View Full Version : Softail Models
- S/s's oil scavenger redline oil
- 1.5 inch carlini apes on a train
- Assistance needed please..........
- Internal wiring handlebars 2003 Heritage?
- first harley, need advice
- Need to stretch out.
- Relocate Passenger Pegs on Deuce?
- Saddlebag and Seat restoration Before/After
- Some bike night pics ...
- Brake lights
- oil change
- 07 Softail Custom 1-1/2" Lowered (Before and After)
- front brake losing firmness
- RSD Clarity Derby and Black Primary for the Lo Boy
- 96 SS No Spark
- I caved....damn this forum!
- Quick question
- Ok, I have searched, read, and read some more...
- 04 roadking nacelle on 06 deluxe?
- Headlamp bolt
- wixom fairing
- Bagged Lo: The End Is Near.
- Rear footpegs not same length?
- Fyi
- 2012 FLSTC Heritage Softail Classic handlebar swap
- Needs ideas/opinions on putting speakers on a Deluxe
- Swing arm on an '85 Softail question
- Ape and Nacelle Install.
- Harbor Freight Motorcycle Lift
- Solo travel rack options for 2012 Slim?
- 36 Samson True Dual Long tails w/baffles time to go?
- Deuce with raked cups?
- Fitting a new tyre
- Brake piston question
- At last: chrome coil cover for Rocker and Rocker C
- need your advice on cam choice
- Newb on two wheels
- Softail rider again....
- want to change my crossbones rear fender to a heritage
- new paint on my Rocker
- need lifters?cams or 107
- Seat option?
- help with starter
- Clutch problem...or no?
- Screaming Eagle Tuner Software
- Heritage make over
- Will my wheel fit the OEM Springer front end???
- She's Gone
- Tour Pac and Bags for Fatboy
- Loc-title after adjusting handlebars?
- Seat Brand? Value?
- A few mods
- Handlebar Audio Stereo
- Opinions on a new style of crash bar for Fatboy
- Lowering front of a deluxe
- Right turn signal does not flash.
- Undermount mirrors
- Softail deluxe
- 05/06 Night Train Seats
- 2009 Nightrain parts for sale
- No More SE Super Tuners
- shock bolts from softail shocks.
- Need help fuel gauge not reading correctly
- Passenger Pillion with Le Pera solo seat
- Progressive Monotubes?
- Patch seat??
- Jackshaft bolt too short?
- Aftermarket (ebay) half moons?
- Softail Handling in Curves
- Softail Lowering Kit
- Dialed In Now
- questions about some softails with a springer and a 23!
- Plate frame
- Rider Back rest
- To Vicla or Not to Vicla
- Brake fluid recommendation
- Fxstd problem, please advise!
- back fire during start
- Dragged boards today!
- HELP!!!! Im lost behind bars!
- I'm Out
- Tuner advice
- need help 04 Nighttrain
- Belt Drive problems
- New Front Saddle for 2006 Deluxe
- Where can I get an exhaust like this for my Bones?
- Drag Speciaties 8" T-Bar and Saddleman seat *Pics*
- Need some info on a 1992 softail classic
- Horn-Knee. Advice
- Putting Traditional-Shape Footboards on Fat Boy Lo
- Shotgun shock deal?
- RSD Avenger Levers
- What is this "thing" by my throttle?
- Feel the heat coming from...
- Side mount plate-brake clearance
- deuce windshield
- Help - grips
- exhaust on 08 Softail Deluxe
- 2003 Aniversary is rear fender stock?
- Any other Fatty Los with Voltage Regulator Issues?
- Here she is...my 2009 crossbones
- Rode a Fat Boy Low today
- S&S 113ci motor keep it, sell it or trade it
- Night train headlight issue
- 2007 night train headlight issue
- How tall are stock crossbones apes?
- How much to charge for detailing
- New Blackline tail light
- replacing low fuel light
- Magnet on the frame brace??
- Knocking sound coming from rear wheel
- Dyno.....dealership only?
- Blackline progressive fork drop-ins
- oil cooler vs oil pressure?
- 2000 Deuce questions
- Barnett Cable Problems 2012 Deluxe
- Slim model service manual
- brake light: no running light but braking light works.
- Headlight and Indicator Lamps flashing on and off. HELP>>>>>>>>
- Let's see your billet grips
- Power Vision Tuner
- Just got a new starter clutch installed!!!
- Harley fatboy tins with custom $1600 paint job for sale
- efi swap to carb 06 nightrain
- End Caps for Harley brand grips?
- Lost the Train, Time to Move On
- V & H pipes with power vision with ?? Filter on 2011 FB
- Which Wire Extension Kit?
- Value? Am I making a decent deal here?
- Running light in brake light not working
- Need to find the original paint code for my 84 fxsb
- Light Bar Mounting Hardware?
- New guy with and oil leak question...
- Tubless wheels for 07 softail??
- Wobble/front fork ?
- Bags and Slip-ons for 12 Deluxe
- Power Vision Best Price?
- Hardware question
- Cable Lengths?
- Shopping for a Softail
- Retro Tank Emblems Installed
- Front forks
- Nighttrain - Worth it?
- Brake and shifter arm/levers for FWD. controls..
- bleeding brakes -help!
- Questions on a Blackline Stage 1
- A question for Blackline owner
- What else besides cams for my install?
- Tank Console or "Tank Bib" on Night train
- Need some handlebar advice from You softtail guy's
- Heritage seat
- 2012 Fatboy Lo Buzz
- Help adjusting progressive 422's
- power commander , VS< ?????
- Trick To Keep ECU In Plave After V&H Fuel Pack Install
- Tsukayu Patrol saddlebags for my Fatboy Lo
- Want to put a wide glide wheel on my 09 train
- Different Years
- Vance & Hines Fuel Pack PN 61001A
- Kuryakyn Mach 2 Air Cleaner
- Vance and Hines SideShots for sale Black
- Side mount plate wire routing
- anyone runnin 422rap's on their softie
- 2009 Softail Deluxe Transmission Filler Cap
- Brake Line?
- removing springer wheel
- Probably a dumb question, but...
- Fuel splashing problems.
- Dual Composition Tires
- Night Train air cleaner
- 07 FLSTC Rear Brake Sensor Removal...
- 2012 Fat boy lo Sissy Bar detachable recommendations
- looking for the crankcase oil drain plug
- Seat help for 2011 Heritage
- 1996 Heritage Lighting Problem...Help!
- Summer Dealer Meeting
- super E jetting for 99 heritage
- Tire 140
- rocker with cruise control
- Crossbones exhaust
- Need help with fuel problem!
- Rocker Lowering Bolts Trouble
- Guess What the Man in Brown Just Delivered...
- Mounting kit for FLH hard bags on SofTail
- Coming from a crotch rocket to a FatBoy
- 05 Springer fork for 97 Heritage
- Customizing detachables? Show me what you did.
- FatBoy Sputtering
- Softail engine sound?
- Rocker Style Passenger Seat
- Pushing into some new fender mods.. PICS..
- Lowest SERT idle setting
- Location of Siren Plug on 2002 FLSTCI
- 2012 Fat boy lo Saddlebags/Common Upgrades
- 2012 Fat Boy Lo w Vance and Hines Big Radius?
- 2001 Softail Duece Custom
- Belt drive and a new kick stand!!!
- Softail Deluxe Sport Tour-Pak
- just a little ride with my older bro
- Scraped my Samson 33" longtails
- Dynojet Powervision
- Wobble/spokes question
- need to Indian circute board
- Headed to paint shop......how does this disconnect?
- West Coast T-Bars in a Night Train, anybody have them??
- Sissy bar bag
- floorboard risers??
- lucky sucker?
- 2010 Heritage Saddlebag Problem
- Pricing on softail.
- nostalgic, curved ,engine guard help
- Fat Boy Lo Saddlebags
- Back from ATLANTICADE, PEI, Canada - AWESOME!
- What's this worth, anything special I need to look for?
- Purchasing 2012 Heritage Softail
- Opinions on Trading My Heritage for an Ultra
- Enough Wire?
- Congrats Honkylips
- 06 heritage running bad
- ABS Compatable Mustache Bars
- HD Cruise Control for Heritage?
- Rivco 2012 Fatboy Compressor Location
- Pics: Installed Slipstreamer SS-20 Stealth on My 09 Night Train
- Not new to Harleys, but new to softails. Fair price for this bike?
- New apes on, first stage of mods DONE!!!
- blue book?
- SE 110 or 103 heads on 96b cylinders?
- FatBoy Lo instrument lights keep going off
- BLACK OR CHROME??? Input Please.
- passenger floorboards with vance and hines straight shots?
- Fangs and engine cooling
- Not a rear shock question
- Swing arm mount license plate holder
- teardrop tool box ?
- Chrome covers for saddlebag bolts
- Cheapest spot for ride wrights
- Progressive 2" Drop kit round#1
- Downshift pops and stalls at stops
- Heritage handlebar options. Fatboy bars?
- Shocks for Heritage
- Question about Cobra 2 wiring
- front axle torque?
- Mainshaft nut
- cold hesitation
- HELP - 18" tire issues
- Hard Bag guard rails
- Balance Rocker Front Tire
- anyone use this Rick Doss LED Triple Light Kit
- 2006 Fatboy Rear Pulley
