View Full Version : Softail Models
- Spring change needed for 21" front wheel/tire?
- Brake light will not shut off on 2011 FLSTC
- stock breakout bar width
- Passing lamp turn signals
- 2000-2013 HD Service Manual
- 01 Deuce, No spark Hard DTC 41
- Burly Slammer Kit?
- Right Height HandleBar For 2008 FatBoy - My height 5'7
- 2010 fatboy lo passager pegs
- Oil Leak '02' Deuce behind Inner Primary
- Seat Question
- Progressive lowering drop in kit on Fatboy
- Meet Eartha From Australia
- Garage door opener consensus on a Slim
- Leather solo seat rec for Heritage Softail Classic
- Question on quick release backrest for 2k Heritage
- ? price to cut windshield?
- Flush mount fuel cap and gauge installed
- 2007 Night Train handlebar swap
- Need help selecting a new air cleaner.
- any new lighting options?
- 2007 Night Train - Forks question
- Need recommendations for a good solo seat for a Fatboy
- 160 rear tire on a Blackline
- Streched bag and fender mockup
- Phantom Scratches
- 2004 Softail, good deal ?
- HD Soft Lowers Question
- 95 Heritage the good & bad.....
- Carlini Originals - 7 or 9
- Speedo problem FIXED! (2006 Hertitage Classic)
- Rear fender fit, 2 questions
- Possible electrical problem
- shadetree Fab foorboards
- Olive Pearl, Crossbones or other owners?
- Replaced Breakout Tank Badges
- PC3usb map needed 07 FXST
- First Harley
- Modifying a Deluxe Seat?
- Early 84 FXST can't find a belt primary to save my life
- Downshifting Problems
- Need Some Pullback Risers-'01 Springer - FLSTS
- Decel popping after new exhaust and dyno'd
- 1999 Fatboy True Duals Fitment
- Slim 150 Rear Tyre
- Slim Pillion Rubbing Paint??
- Slim Fuel Mileage Tips.
- another barebones (but a lil different)
- Updates on Lithium Ion Batteries?
- New breakout, some basic questions...
- Looking at 1994 Evo Fatboy
- shotgun shock and traction
- Valve Guide cracked after 14k Miles. What gives?
- Garage Door Opener
- Edge Cut Rear Brake Lever on 2003 FXSTB?
- PM Calipers
- Big move this weekend...
- New with a Softail
- Oil Quantity/Draining Question.
- CVO bags on Deluxe
- Security bolt on SE slip on muffler.
- Searching for a quiet exhaust...
- what pipes look good with dual headers? NOT SAMSON!!!
- Handlebar swap help for 04 FatBoy
- Motor cases, aluminum polishing
- if it werent for bad luck
- softail deluxe rear tire
- Rang a Bell Today!
- Deuce Fuel Programmer?
- Does these exhaust flange bolts look right?
- Softail Deluxe Seat question
- Headlight and Tail light issues
- Low Rider sidecar on a Softail Deluxe?
- replacing the starter
- Engine noise
- risers
- Vance & Hines Pro Pipe/Screamin Eagle Heavy Breather
- Rear brake rotor
- Heritage mufflers
- highest horsepower softtail
- Beach Bars on a '11 Up DeLuxe Question
- Question about mounting touring style bags on a Heritage
- Racking up miles
- softail slim vs. dyna Street bob????
- Fatboy fender swap
- Fluids
- Just bought 2014 Fat Boy Lo
- Kuryakyn Alley Cat vs Stocker a/c
- Rocker boxes
- Deuce Back Rest, Hi - Low?
- 12" ape on 2013 Deluxe
- 2012 fls build
- Just joined in, and purchased a new softail
- Fuel coming out of tank breather hose
- Rusty spokes
- 2015 softail deluxe bearing size?
- Deuce batwing and bags
- Power vision mount on softie
- Front fender
- BUSSrr error on Harley Speed/Tachometer gauge
- Some 'Slim' changes
- lighting ideas
- fatboy bars
- low profile dash fitment issues? 71202-03
- Question Concerning Forward Controls.
- Problems with my EVO
- 2014 HD Softail Service Manual
- THIN WW for Rear Wheel
- Exhausts for 08 Softail Deluxe
- 2012 Fatboy Lo Fuelpak Map - V&H Big Radius Pipes with Monster Baffles
- Softail Heritage Classic - Should I buy
- Snake bit > gotta laugh
- Security system problem
- Any tall guys running a Lindby Twinbar
- Exhaust
- Stator Failure
- My Blackline now has Mid Controls.. :-)
- C&C Fastback on a Deluxe...Advice Needed!
- Solenoid cover with starter button
- Rinehart 2 into 1 on Crossbones
- Avon 120/70 21WWW
- Brake Pedal Peg
- Removing Transmission Assembly
- highway peg and engine guard
- What's the 0-60 on a Stock Breakout?
- How much should I pay for a Softail Slim?
- oil tank - powder coat or paint?
- Solo Seat Frame Cover.
- Engine guards
- 21" Wheel on Deluxe
- Dyna to Softail
- License plate light plug unknown
- 21"-3.5 front rim
- Riders Back Rest
- Decel popping, FP3 vs HD Tuner to fix it.
- Handle Grips
- SERT upgrade to ThunderMax
- Unusual Idea: someone must have come up with
- Will Vance & Hines Shortshots from 03 XL883 fit 97 Fatboy
- Softail......No Way !!
- HD Price for cam installation > eek!
- Rocker 2 up struts and pillion seat needed
- Breakout speedo relocation
- Lowering a softail
- What's it worth - 05 Heritage FLSTCI
- Online parts buy
- Breakout-riser spacers
- TC88 Balancer Problem
- Help with a sissy bar for a 2011 fatboy lo
- Chrome rear cylinder base cover- Deluxe
- Fatboy parts interchange
- 2011 Windshield for Fatboy
- Looking for particular photo...
- jeez, this is harder than i thought.
- Rush Crossover, go or no?
- Springer risers
- Forward controls for Fatboy Lo - which kit is best?
- Chrome Rear Fender supports/struts
- FLS/FXS with Mustang Wide Touring seat?
- How Possible Is This?
- Lemon Law Tx
- It's been Two years since I "finished"...
- Night Train winter project is complete
- Power Vision cable on Breakout
- Fender trim suggestions
- Straight or Drag bar on Heritage
- S&S 124 fitted ... pics Finally !
- Dyna beads Question
- new member with new fatboy lo
- 06 softail primary clanking noise?
- Another shotgunned deluxe
- Weird Starting Issue
- aftermarket turn signal self cancel, 87 Heritage
- new fatboy lo
- DK Customs External Breather Kit
- 2007 Heritage Softail?
- New Exhaust Fit Issues with Stage One
- Electra glide to a Softail, Any regrets?
- Slim with D&D Fatcat anyone?
- Lay down plate\tail installed
- got some apes
- Tach bouncing
- Recovering my seat
- Fellow OC Riders
- harley back rest
- ***HOW TO*** Progressive Drop In springs with pics
- Part number for the ?false seat post? anybody
- Swing Arm for 95 FLSTN
- Fat Boy engine/performance upgrades?
- Air horn mod
- stinkin badges
- Damn nice looking Breather
- Unknown spring, need help
- 2000 FXST no spark
- Pulsating rear lights??
- Fatboy seat bolt
- 1" lower Slim = J&S jack won't fit
- LED upgrade review
- Looking for alternative to Sundowner Touring seat
- New Seated for Breakouy
- Quick disconnect for passenger backrest
- LED lights from SOCALMOTOGEAR
- Somebody go buy this
- New to HD
- Going nowhere fast!
- Deluxe handlebar riser clamp?
- Driving lights on Heritage Classic handlebars
- Springer Handlebar options ( post your pics)
- Few mods done to my 13 Heritage Classic.
- Those who have made your own tank bib
- 2014 Breakout Cam
- Cable kit for 20inch Carlini gangster apes
- Hhi raked trees
- Sometimes it's the little things
- 2014 Deluxe Minor Upgrades
- Brake Pad Life
- FXSB BREAKOUT - Project (Almost) Completed
- 2005 Springer & 9 Spoke Wheels
- fuel capacity and mpg?
- Looking for a set of FLSTS tins 2000-2003
- Fluid change
- Passing lamps,now vibration
- My 2013 Breakout - Lyla
- Fork mounted wind deflectors
- ECM/PCiii Troubles
- 2007 nighttrain fat tire
- Finally ! I got to ride it
- Quick question
- Super nice rear axle covers for Breakouts
- walk around of my slam'd, stretch'd, & cholo'd Deuce
- ISO pictures of softies with fairings
- Breakout ABS removal
- streched gas tank with hearland fender question
- Trade Vance & Hines Big Radius 2 to 2 for true duals!
- Which Windshield
- Fork Question
- LaBriola jockey
- Exhaust .. Bolt size ?
- 200mm stretched rear fender
- hardware bolts kit rear caliper softail 08
- For sale take off parts
- couple wiring questions 2005 springer classic
- Idle Issues
- HD 2002 Fatboy HELP!!!
- 2002 Night Train, Tire pessure?
- max width tire on current wheel?
- HD pass. backrest
- accutronix black fork tube covers?
- New Paint Is Done
