- Andrews 44H in a 96"?
- Balanced Engines
- 103 kit Old parts
- Crank Cost $$$
- Help with SE a/c cleaning
- Andrews 37 Cams
- Looking for Information RE: oil pumps
- differance in 2 into 1 and stagerd 2 into 2 exhaust
- I need some advice
- K&N replacement element for '99-01 MM FLHRI
- panhead big bore head gasket
- Inner Cam bearing
- Looking for Indy
- ProChargers for 07 Fatboy
- Baffles pro's and con's
- Roller Rockers, Which???
- Cams for Deluxe
- Air Intake Leak???
- Dyna Rocker Box Replacement
- fuel leak
- cv carb needle and jet question
- 88 sporty not fireing on both
- Oil in the Air Filter
- what year did Harley do it? (motor)
- oil leak help
- Twin Cam 88 vs 96 Heads
- My new build for '05 Ultra...
- V&H too loud !
- Air Cleaner
- K&N vs Big Sucker
- Rocker box removal
- Cylinder prep
- stage 3 etc
- Paugho Mufflers anyone ?
- Bobvic Reviews Please
- Python 2 into 1 Baffle
- Harley Engines
- SE Heavy Breather or D&M Custom
- lean issues
- Any one familiar with Hot-Shot Motorworks?
- '02 Fatboy - Stock 88 engine recommendations
- Installed new cams
- 08 engine parts on an 03?
- stage 1 download enough for big radius install
- Burnt O2 sensors?
- Who Makes Python Pipes
- Exhaust
- big radius '07 computer re-mapping
- INA cam bearing failed.........
- Freakin Vibration problems
- Another exhaust question
- BuB 7 2 Into 1 Exhaust
- CLOSED loop versus OPEN loop
- carb air/fuel adjustment ?
- Weird Deal
- Blacked Out Engine
- muffler clamps
- Santee Cheatin Death pipes
- rush pipes
- New cam question
- Part #'s ??? Fat Boy or Deluxe
- How To on Gear Cams.
- V & H Short Shots
- Screaming Eagle Adj Push Rods
- I think that I need more exhaust backpressure?
- Oil coming out breather
- se heads & hi comp cast pistons
- oilfeild blues
- V & H Quite Baffles
- Engine Performance '06 Softail
- 95" questions
- Muffler packing question
- occasional vibration at low cruising speed
- heads with stock 88
- Opinions on Cobra Pipes??
- 50 model cam cover dowel pin question
- newbe here
- Professional Opinions Needed!
- cam comparison
- V & H "Black" Exhaust!
- Why Not...
- Fuel shut off valve leaks when in off position
- V&H SHORTSHOTS ?
- SERT Dyno Tuning Help
- se 204 cam and high compression
- 2 into 1 exhaust
- Black Exhaust Care?
- Stage 1 Kit and Dyna Tune - Necessary?
- Dual Conversion
- How can I tell if I have SE I download?
- Anybody running D&D?
- 2000 Sportster Repair
- Extended Warranty and cam replacement
- V&H Big Shots Staggered or Straightshots HS??
- TW5 cam ?
- Crank Run Out
- Andrews Gear Drive Cam Set
- Upgrade for FLSTS pipes
- Good Indy in W NC
- New one - Diesel as fuel stabilizer??
- CALIFORNIA CHARCOAL CANISTER REMOVAL
- stock 2008 running hot. Will it damage the engine?
- valve adjustment on TC96?
- Oil Pressure Problem, HELP Please.
- BAISLEYS HEADS
- What about Baffles?
- Which Andrews Cam?
- which adjustable pushrods to use?
- Best air cleaner??
- big bore build horse power not good
- Poormans Air Cleaner?
- Rush add ons exhaust leak
- Rocker cover replacement.
- SE 103 PRO Stage II Kit Question
- stock header front mount plate
- Heads?????
- New 103 build will not ilde
- HELP! exhaust options for 07 Springer Classic
- 2008 TC throttle body size
- which lenght pushrods sportster 87
- 02 sensor bungs
- Doherty Machine Power Vents
- O2 Sensor clearance on Rinehart True Duals
- Requesting Specific Guidance for Keihin CV 40 Re-Jetting
- suggestions
- Snap ring install?
- DD fat cat or Bassani road rage for 03 heritage?
- Engine Life Expectancy?
- Anyone running a 21 grind Andrews
- Heat Shields.
- air cleaner??
- Italian V-Twin
- Feuling Oil Pumps
- 88 Cubic Inch to 95
- aerowinder
- New Great Engine Builder In Midwest
- Crane cams
- Lifter roller bearing died. Do I have a problem?
- Does Baffle Size on the Rush Slipons affect Horse Power Boost?
- Weirdest Sounds
- Freedom Performance exhaust?
- cam upgrade ?
- 2002 Road King Help
- CV Carb with Thunderslide
- Reprogramming FI ?
- V&H Big Shot Dual install????
- Turn Down Exhaust Question
- Evo engine mod question
- 2004 1200 cylinders HELP PLEASE
- Head work and cam
- Vance and Hines w quiet baffles
- What about Rush Mufflers
- **Rush mufflers self calibration technology!!!
- SE 51MM Carb.
- Ripping off the horizontal bar ???
- Pipes Glow Red
- SE 103 with HTCC's
- Santee Serpentz?
- ECM flash after header install?
- 07 Engine Upgrade?
- intake
- Sta-Bil Bad?
- Need More Power!
- tune
- Simple Fatcat Question
- stroker flywheels
- Baffles for Curved Pipes
- V&H exhaust leak
- Rinehart tips....options???
- wild pigs it is
- Engine Hickup!
- What's my next engine mod?
- inner cam bearings text face out or in?
- New Exhaust for the 120 is in
- My HQ 95" build (done)
- crane lifters
- Injectors 06
- V&H from Eastern Perfomance
- SEAP-Mufflers
- EXHAUST TORQUE QUESTION
- 06' exhaust on 08'? will this work
- Map change for new pipes?
- supertrapp se mufflers
- stock cv jet kit
- axtel 117 build--opinions wanted
- R&R 615/585 cam builds
- t-bodys
- Carb re-jetting??
- Port my heads or CNC heads
- FINALLY an answer to the Gear /chain drive issue
- V & H Quiet Baffles
- Breaking in?
- samson ripsaws
- D & D Fat Cat Leak ( Help )
- A tru bolt in cam?
- breather pipe
- rush vs cycle shacks vs vance hines slip ons
- .040 CYLINDER BORE ON 1340 EVO
- Woods Cam TW400-6
- Front Exhuast Valve lighter color than rear
- Carb Questions for Heritage Classic - Please Help
- 2000 SE Roadglide-SE Heavy Breather
- A/C cover removal and power gains?
- top end apart
- carb. cough/ blown base gasket
- Lifter Bore Scoring
- Samson Big Guns
- Replacing the enricher cable
- Sifton pushrods and lifters
- Top 2 into 1 exhaust
- 2008 Softtail Custom Mileage
- Problem with my Motor 08 103"
- Rocker Box Breather Bolt
- 103 buile stadic compression .(continued)
- Force Forcewinder
- Help! Backfire!
- More Compression
- Slip Ons, True Duels or 2 into 1 ?
- V & H Pro Pipe Mods
- Harley Davidson Muffler 80063-95, Is it any good?
- Engine Case ReAssembly
- N00bie question about HD engines
- Exhaust Pops
- What should cylinder pressure be
- Loss of power..suggestions please
- Intake advice
- V&H Q-Serries/SE Double Barrel Map
- true dual vibration
- Incredible
- 2008 Cylinder Head Vulume
- Fuel pack yes or no!
- Do I need fuel management?
- Please list all gaskets/O rings that will be changed
- Question about stock twin cam heads.
- Primary noise, "Clacking".
- 110" Kit vs 103" Kit California Style
- 07 Dyna 103 build advice.
- flat top vs pop up pistons?
- Crank Runout
- 07 SE Big Bore Kit?
- Power comander VS Thundermax
- Dynamic Pressure equations.
- Keyed vs Splined Twin Cam Drive?
- CV Carb needles
- what springs
- V&H Sideshot Baffles
- 100" Fatso motor
- Bassani Exhaust Road Rage or Pro Street?
- VH Big Radius w/bigcitythunder baffles any good for perf.
- Bassani SLIP ON's
