- Removing baffles on Deuce (Screaming Eagle Pipes)
- Anyone with explanation?
- Screamin eagle 2 to 1
- "ANOTHER" exhaust question
- Ingnitions and cams
- K&N-3909
- I need a rough estimate of cost for bore N hotter cams
- Tell me the difference between big bore VS Stroker kits
- Carb re jetting question
- 103 kit, pipes
- Anyone running the Super Trapp SE slip ons?
- exhaust change
- Carb jet- I did not drill out the slide
- Can 88" be converted to bigger?
- WS6 Formula i think you started something
- chirping exhaust
- oil pump install
- Will I notice a performance difference...
- poish instead of chrome?
- Which Tuner?
- What's the most anyone paid for exhaust?
- FI stumble on itnitial accel
- S&S 124"
- Cam chain tensioner
- FLHTCUI Fuel Filter = Check Valve?
- rinehart heat shields
- Screamin Eagle 42mm and 42mm HSR...?
- SE Touring Slip-ons
- CHANGING AIR FILTER
- Exaust for FLSTS 03
- any tricks to getting of air cleaner backing plate?
- MIKUNI 45
- Anyone painted the motor on a Standard?
- head work
- Engine light comes on for a short time
- spark plugs
- New Streetglide....stage 2 or highout out build??
- Big Shots Staggered vs Big Shot Longs
- twin cam bolt list
- dyno power slipons
- Engine Heat
- 07 cams for 103" SE253, SE255 or other
- What' the diff btwn Stage I and II AC's???
- WS6 Formula - I stole your idea!
- Advice - TFI/intake
- Wrapping Exhaust with black heat wrap
- Khrome Werks kick a$$
- Python Staggereds
- tappet noise
- torque cones
- One quick question!
- doherty machine powerpacc
- Another AC question.
- vacuum petcock
- cams....
- Anybody Know???
- shield clamps
- K@N air filter
- Baptism By Fire
- Baffel Question
- Got My Mystfree Breathers!
- What are stock number for 07 - 96 cu in
- Stock exhaust headpipes..or true duals..on a bagger?
- Engine Temp
- TC88 Flywheel assembly "A" vs "B"
- Exhaust Question etc
- SE Stage 1 Kit vs. K&N's RK-3909 Kit
- Removal of EFI - Softail Air Cleaner Trim
- exhaust cost question
- Fueling pump and Baisley spring?
- BAFFLES
- 103CI Upgrade
- 2 into 1 question
- s.e.44 carb
- i think she is gonna f&$^ing scream !!!!
- Exhaust Sound Comparison: 2006 vs. 2007 Engine
- Photos of V&H turndown mufflers
- Gas Mileage - Cold Weather
- SE Performance Heads or HTCC Ported?
- XL Surge @ 2700 rpm
- o7 o2 sensors?
- engine or drive train noise ?
- Re-Glassing a V&H Pro-Pipe
- Condensation
- Help !!! engine running rough
- 96 inch dyno results-
- Dual Pipes on '94 Softtail
- Softail Premium Oil Cooler?
- Dyna Guys....
- Stage II Big Bore Kit Questions!!!
- Stage I
- Grinding/Vibration Type Noise Coming From Engine
- fuel leak at carb inlet
- Big Sucker
- Bad Cometic Gaskets?
- tc96 cam problems? Anyone hear about this?
- exhaust routing question for big Harley
- Slip-On Muffler Recommendations
- Nice 510 cams and reed oiler
- d+d fatcat on 88in road king
- V&H Short Shot Quiet Baffles
- Which V&H pipes for 07 Deuce?
- HOT engine
- need a new carb
- Exhaust Fitment Question
- Broken Cases, bent crank.
- Heat Shields for V&H Big Shots
- Twin cam engine upgrade
- Dyno after pipes, stage 1 and PCIII?
- insulating wrap for exhaust
- Pinion oil pump gear
- tc vs evo dresser exhaust?
- TWIN CAM GEAR DRIVE
- flhsbob 07 air intake
- screaming intake or drill holes?
- DOHERTY MACHINE POWER PACC
- Carbs which one
- To those who have built or repaired
- 95" Build
- Filter change with SEII exhaust
- mods to as for at 1000 mi oil chnage?
- Ready to install
- What's that dangling off my air intake?
- EFI Question
- Woods cams TW-400 Anybody using them?
- Front Engine Mount Question
- Dyna Fuel Overflow
- RB Racing LSR 2-1
- Backfire Problem
- D&M spear intake
- Ready to install BSS on 07 softail
- D&D 2 1/2" slipons for RK
- Timing curve
- 07 bagger LH muffler versus RH
- RB Racing LSR 2-1
- Round Stage 1 Air Filter Cover?
- Cam Chain Tensioner Question for people with 2001 or newer Twin Cam
- 95" rebuild
- mufflers 07
- 2007 Softail Exhaust from Vance and Hines
- My bike sounds like its choking
- Stand for jugs and heads
- Question on adding baffles to exhaust.
- difference in pistons?
- V-Twin temperature & Oil coolers.
- Painting exhaust
- where can i get a 2007 thunderheader for my dyna
- Trying to convince myself...
- rinehearts on 07
- Big Sucker or SE?
- The MANIAC is gone.
- 06 pipes fit on 07 softail?
- Metal in oil filter.
- LongShots HS vs. Big Shots Long
- 95" kits
- whats up w/ magazines?
- K&N RK3909 - Dripping oil?
- Help on the air cleaner
- thunder baffles in V&H shorties
- Intake...
- Exhaust performance question
- Rush Customer Service - Above & Beyond
- slash up or slash down
- Loose rear motor mount bolts
- road king engine falters
- draining fuel tank
- vance n hines ovals...baffle break
- SE air filter
- Anyone have a pic of the K&N intake?
- Mikuni 42 vs 45... another 95 but built
- Air Cleaner cover removal
- Air Cleaner Covers from Dewey's
- fuel filter
- spark plug reading?
- Reed valve found the perfect tech page
- S@S reed valve twin cam breather
- Octane Info
- MOTOR HEATERS FOR WINTER
- WHICH PIPE FOR A 07 ULTRA.
- wanting a little more torque
- COULD SOMEONE PLEASE HELP ME !
- is a mikuni hsr 45 to big for a 95 cubic
- Samson Big Guns 3
- expexcted cost???????
- Looking for your opinion
- forcewinder
- Different Endcaps make SE Slip-on's Louder?
- Best tool for baffle removal?
- Once and for all: Popping on decel???
- Pipes on a stock motor without tuning
- '03 Fatboy Help
- Engine light and rough idle
- Chirping sound in exhaust?
- Fullsac questions
- Driving me crazy
- 1987 FLT Exhaust retrofit
- Looking for a short 2 into 1 bagger exhaust
- Wrapping Pipes?
- rear header pipe part # please
- Any suggestion on cams for a RG
- New setup in progress
- which way to go(or not go)?
- 25* Injectors 06 Softail - Slip-ons Only
- anyone know these supertrapp pipes?
- Nickel Silicon Carbide Coatings
- Leaky
- 98" Owners thoughts
- Load pipes for 06 Sporty???? carb adjust??
- How often do you clean your K&N
- Carb pops
- True Duals, or 2 into 1 on FLH.
- 07 fuel mapping
- jugs, heads, TC88
- TERRY fuel management
- baffle sizes
- python vs. vance @ hines
- touring slip ons
- AMS Lifters?
- Upgrading Motor Question?
- Cobra Exhaust
- Fullsac True Duals-You were right
- True Duals
- upgrade
- Screaming Eagle race fueler instead of a PC3??????
- Gas Mileage
- Eng mod for trike
- Will running leaded gasoline harm a TC88?
- S & S SUPER E CARB PROBLEM
- Not impressed with cams!
- Header bolt torque values
- New bassanis road rages
- 72 sporty starting problem
- Installing a 07 96" crank in an 05 95"
- got my pistons today
- Total Performance Cyl. Hone
- Good gas versus 10% ethanol gas ?
- voided warranty
- Tapping after rocker gasket replacement
- Weber DCOE 45 card
- 95 stage II big bore kit...
- Double carb set up
- snapping noise
- Sportster Carb Farts
- TAP TAP TAP
- Vance and Hines
- Cam chain tensioner question
- Repacked my V&H Baffles
- vance & hines slip ons 2007 electic glide
- 05 RKC using oil
