with various mufflers
  113. Harley Jugs, NEED HELP!!!
  114. Which Pushrods for the CAM change?
  115. Low idle issue, idle screw maxed out
  116. Sert or pciii?
  117. Noise reduction
  118. Who's running SE PRO MCR Heads 16952-08
  119. wondering if anyone has done this and any info on it
  120. Cam gear drive conversion help
  121. Bad day on the bike yesterday!
  122. More than 4 qt's ?
  123. How do I know if running lean?
  124. Troublemakers with Thunder Monsters
  125. True Dual Exhaust...What do you Recomend?
  126. Air Fuel mixture help
  127. Dip Stick Stuck!
  128. Muffler baffle help
  129. Pipes w/o shields
  130. Oil filter housing
  131. Comments about Wimmer High Flow Intake kit ?
  132. Carburetor lope w/ fuel injection?
  133. Evo Case
  134. Drop in Cams
  135. TC88 vs TC95 SE
  136. V&H True duals Softail
  137. TC 103 Air intake
  138. changing pipes+air intake,adding power comander
  139. Sportster running on one cylinder only
  140. Selecting a performance cam kit?
  141. TC88 cam bearings
  142. Zippers oil bypass shim
  143. Fuel Pack
  144. S&S Super-Stock heads on a TC...?
  145. Bored and Stroked Specifics?
  146. Not blueing pipes during tuning???
  147. Air/Fuel meter vs. Plug reading
  148. Cylinder Studs
  149. Lucas fuel additive
  150. Jetting for a 2002 California model 1200 Sporster
  151. Intake and Exhaust questions
  152. speeds performance plus
  153. what size injectors for a 116" ?
  154. Can't find correct case seal
  155. Big Bore Question!! Help
  156. 103/255 Head Gasket
  157. Boring '95 80" Evo Cases
  158. V&H BSS or V&H BS Standard
  159. 1200 sporster stage one
  160. New build underway w/ R&R 5-Piece Crank and SE 113 Top
  161. New SE fat Plug wires = Code P1353?
  162. valve sizes on a twin cam????
  163. Anyone runnig 10:1 comp with 37gs???
  164. Cam Project- Cut the Pushrods question
  165. Fuel Problem
  166. A little help from the field
  167. Going through the top end....
  168. '09 Mufflers
  169. 96 Fatboy Carb Help
  170. Breather hose for 2007 Dyna FXD
  171. Stage 1 - Lost Power! WTF?!
  172. Which Doherty Power Pacc - '08 Dyna
  173. Backfiring
  174. V&H Big Shot Staggered or Rinehart staggered
  175. Hybrid Cam Plate Install Update and ??
  176. SE Kompressor heads & SE-257 cams
  177. Spark knock?
  178. Upgrade to 2006 Street Glide
  179. Fuel tank with rust....
  180. "DIY TD" experimenting on Ultras....
  181. AN Stage I or II
  182. SE 255 or Andrews 26
  183. Cams for the Glide.
  184. Valve Color
  185. Shovel mechanics help
  186. How to verify good break-in?
  187. Retune after aftermarket exhaust swap?
  188. Fuel Pump Seal
  189. Not So " GOOD VIBRATIONS "
  190. Adj. Pushrods with enigine build??
  191. pipes without any tuner..
  192. gas milage
  193. Miffed that you can't buy a new 07 & newer case for hotrodding.
  194. Baffle size, backpressure and engine heat
  195. Using oil?
  196. air breather
  197. Twin Cam Tensioners
  198. True Dual Conversion Kit?
  199. D&D Lowcat vs Bassani RR-Short???
  200. fuel management for 09's
  201. first question true duals on a f.i. tc88 rk
  202. Idle cable installation
  203. Which size jets for my 95"
  204. Andrews 21H in TC96 bagger
  205. washed my bike now she won't run over idle?
  206. Thunderheader trouble...
  207. Newbie and looking for advice
  208. 103 Advice
  209. Weaping Oil
  210. got a pipe question 08 softail
  211. Pic Test TC Intake Port
  212. Oil Leak Frustration after big bore build!!!
  213. Removing matting on baffles
  214. TC CAM Ball Bearings Question and great link
  215. samson true dual on an 07 flstsc
  216. Need you thoughts on these engine mod...
  217. New build.
  218. Santee "quiet" 2 into 1 exhaust
  219. The moment of truth
  220. Which 2 into 1 pipe???
  221. AIM VP84T Clutch 4 sale
  222. carb help.
  223. Problems with cam bearing change
  224. Headwork?
  225. Zippers shim
  226. Correcting Gear Drive lash
  227. Need advice for jetting of Mikuni kit on 86 EVO
  228. Is it okay to run without baffle?
  229. Dyno results on my 95" build.
  230. pipe size...
  231. cam chain tensioner questions
  232. Mikuni Idle air screw
  233. Screamin' Eagle 2 and Supertrap Difference
  234. any info on a product called JETSCREAM
  235. straight pipe question
  236. more questions
  237. Rush Slip-ons
  238. 05 electra glide crank????????
  239. got a great deal today. got some questions
  240. remap?
  241. Mikuni 45 question?
  242. Another cam chain tensioner story
  243. How do I change my oil?...J/K Pinon shaft inner race?
  244. 'SE Heavy Breather' Question
  245. Better low end torque,,SE 50 state or V&H Monster Ovals?
  246. New Exhaust
  247. Smoke coming from Air Filter
  248. V&H Big Shot Staggered--Quiet baffle or not?
  249. Exhaust comparison
  250. pc111 tune in daytona
