View Full Version : Exhaust System Topics
- sprocket shaft seal
- dyno tune worth it for a carb bike?
- Troublemakers Big Straight Pipes
- Dual fire coil question
- slipons wouldn't
- trock cylinders
- S/E air cleaner
- Exhaust Gaskets - SE vs Stock
- Evo heads
- Exhaust Baffle Size...
- exhaust gaskets
- carb jetting opinions
- edelbrock sportster package
- Suggestions for a problem
- engine question
- Adjusting Adjustable Pushrods?
- What is this needle???
- Missing and Backfiring
- DaVinci/S&S
- Valve train noise...
- 96" S&S heads question
- Custom Chrome???
- overheat sensor
- Aftermarket parts?
- How do I adjust idle on MM EFI Ultra
- A good deep exhaust note?
- FLSTN 94' .. back firing and hard starting
- Can I put on exhuast on my stock bike?
- main jet size
- Supertrapp Super Elite Slip Ons
- Nearly stalling and other issues.
- Problem: Intemittent Loss of Power While Cruising
- LA CHOPPERS EXHAUST
- Punching baffles on 06 injected Softail
- Need carb help...Please.
- cruise control
- Oil on rocker box cover
- Front cylinder not firing
- question about big sucker air kit 18-505
- Whining noise
- Exhaust Upgrade; V&H, Hooker? Performance
- I guess I need to ask this carb guestion here
- S/E FI Kit
- head gaskets for a softail
- true duals pros and cons...
- Lost all Power
- kn on 1450cc
- Best exhaust to use on a Heritage???
- oil from crankcase breather?
- Throttle position help with PCIII!!
- 2006 Softail Deluxe Exhaust
- 06" Dresser Exhaust ?
- V&H Ovals - Tunable baffles???
- What are these plugs for???
- Fuel smell...
- Thanks ~ BigBoyz
- super trapp exhaust
- Fat Boy tank vent lines
- Engine just, well, stops runnig.
- Repost Check Enging Light
- 06 softail
- carb work and new exhaust
- Can you modify stock exhaust?
- Ran out of Gas - Or at least I thought so
- Will cam make it LOUDER?
- low oil psi
- rocker box cover bolts
- 06 EFI FXDBI Engine Build
- 1-3/4" or 2" drag pipe?
- V&H SE exhaust
- Cobra / Vance & Hines
- Carb, Fuel
- Exhaust and How you like it
- Best Price On A Power Commander ?
- RB Racing
- sportster running too rich.
- Hackerpipes
- Rinehart True Dual crack
- Engine burning oil
- V&H vs. Fullsac on a Bagger
- V&H Quiet Baffles
- vance & hines fuel pak
- engine upgrade questions
- How to Set Up CV carb on 03 Softail
- D&D Fat Cat
- Correct intake seating
- Used bike, New problems ...
- Mikuni tune, runs great now, but farts on idle and when I back off.
- Cam Chain Tensioners, Oil Leak, etc.
- 510 Or 26g Cams?
- V/H true dual pipes
- Dyna 06, Fatcat, Dyno pics
- CATALYST STOCK MUFFLER
- Easy Off Oven Cleaner?
- Fuel
- Mikuni tune, runs rich?
- V&H Pro-Pipe ?
- HELP cams and such
- SUPERTRAPP ELITE SLIP ON
- Snap, crackle, pop...
- oil burnibg
- runs rough
- Samson Exhaust
- HD Catalyst Touring Mufflers for 06
- Little back fire in the airbox..
- 05 efi roadking custom
- ThunderHeader/Carb Jetting?
- Overheating - Too lean?
- Please help identify this carburetor. Should it be on my bike? (pics)
- Fuel Pump
- Lifters??????
- Carburator for XL883
- Gear drive cams
- Downloads from HD Question
- rinehart true dual gaskets on rkc help
- Dyno tune on carb TC 88
- slip ons
- slip ons
- 2006 sporty exhaust
- 06 Heritage Knocking Noise ?
- V & H Classic Slip-ons w/ billet
- V&H Slip Ons
- Bagger Exhaust Question
- Installing V&H BSS on '06 Deluxe
- Python staggered Duals on Heritagew
- Cam Chain tensioner change
- What is the #1 cause of backfires & sputtering on 1972 Iron Head?
- K&N Filters Price
- SE 251 or 257
- Idle, yes. Go? Ugh...
- how do I get these mufflers off?
- Help! Please check my post in Custom Models under zenwarrior " sputters, stalled, wont start"
- OCTANE BOOSTERS?
- evo heads
- Exhaust Question
- Cam Choice - Opinions??
- Exhaust gaskets
- Harley Slip On Mufflers?
- Thunder Header vs. Rinehart 2 into 1
- Pre Dyno check list
- Cam chain adjusters
- What ECM Mods Do You Think?
- Cutting chrome pipes....
- seating the intake manifold?
- Lesson Learned....
- Is it safe?
- heads
- REPLACING MUFFLERS
- Which filter element for SE?
- noisey valves and fouled plugs
- Lifter Noise?
- Backfiring
- Backfiring
- fuel overflow
- 103 Stroker done
- engine noise
- Painting header wrap
- Newbie exhaust question
- Vance & Hines slip ons vs. gas milage
- D & D eshaust
- Hard chrome exhaust
- Compression
- True Dual Thunder Header
- Am I running to lean?
- Engine upgrade advice after stupid mistake?
- Rush Pipes (slip-on's)
- S&S Super E
- exhaust question
- Hard Starting
- SE II's sound like sh**
- engine mods?
- Vance & Hines slip on Oval vrs S&S SPO Touring Mufflers
- D&D slip on pipes for Dyan Glide
- Dyno Jet kit 95 EVO
- 00 Sporty Excessive Gas
- iV & H Big Shots Torque Loss
- 2 into 1 pipes
- Bad Gas or Crud?
- Help!!! EFI bike, no fire and no gas
- Need help with backfire
- O2 sensor removal
- backfiring from carb and out pipes after eng gets hot leaks oil from gaskets
- Help, broken exhaust stud
- 95" Big Bore Kit
- Engine Light
- 2006 injectors
- K&N air filter in stock housing?
- Rinehart heat shields
- How much for a D&D Fat Cat 2 into 1
- Going to ask again
- Sagging engine power on '88 FLHS
- Power Commander with SERT?
- Big Bore Kit, VH Slip Ons, SERT, Fuel Econ?
- melted boots
- gas milage ?
- S&S super E setup advice PLEASE
- dynojet jet kit
- Back to stock mufflers ??
- 2006 Dyna Super Glide Pipes
- stage 1 flash ???
- TC88 1999
- 05 SE II slip ons on an 06
- rinehart 2 in 1 on softail deluxe
- Trouble with Fuel after 100 miles
- Engine mount tight enough...
- ?? about true duals
- Exhaust Gaskets?
- JIMS 120 EXHAUST QUESTION
- Slight engine tick
- Harley heritage exhaust
- Pro Pipe Collector Yellowing ?
- powder coat?
- okay, which exhaust will boost performance, shovel head bob?
- emergency!!!!!!!!
- Why is my RK idle so lousy????? PLEASE HELP!
- Cobra 2:1/FI2000R/K&N filter combo
- need reassurance
- HELP? SLIP -ON QUESTION
- pipe coating
- Why are my head nuts coming loose on exhaust?
- LIL HELP WITH TAMK REMOVAL PLEASE
- Spitting/Stalling when cold - new problem
- D & D 2 /1/2" slip ons Exhaust on a 2006 Electra Glide Classic
- 06 fatboy vs. V&H exhaust
- 2006 Electra Glide surging at 2000 rpm
- Fuel Injected fuel line Problem
- PCIII Map Needed
- 5 or 6 gallons tank on Fat Boy Twin Cam?
- no compression
- trouble with HD dealership-95" inch build
- 05/06 flstsci and 95"
- Fullsac tru duels
- Remap with V&H short shots?
- RB racing 2-1 pipes?
- Rinehart baffels
- Re jet or not?
- idle stalling
- Bike Sputtering
- Cams and Exhaust noise
- Dynojet Stage 1 jet kit Question...
- Beginners Exhaust Question...
- Re-Jetting Needed With Slip-Ons?
- V&H or D&D?
- Road King Exhaust
- 95 inch build pinging, looking for fix
- Vance and Hines Longshots
- 96 Road King Carb/fuel/oil issue
- fuel gauge wiring
- SE Exhaust Audio File
