PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Help with my 103 build
  2. New Cams - Excessive TICK
  3. Balancers Chain on an 88B ??
  4. Swapping Stock Mufflers / Nightster to 883 Low
  5. screaming eagle pro tuner help
  6. Help me decide on a 2-into-1 pipe for my '06 Street Glide.
  7. Need help with getting extended crank case breather bolts
  8. EXOTIX Air Cleaner?
  9. New Pipes today
  10. Headers??
  11. Main, rod, or piston...
  12. V&H shortshots question.
  13. Drag pipe how to
  14. I need help
  15. howto keep 'em from bluing?
  16. TC88 build tips required
  17. Dyno question
  18. 2000 superglide running bad
  19. Mikuni 42 Jetting HELP 80"
  20. fat cat
  21. stage 1 kit going to stage II
  22. *which air cleaner?*
  23. twin cam B drawing/picture
  24. Cam swap on 30k mile motor?
  25. Engine swap question
  26. Engine rebuild, gasket sealant
  27. Front cylinder overheat problem
  28. Building pressure in oil bag?
  29. sprocket side shaft runout
  30. 99 Sportster with S&S carb, bad dead spot, what to do?
  31. Seafoam
  32. Just replacing Mufflers require Dyno or Fuel Pak?
  33. Which slipon for a 2010 FLHX?
  34. compression releases?
  35. oil light on 2009 Deluxe
  36. knocking noise at idle
  37. Thunderheader Heat Shields
  38. Baffle ring/ lolipop baffle installation?
  39. Advance, or No Advance
  40. 2006 Rk Exhaust?
  41. 97 Fatboy power issues
  42. Too rich? Too lean? Just right?
  43. Does this sound right?
  44. Vance and Hines Longshots or Big Shots...
  45. Arlen Ness Big Sucker
  46. '91 EVO Carb/Tuning issue?
  47. Lifter install questuion 96"
  48. This is enough to piss me off....
  49. T-man 525C cams
  50. "hopping up"
  51. V&H Big Radius 2-1's
  52. Teach me about the cam chain issues
  53. Excessive Valve Noise...Possible Lifters?
  54. Blue Flame
  55. 07 Street Glide exhaust question
  56. Samson Fish Tail tips on V&H true duals?
  57. Head pipe
  58. Am I headed in the right direction?
  59. TC 88 Bore limit
  60. What way is cooler?
  61. Won't start when warm
  62. Shovster question.
  63. 103 stage v with se 255 cams
  64. hsr42 or 45? can a builder/tuner help?
  65. SE stage 1 air kit
  66. HELP: my first Harley
  67. Forcewind and CV44 help needed
  68. What dial indicator for measuring crank runout?
  69. How to? I need to remove a crimped on hose clamp
  70. Vapor Lock???
  71. Another Oil Pump Question
  72. Who has info about the newer heads/96 inch.
  73. Need velocity stack
  74. Vance&Hines FuelPak
  75. Fuel Pump Noise
  76. oil pump
  77. V&H Big radius ordered - I need a PC3 and new intake right?
  78. returned Cobra Exhaust system for refund
  79. V & H Slip-On Drill Baffle
  80. Loud back fire when starting cold???
  81. Cam timing
  82. Help! need nos part.
  83. 2010 Street Glide Exhaust Question???
  84. Lifters?
  85. Help choosing cams
  86. Black Smoke from one pipe
  87. H-D 29259-93 Air Filter??
  88. Need help building up 88B
  89. Pressure realease
  90. 2010 Street Glide Stage II overheating!!
  91. twistedcrank
  92. Choosing a cam
  93. Smoke out of air cleaner
  94. Big City Thunder Baffles: Washer/Diffuser position
  95. K&N Versus Screamin Eagle Air Cleaner
  96. EXTREME parts cross reference question
  97. Barrels and pistons
  98. Motor smells hot
  99. 2009 xl1200n
  100. gear whine in 95 flstn
  101. Stock pushrods
  102. removing cylinder heads on '08 SG
  103. 88" Silver Jugs
  104. Anybody fitted a Crimescene choppers Speedlines Air Filter
  105. adjustable pushrods
  106. Air Cleaner Bolts
  107. V&H slip-ons/Baffle wrapping ?
  108. Stage 1 Question
  109. engine gear whine noise
  110. Uh-oh engine's running bad
  111. Removing Bub 7 Slip-ons?
  112. Woods roller lifters
  113. Exhaust clamps
  114. Short Shot Question
  115. Oil leak
  116. Head Spinning Update
  117. 2004 Fatboy - Idle Screw location
  118. Anyone know..
  119. Valve Train Noise
  120. Oil out the vent tubes
  121. Perfomance help
  122. evo jug score
  123. Help - Looking for o2 sensor eliminators for PCIII
  124. 91 sportster surges and dies
  125. First Performance Upgrade
  126. Removing Fiberglass Wrap from Mikuni Baffles
  127. do 09 headers fit 86 evo
  128. Headbolt bridge with compression release???
  129. What do I have?
  130. HELP - Leftover part form installing Slide Needle in Carb
  131. TOO Rich???
  132. Which head gasket?
  133. CA riders Where can I buy 100+ Octane Fuel
  134. Calling All Stroker Masters
  135. Tune after Cam Change
  136. need some torque specs
  137. V&H big shot quiet baffel for newbie
  138. Exhaust decisions help !!!!!
  139. Help with exhaust!!!!
  140. early SE cast 95" piston failures near wrist pin
  141. Night Train Won't start
  142. Snake Oil?
  143. S&S 106 BB break in
  144. firing through intake
  145. Severe Oil Consumption.
  146. How to remove 2010 harley davidson fat bob fuel tank
  147. Engine swap??
  148. Rinehart Crossbacks
  149. camshaft shimming?.
  150. What kind of CR will the SE 95 kit give me?
  151. Air filter help
  152. First post with an exhaust question
  153. Reinhart 2 into 1
  154. Any of you spun a cam gear?
  155. Woods or Tman?
  156. High oil pressure
  157. Need Exhaust Explained
  158. Exhaust Heat Wrap
  159. Thinking of getting a V&H Pro-Pipe. Have some questions.
  160. Drilling rocker arm stands
  161. Screamin Eagle Hydro Cam Plate Probelm
  162. Crane Cam installation tool ... any reviews?
  163. Wierd oil leak
  164. Looking for Pictures and Ideas for Rerouting Head Breathers outside Air Cleaner
  165. HELP! '09 Ultra Clasic & Hookers
  166. O2 sensor plugs - easy to find
  167. need Some Jettig Advice
  168. Please Help!!!Do I run 9.8,10 10.5? Can 10.5:1 be reliable???
  169. Baffled With Baffles
  170. Anyone tried the Andrews 48H yet?
  171. Good builder/dyno shop in the Tampa area?
  172. Boyesen twinshot
  173. zenith 40mm carb
  174. Andrews 21H or 26H for 09 Dyna
  175. Oil pathway question
  176. Issues after Fatcat install
  177. To clean or not to clean
  178. Trouble maker darksides got scratched....
  179. 85 low rider performance
  180. Fuel drip.... need help please!
  181. Can i just install pipes without rejetting?
  182. No More Ping - FINALLY
  183. Going from "Cat" to "Non-Cat" mufflers...
  184. Hooker Headers
  185. Flame out of front exhaust pipe on Sporty.
  186. Other then tear it down, anyway to tell what my bike has in it
  187. 1970 ironhead
  188. 95" without cams
  189. Oil pouring from breather
  190. Do I really need to re-tune and dyno AGAIN!?
  191. Could I have found the problem?
  192. lifter question
  193. Screamin Eagle heads on EVO 1340
  194. Engine upgrade question
  195. Yet another head modification question
  196. Cams and my head is swimming
  197. Time for a new dyno tune?
  198. ?'s SE255 or SE204 + BCT baffles + Big Shots + Heavy Breather + SERT
  199. could i be too lean?
  200. V&H BSS heat sheild question, quiet baffle install question
  201. Questions on SE pro air cleaner back plate
  202. Oil-spray(?) on rear headpipe and side cover after ride...
  203. 2010 sportster forty eight
  204. 88" upgrade opinions?
  205. Stage 1 and Screaming Eagle Air Cleaner ?
  206. were is the site?
  207. 96" specification questions
  208. 2009 street glide exhaust
  209. Need a tuner with Rush Mufflers?
  210. 1st issue with my new Harley
  211. 80 inch upgrade
  212. Take A Look At These Heads
  213. need help! bike is choking and backfiring
  214. Street Glide
  215. Dyno Tune in San Diego
  216. $459 Tuner package for new exhaust?
  217. Andrews EZ Install Pushrods ??
  218. 2010 wide glide exhaust
  219. Exhaust for 2007 Softail Deluxe FLSTN
  220. oil leak
  221. Evo intake leak
  222. fuel filter
  223. VROD Cylinder compression question
  224. can i make make my 2000 Fatboy sound like a Roadking??
  225. Mikuni Carb bracket ID Help
  226. Central Ohio Tuner Needed
  227. 107 build on 08 ultra
  228. engine rebuild
  229. make your own true duals
  230. 09 sportster
  231. time to crap or get off the pot
  232. Rocker Box cover screws for big twin
  233. Initial Super E jet sizes
  234. Anyone have a Velocity Stack for a Super B?
  235. What cam?
  236. Definition "Bolt In Cam" ?
  237. Looking for a tuner in Eastern North Carolina
  238. Oil Cooler , Lifter Noise????
  239. Ironhead carburetor
  240. Head bolt replacement?
  241. Head & cam upgrade possibilities
  242. Considering Venturi knock-off by Kury
  243. Kuryakyn hypercharger installation question
  244. Rocker box cover gasket question
  245. AN stage II Air cleaner
  246. Another 88 -> 95 Question
  247. K&N 63-1125 filter
  248. Cam experts????????
  249. What is the purpose of end caps?
  250. aftermarket exhaust ?
