PDA
View Full Version : Exhaust System Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. dowel pin ?
  2. engine knock
  3. AN Big Sucker or SE Heavy Breather?
  4. Samson true dual for softail
  5. Air Cleaner Options: Kuryakyn High 5 or PM Super Gas
  6. Inline fuel filter breaks ? Come on
  7. Jackpot vs Rush
  8. TC88 heads on a TC96
  9. Looking for lifters.. any advice?
  10. Plugs are black and gas in the oil
  11. No oil pressure on 04 Roadking
  12. Nut under the starter
  13. New FLD
  14. Powdercoating FLTR Exhaust Shields.....
  15. Pre 95 Differences
  16. Quiet Stage 1-4?
  17. VIDEO of slight misfire and popping from air filter, but why?
  18. Question B-168 bearing
  19. Samson Outlaw / Big Growl long guns
  20. Fuel not flowing through petcock
  21. changing to full exhaust instead of slip-ons ... worth it?
  22. S&S 583 Easy Start Cams
  23. What percentage of Harleys have aftermarket air cleaners/exhaust.
  24. stock head gasket thickness?
  25. Tuner / Compression / Exhaust Question...
  26. Stage IV 103" SE-Fully Warranteed now
  27. Any tricks to cool off hot exhaust systems if you want them off in a hurry?
  28. Hey look, burnt up valve! (damn this sucks)
  29. Air filter questions???
  30. petcock leaking fuel
  31. One piece crank.
  32. What years did twin cams have forged cranks?
  33. TC88-knock in top end?
  34. 04 softail popping back through the carb
  35. mikuni with hypercharger stall problem
  36. Bike wont start...
  37. Full Boar Exhaust clain 8.11 TQ with no other mods??
  38. TC88 and cam lifter direction??
  39. 97" build started quiet now has top end rattle in front cylinder
  40. have cams improved in the past 10 years?
  41. hypercharger installed
  42. Overflow from gas tank
  43. Overflow from gas tank
  44. Long time since last post
  45. 1996 FLHTCI high idle rpms
  46. Quick intake qst??
  47. cam swap, now no fire on rear cyl.
  48. carb and jet question
  49. 95 kit done
  50. SE Street Performance Slip Ons
  51. 95 Evo
  52. 103 Rear Cylinder
  53. Cam recommendation needed
  54. Cam Chest ???
  55. Thank you to everyone! plus new info
  56. Recommend 95 big bore kit?
  57. will it swap
  58. TW6-6 Cams, build? input thoughts?
  59. Am I wasting $ ?
  60. Think I found my cam chest noise (w/video)
  61. 88ci to 96ci Jug swap?
  62. Piston ID
  63. Update to noise#3, it makes coffee!(photos)
  64. Cam plate bearing question.
  65. Update to "noise" (with video)
  66. use choke in hawaii???
  67. oil coming from under breather
  68. Side to side Pushrod movment at TDC ???
  69. Few qsts?
  70. Difference between TC88 cam support plates (25267-99 25267-99A 25267-99B)
  71. Adapter Bracket Mount for FXR Gas Tank
  72. no sign of life
  73. Hydraulic Cam Tensioners
  74. 2002 softail big bore kit
  75. best cam upgrade for 88"
  76. Slight misfire at idle and low cruising speeds
  77. Rattle with new Vance and Hines dresser duals reinhart slipons
  78. S&S Super E problems
  79. PCIII or Fuel pack for Samson Fishtails
  80. Help reading my plugs
  81. Engine stoped and engine check lamp came on
  82. Hypercharger install question.
  83. Evo Valve piston contact?
  84. Hi
  85. Watch vid and tell me whats wrong
  86. Thoughts before I pull the trigger on this build.
  87. Wrist pin removal
  88. v&h fuel pak
  89. SE 103" cylinders just bored out stock 96"s?
  90. Does A. Ness make a Big Sucker for an S&S carb?
  91. Help! Can you identify these slip on Mufflers
  92. CV Jetting help?
  93. V&H duke intake and exhaust w/SE EFI Tuner
  94. SE 255 Cam - 96" Fat Bob
  95. Mind made up, Parts ordered.
  96. Twin Cam Starter?
  97. cost of upgrading tensioners...cams?
  98. Cam swap finished - Thanks Fuel Moto!
  99. S&S 58mm throttle body
  100. v&h packing removal hurt or help???
  101. baisley spring
  102. I'm sorry, cam plate blues
  103. Rinehart crossback heat issues
  104. Vance hines Big shot longs to Patriot defender 2into1..question.
  105. 2009 Night Train info
  106. White Brothers 2-1 exhauat?
  107. Screaming Eagle Heads 96ci
  108. stupid qst but have to ask
  109. Years of Camplate
  110. Point me in the right direction
  111. American Customs exhaust users Input
  112. Anyone running the NGK Spark Plugs DCPR7EIX - NGK Iridium
  113. Improvements to H-D Engine Design?
  114. Oil Pump failure?
  115. I need some advice. Will these work?
  116. 1992 Gasket issue
  117. Need help with fishtail mufflers for my Road King
  118. Big Bore and SE203, what next?
  119. Steel breather gear with plastic spacer
  120. CV carb in winter time
  121. 2007 ultra classic with 103
  122. TC-96 making noise
  123. just took my exhaust off.. gasket rings look still intact.. options?
  124. VH Power duals vs Fuel Moto 2-1-2?
  125. Which BB kit do I have?
  126. Indy Suggestions in Central Florida
  127. Machine work
  128. Andrews 37H in 103 ci RG
  129. stupid ? @ MCRs
  130. Another frickin' Cam/Piston/Head question (X post)
  131. what #'s r u getting w/monster round/ovals
  132. Spewing Oil - Help
  133. Samson Duals Sound Levels Measured
  134. Cam Help! Urgent!
  135. Running on 1 cylinder after warming up???
  136. What kind of exhaust is this?
  137. mapping for new pipes
  138. 88 to 95" have a few questions about compression
  139. 99 Sportster 883 Jetting
  140. Forcwinder XR2 vs SE AC?
  141. will fuel treated with seafoam for winter affect tuning on the dyno?
  142. 96 parts whats it worth
  143. baffle wrap
  144. Lifter testing
  145. Lifter testing
  146. $1000-$1500 where to start.
  147. Starter Solenoid
  148. Smoke Coming From Motor
  149. Need cam advice - SE204 vs. 254E in a '09 Fatbob
  150. 05 Wide Glide Exhuast
  151. dyna red shift 577 cams
  152. Quick disconnect fuel lines
  153. lots of exhaust questions
  154. My New FLHX lands this week.
  155. Ajustable pushrod question
  156. Dyna cam advice
  157. Hydraulic Cam Chain plate upgrade
  158. Timing gear swapout
  159. Will 2006 Rinehart True Duals fit on a 2011 RoadGlide
  160. Rear cylinder TDC ? ? ?
  161. 99 Ultra TC88 Top End and cams?????
  162. Twin cam motor in a sportster
  163. Exhaust Flow
  164. Engin just dies
  165. Reducing Compression?
  166. One for the experts
  167. Fuel dropping out of fuel Line by Petcock
  168. What if any Performance Gains
  169. SE 255 cams for my Road Glide Custom?
  170. Twin Cam Heads: Buy '06 or Rebuild '00
  171. Thanks for 95' Big Bore advice
  172. exhaust advice
  173. E85 changeover
  174. Twin Cam S&S carb guys, where is your MAP sensor???
  175. Stage 2 explanation
  176. 103 Stage II Kit Questions
  177. I think I blew up my Dyna??
  178. Break-in Mileage Before Dyno
  179. Upgrading 2010 Touring to 103ci?
  180. Upgrading 2010 Touring from 96ci to 103ci
  181. S&S 116" vs. 124"
  182. '00 FXDX OEM Exhaust System - Need Advice
  183. 8 and a half thou in the hole
  184. Evo opened up and need opinions
  185. SE Air Filter Question
  186. Worth the money, Heads and big bore ?
  187. sumping
  188. 12' FLSTN Exhaust Change
  189. 06 and 09 Top ends
  190. H-D ACR Solenoid Location
  191. Backfiring and stalling
  192. need advice
  193. Re-tune Needed with Sharkfins?
  194. V+H Straightshots part #17821
  195. Stupid question - probably an easy answer...
  196. Questions on an big sucker 2 on 08 fxdc
  197. Head Removal - TC96
  198. S&S .570G rear cam
  199. Vance & Hines Straightshots for Fat Boy
  200. 88 to 95 or 98 LOOKING FOR FEEDBACK
  201. 120R exhaust system..?
  202. automatic compression releases
  203. Big Bore kit 88 to 95, question
  204. 204 cams and 103 cylinders
  205. Cam Plate
  206. anyone know what cam shim i will need
  207. exhaustpipe heat problem 2009 cvo 110
  208. cam plate upgrade problems
  209. Rocker Box Removal 2009 Road Glide
  210. Exhaust heat cures on 2003 Ultra Classic?
  211. Short shots vs Big radius 2 into 2
  212. Need install sheet for thunderheader dyna
  213. '06 up heads on a '01 88"?
  214. Install new Air Cleaner Question!
  215. Fuel Crossover
  216. Any potential pinging problems?
  217. Cobra FI2000 Power Pro info requested.
  218. smw proof motors
  219. Another cam Question
  220. 2-1-2 vs. true duals on 2012 FLTRU
  221. camshafts upgrade?
  222. Power Commander III USB
  223. PowerCommander map for V&H 2-1 change
  224. Here's a New One
  225. How long should it take
  226. Mystery gas tank
  227. another octane question
  228. recalibration for new mufflers?
  229. Quiet down a set of V&H BSL
  230. Push Rods hitting outer tube???
  231. Cam Tensioners
  232. stage 1 air kit parts
  233. thunderheaders
  234. V&H two into one cut down
  235. Help engine trouble, 85 softtail
  236. Road King air filter dripping oil/fuel
  237. Upgrade butterfly carb to CV?
  238. cam install
  239. fishtails on a 2006 ultra classic
  240. Pushrod Install Question. Why? Cuz' I screwed up.
  241. It's began!
  242. Timken Conversion Kit Rental, Anyone?
  243. Keith black kb348
  244. Jetting question
  245. Big Bore kit at 29,000
  246. 2008 RG Air Breather Replacement
  247. HELP!! My CFRs are blueing!
  248. Wrong oil filter; trashed motor?
  249. Primary oil seal orientation?
  250. Stage 1?
